[GRASS-SVN] r33673 - in grass/trunk/raster: . r.statistics2
svn_grass at osgeo.org
Sat Oct 4 18:40:44 EDT 2008
Author: glynn
Date: 2008-10-04 18:40:43 -0400 (Sat, 04 Oct 2008)
New Revision: 33673
Added:
grass/trunk/raster/r.statistics2/
grass/trunk/raster/r.statistics2/Makefile
grass/trunk/raster/r.statistics2/main.c
grass/trunk/raster/r.statistics2/r.statistics2.html
grass/trunk/raster/Makefile
Add r.statistics2
Modified: grass/trunk/raster/Makefile
--- grass/trunk/raster/Makefile 2008-10-04 19:33:16 UTC (rev 33672)
+++ grass/trunk/raster/Makefile 2008-10-04 22:40:43 UTC (rev 33673)
@@ -79,6 +79,7 @@
r.series \
r.slope.aspect \
r.statistics \
+ r.statistics2 \
r.stats \
r.sum \
r.sun \
Property changes on: grass/trunk/raster/r.statistics2
___________________________________________________________________
+ *OBJ*
Added: grass/trunk/raster/r.statistics2/Makefile
--- grass/trunk/raster/r.statistics2/Makefile (rev 0)
+++ grass/trunk/raster/r.statistics2/Makefile 2008-10-04 22:40:43 UTC (rev 33673)
@@ -0,0 +1,10 @@
+MODULE_TOPDIR = ../..
+PGM = r.statistics2
+LIBES = $(GISLIB)
+DEPENDENCIES = $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass/trunk/raster/r.statistics2/main.c
--- grass/trunk/raster/r.statistics2/main.c (rev 0)
+++ grass/trunk/raster/r.statistics2/main.c 2008-10-04 22:40:43 UTC (rev 33673)
@@ -0,0 +1,528 @@
+ * MODULE: r.statistics2
+ * AUTHOR(S): Glynn Clements; loosely based upon r.statistics, by
+ * Martin Schroeder, Geographisches Institut Heidelberg, Germany
+ * PURPOSE: Category or object oriented statistics
+ * COPYRIGHT: (C) 2007,2008 Martin Schroeder, Glynn Clements
+ * and the GRASS Development Team
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
+#include <string.h>
+#include <stdlib.h>
+#include <math.h>
+#include <grass/gis.h>
+#include <grass/spawn.h>
+#include <grass/glocale.h>
+#define COUNT 1 /* Count */
+#define SUM 2 /* Sum */
+#define MIN 3 /* Minimum */
+#define MAX 4 /* Maximum */
+#define RANGE 5 /* Range */
+#define AVERAGE 6 /* Average (mean) */
+#define ADEV 7 /* Average deviation */
+#define VARIANCE1 8 /* Variance */
+#define STDDEV1 9 /* Standard deviation */
+#define SKEWNESS1 10 /* Skewnes */
+#define KURTOSIS1 11 /* Kurtosis */
+#define VARIANCE2 12 /* Variance */
+#define STDDEV2 13 /* Standard deviation */
+#define SKEWNESS2 14 /* Skewnes */
+#define KURTOSIS2 15 /* Kurtosis */
+struct menu
+ const char *name; /* method name */
+ int val; /* number of function */
+ const char *text; /* menu display - full description */
+extern struct menu menu[];
+/* modify this table to add new methods */
+struct menu menu[] = {
+ {"count", COUNT, "Count of values in specified objects"},
+ {"sum", SUM, "Sum of values in specified objects"},
+ {"min", MIN, "Minimum of values in specified objects"},
+ {"max", MAX, "Maximum of values in specified objects"},
+ {"range", RANGE, "Range of values (max - min) in specified objects"},
+ {"average", AVERAGE, "Average of values in specified objects"},
