[GRASS-SVN] r34417 - in grass/trunk/general: . g.copy g.list g.remove g.rename manage
Thu Nov 20 17:48:50 EST 2008
Author: glynn
Date: 2008-11-20 17:48:50 -0500 (Thu, 20 Nov 2008)
New Revision: 34417
Added:
   grass/trunk/general/g.copy/
   grass/trunk/general/g.copy/Makefile
   grass/trunk/general/g.copy/copy.c
   grass/trunk/general/g.copy/g.copy.html
   grass/trunk/general/g.list/
   grass/trunk/general/g.list/Makefile
   grass/trunk/general/g.list/g.list.html
   grass/trunk/general/g.list/list.c
   grass/trunk/general/g.remove/
   grass/trunk/general/g.remove/Makefile
   grass/trunk/general/g.remove/g.remove.html
   grass/trunk/general/g.remove/remove.c
   grass/trunk/general/g.rename/
   grass/trunk/general/g.rename/Makefile
   grass/trunk/general/g.rename/g.rename.html
   grass/trunk/general/g.rename/rename.c
Removed:
   grass/trunk/general/manage/cmd/
   grass/trunk/general/Makefile
   grass/trunk/general/manage/Makefile
Split general/manage/cmd into separate modules
Modified: grass/trunk/general/Makefile
--- grass/trunk/general/Makefile	2008-11-20 22:37:21 UTC (rev 34416)
+++ grass/trunk/general/Makefile	2008-11-20 22:48:50 UTC (rev 34417)
@@ -3,12 +3,14 @@
 SUBDIRS = \
 	g.access \
+	g.copy \
 	g.dirseps \
 	g.filename \
 	g.findetc \
 	g.findfile \
 	g.gisenv \
 	g.gui \
+	g.list \
 	g.mapset \
 	g.mapsets \
 	g.message \
@@ -16,9 +18,11 @@
 	g.mlist \
 	g.mremove \
 	g.parser \
+	g.pnmcomp \
 	g.proj \
-	g.pnmcomp \
 	g.region \
+	g.remove \
+	g.rename \
 	g.tempfile \
 	g.transform \
 	g.version \
Property changes on: grass/trunk/general/g.copy
___________________________________________________________________
   + *OBJ*
Added: grass/trunk/general/g.copy/Makefile
--- grass/trunk/general/g.copy/Makefile	                        (rev 0)
+++ grass/trunk/general/g.copy/Makefile	2008-11-20 22:48:50 UTC (rev 34417)
@@ -0,0 +1,12 @@
+MODULE_TOPDIR = ../..
+PGM = g.copy
+include $(MODULE_TOPDIR)/include/Make/Module.make
+LIBES = $(MANAGELIB) $(VECTLIB) $(DBMILIB) $(GISLIB) $(G3DLIB)
+DEPENDENCIES = $(GISDEP) $(VECTDEP) $(DBMIDEP) $(MANAGEDEP) $(G3DDEP)
+default: cmd
Copied: grass/trunk/general/g.copy/copy.c (from rev 34416, grass/trunk/general/manage/cmd/copy.c)
--- grass/trunk/general/g.copy/copy.c	                        (rev 0)
+++ grass/trunk/general/g.copy/copy.c	2008-11-20 22:48:50 UTC (rev 34417)
@@ -0,0 +1,100 @@
+ * MODULE:       cmd
+ * AUTHOR(S):    CERL (original contributor)
+ *               Radim Blazek <radim.blazek gmail.com>,
+ *               Cedric Shock <cedricgrass shockfamily.net>,
+ *               Huidae Cho <grass4u gmail.com>,
+ *               Glynn Clements <glynn gclements.plus.com>,
+ *               Markus Neteler <neteler itc.it>,
+ *               Martin Landa <landa.martin gmail.com>
+ * PURPOSE:      lets users copy database files
+ * COPYRIGHT:    (C) 2003-2007 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *               License (>=v2). Read the file COPYING that comes with GRASS
+ *               for details.
