[GRASS-SVN] r33722 - grass/trunk/vector/v.vol.rst
Tue Oct 7 07:28:50 EDT 2008
Author: neteler
Date: 2008-10-07 07:28:49 -0400 (Tue, 07 Oct 2008)
New Revision: 33722
   grass/trunk/vector/v.vol.rst/v.vol.rst.html
cosmetics
Modified: grass/trunk/vector/v.vol.rst/v.vol.rst.html
--- grass/trunk/vector/v.vol.rst/v.vol.rst.html	2008-10-07 10:53:02 UTC (rev 33721)
+++ grass/trunk/vector/v.vol.rst/v.vol.rst.html	2008-10-07 11:28:49 UTC (rev 33722)
@@ -26,7 +26,7 @@
 the w-values and z-coordinates of the point data (useful e.g. for
 transformation of elevations given in feet to meters, so that the
 proper values of gradient and curvatures can be computed).
-Rescaling of z-coordinates is also needed when the distances
+Rescaling of z-coordinates (<i>zmult</i>) is also needed when the distances
 in vertical direction are much smaller than the horizontal
 distances, if that is the case, the value of <i>zmult</i>
 should be selected so that the vertical and horizontal distances