+ {"avedev", ADEV, "Average deviation of values in specified objects"},
+ {"variance", VARIANCE1, "Variance of values in specified objects"},
+ {"stddev", STDDEV1, "Standard deviation of values in specified objects"},
+ {"skewness", SKEWNESS1, "Skewness of values in specified objects"},
+ {"kurtosis", KURTOSIS1, "Kurtosis of values in specified objects"},
+ {"variance2", VARIANCE2, "(2-pass) Variance of values in specified objects"},
+ {"stddev2", STDDEV2, "(2-pass) Standard deviation of values in specified objects"},
+ {"skewness2", SKEWNESS2, "(2-pass) Skewnes of values in specified objects"},
+ {"kurtosis2", KURTOSIS2, "(2-pass) Kurtosis of values in specified objects"},
+ {0, 0, 0}
+int main(int argc, char **argv)
+ static DCELL *count, *sum, *mean, *sumu, *sum2, *sum3, *sum4, *min, *max;
+ DCELL *result;
+ struct GModule *module;
+ struct {
+ struct Option *method, *basemap, *covermap, *output;
+ } opt;
+ struct {
+ struct Flag *c, *r;
+ } flag;
+ char methods[2048];
+ const char *basemap, *covermap, *output;
+ int usecats;
+ int reclass;
+ int base_fd, cover_fd;
+ struct Categories cats;
+ CELL *base_buf;
+ DCELL *cover_buf;
+ struct Range range;
+ CELL mincat, ncats;
+ int method;
+ int rows, cols;
+ int row, col, i;
+ G_gisinit(argv[0]);
+ module = G_define_module();
+ module->keywords = _("raster, statistics");
+ module->description =
+ _("Calculates category or object oriented statistics.");
+ opt.basemap = G_define_standard_option(G_OPT_R_BASE);
+ opt.covermap = G_define_standard_option(G_OPT_R_COVER);
+ opt.method = G_define_option();
+ opt.method->key = "method";
+ opt.method->type = TYPE_STRING;
+ opt.method->required = YES;
+ opt.method->description = _("Method of object-based statistic");
+ for (i = 0; menu[i].name; i++) {
+ if (i)
+ strcat(methods, ",");
+ else
+ *(methods) = 0;
+ strcat(methods, menu[i].name);
+ opt.method->options = G_store(methods);
+ if (i)
+ strcat(methods, ";");
+ else
+ *(methods) = 0;
+ strcat(methods, menu[i].text);
+ opt.method->descriptions = G_store(methods);
+ opt.output = G_define_standard_option(G_OPT_R_OUTPUT);
+ opt.output->description = _("Resultant raster map");
+ opt.output->required = YES;
+ flag.c = G_define_flag();
+ flag.c->key = 'c';
+ flag.c->description =
+ _("Cover values extracted from the category labels of the cover map");
+ flag.r = G_define_flag();
+ flag.r->key = 'r';
+ flag.r->description =
+ _("Create reclass map with statistics as category labels");
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ basemap = opt.basemap->answer;
+ covermap = opt.covermap->answer;
+ output = opt.output->answer;
+ usecats = flag.c->answer;
+ reclass = flag.r->answer;
+ if (strcmp(menu[i].name, opt.method->answer) == 0)
+ break;
+ if (!menu[i].name) {
+ G_warning(_("<%s=%s> unknown %s"), opt.method->key, opt.method->answer,
+ opt.method->key);
+ G_usage();
+ method = menu[i].val;
+ base_fd = G_open_cell_old(basemap, "");
+ if (base_fd < 0)
+ G_fatal_error(_("Unable to open base map <%s>"), basemap);
+ cover_fd = G_open_cell_old(covermap, "");