+#include <stdlib.h>
+#include <string.h>
+#include <grass/glocale.h>
+#include <grass/list.h>
+int main(int argc, char *argv[])
+    int i, n;
+    char *mapset;
+    struct GModule *module;
+    struct Option **parm, *p;
+    char *from, *to;
+    int result = EXIT_SUCCESS;
+    G_gisinit(argv[0]);
+    read_list(0);
+    module = G_define_module();
+    module->keywords = _("general, map management");
+    module->description =
+	_("Copies available data files in the user's current mapset "
+	  "search path and location to the appropriate element "
+	  "directories under the user's current mapset.");
+    parm = (struct Option **)G_calloc(nlist, sizeof(struct Option *));
+    for (n = 0; n < nlist; n++) {
+	char *str;
+	p = parm[n] = G_define_option();
+	p->key = list[n].alias;
+	p->key_desc = "from,to";
+	p->type = TYPE_STRING;
+	p->required = NO;
+	p->multiple = NO;
+	G_asprintf(&str, "old,%s,%s", list[n].mainelem, list[n].maindesc);
+	p->gisprompt = str;
+	G_asprintf(&str, _("%s file(s) to be copied"), list[n].alias);
+	p->description = str;
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+	if (parm[n]->answers == NULL)
+	    continue;
+	i = 0;
+	while (parm[n]->answers[i]) {
+	    from = parm[n]->answers[i++];
+	    to = parm[n]->answers[i++];
+	    mapset = find(n, from, "");
+	    if (!mapset) {
+		G_warning(_("<%s> not found"), from);
+		continue;
+	    if (G_strcasecmp(mapset, G_mapset()) == 0 &&
+		G_strcasecmp(from, to) == 0) {
+		G_warning(_("%s=%s,%s: files are the same, no copy required"),
+			  parm[n]->key, from, to);
+		continue;
+	    if (find(n, to, G_mapset()) && !(module->overwrite)) {
+		G_warning(_("<%s> already exists"), to);
+		continue;
+	    if (G_legal_filename(to) < 0) {
+		G_warning(_("<%s> is an illegal file name"), to);
+		continue;
+	    if (do_copy(n, from, mapset, to) == 1) {
+		result = EXIT_FAILURE;
+	    G_remove_misc("cell_misc", "reclassed_to", to);
+    exit(result);
Property changes on: grass/trunk/general/g.copy/copy.c
   + text/x-csrc
   + Author Date Id
   + native
Copied: grass/trunk/general/g.copy/g.copy.html (from rev 34410, grass/trunk/general/manage/cmd/g.copy.html)
--- grass/trunk/general/g.copy/g.copy.html	                        (rev 0)
+++ grass/trunk/general/g.copy/g.copy.html	2008-11-20 22:48:50 UTC (rev 34417)
@@ -0,0 +1,83 @@
+<h2>DESCRIPTION</h2>
+A user may access data stored under the other mapsets
+listed in his mapset search path.  However, the user may
+only modify data stored under his own current mapset.
+<em>g.copy</em> allows the user to copy existing data files
+<em>from</em> other mapsets <em>to</em> the user's current
+mapset ($MAPSET).  The files to be copied must exist in the
+user's current mapset search path and location; output is
+sent to the relevant data element directory(ies) under the
+user's current mapset.
+<h2>EXAMPLES</h2>
+If the user wished to copy the existing raster
+file <em>soils</em> to a file called <em>soils.ph</em> and
+to copy an existing vector map <em>roads</em> to a file
+called <em>rds.old</em>, the user could type:
+<p>
+<div class="code"><pre>
+g.copy rast=soils,soils.ph vect=roads,rds.old
+</pre></div>
+<p>
+Data files can also be specified by their mapsets.  For
+example, the below command copies the raster map named
+<em>soils</em> from the mapset <em>wilson</em> to a new
+file called <em>soils</em> to be placed under the user's
+current mapset:
+<p>
+g.copy rast='soils at wilson',soils
+</pre></div>
+<p>
+If no mapset name is specified, <em>g.copy</em> searches
+for the named <em>from</em> map in each of the mapset
+directories listed in the user's current mapset search path
+in the order in which mapsets are listed there (see
+<em><a HREF="g.mapsets.html">g.mapsets</a></em>).
