[GRASS-SVN] r33867 - grass/branches/releasebranch_6_3/vector/v.out.ogr
Tue Oct 14 06:12:03 EDT 2008
Author: neteler
Date: 2008-10-14 06:12:03 -0400 (Tue, 14 Oct 2008)
New Revision: 33867
   grass/branches/releasebranch_6_3/vector/v.out.ogr/main.c
applied grass64/tools/grass_indent.sh
Modified: grass/branches/releasebranch_6_3/vector/v.out.ogr/main.c
--- grass/branches/releasebranch_6_3/vector/v.out.ogr/main.c	2008-10-14 10:09:16 UTC (rev 33866)
+++ grass/branches/releasebranch_6_3/vector/v.out.ogr/main.c	2008-10-14 10:12:03 UTC (rev 33867)
@@ -16,8 +16,8 @@
  * *               for details.
-#include <stdlib.h>
-#include <string.h>
+#include <stdlib.h>
+#include <string.h>
 #include <grass/gis.h>
 #include <grass/dbmi.h>
 #include <grass/Vect.h>
@@ -27,55 +27,55 @@
 #include "ogr_api.h"
 #include "cpl_string.h"
-int    fout, fskip; /* features written/ skip */
-int    nocat, noatt, nocatskip; /* number of features without cats/atts written/skip */
-int mk_att ( int cat, struct field_info *Fi, dbDriver *Driver, int ncol, int keycol, int doatt,
-	 OGRFeatureH Ogr_feature);
+int fout, fskip;		/* features written/ skip */
+int nocat, noatt, nocatskip;	/* number of features without cats/atts written/skip */
+int mk_att(int cat, struct field_info *Fi, dbDriver * Driver, int ncol,
+	   int keycol, int doatt, OGRFeatureH Ogr_feature);
 char *OGR_list_write_drivers();
 char OGRdrivers[2000];
-int
-main (int argc, char *argv[])
+int main(int argc, char *argv[])
-    int    i, j, k, centroid, otype, donocat;
-    char   *mapset;
-    int    field;
+    int i, j, k, centroid, otype, donocat;
+    char *mapset;
+    int field;
     struct GModule *module;
-    struct Option *in_opt, *dsn_opt, *layer_opt, *type_opt, *frmt_opt, *field_opt, *dsco, *lco;
-    struct Flag   *cat_flag, *esristyle, *poly_flag;
-    char   buf[2000];
-    char   key1[200], key2[200];
+    struct Option *in_opt, *dsn_opt, *layer_opt, *type_opt, *frmt_opt,
+	*field_opt, *dsco, *lco;
+    struct Flag *cat_flag, *esristyle, *poly_flag;
+    char buf[2000];
+    char key1[200], key2[200];
     struct Key_Value *projinfo, *projunits;
     struct Cell_head cellhd;
-    char   **tokens;
+    char **tokens;
     /* Vector */
     struct Map_info In;
     struct line_pnts *Points;
     struct line_cats *Cats;
-    int    type, cat;
+    int type, cat;
     /* Attributes */
-    int doatt=0, ncol=0, colsqltype, colctype, keycol=-1;
-    struct field_info *Fi=NULL;
-    dbDriver *Driver=NULL;
+    int doatt = 0, ncol = 0, colsqltype, colctype, keycol = -1;
+    struct field_info *Fi = NULL;
+    dbDriver *Driver = NULL;
     dbHandle handle;
     dbTable *Table;
     dbString dbstring;
     dbColumn *Column;
     /* OGR */
-    int drn, ogr_ftype=OFTInteger;
+    int drn, ogr_ftype = OFTInteger;
     OGRDataSourceH Ogr_ds;
-    OGRSFDriverH Ogr_driver;
-    OGRLayerH Ogr_layer;
-    OGRFieldDefnH Ogr_field;
-    OGRFeatureH Ogr_feature;
+    OGRSFDriverH Ogr_driver;
+    OGRLayerH Ogr_layer;
+    OGRFieldDefnH Ogr_field;
+    OGRFeatureH Ogr_feature;
     OGRFeatureDefnH Ogr_featuredefn;
     OGRGeometryH Ogr_geometry;