+ if (cover_fd < 0)
+ if (usecats && G_read_cats(covermap, "", &cats) < 0)
+ G_fatal_error(_("Unable to read category file of cover map <%s>"), covermap);
+ if (G_raster_map_is_fp(basemap, "") != 0)
+ G_fatal_error(_("The base map must be an integer (CELL) map"));
+ if (G_read_range(basemap, "", &range) < 0)
+ G_fatal_error(_("Unable to read range of base map <%s>"), basemap);
+ mincat = range.min;
+ ncats = range.max - range.min + 1;
+ rows = G_window_rows();
+ cols = G_window_cols();
+ switch (method) {
+ case COUNT:
+ count = G_calloc(ncats, sizeof(DCELL));
+ break;
+ case SUM:
+ sum = G_calloc(ncats, sizeof(DCELL));
+ break;
+ case MIN:
+ min = G_malloc(ncats * sizeof(DCELL));
+ break;
+ case MAX:
+ max = G_malloc(ncats * sizeof(DCELL));
+ break;
+ case RANGE:
+ break;
+ case AVERAGE:
+ case ADEV:
+ case VARIANCE2:
+ case STDDEV2:
+ case SKEWNESS2:
+ case KURTOSIS2:
+ break;
+ case VARIANCE1:
+ case STDDEV1:
+ sum2 = G_calloc(ncats, sizeof(DCELL));
+ break;
+ case SKEWNESS1:
+ sum3 = G_calloc(ncats, sizeof(DCELL));
+ break;
+ case KURTOSIS1:
+ sum4 = G_calloc(ncats, sizeof(DCELL));
+ break;
+ if (min)
+ for (i = 0; i < ncats; i++)
+ min[i] = 1e300;
+ if (max)
+ max[i] = -1e300;
+ base_buf = G_allocate_c_raster_buf();
+ cover_buf = G_allocate_d_raster_buf();
+ G_message(_("First pass"));
+ for (row = 0; row < rows; row++) {
+ G_get_c_raster_row(base_fd, base_buf, row);
+ G_get_d_raster_row(cover_fd, cover_buf, row);
+ for (col = 0; col < cols; col++) {
+ int n;
+ DCELL v;
+ if (G_is_c_null_value(&base_buf[col]))
+ continue;
+ if (G_is_d_null_value(&cover_buf[col]))
+ continue;
+ n = base_buf[col] - mincat;
+ if (n < 0 || n >= ncats)
+ continue;
+ v = cover_buf[col];
+ if (usecats)
+ sscanf(G_get_cat((CELL) v, &cats), "%lf", &v);
+ if (count)
+ count[n]++;
+ if (sum)
+ sum[n] += v;
+ if (sum2)
+ sum2[n] += v * v;
+ if (sum3)
+ sum3[n] += v * v * v;
+ if (sum4)
+ sum4[n] += v * v * v * v;
+ if (min && min[n] > v)
+ min[n] = v;
+ if (max && max[n] < v)
+ max[n] = v;
+ G_percent(row, rows, 2);
+ result = G_calloc(ncats, sizeof(DCELL));
+ switch (method) {
+ case ADEV:
+ case VARIANCE2:
+ case STDDEV2:
+ case SKEWNESS2:
+ case KURTOSIS2:
+ mean = G_calloc(ncats, sizeof(DCELL));
+ mean[i] = sum[i] / count[i];
+ G_free(sum);
+ break;
+ switch (method) {
+ case ADEV:
+ sumu = G_calloc(ncats, sizeof(DCELL));
+ break;
+ case VARIANCE2:
+ case STDDEV2:
+ break;
+ case SKEWNESS2:
+ break;
+ case KURTOSIS2:
+ break;
+ if (mean) {
+ G_message(_("Second pass"));
+ int n;
+ DCELL v, d;
+ continue;
+ continue;
+ continue;
+ if (usecats)
+ d = v - mean[n];
+ if (sumu)
+ sumu[n] += fabs(d);
+ if (sum2)
+ sum2[n] += d * d;
+ if (sum3)
+ sum3[n] += d * d * d;
+ if (sum4)
+ sum4[n] += d * d * d * d;
+ G_free(mean);
+ G_free(cover_buf);
+ switch (method) {
+ case COUNT:
+ result[i] = count[i];
+ break;
+ case SUM:
+ result[i] = sum[i];
+ break;
+ case AVERAGE:
+ result[i] = sum[i] / count[i];
+ break;
+ case MIN:
+ result[i] = min[i];
+ break;
+ case MAX:
