[GRASS-SVN] r34593 - in grass/trunk/vector: v.build.polylines
v.category v.clean v.kcv v.net v.proj v.transform v.type
svn_grass at osgeo.org
Fri Nov 28 04:30:14 EST 2008
Author: marisn
Date: 2008-11-28 04:30:14 -0500 (Fri, 28 Nov 2008)
New Revision: 34593
grass/trunk/vector/v.build.polylines/main.c
grass/trunk/vector/v.category/main.c
grass/trunk/vector/v.clean/main.c
grass/trunk/vector/v.kcv/main.c
grass/trunk/vector/v.net/main.c
grass/trunk/vector/v.proj/main.c
grass/trunk/vector/v.transform/main.c
grass/trunk/vector/v.type/main.c
Print warning if copying attribute table to new vector map fails (merge from devbr6 r34592)
Modified: grass/trunk/vector/v.build.polylines/main.c
--- grass/trunk/vector/v.build.polylines/main.c 2008-11-28 09:22:16 UTC (rev 34592)
+++ grass/trunk/vector/v.build.polylines/main.c 2008-11-28 09:30:14 UTC (rev 34593)
@@ -204,7 +204,8 @@
/* Copy (all linked) tables if needed */
if (write_cats != NO_CATS) {
- Vect_copy_tables(&map, &Out, 0);
+ if (Vect_copy_tables(&map, &Out, 0))
+ G_warning(_("Failed to copy attribute table to output map"));
/* Tidy up */
Modified: grass/trunk/vector/v.category/main.c
--- grass/trunk/vector/v.category/main.c 2008-11-28 09:22:16 UTC (rev 34592)
+++ grass/trunk/vector/v.category/main.c 2008-11-28 09:30:14 UTC (rev 34593)
@@ -482,7 +482,8 @@
if (option == O_ADD || option == O_DEL || option == O_CHFIELD ||
option == O_SUM) {
- Vect_copy_tables(&In, &Out, 0);
+ if (Vect_copy_tables(&In, &Out, 0))
Vect_build(&Out);
Vect_close(&Out);
Modified: grass/trunk/vector/v.clean/main.c
--- grass/trunk/vector/v.clean/main.c 2008-11-28 09:22:16 UTC (rev 34592)
+++ grass/trunk/vector/v.clean/main.c 2008-11-28 09:30:14 UTC (rev 34593)
@@ -271,7 +271,8 @@
/* This works for both level 1 and 2 */
Vect_copy_map_lines(&In, &Out);
Vect_set_release_support(&In);
Vect_close(&In);
Modified: grass/trunk/vector/v.kcv/main.c
--- grass/trunk/vector/v.kcv/main.c 2008-11-28 09:22:16 UTC (rev 34592)
+++ grass/trunk/vector/v.kcv/main.c 2008-11-28 09:30:14 UTC (rev 34593)
@@ -152,7 +152,8 @@
/* Copy tables */
/* Add column */
db_init_string(&sql);
Modified: grass/trunk/vector/v.net/main.c
--- grass/trunk/vector/v.net/main.c 2008-11-28 09:22:16 UTC (rev 34592)
+++ grass/trunk/vector/v.net/main.c 2008-11-28 09:30:14 UTC (rev 34593)
@@ -182,7 +182,8 @@
Vect_close(&Points);
/* support */
Vect_build_partial(&Out, GV_BUILD_NONE);
Modified: grass/trunk/vector/v.proj/main.c
--- grass/trunk/vector/v.proj/main.c 2008-11-28 09:22:16 UTC (rev 34592)
+++ grass/trunk/vector/v.proj/main.c 2008-11-28 09:30:14 UTC (rev 34593)
@@ -275,7 +275,8 @@
fprintf(stderr, "\r");
/* Copy tables */
- Vect_copy_tables(&Map, &Out_Map, 0);
+ if (Vect_copy_tables(&Map, &Out_Map, 0))
Vect_close(&Map);
Modified: grass/trunk/vector/v.transform/main.c
--- grass/trunk/vector/v.transform/main.c 2008-11-28 09:22:16 UTC (rev 34592)
+++ grass/trunk/vector/v.transform/main.c 2008-11-28 09:30:14 UTC (rev 34593)
@@ -336,7 +336,8 @@
ztozero, trans_params,
table->answer, columns_name, atoi(field->answer));
- Vect_copy_tables(&Old, &New, 0);
+ if (Vect_copy_tables(&Old, &New, 0))
Vect_close(&Old);
Vect_build(&New);
Modified: grass/trunk/vector/v.type/main.c
--- grass/trunk/vector/v.type/main.c 2008-11-28 09:22:16 UTC (rev 34592)
+++ grass/trunk/vector/v.type/main.c 2008-11-28 09:30:14 UTC (rev 34593)
@@ -225,7 +225,8 @@
Vect_write_line(&Out, type, Points, Cats);
Vect_build(&Out);
Vect_close(&Out);
Vect_close(&In);
