[GRASS-SVN] r34379 - grass/trunk/scripts/i.fusion.brovey
svn_grass at osgeo.org
Tue Nov 18 15:43:46 EST 2008
Author: martinl
Date: 2008-11-18 15:43:46 -0500 (Tue, 18 Nov 2008)
New Revision: 34379
grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py
i.fusion.brovey: message standardization + verbose mode
Modified: grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py
--- grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py 2008-11-18 20:37:43 UTC (rev 34378)
+++ grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py 2008-11-18 20:43:46 UTC (rev 34379)
@@ -29,53 +29,56 @@
#%Module
#% description: Brovey transform to merge multispectral and high-res panchromatic channels
-#% keywords: raster, imagery, fusion
+#% keywords: imagery, fusion, Brovey
#%End
#%Flag
#% key: l
-#% description: sensor: LANDSAT
+#% description: LANDSAT sensor
+#% guisection: Sensor
#%END
#%Flag
#% key: q
-#% description: sensor: QuickBird
+#% description: QuickBird sensor
#%END
#%Flag
#% key: s
-#% description: sensor: SPOT
+#% description: SPOT sensor
#%END
#%option
#% key: ms1
#% type: string
#% gisprompt: old,cell,raster
-#% description: raster input map (green: tm2 | qbird_green | spot1)
+#% description: Name of input raster map (green: tm2 | qbird_green | spot1)
#% required : yes
#%end
#%option
#% key: ms2
#% type: string
-#% description: raster input map (NIR: tm4 | qbird_nir | spot2)
+#% description: Name of input raster map (NIR: tm4 | qbird_nir | spot2
#% required : yes
#%end
#%option
#% key: ms3
#% type: string
-#% description: raster input map (MIR; tm5 | qbird_red | spot3)
+#% description: Name of input raster map (MIR; tm5 | qbird_red | spot3
#% required : yes
#%end
#%option
#% key: pan
#% type: string
-#% description: raster input map (etmpan | qbird_pan | spotpan)
+#% description: Name of input raster map (etmpan | qbird_pan | spotpan)
#% required : yes
#%end
#%option
#% key: outputprefix
#% type: string
#% gisprompt: new,cell,raster
-#% description: raster output map prefix (e.g. 'brov')
+#% description: Name for output raster map prefix (e.g. 'brov')
#% required : yes
#%end
@@ -111,10 +114,10 @@
# clone current region
grass.use_temp_region()
- grass.message("Using resolution from PAN: %f" % panres)
+ grass.verbose("Using resolution from PAN: %f" % panres)
grass.run_command('g.region', flags = 'a', res = panres)
- grass.message("Performing Brovey transformation...")
+ grass.verbose("Performing Brovey transformation...")
# The formula was originally developed for LANDSAT-TM5 and SPOT,
# but it also works well with LANDSAT-TM7
@@ -153,7 +156,7 @@
if spot:
#apect table is nice for SPOT:
- grass.message("Assigning color tables for SPOT ...")
+ grass.message("Assigning color tables for SPOT...")
for ch in ['red', 'green', 'blue']:
grass.run_command('r.colors', map = "%s.%s" % (out, ch), col = 'aspect')
grass.message("Fixing output names...")
@@ -163,7 +166,7 @@
grass.run_command('g.rename', rast = (src, dst), quiet = True)
else:
#aspect table is nice for LANDSAT and QuickBird:
- grass.message("Assigning color tables for LANDSAT or QuickBird ...")
+ grass.message("Assigning color tables for LANDSAT or QuickBird...")
@@ -171,10 +174,10 @@
grass.message("%s.%s" % (out, ch))
- grass.message("To visualize output, run:")
- grass.message("g.region -p rast=%s.red" % out)
- grass.message("d.rgb r=%s.red g=%s.green b=%s.blue" % (out, out, out))
- grass.message("If desired, combine channels with 'r.composite' to a single map.")
+ grass.verbose("To visualize output, run:")
+ grass.verbose("g.region -p rast=%s.red" % out)
+ grass.verbose("d.rgb r=%s.red g=%s.green b=%s.blue" % (out, out, out))
+ grass.verbose("If desired, combine channels with 'r.composite' to a single map.")
# write cmd history:
