[GRASS-SVN] r34432 - grass/branches/develbranch_6/general/g.mlist
svn_grass at osgeo.org
Fri Nov 21 15:45:26 EST 2008
Author: neteler
Date: 2008-11-21 15:45:26 -0500 (Fri, 21 Nov 2008)
New Revision: 34432
grass/branches/develbranch_6/general/g.mlist/description.html
explain exclude parameter
Modified: grass/branches/develbranch_6/general/g.mlist/description.html
--- grass/branches/develbranch_6/general/g.mlist/description.html 2008-11-21 20:38:25 UTC (rev 34431)
+++ grass/branches/develbranch_6/general/g.mlist/description.html 2008-11-21 20:45:26 UTC (rev 34432)
@@ -26,11 +26,33 @@
g.mlist type=rast pattern="N45E00?.meters"
</pre></div>
+Use of <em>exclude</em> parameter:
+<div class="code"><pre>
+# without exclude:
+g.mlist rast pat="r*" mapset=PERMANENT
+railroads
+roads
+rstrct.areas
+rushmore
+# exclude only complete word(s):
+g.mlist rast pat="r*" exclude=roads mapset=PERMANENT
+railroads
+rstrct.areas
+rushmore
+# exclude with wildcard:
+g.mlist rast pat="r*" exclude="*roads*" mapset=PERMANENT
+rstrct.areas
+rushmore
+</pre></div>
<h3>Regular expressions:</h3>
Print out all soils map with "soils" in their name:
- g.mlist -r type=rast pattern='^soils'
+g.mlist -r type=rast pattern='^soils'
</pre></div>
Print out "tmp" if "tmp" raster map exists:
