[GRASS-SVN] r33866 - grass/trunk/vector/v.out.ogr
svn_grass at osgeo.org
Tue Oct 14 06:09:17 EDT 2008
Author: neteler
Date: 2008-10-14 06:09:16 -0400 (Tue, 14 Oct 2008)
New Revision: 33866
grass/trunk/vector/v.out.ogr/main.c
Roger Bivand, Frank Warmerdam, Dylan Beaudette: prevent writing NULL values (trac #327)
Modified: grass/trunk/vector/v.out.ogr/main.c
--- grass/trunk/vector/v.out.ogr/main.c 2008-10-14 00:35:21 UTC (rev 33865)
+++ grass/trunk/vector/v.out.ogr/main.c 2008-10-14 10:09:16 UTC (rev 33866)
@@ -712,25 +712,29 @@
colsqltype = db_get_column_sqltype(Column);
colctype = db_sqltype_to_Ctype(colsqltype);
G_debug(2, " colctype = %d", colctype);
- switch (colctype) {
- case DB_C_TYPE_INT:
- OGR_F_SetFieldInteger(Ogr_feature, j,
- db_get_value_int(Value));
- break;
- case DB_C_TYPE_DOUBLE:
- OGR_F_SetFieldDouble(Ogr_feature, j,
- db_get_value_double(Value));
- break;
- case DB_C_TYPE_STRING:
- OGR_F_SetFieldString(Ogr_feature, j,
- db_get_value_string(Value));
- break;
- case DB_C_TYPE_DATETIME:
- db_convert_column_value_to_string(Column,
- &dbstring);
- db_get_string(&dbstring));
- break;
+ /* prevent writing NULL values */
+ if (!db_test_value_isnull(Value)) {
+ switch (colctype) {
+ case DB_C_TYPE_INT:
+ OGR_F_SetFieldInteger(Ogr_feature, j,
+ db_get_value_int(Value));
+ break;
+ case DB_C_TYPE_DOUBLE:
+ OGR_F_SetFieldDouble(Ogr_feature, j,
+ db_get_value_double(Value));
+ break;
+ case DB_C_TYPE_STRING:
+ OGR_F_SetFieldString(Ogr_feature, j,
+ db_get_value_string(Value));
+ break;
+ case DB_C_TYPE_DATETIME:
+ db_convert_column_value_to_string(Column,
+ &dbstring);
+ db_get_string(&dbstring));
+ break;
