[GRASS-SVN] r34594 - grass/branches/develbranch_6/vector/v.kcv
Fri Nov 28 05:21:28 EST 2008
Author: marisn
Date: 2008-11-28 05:21:27 -0500 (Fri, 28 Nov 2008)
New Revision: 34594
   grass/branches/develbranch_6/vector/v.kcv/main.c
Create new attribute table if input map doesn't has one; Don't leave unvinished output map around in case of fatal error.
Modified: grass/branches/develbranch_6/vector/v.kcv/main.c
--- grass/branches/develbranch_6/vector/v.kcv/main.c	2008-11-28 09:30:14 UTC (rev 34593)
+++ grass/branches/develbranch_6/vector/v.kcv/main.c	2008-11-28 10:21:27 UTC (rev 34594)
@@ -52,7 +52,7 @@
 int main(int argc, char *argv[])
-    int line, nlines;
+    int line, nlines, nlinks;
     double east, north, (*rng) (), max, myrand();
     int i, j, n, nsites, verbose, np, *p, dcmp();
     int *pnt_part;
@@ -158,32 +158,48 @@
     /* Copy tables */
     if (Vect_copy_tables(&In, &Out, 0))
-        G_warning(_("Failed to copy attribute table to output map"));
+	G_warning(_("Failed to copy attribute table to output map"));
     /* Add column */
     db_init_string(&sql);
-    Fi = Vect_get_field(&Out, 1);
+    /* Check if there is a database for output */
+    nlinks = Vect_get_num_dblinks(&Out);
+    if (nlinks < 1)
+	Fi = Vect_default_field_info(&Out, 1, NULL, GV_1TABLE);
+    else
+	Fi = Vect_get_field(&Out, 1);
     if (Fi == NULL) {
+	Vect_delete(Out.name);
 	G_fatal_error(_("Unable to get layer info for vector map <%s>"),
-		      in_opt->answer);
+		      out_opt->answer);
     Driver = db_start_driver_open_database(Fi->driver, Fi->database);
-    if (Driver == NULL)
+    if (Driver == NULL) {
 	G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
 		      Fi->database, Fi->driver);
-    sprintf(buf, "alter table %s add column %s integer", Fi->table,
-	    col_opt->answer);
+    if (nlinks < 1)
+	sprintf(buf, "create table %s (%s integer, %s integer)", Fi->table,
+		Fi->key, col_opt->answer);
+    else
+	sprintf(buf, "alter table %s add column %s integer", Fi->table,
+		col_opt->answer);
     db_set_string(&sql, buf);
     G_debug(3, "SQL: %s", db_get_string(&sql));
     if (db_execute_immediate(Driver, &sql) != DB_OK) {
 	G_fatal_error(_("Cannot alter table: %s"), db_get_string(&sql));
+    if (nlinks < 1)
+	Vect_map_add_dblink(&Out, Fi->number, Fi->name, Fi->table, Fi->key,
+			    Fi->database, Fi->driver);
      * make histogram of number sites in each test partition since the
@@ -238,14 +254,19 @@
 		Vect_read_line(&In, Points, Cats, nearest);
 		Vect_cat_get(Cats, 1, &cat);
-		sprintf(buf, "update %s set %s = %d where %s = %d", Fi->table,
-			col_opt->answer, i + 1, Fi->key, cat);
+		if (nlinks < 1)
+		    sprintf(buf, "insert into %s (%s, %s) values (%d, %d)",
+			    Fi->table, Fi->key, col_opt->answer, cat, i + 1);
+		else
+		    sprintf(buf, "update %s set %s = %d where %s = %d",
+			    Fi->table, col_opt->answer, i + 1, Fi->key, cat);
 		    G_fatal_error(_("Unable to insert row: %s"),