+<H2>NOTES</H2>
+If the user does not enter parameter values but instead
+types only <b>g.copy</b> on the command line the program
+will prompt the user for a data type, the name of a file of
+this data type to copy, and the name of a new file to hold
+the copy.  After both file names have been entered, the
+copy is created and the user is again prompted for a data
+element to be copied, until the user hits RETURN.  When
+prompted for file names, the user may enter 'list' to see a
+list of existing files, or hit RETURN to end the file
+listing.
+<p>
+If a file has support files (e.g., as do raster data
+files), these support files will also be copied.
+<h2>SEE ALSO</h2>
+<em><a HREF="g.access.html">g.access</a></em><br>
+<em><a HREF="g.list.html">g.list</a></em><br>
+<em><a HREF="g.mapsets.html">g.mapsets</a></em><br>
+<em><a HREF="g.remove.html">g.remove</a></em><br>
+<em><a HREF="g.rename.html">g.rename</a></em><br>
+<em><a HREF="parser.html">parser</a></em>
+<h2>AUTHOR</h2>
+Michael Shapiro,
+U.S.Army Construction Engineering
+Research Laboratory
+<p><i>Last changed: $Date$</i><p>
Property changes on: grass/trunk/general/g.copy/g.copy.html
   + text/html
   + Author Date Id
   + native
Property changes on: grass/trunk/general/g.list
   + *OBJ*
Added: grass/trunk/general/g.list/Makefile
--- grass/trunk/general/g.list/Makefile	                        (rev 0)
+++ grass/trunk/general/g.list/Makefile	2008-11-20 22:48:50 UTC (rev 34417)
@@ -0,0 +1,12 @@
+PGM = g.list
+default: cmd
Copied: grass/trunk/general/g.list/g.list.html (from rev 34410, grass/trunk/general/manage/cmd/g.list.html)
--- grass/trunk/general/g.list/g.list.html	                        (rev 0)
+++ grass/trunk/general/g.list/g.list.html	2008-11-20 22:48:50 UTC (rev 34417)
@@ -0,0 +1,59 @@
+<em>g.list</em> allows the user to list user-specified, available
+and accessible files from <em>mapsets</em> under the user's current location.
+<h2>OPTIONS</h2>
+When invoked simply as <b>g.list</b>, the program prompts
+the user for the type of data to be listed from all
+<em>mapsets</em> in the user's current mapset search path.
+The user can list files from a mapset not listed in the
+current mapset search path by running the program
+non-interactively, specifying the (optional) flag setting
+and parameter values on the command line.  Program flag and
+parameters are described below.
+<h2>EXAMPLES</h2>
+List all raster maps:
+<br>
+<tt>g.list type=rast</tt>
+<p>
+List all raster and vector maps from mapset &quot;user&quot;:
+<br>
+<tt>g.list type=rast,vect mapset=user</tt>
+<p>
+<h2>NOTES</h2>
+If unspecified, files of the specified <em>type</em> from all mapsets
+in the user's current search path will be listed to standard output. To
+find out which mapsets are in the cuurent search path, use
+<em><a HREF="g.mapsets.html">'g.mapsets</a> -p'</em>.
+<p>
+If the user requests that files from a mapset to which
+access has been restricted (see
+<em><a HREF="g.access.html">g.access</a></em>)
+be listed, no files from this mapset will be listed.
