[GRASS-SVN] r33723 - grass/branches/develbranch_6/vector/v.vol.rst
svn_grass at osgeo.org
Tue Oct 7 07:30:03 EDT 2008
Author: neteler
Date: 2008-10-07 07:30:03 -0400 (Tue, 07 Oct 2008)
New Revision: 33723
grass/branches/develbranch_6/vector/v.vol.rst/description.html
cosmetics
Modified: grass/branches/develbranch_6/vector/v.vol.rst/description.html
--- grass/branches/develbranch_6/vector/v.vol.rst/description.html 2008-10-07 11:28:49 UTC (rev 33722)
+++ grass/branches/develbranch_6/vector/v.vol.rst/description.html 2008-10-07 11:30:03 UTC (rev 33723)
@@ -26,7 +26,7 @@
the w-values and z-coordinates of the point data (useful e.g. for
transformation of elevations given in feet to meters, so that the
proper values of gradient and curvatures can be computed).
-Rescaling of z-coordinates is also needed when the distances
+Rescaling of z-coordinates (<i>zmult</i>) is also needed when the distances
in vertical direction are much smaller than the horizontal
distances, if that is the case, the value of <i>zmult</i>
should be selected so that the vertical and horizontal distances
