[GRASS-SVN] r33674 - in grass/trunk: raster/r.mapcalc
	scripts/i.fusion.brovey scripts/r.shaded.relief
    svn_grass at osgeo.org
    Sun Oct  5 04:12:55 EDT 2008
Author: glynn
Date: 2008-10-05 04:12:55 -0400 (Sun, 05 Oct 2008)
New Revision: 33674
   grass/trunk/raster/r.mapcalc/evaluate.c
   grass/trunk/raster/r.mapcalc/mapcalc.y
   grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py
   grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py
Allow eval() at top level
Modified: grass/trunk/raster/r.mapcalc/evaluate.c
--- grass/trunk/raster/r.mapcalc/evaluate.c	2008-10-04 22:40:43 UTC (rev 33673)
+++ grass/trunk/raster/r.mapcalc/evaluate.c	2008-10-05 08:12:55 UTC (rev 33674)
@@ -271,10 +271,13 @@
 	expression *e = l->exp;
 	const char *var;
-	if (e->type != expr_type_binding)
+	if (e->type != expr_type_binding && e->type != expr_type_function)
 	    G_fatal_error("internal error: execute: invalid type: %d",
 			  e->type);
+	if (e->type != expr_type_binding)
+	    continue;
 	var = e->data.bind.var;
 	if (!overwrite && check_output_map(var))
@@ -286,12 +289,11 @@
 	const char *var;
 	expression *val;
+	initialize(e);
-	    G_fatal_error("internal error: execute: invalid type: %d",
-			  e->type);
+	    continue;
-	initialize(e);
 	val = e->data.bind.val;
@@ -308,9 +310,14 @@
 	    for (l = ee; l; l = l->next) {
-		int fd = e->data.bind.fd;
+		int fd;
 		evaluate(e);
+		    continue;
+		fd = e->data.bind.fd;
 		put_map_row(fd, e->buf, e->res_type);
@@ -322,10 +329,17 @@
-	const char *var = e->data.bind.var;
-	expression *val = e->data.bind.val;
+	const char *var;
+	expression *val;
+	int fd;
+	    continue;
+	var = e->data.bind.var;
+	val = e->data.bind.val;
 	close_output_map(fd);
 	e->data.bind.fd = -1;
Modified: grass/trunk/raster/r.mapcalc/mapcalc.y
--- grass/trunk/raster/r.mapcalc/mapcalc.y	2008-10-04 22:40:43 UTC (rev 33673)
+++ grass/trunk/raster/r.mapcalc/mapcalc.y	2008-10-05 08:12:55 UTC (rev 33674)
@@ -92,6 +92,7 @@
 def		: STRING '=' exp	{ $$ = binding($1,$3); define_variable($$);	}
 		| NAME '=' exp		{ $$ = binding($1,$3); define_variable($$);	}
+		| atom_func
 map		: STRING
Modified: grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py
--- grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py	2008-10-04 22:40:43 UTC (rev 33673)
+++ grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py	2008-10-05 08:12:55 UTC (rev 33674)
@@ -132,9 +132,10 @@
     grass.message("Calculating %s.{red,green,blue}: ..." % out)
     t = string.Template(
-	'''"$out.red"   = eval(k = "$pan" / ("$ms1" + "$ms2" + "$ms3"), 1. * "$ms3" * k)
-	   "$out.green" = 1. * "$ms2" * k
-	   "$out.blue"  = 1. * "$ms1" * k''')
+	'''eval(k = float("$pan") / ("$ms1" + "$ms2" + "$ms3"))
+	   "$out.red"   = "$ms3" * k
+	   "$out.green" = "$ms2" * k
+	   "$out.blue"  = "$ms1" * k''')
     e = t.substitute(out = out, pan = pan, ms1 = ms1, ms2 = ms2, ms3 = ms3)
     if grass.run_command('r.mapcalc', expression = e) != 0:
 	grass.fatal("An error occurred while running r.mapcalc")
Modified: grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py
--- grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py	2008-10-04 22:40:43 UTC (rev 33673)
+++ grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py	2008-10-05 08:12:55 UTC (rev 33674)
@@ -120,7 +120,7 @@
     units = options['units']
     if not grass.find_file(input)['file']:
-	grass.fatal("Map <%s> not found." % elev)
+	grass.fatal("Map <%s> not found." % input)
     if input == output:
 	grass.fatal("Input elevation map and output relief map must have different names")
@@ -152,18 +152,19 @@
     grass.message("Calculating shading, please stand by.")
-    t = string.Template(r'''$elev_out = eval( \
-x=($zmult*$elev[-1,-1] + 2*$zmult*$elev[0,-1] + $zmult*$elev[1,-1] - \
- $zmult*$elev[-1,1] - 2*$zmult*$elev[0,1] - $zmult*$elev[1,1])/(8.*ewres()*$scale), \
-y=($zmult*$elev[-1,-1] + 2*$zmult*$elev[-1,0] + $zmult*$elev[-1,1] - \
- $zmult*$elev[1,-1] - 2*$zmult*$elev[1,0] - $zmult*$elev[1,1])/(8.*nsres()*$scale), \
-slope=90.-atan(sqrt(x*x + y*y)), \
-a=round(atan(x,y)), \
-a=if(isnull(a),1,a), \
-aspect=if(x!=0||y!=0,if(a,a,360.)), \
-cang = sin($alt)*sin(slope) + cos($alt)*cos(slope) * cos($az-aspect), \
-if(cang < 0.,0.,100.*cang), \
-if(isnull(cang), null(), 100.*cang))''')
+    t = string.Template(
+	r'''eval( \
+	x=($zmult*$elev[-1,-1] + 2*$zmult*$elev[0,-1] + $zmult*$elev[1,-1] - \
+	$zmult*$elev[-1,1] - 2*$zmult*$elev[0,1] - $zmult*$elev[1,1])/(8.*ewres()*$scale), \
+	y=($zmult*$elev[-1,-1] + 2*$zmult*$elev[-1,0] + $zmult*$elev[-1,1] - \
+	$zmult*$elev[1,-1] - 2*$zmult*$elev[1,0] - $zmult*$elev[1,1])/(8.*nsres()*$scale), \
+	slope=90.-atan(sqrt(x*x + y*y)), \
+	a=round(atan(x,y)), \
+	a=if(isnull(a),1,a), \
+	aspect=if(x!=0||y!=0,if(a,a,360.)), \
+	cang = sin($alt)*sin(slope) + cos($alt)*cos(slope) * cos($az-aspect), \
+	$elev_out = if(isnull(cang), null(), 100.*cang)''')
     expr = t.substitute(alt = alt, az = az, elev = elev, elev_out = elev_out, scale = scale, zmult = zmult)
     p = grass.feed_command('r.mapcalc')
     p.stdin.write(expr)
