[GRASS-SVN] r33842 - in grass/trunk: gui/tcltk/gis.m
gui/wxpython/gui_modules imagery imagery/i.latlong
svn_grass at osgeo.org
Sun Oct 12 04:59:03 EDT 2008
Author: ychemin
Date: 2008-10-12 04:59:02 -0400 (Sun, 12 Oct 2008)
New Revision: 33842
Added:
grass/trunk/imagery/i.latlong/
grass/trunk/imagery/i.latlong/Makefile
grass/trunk/imagery/i.latlong/i.latlong.html
grass/trunk/imagery/i.latlong/main.c
grass/trunk/gui/tcltk/gis.m/gmmenu.tcl
grass/trunk/gui/wxpython/gui_modules/menudata.py
grass/trunk/imagery/Makefile
added i.latlong with GUIs menus
Modified: grass/trunk/gui/tcltk/gis.m/gmmenu.tcl
--- grass/trunk/gui/tcltk/gis.m/gmmenu.tcl 2008-10-12 08:50:48 UTC (rev 33841)
+++ grass/trunk/gui/tcltk/gis.m/gmmenu.tcl 2008-10-12 08:59:02 UTC (rev 33842)
@@ -549,6 +549,7 @@
{separator}
{cascad {[G_msg "Basic RS processing"]} {} "" $tmenu {
{command {[G_msg "MODIS Quality flags"]} {} "i.modis.qc: Extracts Modis Quality flags as raster values." {} -command {execute i.modis.qc }}
+ {command {[G_msg "Latitude/longitude maps"]} {} "i.latlong: Latitude or Longitude maps." {} -command {execute i.latlong }}
{separator}
{command {[G_msg "Albedo"]} {} "i.albedo: Calculates Albedo from Modis, Aster, Landsat or AVHRR" {} -command {execute i.albedo }}
{separator}
Modified: grass/trunk/gui/wxpython/gui_modules/menudata.py
--- grass/trunk/gui/wxpython/gui_modules/menudata.py 2008-10-12 08:50:48 UTC (rev 33841)
+++ grass/trunk/gui/wxpython/gui_modules/menudata.py 2008-10-12 08:59:02 UTC (rev 33842)
@@ -1630,6 +1630,11 @@
_("Extract Modis Quality flags as raster values."),
"self.OnMenuCmd",
"i.modis.qc"),
+ (_("Latitude/longitude maps"),
+ _("Creates Latitude or Longitude map."),
+ "self.OnMenuCmd",
+ "i.latlong"),
(_("Albedo"),
Modified: grass/trunk/imagery/Makefile
--- grass/trunk/imagery/Makefile 2008-10-12 08:50:48 UTC (rev 33841)
+++ grass/trunk/imagery/Makefile 2008-10-12 08:59:02 UTC (rev 33842)
@@ -12,6 +12,7 @@
i.gensigset \
i.group \
i.his.rgb \
+ i.latlong \
i.maxlik \
i.modis.qc \
i.rectify \
Added: grass/trunk/imagery/i.latlong/Makefile
--- grass/trunk/imagery/i.latlong/Makefile (rev 0)
+++ grass/trunk/imagery/i.latlong/Makefile 2008-10-12 08:59:02 UTC (rev 33842)
@@ -0,0 +1,15 @@
+MODULE_TOPDIR = ../..
+PGM = i.latlong
+LIBES = $(GPROJLIB) $(GISLIB)
+DEPENDENCIES = $(GPROJDEP) $(GISDEP)
+EXTRA_INC = $(PROJINC)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+ifneq ($(USE_LARGEFILES),)
+ EXTRA_CFLAGS = -D_FILE_OFFSET_BITS=64
+endif
+default: cmd
Added: grass/trunk/imagery/i.latlong/i.latlong.html
--- grass/trunk/imagery/i.latlong/i.latlong.html (rev 0)
+++ grass/trunk/imagery/i.latlong/i.latlong.html 2008-10-12 08:59:02 UTC (rev 33842)
@@ -0,0 +1,26 @@
+<H2>DESCRIPTION</H2>
+<EM>i.latlong</EM> creates a latitude (degree decimal) map, or longitude if the -l flag is used, from any map in any projection using PROJ.4 library.
+This is an input to r.sun and i.evapo.potrad.
+<H2>NOTES</H2>
+The proj <A HREF="http://www.remotesensing.org/proj/">website</A>.
+<H2>TODO</H2>
+Datum transform is not implemented, the same datum is taken as output.
+<H2>SEE ALSO</H2>
+<em>
+<A HREF="i.evapo.potrad.html">i.evapo.potrad</A><br>
+<A HREF="r.sun.html">r.sun</A><br>
+</em>
+<H2>AUTHORS</H2>
+Yann Chemin, International Rice Research Institute, The Philippines.<br>
+<p>
+<i>Last changed: $Date: 2008/10/12 12:25:55 $</i>
Added: grass/trunk/imagery/i.latlong/main.c
--- grass/trunk/imagery/i.latlong/main.c (rev 0)
+++ grass/trunk/imagery/i.latlong/main.c 2008-10-12 08:59:02 UTC (rev 33842)
@@ -0,0 +1,156 @@
+ * MODULE: i.latlong
+ * AUTHOR(S): Yann Chemin - yann.chemin at gmail.com
+ * PURPOSE: Calculates the longitude of the pixels in the map.