-    unsigned int wkbtype=wkbUnknown;  /* ?? */
+    unsigned int wkbtype = wkbUnknown;	/* ?? */
     OGRSpatialReferenceH Ogr_projection;
     char **papszDSCO = NULL, **papszLCO = NULL;
@@ -84,62 +84,68 @@
     /* Module options */
     module = G_define_module();
     module->keywords = _("vector, export");
-    module->description = _("Converts to one of the supported OGR vector formats.");
+    module->description =
+	_("Converts to one of the supported OGR vector formats.");
     in_opt = G_define_standard_option(G_OPT_V_INPUT);
-    type_opt = G_define_standard_option(G_OPT_V_TYPE) ;
+    type_opt = G_define_standard_option(G_OPT_V_TYPE);
     type_opt->options = "point,kernel,centroid,line,boundary,area,face";
     type_opt->answer = "line,boundary";
-    type_opt->description = _("Feature type. Combination of types is not supported"
-                              " by all formats.");
+    type_opt->description =
+	_("Feature type. Combination of types is not supported"
+	  " by all formats.");
     dsn_opt = G_define_option();
     dsn_opt->key = "dsn";
-    dsn_opt->type =  TYPE_STRING;
+    dsn_opt->type = TYPE_STRING;
     dsn_opt->required = YES;
     dsn_opt->label = _("OGR output datasource name");
-    dsn_opt->description = _("For example: ESRI Shapefile: filename or directory for storage");
+    dsn_opt->description =
+	_("For example: ESRI Shapefile: filename or directory for storage");
     layer_opt = G_define_option();
     layer_opt->key = "olayer";
     layer_opt->type = TYPE_STRING;
     layer_opt->required = NO;
-    layer_opt->label = _("OGR layer name. If not specified, input name is used.");
+    layer_opt->label =
+	_("OGR layer name. If not specified, input name is used.");
     layer_opt->description = _("For example: ESRI Shapefile: shapefile name");
     field_opt = G_define_standard_option(G_OPT_V_FIELD);
     frmt_opt = G_define_option();
     frmt_opt->key = "format";
-    frmt_opt->type =  TYPE_STRING;
+    frmt_opt->type = TYPE_STRING;
     frmt_opt->required = NO;
     frmt_opt->multiple = NO;
     frmt_opt->answer = "ESRI_Shapefile";
     frmt_opt->options = OGR_list_write_drivers();
     frmt_opt->description = _("OGR format");
-    dsco              = G_define_option();
-    dsco->key         = "dsco";
-    dsco->type        = TYPE_STRING;
-    dsco->required    = NO;
-    dsco->multiple    = YES;
-    dsco->answer      = "";
-    dsco->description = _("OGR dataset creation option (format specific, NAME=VALUE)");
-    lco               = G_define_option();
-    lco->key          = "lco";
-    lco->type         = TYPE_STRING;
-    lco->required     = NO;
-    lco->multiple     = YES;
-    lco->answer       = "";
-    lco->description  = _("OGR layer creation option (format specific, NAME=VALUE)");
-    cat_flag = G_define_flag ();
-    cat_flag->key            = 'c';
-    cat_flag->description    = _("Export features with category (labeled) only. "
-			       "Otherwise all features are exported");
+    dsco = G_define_option();
+    dsco->key = "dsco";
+    dsco->type = TYPE_STRING;
+    dsco->required = NO;
+    dsco->multiple = YES;
