[GRASS-SVN] r33841 - grass-addons/gipe/i.latlong
svn_grass at osgeo.org
Sun Oct 12 04:50:48 EDT 2008
Author: ychemin
Date: 2008-10-12 04:50:48 -0400 (Sun, 12 Oct 2008)
New Revision: 33841
grass-addons/gipe/i.latlong/i.latlong.html
grass-addons/gipe/i.latlong/main.c
Prepared i.latlong for main SVN
Modified: grass-addons/gipe/i.latlong/i.latlong.html
--- grass-addons/gipe/i.latlong/i.latlong.html 2008-10-12 08:32:46 UTC (rev 33840)
+++ grass-addons/gipe/i.latlong/i.latlong.html 2008-10-12 08:50:48 UTC (rev 33841)
@@ -7,7 +7,7 @@
The proj <A HREF="http://www.remotesensing.org/proj/">website</A>.
<H2>TODO</H2>
-Datum corrected reprojection is not implemented.
+Datum transform is not implemented, the same datum is taken as output.
<H2>SEE ALSO</H2>
Modified: grass-addons/gipe/i.latlong/main.c
--- grass-addons/gipe/i.latlong/main.c 2008-10-12 08:32:46 UTC (rev 33840)
+++ grass-addons/gipe/i.latlong/main.c 2008-10-12 08:50:48 UTC (rev 33841)
@@ -1,4 +1,3 @@
* MODULE: i.latlong
@@ -23,43 +22,41 @@
int main(int argc, char *argv[])
struct Cell_head cellhd; /*region+header info */
- char *mapset; /*mapset name */
int nrows, ncols;
int row, col;
int not_ll = 0; /*if proj is not lat/long, it will be 1. */
struct GModule *module;
struct Option *input1, *output1;
struct Flag *flag1;
struct History history; /*metadata */
struct pj_info iproj;
struct pj_info oproj;
+ struct Key_Value *in_proj_info, *in_unit_info;
- char *name; /*input raster name */
char *result1; /*output raster name */
int infd;
int outfd1;
char *in;
- int i = 0, j = 0;
- double xp, yp;
double xmin, ymin;
double xmax, ymax;
double stepx, stepy;
double latitude, longitude;
void *inrast;
DCELL * outrast1;
- RASTER_MAP_TYPE data_type_output = DCELL_TYPE;
- RASTER_MAP_TYPE data_type_inrast;
+ DCELL d;
- G_gisinit(argv[0]);
+ G_gisinit(argv[0]);
module = G_define_module();
- module->keywords = _("longitude, projection");
- module->description = _("creates a longitude map");
+ module->keywords = _("imagery, latitude, longitude, projection");
+ module->description = _("creates a latitude/longitude map");
- /* Define the different options */
- input1 = G_define_standard_option(G_OPT_R_INPUT);
+ /* Define the different options */
+ input1 = G_define_standard_option(G_OPT_R_INPUT);
input1->description = _("Name of the input map");
output1 = G_define_standard_option(G_OPT_R_OUTPUT);
@@ -67,28 +64,23 @@
flag1 = G_define_flag();
flag1->key = 'l';
- flag1->description = _("Loongitude output");
+ flag1->description = _("Longitude output");
- if (G_parser(argc, argv))
+ if (G_parser(argc, argv))
exit(EXIT_FAILURE);
in = input1->answer;
result1 = output1->answer;
- mapset = G_find_cell2(in, "");
- if (mapset == NULL) {
- G_fatal_error(_("cell file [%s] not found"), in);
- data_type_inrast = G_raster_map_type(in, mapset);
- if ((infd = G_open_cell_old(in, mapset)) < 0)
+ if ((infd = G_open_cell_old(in, "")) < 0)
G_fatal_error(_("Cannot open cell file [%s]"), in);
- if (G_get_cellhd(in, mapset, &cellhd) < 0)
+ if (G_get_cellhd(in, "", &cellhd) < 0)
G_fatal_error(_("Cannot read file header of [%s])"), in);
- inrast = G_allocate_raster_buf(data_type_inrast);
+ inrast = G_allocate_d_raster_buf();
stepx = cellhd.ew_res;
stepy = cellhd.ns_res;
xmin = cellhd.west;
@@ -98,12 +90,11 @@
nrows = G_window_rows();
ncols = G_window_cols();
- /*Shamelessly stolen from r.sun !!!! */
- /* Set up parameters for projection to lat/long if necessary */
+ /*Stolen from r.sun */
+ /* Set up parameters for projection to lat/long if necessary */
if ((G_projection() != PROJECTION_LL))
not_ll = 1;
- struct Key_Value *in_proj_info, *in_unit_info;
if ((in_proj_info = G_get_projinfo()) == NULL)
G_fatal_error(_("Can't get projection info of current location"));
@@ -120,43 +111,34 @@
sprintf(oproj.proj, "ll");
if ((oproj.pj = pj_latlong_from_proj(iproj.pj)) == NULL)
G_fatal_error(_("Unable to set up lat/long projection parameters"));
- } /* End of stolen from r.sun :P */
+ } /* End of stolen from r.sun */
- outrast1 = G_allocate_raster_buf(data_type_output);
+ outrast1 = G_allocate_d_raster_buf();
- if ((outfd1 = G_open_raster_new(result1, data_type_output)) < 0)
+ if ((outfd1 = G_open_raster_new(result1,DCELL_TYPE)) < 0)
G_fatal_error(_("Could not open <%s>"), result1);
for (row = 0; row < nrows; row++)
- DCELL d;
- DCELL d_lon;
- DCELL d_lat;
G_percent(row, nrows, 2);
- if (G_get_raster_row(infd, inrast, row, data_type_inrast) < 0)
+ if (G_get_d_raster_row(infd, inrast, row) < 0)
G_fatal_error(_("Could not read from <%s>"), in);
for (col = 0; col < ncols; col++)
latitude = ymax - (row * stepy);
longitude = xmin + (col * stepx);
- if (not_ll) {
- if (pj_do_proj(&longitude, &latitude, &iproj, &oproj) < 0) {
+ if (not_ll)
+ if (pj_do_proj(&longitude, &latitude, &iproj, &oproj) < 0)
G_fatal_error(_("Error in pj_do_proj"));
- else {
- /*Do nothing */
if(flag1->answer)
d = longitude;
else
d = latitude;
outrast1[col] = d;
- if (G_put_raster_row(outfd1, outrast1, data_type_output) < 0)
+ if (G_put_d_raster_row(outfd1, outrast1) < 0)
G_fatal_error(_("Cannot write to output raster file"));
G_free(inrast);