+<h2>SEE ALSO</h2>
+<em><a HREF="g.mlist.html">g.mlist</a></em>
+<h2>AUTHOR</h2>
+Michael Shapiro,
Property changes on: grass/trunk/general/g.list/g.list.html
   + text/html
   + Author Date Id
   + native
Copied: grass/trunk/general/g.list/list.c (from rev 34416, grass/trunk/general/manage/cmd/list.c)
--- grass/trunk/general/g.list/list.c	                        (rev 0)
+++ grass/trunk/general/g.list/list.c	2008-11-20 22:48:50 UTC (rev 34417)
@@ -0,0 +1,124 @@
+ * MODULE:       g.list
+ * AUTHOR(S):    Michael Shapiro,
+ *               U.S.Army Construction Engineering Research Laboratory
+ * PURPOSE:      Lists available GRASS data base files of the
+ *               user-specified data type to standard output
+ * COPYRIGHT:    (C) 1999-2007 by the GRASS Development Team
+ *               for details.
+#include <unistd.h>
+#include <grass/spawn.h>
+struct Option *element;
+int parse(const char *data_type);
+    int i, n, len;
+    struct Option *mapset;
+    struct Flag *full;
+    char *str;
+    read_list(0);
+	_("Lists available GRASS data base files "
+	  "of the user-specified data type to standard output.");
+    element = G_define_option();
+    element->key = "type";
+    element->key_desc = "datatype";
+    element->type = TYPE_STRING;
+    element->required = YES;
+    element->multiple = YES;
+    element->description = "Data type";
+    for (len = 0, n = 0; n < nlist; n++)
+	len += strlen(list[n].alias) + 1;
+    str = G_malloc(len);
+	if (n) {
+	    strcat(str, ",");
+	    strcat(str, list[n].alias);
+	else
+	    strcpy(str, list[n].alias);
+    element->options = str;
+    mapset = G_define_option();
+    mapset->key = "mapset";
+    mapset->type = TYPE_STRING;
+    mapset->required = NO;
+    mapset->multiple = NO;
+    mapset->description = _("Mapset to list (default: current search path)");
+    full = G_define_flag();
+    full->key = 'f';
+    full->description = _("Verbose listing (also list map titles)");
+    if (mapset->answer == NULL)
+	mapset->answer = "";
+    if (G_strcasecmp(mapset->answer, ".") == 0)
+	mapset->answer = G_mapset();
+    i = 0;
+    while (element->answers[i]) {
+	n = parse(element->answers[i]);
+	if (full->answer) {
+	    char lister[GPATH_MAX];
+	    sprintf(lister, "%s/etc/lister/%s", G_gisbase(),
+		    list[n].element[0]);
+	    G_debug(3, "lister CMD: %s", lister);
+	    if (access(lister, 1) == 0)	/* execute permission? */
+		G_spawn(lister, lister, mapset->answer, NULL);
+	    else
+		do_list(n, mapset->answer);
+	else {
+	i++;
+    exit(EXIT_SUCCESS);
+    int n;
+	if (G_strcasecmp(list[n].alias, data_type) == 0)
+	    break;
+    return n;
Property changes on: grass/trunk/general/g.list/list.c
   + text/x-csrc
   + Author Date Id
   + native
Property changes on: grass/trunk/general/g.remove
   + *OBJ*
Added: grass/trunk/general/g.remove/Makefile
--- grass/trunk/general/g.remove/Makefile	                        (rev 0)
+++ grass/trunk/general/g.remove/Makefile	2008-11-20 22:48:50 UTC (rev 34417)
@@ -0,0 +1,12 @@
+PGM = g.remove
+default: cmd
Copied: grass/trunk/general/g.remove/g.remove.html (from rev 34410, grass/trunk/general/manage/cmd/g.remove.html)
--- grass/trunk/general/g.remove/g.remove.html	                        (rev 0)
+++ grass/trunk/general/g.remove/g.remove.html	2008-11-20 22:48:50 UTC (rev 34417)
@@ -0,0 +1,59 @@
+<em>g.remove</em> allows the user to remove specified data
+base element files from the current mapset.