+    dsco->answer = "";
+    dsco->description =
+	_("OGR dataset creation option (format specific, NAME=VALUE)");
+    lco = G_define_option();
+    lco->key = "lco";
+    lco->type = TYPE_STRING;
+    lco->required = NO;
+    lco->multiple = YES;
+    lco->answer = "";
+    lco->description =
+	_("OGR layer creation option (format specific, NAME=VALUE)");
+    cat_flag = G_define_flag();
+    cat_flag->key = 'c';
+    cat_flag->description = _("Export features with category (labeled) only. "
+			      "Otherwise all features are exported");
     esristyle = G_define_flag();
     esristyle->key = 'e';
     esristyle->description = _("Use ESRI-style .prj file format "
@@ -148,88 +154,97 @@
     poly_flag = G_define_flag();
     poly_flag->key = 'p';
     poly_flag->description = _("Export lines as polygons");
-    if (G_parser (argc, argv)) exit(EXIT_FAILURE);
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
     /* read options */
-    field = atoi( field_opt->answer );
+    field = atoi(field_opt->answer);
     /* Check output type */
-    otype = Vect_option_to_types ( type_opt );
-    if (! layer_opt->answer)
-       layer_opt->answer = G_store(in_opt->answer);
-    if ( otype & GV_POINTS ) wkbtype = wkbPoint;
-    else if ( otype & GV_LINES ) wkbtype = wkbLineString;
-    else if ( otype & GV_AREA ) wkbtype = wkbPolygon;
-    else if ( otype & GV_FACE ) wkbtype = wkbPolygon25D;
+    otype = Vect_option_to_types(type_opt);
-    if ( poly_flag->answer ) wkbtype = wkbPolygon;
+    if (!layer_opt->answer)
+	layer_opt->answer = G_store(in_opt->answer);
-    if ( ((GV_POINTS & otype) && (GV_LINES & otype)) ||
-	 ((GV_POINTS & otype) && (GV_AREA & otype)) ||
-	 ((GV_POINTS & otype) && (GV_FACE & otype)) ||
-	 ((GV_LINES & otype) && (GV_AREA & otype)) ||
-	 ((GV_LINES & otype) && (GV_FACE & otype))
-	 G_warning (_("The combination of types is not supported"
-                      " by all formats."));
-          wkbtype=wkbUnknown;
+    if (otype & GV_POINTS)
+	wkbtype = wkbPoint;
+    else if (otype & GV_LINES)
+	wkbtype = wkbLineString;
+    else if (otype & GV_AREA)
+	wkbtype = wkbPolygon;
+    else if (otype & GV_FACE)
+	wkbtype = wkbPolygon25D;
-    if ( cat_flag->answer ) donocat = 0; else donocat = 1;
-    Points = Vect_new_line_struct ();
-    Cats = Vect_new_cats_struct ();
+    if (poly_flag->answer)
+    if (((GV_POINTS & otype) && (GV_LINES & otype)) ||
+	((GV_POINTS & otype) && (GV_AREA & otype)) ||
+	((GV_POINTS & otype) && (GV_FACE & otype)) ||
+	((GV_LINES & otype) && (GV_AREA & otype)) ||
+	((GV_LINES & otype) && (GV_FACE & otype))
+	G_warning(_("The combination of types is not supported"
+		    " by all formats."));
+	wkbtype = wkbUnknown;
+    if (cat_flag->answer)
+	donocat = 0;
+    else
+	donocat = 1;
+    Points = Vect_new_line_struct();
+    Cats = Vect_new_cats_struct();
     /* open input vector */
-    if ((mapset = G_find_vector2 (in_opt->answer, "")) == NULL) {
-	 G_fatal_error (_("Vector map <%s> not found"), in_opt->answer);
+    if ((mapset = G_find_vector2(in_opt->answer, "")) == NULL) {
+	G_fatal_error(_("Vector map <%s> not found"), in_opt->answer);
