[GRASS-SVN] r34416 - grass/trunk/general/manage/cmd
Thu Nov 20 17:37:22 EST 2008
Author: glynn
Date: 2008-11-20 17:37:21 -0500 (Thu, 20 Nov 2008)
New Revision: 34416
Removed:
   grass/trunk/general/manage/cmd/init.c
   grass/trunk/general/manage/cmd/local_proto.h
   grass/trunk/general/manage/cmd/Makefile
   grass/trunk/general/manage/cmd/copy.c
   grass/trunk/general/manage/cmd/list.c
   grass/trunk/general/manage/cmd/remove.c
   grass/trunk/general/manage/cmd/rename.c
Clean up management utilities
Modified: grass/trunk/general/manage/cmd/Makefile
--- grass/trunk/general/manage/cmd/Makefile	2008-11-20 22:31:12 UTC (rev 34415)
+++ grass/trunk/general/manage/cmd/Makefile	2008-11-20 22:37:21 UTC (rev 34416)
@@ -3,10 +3,10 @@
 PROGRAMS = g.copy g.list g.remove g.rename
-g_copy_OBJS = copy.o init.o
-g_list_OBJS = list.o init.o
-g_remove_OBJS = remove.o init.o
-g_rename_OBJS = rename.o init.o
+g_copy_OBJS = copy.o
+g_list_OBJS = list.o
+g_remove_OBJS = remove.o
+g_rename_OBJS = rename.o
 include $(MODULE_TOPDIR)/include/Make/Multi.make
Modified: grass/trunk/general/manage/cmd/copy.c
--- grass/trunk/general/manage/cmd/copy.c	2008-11-20 22:31:12 UTC (rev 34415)
+++ grass/trunk/general/manage/cmd/copy.c	2008-11-20 22:37:21 UTC (rev 34416)
@@ -22,7 +22,6 @@
 #include <string.h>
 #include <grass/glocale.h>
 #include <grass/list.h>
-#include "local_proto.h"
 int main(int argc, char *argv[])
@@ -33,8 +32,10 @@
     char *from, *to;
     int result = EXIT_SUCCESS;
-    init(argv[0]);
+    G_gisinit(argv[0]);
+    read_list(0);
     module = G_define_module();
     module->keywords = _("general, map management");
     module->description =
Deleted: grass/trunk/general/manage/cmd/init.c
--- grass/trunk/general/manage/cmd/init.c	2008-11-20 22:31:12 UTC (rev 34415)
+++ grass/trunk/general/manage/cmd/init.c	2008-11-20 22:37:21 UTC (rev 34416)
@@ -1,11 +0,0 @@
-#include <grass/list.h>
-int init(char *pgm)
-    G_gisinit(pgm);
-    read_list(0);
-    return 0;
Modified: grass/trunk/general/manage/cmd/list.c
--- grass/trunk/general/manage/cmd/list.c	2008-11-20 22:31:12 UTC (rev 34415)
+++ grass/trunk/general/manage/cmd/list.c	2008-11-20 22:37:21 UTC (rev 34416)
@@ -22,10 +22,11 @@
 #include <unistd.h>
 #include <grass/spawn.h>
 struct Option *element;
+int parse(const char *data_type);
     int i, n, len;
@@ -34,8 +35,10 @@
     struct Flag *full;
     char *str;
-    init(argv[0]);
+    read_list(0);
Deleted: grass/trunk/general/manage/cmd/local_proto.h
--- grass/trunk/general/manage/cmd/local_proto.h	2008-11-20 22:31:12 UTC (rev 34415)
+++ grass/trunk/general/manage/cmd/local_proto.h	2008-11-20 22:37:21 UTC (rev 34416)
@@ -1,15 +0,0 @@
-/* copy.c */
-int main(int, char *[]);
-/* init.c */
-int init(char *);
-/* list.c */
-int parse(const char *);
-/* remove.c */
-/* rename.c */
Modified: grass/trunk/general/manage/cmd/remove.c
--- grass/trunk/general/manage/cmd/remove.c	2008-11-20 22:31:12 UTC (rev 34415)
+++ grass/trunk/general/manage/cmd/remove.c	2008-11-20 22:37:21 UTC (rev 34416)
@@ -22,7 +22,6 @@
 #include <string.h>
 static int check_reclass(const char *name, const char *mapset, int force)
@@ -92,8 +91,10 @@
     int force = 0;
-    init(argv[0]);
+    read_list(0);
Modified: grass/trunk/general/manage/cmd/rename.c
--- grass/trunk/general/manage/cmd/rename.c	2008-11-20 22:31:12 UTC (rev 34415)
+++ grass/trunk/general/manage/cmd/rename.c	2008-11-20 22:37:21 UTC (rev 34416)
@@ -22,7 +22,6 @@
 #include <grass/gis.h>
@@ -34,8 +33,10 @@
     char *mapset, *location_path, **rmaps;
-    init(argv[0]);
+    read_list(0);