+<h2>EXAMPLE</h2>
+For example, the below command will cause the raster maps
+named <em>soils</em>, <em>slope</em>, and <em>temp</em>,
+the vector maps named <em>roads</em> and <em>rail</em>,
+and the
+<a HREF="i.group.html">imagery</a> group files
+named <em>nhap.1</em> and <em>nhap.2</em>, and these files'
+associated support files (e.g., cell header files, category
+files, etc.), to be removed from the user's current
+mapset.
+g.remove rast=soils,slope,temp vect=roads,rail group=nhap.1,nhap.2
+</pre></div>
+<h2>NOTE</h2>
+If a particular data base element file has support files
+associated with it (e.g., as is commonly the case with
+raster maps), <em>g.remove</em> will remove these support
+files along with the data base element file specified.
+<p>
+The user can only use <em>g.remove</em> to remove data
+files existing under the user's <em>current mapset</em>.
+<p>
+To remove multiple files, the script <em>g.mremove</em> may be used.
+<h2>FILES</h2>
+<kbd>$GISBASE/etc/element_list</kbd> lists the element
+types whose files can be removed by the user.
+<h2>SEE ALSO</h2>
+<em><a HREF="g.copy.html">g.copy</a></em><br>
+<em>g.mremove</em>
+<h2>AUTHOR</h2>
+Michael Shapiro,
Property changes on: grass/trunk/general/g.remove/g.remove.html
   + text/html
   + Author Date Id
   + native
Copied: grass/trunk/general/g.remove/remove.c (from rev 34416, grass/trunk/general/manage/cmd/remove.c)
--- grass/trunk/general/g.remove/remove.c	                        (rev 0)
+++ grass/trunk/general/g.remove/remove.c	2008-11-20 22:48:50 UTC (rev 34417)
@@ -0,0 +1,146 @@
+ * MODULE:       cmd
+ *               Jachym Cepicky <jachym les-ejk.cz>,
+ * PURPOSE:      lets users remove GRASS database files
+ *               for details.
+static int check_reclass(const char *name, const char *mapset, int force)
+    char rname[GNAME_MAX], rmapset[GMAPSET_MAX];
+    char **rmaps;
+    int nrmaps;
+    if (G_is_reclassed_to(name, mapset, &nrmaps, &rmaps) > 0) {
+	for (; *rmaps; rmaps++) {
+	    /* force remove */
+	    if (force)
+		G_warning(_("[%s@%s] is a base map for [%s]. Remove forced."),
+			  name, mapset, *rmaps);
+	    else
+		G_warning(_("[%s@%s] is a base map. Remove reclassed map first: %s"),
+	if (!force)
+	    return 1;
+    if (G_is_reclass(name, mapset, rname, rmapset) > 0 &&
+	G_is_reclassed_to(rname, rmapset, &nrmaps, &rmaps) > 0) {
+	char path[GPATH_MAX];
+	char *p = strchr(rname, '@');
+	char *qname = G_fully_qualified_name(name, mapset);
+	if (p)
+	    *p = '\0';
+	G__file_name_misc(path, "cell_misc", "reclassed_to", rname, rmapset);
+	if (nrmaps == 1 && !G_strcasecmp(rmaps[0], qname)) {
+	    if (remove(path) < 0)
+		G_warning(_("Removing information about reclassed map from [%s@%s] failed"),
+			  rname, rmapset);
+	else {
+	    FILE *fp = fopen(path, "w");
+	    if (fp) {
+		    if (G_strcasecmp(*rmaps, qname))
+			fprintf(fp, "%s\n", *rmaps);
+		fclose(fp);
+	    else
+			  rname, rmapset);
+    return 0;
+    int i, n;
+    struct Flag *force_flag;
+    char *name, *mapset;
+    char *location_path;
+    int force = 0;
+    read_list(0);
+	_("Removes data base element files from "
+	  "the user's current mapset.");
+    force_flag = G_define_flag();
+    force_flag->key = 'f';
+    force_flag->description = _("Force remove");