-    Vect_set_open_level (2);
-    Vect_open_old (&In, in_opt->answer, mapset);
+    Vect_set_open_level(2);
+    Vect_open_old(&In, in_opt->answer, mapset);
     /* check if the map is 3d */
     if (Vect_is_3d(&In)) {
-	G_warning (_("Vector map <%s> is 3D. "
-		     "Use format specific layer creation options (parameter 'lco') to export in 3D rather than 2D (default)"),
-		   in_opt->answer);
+	G_warning(_("Vector map <%s> is 3D. "
+		    "Use format specific layer creation options (parameter 'lco') to export in 3D rather than 2D (default)"),
+		  in_opt->answer);
     /* fetch PROJ info */
     G_get_default_window(&cellhd);
-    if( cellhd.proj == PROJECTION_XY )
-        Ogr_projection = NULL;
-    else
-        projinfo = G_get_projinfo();
-        projunits = G_get_projunits();
-        Ogr_projection = GPJ_grass_to_osr(projinfo, projunits);
-        if (esristyle->answer && (strcmp(frmt_opt->answer, "ESRI_Shapefile") == 0))
-           OSRMorphToESRI(Ogr_projection);
+    if (cellhd.proj == PROJECTION_XY)
+	Ogr_projection = NULL;
+    else {
+	projinfo = G_get_projinfo();
+	projunits = G_get_projunits();
+	Ogr_projection = GPJ_grass_to_osr(projinfo, projunits);
+	if (esristyle->answer &&
+	    (strcmp(frmt_opt->answer, "ESRI_Shapefile") == 0))
+	    OSRMorphToESRI(Ogr_projection);
     /* Open OGR DSN */
     OGRRegisterAll();
-    G_debug (2, "driver count = %d", OGRGetDriverCount() );
+    G_debug(2, "driver count = %d", OGRGetDriverCount());
     drn = -1;
-    for ( i = 0; i < OGRGetDriverCount(); i++ ) {
-	Ogr_driver = OGRGetDriver( i );
-	G_debug (2, "driver %d : %s", i, OGR_Dr_GetName ( Ogr_driver) );
-        /* chg white space to underscore in OGR driver names */
-	sprintf (buf, "%s", OGR_Dr_GetName ( Ogr_driver) );
-	G_strchg(buf,' ','_');
-	if ( strcmp ( buf ,  frmt_opt->answer ) == 0 ) {
+    for (i = 0; i < OGRGetDriverCount(); i++) {
+	Ogr_driver = OGRGetDriver(i);
+	G_debug(2, "driver %d : %s", i, OGR_Dr_GetName(Ogr_driver));
+	/* chg white space to underscore in OGR driver names */
+	sprintf(buf, "%s", OGR_Dr_GetName(Ogr_driver));
+	G_strchg(buf, ' ', '_');
+	if (strcmp(buf, frmt_opt->answer) == 0) {
 	    drn = i;
-	    G_debug (2, " -> driver = %d", drn);
+	    G_debug(2, " -> driver = %d", drn);
-    if ( drn == -1 ) G_fatal_error ( _("Driver %s not found"), frmt_opt->answer );
-    Ogr_driver = OGRGetDriver( drn );
+    if (drn == -1)
+	G_fatal_error(_("Driver %s not found"), frmt_opt->answer);
+    Ogr_driver = OGRGetDriver(drn);
     /* parse dataset creation options */
     i = 0;
@@ -242,9 +257,10 @@
     papszDSCO = dsco->answers;
-    Ogr_ds = OGR_Dr_CreateDataSource( Ogr_driver, dsn_opt->answer, papszDSCO );
-    CSLDestroy( papszDSCO );
-    if ( Ogr_ds == NULL ) G_fatal_error (_("Cannot open OGR data source '%s'"), dsn_opt->answer);
+    Ogr_ds = OGR_Dr_CreateDataSource(Ogr_driver, dsn_opt->answer, papszDSCO);
+    CSLDestroy(papszDSCO);
+    if (Ogr_ds == NULL)
+	G_fatal_error(_("Cannot open OGR data source '%s'"), dsn_opt->answer);
     /* parse layer creation options */
     i = 0;
@@ -256,398 +272,450 @@
 	i++;