+ result[i] = max[i];
+ break;
+ case RANGE:
+ result[i] = max[i] - min[i];
+ case VARIANCE1:
+ for (i = 0; i < ncats; i++) {
+ double n = count[i];
+ double var = (sum2[i] - sum[i] * sum[i] / n) / (n - 1);
+ result[i] = var;
+ break;
+ case STDDEV1:
+ result[i] = sqrt(var);
+ break;
+ case SKEWNESS1:
+ double skew = (sum3[i] / n
+ - 3 * sum[i] * sum2[i] / (n * n)
+ + 2 * sum[i] * sum[i] * sum[i] / (n * n * n))
+ / (pow(var, 1.5));
+ result[i] = skew;
+ break;
+ case KURTOSIS1:
+ double kurt = (sum4[i] / n
+ - 4 * sum[i] * sum3[i] / (n * n)
+ + 6 * sum[i] * sum[i] * sum2[i] / (n * n * n)
+ - 3 * sum[i] * sum[i] * sum[i] * sum[i] / (n * n * n * n))
+ / (var * var) - 3;
+ result[i] = kurt;
+ break;
+ case ADEV:
+ result[i] = sumu[i] / count[i];
+ break;
+ case VARIANCE2:
+ result[i] = sum2[i] / (count[i] - 1);
+ break;
+ case STDDEV2:
+ result[i] = sqrt(sum2[i] / (count[i] - 1));
+ break;
+ case SKEWNESS2:
+ double var = sum2[i] / (n - 1);
+ double sdev = sqrt(var);
+ result[i] = sum3[i] / (sdev * sdev * sdev) / n;
+ G_free(count);
+ G_free(sum2);
+ G_free(sum3);
+ break;
+ case KURTOSIS2:
+ result[i] = sum4[i] / (var * var) / n - 3;
+ G_free(count);
+ G_free(sum2);
+ G_free(sum4);
+ break;
+ if (reclass) {
+ const char *tempfile = G_tempfile();
+ char *input_arg = G_malloc(strlen(basemap) + 7);
+ char *output_arg = G_malloc(strlen(output) + 8);
+ char *rules_arg = G_malloc(strlen(tempfile) + 7);
+ FILE *fp;
+ G_message(_("Generating reclass map"));
+ sprintf(input_arg, "input=%s", basemap);
+ sprintf(output_arg, "output=%s", output);
+ sprintf(rules_arg, "rules=%s", tempfile);
+ fp = fopen(tempfile, "w");
+ if (!fp)
+ G_fatal_error(_("Unable to open temporary file"));
+ fprintf(fp, "%d = %d %f\n", mincat + i, mincat + i, result[i]);
+ fclose(fp);
+ G_spawn("r.reclass", "r.reclass", input_arg, output_arg, rules_arg, NULL);
+ else {
+ int out_fd;
+ DCELL *out_buf;
+ struct Colors colors;
+ G_message(_("Writing output map"));
+ out_fd = G_open_fp_cell_new(output);
+ if (out_fd < 0)
+ G_fatal_error(_("Unable to open output map <%s>"), output);
+ out_buf = G_allocate_d_raster_buf();
+ G_set_d_null_value(&out_buf[col], 1);
+ else
+ out_buf[col] = result[base_buf[col] - mincat];
+ G_put_d_raster_row(out_fd, out_buf);
+ G_close_cell(out_fd);
+ if (G_read_colors(covermap, "", &colors) > 0)
+ G_write_colors(output, G_mapset(), &colors);
+ return 0;
Added: grass/trunk/raster/r.statistics2/r.statistics2.html
--- grass/trunk/raster/r.statistics2/r.statistics2.html (rev 0)
+++ grass/trunk/raster/r.statistics2/r.statistics2.html 2008-10-04 22:40:43 UTC (rev 33673)
@@ -0,0 +1,16 @@
+<h2>DESCRIPTION</h2>
+<em>r.statistics2</em> is intended to be a partial replacement for
+r.statistics, with support for floating-point cover maps at the
+expense of not support quantiles.
+<br>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.statistics.html">r.statistics</a>,
+</em>
+<h2>AUTHOR</h2>
+Glynn Clements
+<p><i>Last changed: $Date: 2008-08-15 07:16:42 +0100 (Fri, 15 Aug 2008) $</i></p>