+	char *str;
+	p->required = NO;
+	p->multiple = YES;
+	G_asprintf(&str, _("%s file(s) to be removed"), list[n].alias);
+    location_path = G_location_path();
+    mapset = G_mapset();
+    if (force_flag->answer)
+	force = 1;
+	if (parm[n]->answers)
+	    for (i = 0; (name = parm[n]->answers[i]); i++) {
+		if (G_strcasecmp(list[n].alias, "rast") == 0 &&
+		    check_reclass(name, mapset, force))
+		    continue;
+		if (do_remove(n, name) == 1) {
+    exit(result);
Property changes on: grass/trunk/general/g.remove/remove.c
   + text/x-csrc
   + Author Date Id
   + native
Property changes on: grass/trunk/general/g.rename
   + *OBJ*
Added: grass/trunk/general/g.rename/Makefile
--- grass/trunk/general/g.rename/Makefile	                        (rev 0)
+++ grass/trunk/general/g.rename/Makefile	2008-11-20 22:48:50 UTC (rev 34417)
@@ -0,0 +1,12 @@
+PGM = g.rename
+default: cmd
Copied: grass/trunk/general/g.rename/g.rename.html (from rev 34410, grass/trunk/general/manage/cmd/g.rename.html)
--- grass/trunk/general/g.rename/g.rename.html	                        (rev 0)
+++ grass/trunk/general/g.rename/g.rename.html	2008-11-20 22:48:50 UTC (rev 34417)
@@ -0,0 +1,85 @@
+<em>g.rename</em> allows the user to rename data base
+element files in the user's current mapset.  The user can
+specify all necessary information to <em>g.rename</em> on
+the command line, by specifying:  the type of data base
+element to be renamed (one or more of:  <b>rast</b>,
+<b>vect</b>, <b>icon</b>, <b>labels</b>, <b>sites</b>,
+<b>region</b>, and <b>group</b>); the specific file element
+in the current mapset to be renamed (<em>old</em>); and the
+new name to be assigned to this file element (<em>new</em>)
+in the current mapset.  The file element <em>old</em> is
+then renamed to <em>new</em>.
+<p>
+Users can also simply type <em>g.rename -help</em> without
+arguments on the command line, to receive a menu of
+existing data base element types and files from which to
+choose for possible renaming:
+<div class="code">
+<pre>
+     rast   rast file(s) to be renamed
+  oldvect   oldvect file(s) to be renamed (GRASS 5.0)
+     vect   vect file(s) to be renamed	  (GRASS >5.1)
+     icon   icon file(s) to be renamed
+   labels   labels file(s) to be renamed
+    sites   sites file(s) to be renamed
+   region   region file(s) to be renamed
+    group   group file(s) to be renamed
+   3dview   3dview file(s) to be renamed
+</pre></div>
+<h2>NOTES</h2>
+If a data base element has support files (e.g., as is
+commonly the case with raster maps), these support files
+also are renamed.
+<p>
+If the user attempts to rename a file to itself by setting
+the <em>new</em> file name equal to the <em>old</em> file
+name (e.g., <b>g.rename rast=soils,soils</b>),
+<em>g.rename</em> will not execute the rename, but instead
+state that no rename is needed.  However, <em>g.rename</em>
+will allow the user to overwrite other existing files in
+the current mapset by making the <em>new</em> file name
+that of an already existing file.
+<p>
+For portability reasons, <em>g.rename</em> is ignoring case of
+names. To change the case of a map name, first rename the map
+to a name which differs by more than case, then rename it to
+the intended name.