-    Ogr_layer = OGR_DS_CreateLayer( Ogr_ds, layer_opt->answer, Ogr_projection, wkbtype, papszLCO );
-    CSLDestroy( papszLCO );
-    if ( Ogr_layer == NULL ) G_fatal_error (_("Cannot create layer"));
+    Ogr_layer =
+	OGR_DS_CreateLayer(Ogr_ds, layer_opt->answer, Ogr_projection, wkbtype,
+			   papszLCO);
+    CSLDestroy(papszLCO);
+    if (Ogr_layer == NULL)
+	G_fatal_error(_("Cannot create layer"));
     db_init_string(&dbstring);
     /* Vector attributes -> OGR fields */
-    if ( field > 0 ) {
-	 doatt = 1; /* do attributes */
-	 Fi = Vect_get_field( &In, field);
-	 if ( Fi == NULL ) {
-	     G_warning (_("No attribute table found -> using only category numbers as attributes"));
-	     Ogr_field = OGR_Fld_Create( "cat", OFTInteger );
-	     OGR_L_CreateField( Ogr_layer, Ogr_field, 0 );
-	     doatt = 0;
-	 } else {
-	     Driver = db_start_driver(Fi->driver);
-	     if (Driver == NULL) G_fatal_error(_("Unable to start driver <%s>"), Fi->driver);
+    if (field > 0) {
+	doatt = 1;		/* do attributes */
+	Fi = Vect_get_field(&In, field);
+	if (Fi == NULL) {
+	    G_warning(_("No attribute table found -> using only category numbers as attributes"));
-	     db_init_handle (&handle);
-	     db_set_handle (&handle, Fi->database, NULL);
-	     if (db_open_database(Driver, &handle) != DB_OK)
-		 G_fatal_error(_("Unable to open database <%s> by driver <%s>"), Fi->database, Fi->driver);
+	    Ogr_field = OGR_Fld_Create("cat", OFTInteger);
+	    OGR_L_CreateField(Ogr_layer, Ogr_field, 0);
-	     db_set_string(&dbstring, Fi->table);
-	     if(db_describe_table (Driver, &dbstring, &Table) != DB_OK)
-		 G_fatal_error(_("Unable to describe table <%s>"), Fi->table);
+	    doatt = 0;
+	else {
+	    Driver = db_start_driver(Fi->driver);
+	    if (Driver == NULL)
+		G_fatal_error(_("Unable to start driver <%s>"), Fi->driver);
-	     ncol = db_get_table_number_of_columns(Table);
-	     G_debug (2, "ncol = %d", ncol );
-	     keycol = -1;
-	     for (i = 0; i < ncol; i++) {
-		 Column = db_get_table_column (Table, i);
-		 colsqltype = db_get_column_sqltype(Column);
-		 G_debug (2, "col %d: %s (%s)", i, db_get_column_name(Column),
-			   db_sqltype_name(colsqltype) );
-		 colctype = db_sqltype_to_Ctype ( colsqltype );
+	    db_init_handle(&handle);
+	    db_set_handle(&handle, Fi->database, NULL);
+	    if (db_open_database(Driver, &handle) != DB_OK)
+		G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+			      Fi->database, Fi->driver);
-		 switch ( colctype ) {
-		     case DB_C_TYPE_INT:
-			ogr_ftype = OFTInteger;
-			break;
-		     case DB_C_TYPE_DOUBLE:
-			ogr_ftype = OFTReal;
-			break;
-		     case DB_C_TYPE_STRING:
-			ogr_ftype = OFTString;
-			break;
-		     case DB_C_TYPE_DATETIME:
-			break;
-		 G_debug (2, "ogr_ftype = %d", ogr_ftype );
+	    db_set_string(&dbstring, Fi->table);
+	    if (db_describe_table(Driver, &dbstring, &Table) != DB_OK)
+		G_fatal_error(_("Unable to describe table <%s>"), Fi->table);
-		 strcpy ( key1, Fi->key ); G_tolcase ( key1 );
-		 strcpy ( key2, db_get_column_name(Column) ); G_tolcase ( key2 );
-		 if ( strcmp(key1, key2) == 0 ) keycol = i;
-		 G_debug (2, "%s x %s -> %s x %s -> keycol = %d", Fi->key,
