[GRASS-SVN] r34431 - grass/branches/develbranch_6/general/g.mlist
Fri Nov 21 15:38:25 EST 2008
Author: neteler
Date: 2008-11-21 15:38:25 -0500 (Fri, 21 Nov 2008)
New Revision: 34431
   grass/branches/develbranch_6/general/g.mlist/main.c
glynn: Add exclude= option (modified merge from trunk, #34406)
Modified: grass/branches/develbranch_6/general/g.mlist/main.c
--- grass/branches/develbranch_6/general/g.mlist/main.c	2008-11-21 16:07:50 UTC (rev 34430)
+++ grass/branches/develbranch_6/general/g.mlist/main.c	2008-11-21 20:38:25 UTC (rev 34431)
@@ -29,9 +29,9 @@
 static int any;
-static void do_list(const struct list *,
-		    const char *, const char *, const char *,
-		    int, int, int);
+static void make_list(const struct list *,
+		      const char *, const char *,
+		      int, int, int);
 static int parse(const char *);
 static int ls_filter(const char *, void *);
@@ -42,6 +42,7 @@
 	struct Option *type;
 	struct Option *pattern;
+	struct Option *exclude;
 	struct Option *separator;
 	struct Option *mapset;
     } opt;
@@ -55,8 +56,8 @@
 	struct Flag *full;
     } flag;
     int i, n, all, num_types;
-    char *pattern = NULL, separator[2], *buf;
-    regex_t regex;
+    char *pattern = NULL, *exclude = NULL, separator[2], *buf;
+    regex_t regex, regex_ex;
     G_gisinit(argv[0]);
@@ -93,9 +94,15 @@
     opt.pattern->type = TYPE_STRING;
     opt.pattern->required = NO;
     opt.pattern->multiple = NO;
-    opt.pattern->answer = "*";
     opt.pattern->description = _("Map name search pattern (default: all)");
+    opt.exclude = G_define_option();
+    opt.exclude->key = "exclude";
+    opt.exclude->type = TYPE_STRING;
+    opt.exclude->required = NO;
+    opt.exclude->multiple = NO;
+    opt.exclude->description = _("Map name exclusion pattern (default: none)");
     opt.separator = G_define_option();
     opt.separator->key = "separator";
     opt.separator->type = TYPE_STRING;
@@ -147,15 +154,28 @@
     if (flag.regex->answer && flag.extended->answer)
 	G_fatal_error(_("-r and -e are mutually exclusive"));
-    if (flag.regex->answer || flag.extended->answer)
-	pattern = opt.pattern->answer;
-    else
-	pattern = wc2regex(opt.pattern->answer);
+    if (opt.pattern->answer) {
+	if (flag.regex->answer || flag.extended->answer)
+	    pattern = G_store(opt.pattern->answer);
+	else
+	    pattern = wc2regex(opt.pattern->answer);
-    if (regcomp(&regex, pattern, (flag.regex->answer ? 0 : REG_EXTENDED) | REG_NOSUB))
-	G_fatal_error(_("Unable to compile regular expression %s"), pattern);
-    G_set_ls_filter(ls_filter, &regex);
+	if (regcomp(&regex, pattern, (flag.regex->answer ? 0 : REG_EXTENDED) | REG_NOSUB))
+	    G_fatal_error(_("Unable to compile regular expression %s"), pattern);
+	G_set_ls_filter(ls_filter, &regex);
+    if (opt.exclude->answer) {
+	    exclude = G_store(opt.exclude->answer);
+	else
+	    exclude = wc2regex(opt.exclude->answer);
+	if (regcomp(&regex_ex, exclude, (flag.regex->answer ? 0 : REG_EXTENDED) | REG_NOSUB))
+	    G_fatal_error(_("Unable to compile regular expression %s"), exclude);
+	G_set_ls_exclude_filter(ls_filter, &regex_ex);
     if (strcmp(opt.separator->answer, "newline") == 0)
 	separator[0] = '\n';
     else if (strcmp(opt.separator->answer, "comma") == 0)
@@ -204,25 +224,30 @@
 	else
-	    do_list(&list[n], pattern, opt.mapset->answer, separator,
-		    flag.pretty->answer, flag.type->answer,
-		    flag.mapset->answer);
+	    make_list(&list[n], opt.mapset->answer, separator,
+		      flag.pretty->answer, flag.type->answer,
+		      flag.mapset->answer);
     if (!flag.pretty->answer && any)
 	fprintf(stdout, "\n");
-    if (!flag.regex->answer)
+    if (pattern) {
 	G_free(pattern);
+	regfree(&regex);
-    regfree(&regex);
+    if (exclude) {
+	G_free(exclude);
+	regfree(&regex_ex);
     exit(EXIT_SUCCESS);
     const struct list *elem,
-    const char *pattern, const char *mapset, const char *separator,
+    const char *mapset, const char *separator,
     int pretty, int add_type, int add_mapset)
     char path[GPATH_MAX];
@@ -240,8 +265,8 @@
     if (!mapset || !*mapset) {
 	int n;
 	for (n = 0; mapset = G__mapset_name(n), mapset; n++)
-	    do_list(elem, pattern, mapset, separator,
-		    pretty, add_type, add_mapset);
+	    make_list(elem, mapset, separator,
+		      pretty, add_type, add_mapset);
 	return;