+<h2>EXAMPLE</h2>
+# rename raster map
+g.rename rast=oldrast,newrast
+# rename vector map
+g.rename vect=oldvect,newvect
+# combined renaming
+g.rename rast=oldrast,newrast vect=oldvect,newvect
+</pre></div>
+<h2>SEE ALSO</h2>
+<h2>AUTHOR</h2>
+Michael Shapiro,
Property changes on: grass/trunk/general/g.rename/g.rename.html
   + text/html
   + Author Date Id
   + native
Copied: grass/trunk/general/g.rename/rename.c (from rev 34416, grass/trunk/general/manage/cmd/rename.c)
--- grass/trunk/general/g.rename/rename.c	                        (rev 0)
+++ grass/trunk/general/g.rename/rename.c	2008-11-20 22:48:50 UTC (rev 34417)
@@ -0,0 +1,146 @@
+ * MODULE:       g.rename cmd
+ * PURPOSE:
+ * COPYRIGHT:    (C) 1994-2007 by the GRASS Development Team
+ *               for details.
+#include <grass/gis.h>
+    int i, n;
+    char *old, *new;
+    int nrmaps;
+    char *mapset, *location_path, **rmaps;
+    read_list(0);
+	_("Renames data base element files in the user's current mapset.");
+	char *str;
+	p->key_desc = "old,new";
+	p->required = NO;
+	p->multiple = NO;
+	G_asprintf(&str, _("%s file(s) to be renamed"), list[n].alias);
+    location_path = G__location_path();
+	    continue;
+	i = 0;
+	    old = parm[n]->answers[i++];
+	    new = parm[n]->answers[i++];
+	    if (!find(n, old, mapset)) {
+		G_warning(_("%s <%s> not found"), list[n].maindesc, old);
+		continue;
+	    if (find(n, new, "") && !(module->overwrite)) {
+		G_warning(_("<%s> already exists in mapset <%s>"), new,
+			  find(n, new, ""));
+		continue;
+	    if (G_legal_filename(new) < 0) {
+		G_warning(_("<%s> is an illegal file name"), new);
+		continue;
+	    if (strcmp(old, new) == 0) {
+		G_warning(_("%s=%s,%s: files are the same, no rename required"),
+			  parm[n]->key, old, new);
+		continue;
+	    if (G_is_reclassed_to(old, mapset, &nrmaps, &rmaps) > 0) {
+		int ptr, l;
+		char buf1[256], buf2[256], buf3[256], *str;
+		FILE *fp;
+		G_message(_("Renaming reclass maps"));
+		    G_message(" %s", *rmaps);
+		    sprintf(buf3, "%s", *rmaps);
+		    if ((str = strchr(buf3, '@'))) {
+			*str = 0;
+			sprintf(buf2, "%s", str + 1);
+		    else {
+			sprintf(buf2, "%s", mapset);
+		    sprintf(buf1, "%s/%s/cellhd/%s", location_path, buf2,
+			    buf3);
+		    fp = fopen(buf1, "r");
+		    if (fp == NULL)
+			continue;
+		    fgets(buf2, 255, fp);
+		    ptr = ftell(fp);
+		    fseek(fp, 0L, SEEK_END);
+		    l = ftell(fp) - ptr;
+		    str = (char *)G_malloc(l);
+		    fseek(fp, ptr, SEEK_SET);
+		    fread(str, l, 1, fp);
+		    fclose(fp);
+		    fp = fopen(buf1, "w");
+		    fprintf(fp, "reclass\n");
+		    fprintf(fp, "name: %s\n", new);
+		    fprintf(fp, "mapset: %s\n", mapset);
+		    fwrite(str, l, 1, fp);
+		    G_free(str);
+		    fclose(fp);
+	    if (do_rename(n, old, new) == 1) {
+    exit(result);
Property changes on: grass/trunk/general/g.rename/rename.c
   + text/x-csrc
   + Author Date Id
   + native
Modified: grass/trunk/general/manage/Makefile
--- grass/trunk/general/manage/Makefile	2008-11-20 22:37:21 UTC (rev 34416)
+++ grass/trunk/general/manage/Makefile	2008-11-20 22:48:50 UTC (rev 34417)
@@ -1,7 +1,7 @@
-SUBDIRS = cmd lister
+SUBDIRS = lister
 include $(MODULE_TOPDIR)/include/Make/Dir.make