-			 db_get_column_name(Column), key1, key2, keycol );
-		 Ogr_field = OGR_Fld_Create( db_get_column_name(Column), ogr_ftype );
-	     if ( keycol == -1 ) G_fatal_error (_("Key column '%s' not found"), Fi->key );
+	    ncol = db_get_table_number_of_columns(Table);
+	    G_debug(2, "ncol = %d", ncol);
+	    keycol = -1;
+	    for (i = 0; i < ncol; i++) {
+		Column = db_get_table_column(Table, i);
+		colsqltype = db_get_column_sqltype(Column);
+		G_debug(2, "col %d: %s (%s)", i, db_get_column_name(Column),
+			db_sqltype_name(colsqltype));
+		colctype = db_sqltype_to_Ctype(colsqltype);
+		switch (colctype) {
+		case DB_C_TYPE_INT:
+		    ogr_ftype = OFTInteger;
+		    break;
+		case DB_C_TYPE_DOUBLE:
+		    ogr_ftype = OFTReal;
+		    break;
+		case DB_C_TYPE_STRING:
+		    ogr_ftype = OFTString;
+		    break;
+		case DB_C_TYPE_DATETIME:
+		    break;
+		G_debug(2, "ogr_ftype = %d", ogr_ftype);
+		strcpy(key1, Fi->key);
+		G_tolcase(key1);
+		strcpy(key2, db_get_column_name(Column));
+		G_tolcase(key2);
+		if (strcmp(key1, key2) == 0)
+		    keycol = i;
+		G_debug(2, "%s x %s -> %s x %s -> keycol = %d", Fi->key,
+			db_get_column_name(Column), key1, key2, keycol);
+		Ogr_field =
+		    OGR_Fld_Create(db_get_column_name(Column), ogr_ftype);
+	    if (keycol == -1)
+		G_fatal_error(_("Key column '%s' not found"), Fi->key);
-    Ogr_featuredefn = OGR_L_GetLayerDefn( Ogr_layer );
-    Ogr_feature = OGR_F_Create( Ogr_featuredefn );
+    Ogr_featuredefn = OGR_L_GetLayerDefn(Ogr_layer);
+    Ogr_feature = OGR_F_Create(Ogr_featuredefn);
     fout = fskip = nocat = noatt = nocatskip = 0;
     /* check what users wants to export and what's present in the map */
-    if ( Vect_get_num_primitives(&In, GV_POINT) > 0 && !(otype & GV_POINTS) )
-      G_warning(_("%d Point(s) found, but not requested to be exported. Verify 'type' parameter."),Vect_get_num_primitives(&In, GV_POINT));
+    if (Vect_get_num_primitives(&In, GV_POINT) > 0 && !(otype & GV_POINTS))
+	G_warning(_("%d Point(s) found, but not requested to be exported. Verify 'type' parameter."),
+		  Vect_get_num_primitives(&In, GV_POINT));
-    if ( Vect_get_num_primitives(&In, GV_LINE) > 0 && !(otype & GV_LINES) )
-      G_warning(_("%d Line(s) found, but not requested to be exported. Verify 'type' parameter."),Vect_get_num_primitives(&In, GV_LINE));
+    if (Vect_get_num_primitives(&In, GV_LINE) > 0 && !(otype & GV_LINES))
+	G_warning(_("%d Line(s) found, but not requested to be exported. Verify 'type' parameter."),
+		  Vect_get_num_primitives(&In, GV_LINE));
-    if ( Vect_get_num_primitives(&In, GV_BOUNDARY) > 0 && !(otype & GV_BOUNDARY) && !(otype & GV_AREA) )
-      G_warning(_("%d Boundary(ies) found, but not requested to be exported. Verify 'type' parameter."),Vect_get_num_primitives(&In, GV_BOUNDARY));
+    if (Vect_get_num_primitives(&In, GV_BOUNDARY) > 0 &&
+	!(otype & GV_BOUNDARY) && !(otype & GV_AREA))
+	G_warning(_("%d Boundary(ies) found, but not requested to be exported. Verify 'type' parameter."),
+		  Vect_get_num_primitives(&In, GV_BOUNDARY));