+ * COPYRIGHT: (C) 2002-2008 by the GRASS Development Team
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/gprojects.h>
+#include <grass/glocale.h>
+int main(int argc, char *argv[])
+ struct Cell_head cellhd; /*region+header info */
+ int nrows, ncols;
+ int row, col;
+ int not_ll = 0; /*if proj is not lat/long, it will be 1. */
+ struct GModule *module;
+ struct Option *input1, *output1;
+ struct Flag *flag1;
+ struct History history; /*metadata */
+ struct pj_info iproj;
+ struct pj_info oproj;
+ struct Key_Value *in_proj_info, *in_unit_info;
+ char *result1; /*output raster name */
+ int infd;
+ int outfd1;
+ char *in;
+ double xmin, ymin;
+ double xmax, ymax;
+ double stepx, stepy;
+ double latitude, longitude;
+ void *inrast;
+ DCELL * outrast1;
+ DCELL d;
+ G_gisinit(argv[0]);
+ module = G_define_module();
+ module->keywords = _("imagery, latitude, longitude, projection");
+ module->description = _("creates a latitude/longitude map");
+ /* Define the different options */
+ input1 = G_define_standard_option(G_OPT_R_INPUT);
+ input1->description = _("Name of the input map");
+ output1 = G_define_standard_option(G_OPT_R_OUTPUT);
+ output1->description = _("Name of the output longitude layer");
+ flag1 = G_define_flag();
+ flag1->key = 'l';
+ flag1->description = _("Longitude output");
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ in = input1->answer;
+ result1 = output1->answer;
+ if ((infd = G_open_cell_old(in, "")) < 0)
+ G_fatal_error(_("Cannot open cell file [%s]"), in);
+ if (G_get_cellhd(in, "", &cellhd) < 0)
+ G_fatal_error(_("Cannot read file header of [%s])"), in);
+ inrast = G_allocate_d_raster_buf();
+ stepx = cellhd.ew_res;
+ stepy = cellhd.ns_res;
+ xmin = cellhd.west;
+ xmax = cellhd.east;
+ ymin = cellhd.south;
+ ymax = cellhd.north;
+ nrows = G_window_rows();
+ ncols = G_window_cols();
+ /*Stolen from r.sun */
+ /* Set up parameters for projection to lat/long if necessary */
+ if ((G_projection() != PROJECTION_LL))
+ not_ll = 1;
+ if ((in_proj_info = G_get_projinfo()) == NULL)
+ G_fatal_error(_("Can't get projection info of current location"));
+ if ((in_unit_info = G_get_projunits()) == NULL)
+ G_fatal_error(_("Can't get projection units of current location"));
+ if (pj_get_kv(&iproj, in_proj_info, in_unit_info) < 0)
+ G_fatal_error(_("Can't get projection key values of current location"));
+ G_free_key_value(in_proj_info);
+ G_free_key_value(in_unit_info);
+ /* Set output projection to latlong w/ same ellipsoid */
+ oproj.zone = 0;
+ oproj.meters = 1.;
+ sprintf(oproj.proj, "ll");
+ if ((oproj.pj = pj_latlong_from_proj(iproj.pj)) == NULL)
+ G_fatal_error(_("Unable to set up lat/long projection parameters"));
+ } /* End of stolen from r.sun */
+ outrast1 = G_allocate_d_raster_buf();
+ if ((outfd1 = G_open_raster_new(result1,DCELL_TYPE)) < 0)
+ G_fatal_error(_("Could not open <%s>"), result1);
+ for (row = 0; row < nrows; row++)
+ G_percent(row, nrows, 2);
+ if (G_get_d_raster_row(infd, inrast, row) < 0)
+ G_fatal_error(_("Could not read from <%s>"), in);
+ for (col = 0; col < ncols; col++)
+ latitude = ymax - (row * stepy);
+ longitude = xmin + (col * stepx);
+ if (not_ll)
+ if (pj_do_proj(&longitude, &latitude, &iproj, &oproj) < 0)
+ G_fatal_error(_("Error in pj_do_proj"));
+ if(flag1->answer)
+ d = longitude;
+ else
+ d = latitude;
+ outrast1[col] = d;
+ if (G_put_d_raster_row(outfd1, outrast1) < 0)
+ G_fatal_error(_("Cannot write to output raster file"));
+ G_free(inrast);
+ G_close_cell(infd);
+ G_free(outrast1);
+ G_close_cell(outfd1);
+ G_short_history(result1, "raster", &history);
+ G_command_history(&history);
+ G_write_history(result1, &history);
+ exit(EXIT_SUCCESS);
