[GRASS-SVN] r33860 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Oct 13 03:48:42 EDT 2008
Author: martinl
Date: 2008-10-13 03:48:42 -0400 (Mon, 13 Oct 2008)
New Revision: 33860
grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
wxGUI: unused methods removed
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2008-10-13 06:38:14 UTC (rev 33859)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2008-10-13 07:48:42 UTC (rev 33860)
@@ -1467,80 +1467,6 @@
event.Skip()
- def OnDbColumn(self, event):
- """Get list of table columns"""
- choices = []
- p = self.task.get_param('table', raiseError=False)
- if p and p.get('prompt', '') == 'dbtable':
- cmd = ['db.columns',
- 'table=%s' % p.get('value')]
- try:
- choices = gcmd.Command(cmd).ReadStdOutput()
- except gcmd.CmdError:
- choices = []
- if not p:
- p = self.task.get_param('map', raiseError=False)
- if not p:
- p = self.task.get_param('input', raiseError=False)
- if p:
- mapName = utils.GetLayerNameFromCmd(self.task.getCmd(ignoreErrors=True))
- if mapName != _('<required>'):
- layer = 1
- p = self.task.get_param('layer')
- if p:
- value = p.get('value', '1')
- if value:
- layer = int(value)
- cmd = ['v.info',
- 'map=%s' % mapName,
- 'layer=%d' % layer,
- '-c', '--q']
- try:
- for line in gcmd.Command(cmd).ReadStdOutput():
- type, name = line.split('|')
- choices.append(name.strip())
- choices = []
- win = self.FindWindowById(event.GetId())
- win.SetItems(choices)
- if len(choices) < 1:
- win.SetValue('')
- event.Skip()
- def OnDbTable(self, event):
- """Get list of tables"""
- # TODO: add driver/database
- cmd = ['db.tables',
- '-p', '--q']
- for p in self.task.params:
- if p.get('name', '') == 'driver' and \
- len(p.get('value', '')) > 0:
- cmd.append('driver=%s' % p.get('value'))
- elif p.get('name', '') == 'database' and \
- cmd.append('database=%s' % p.get('value'))
- try:
- choices = []
- win.SetValue('')
- event.Skip()
def createCmd( self, ignoreErrors = False ):
Produce a command line string (list) or feeding into GRASS.