-    if ( Vect_get_num_primitives(&In, GV_CENTROID) > 0 && !(otype & GV_CENTROID) && !(otype & GV_AREA) )
-      G_warning(_("%d Centroid(s) found, but not requested to be exported. Verify 'type' parameter."),Vect_get_num_primitives(&In, GV_CENTROID));
+    if (Vect_get_num_primitives(&In, GV_CENTROID) > 0 &&
+	!(otype & GV_CENTROID) && !(otype & GV_AREA))
+	G_warning(_("%d Centroid(s) found, but not requested to be exported. Verify 'type' parameter."),
+		  Vect_get_num_primitives(&In, GV_CENTROID));
-    if ( Vect_get_num_primitives(&In, GV_AREA) > 0  && !(otype & GV_AREA) )
-       G_warning(_("%d Areas found, but not requested to be exported. Verify 'type' parameter."),Vect_get_num_primitives(&In, GV_AREA));
+    if (Vect_get_num_primitives(&In, GV_AREA) > 0 && !(otype & GV_AREA))
+	G_warning(_("%d Areas found, but not requested to be exported. Verify 'type' parameter."),
+		  Vect_get_num_primitives(&In, GV_AREA));
-    if ( Vect_get_num_primitives(&In, GV_FACE) > 0  && !(otype & GV_FACE) )
-       G_warning(_("%d Faces found, but not requested to be exported. Verify 'type' parameter."),Vect_get_num_primitives(&In, GV_FACE));
+    if (Vect_get_num_primitives(&In, GV_FACE) > 0 && !(otype & GV_FACE))
+	G_warning(_("%d Faces found, but not requested to be exported. Verify 'type' parameter."),
+		  Vect_get_num_primitives(&In, GV_FACE));
     /* add? GV_KERNEL */
     /* Lines (run always to count features of different type) */
-    if ( (otype & GV_POINTS) || (otype & GV_LINES) ) {
-	G_message(_("Exporting %i points/lines..."), Vect_get_num_lines(&In) );
-	for ( i = 1; i <= Vect_get_num_lines(&In) ; i++ ) {
+    if ((otype & GV_POINTS) || (otype & GV_LINES)) {
+	G_message(_("Exporting %i points/lines..."), Vect_get_num_lines(&In));
+	for (i = 1; i <= Vect_get_num_lines(&In); i++) {
-	    G_percent(i,Vect_get_num_lines(&In),1);
+	    G_percent(i, Vect_get_num_lines(&In), 1);
-	    type = Vect_read_line (&In, Points, Cats, i);
-	    G_debug (2, "line = %d type = %d", i, type );
-	    if ( !(otype & type ) ) {
-		 G_debug (2, "type %d not specified -> skip", type );
-		 fskip++;
-		 continue;
+	    type = Vect_read_line(&In, Points, Cats, i);
+	    G_debug(2, "line = %d type = %d", i, type);
+	    if (!(otype & type)) {
+		G_debug(2, "type %d not specified -> skip", type);
+		fskip++;
+		continue;
-	    Vect_cat_get (Cats, field, &cat);
-	    if ( cat < 0 && !donocat ) { /* Do not export not labeled */
+	    Vect_cat_get(Cats, field, &cat);
+	    if (cat < 0 && !donocat) {	/* Do not export not labeled */
 		nocatskip++;
-		continue;
+		continue;
 	    /* Geometry */
-            if ( type == GV_LINE && poly_flag->answer )
-                OGRGeometryH    ring;
+	    if (type == GV_LINE && poly_flag->answer) {
+		OGRGeometryH ring;
-                ring = OGR_G_CreateGeometry( wkbLinearRing );
-                Ogr_geometry = OGR_G_CreateGeometry( wkbPolygon );
+		ring = OGR_G_CreateGeometry(wkbLinearRing);
+		Ogr_geometry = OGR_G_CreateGeometry(wkbPolygon);
-                /* Area */
-                for ( j = 0; j < Points->n_points; j++ ) {
-                    OGR_G_AddPoint( ring, Points->x[j], Points->y[j], Points->z[j] );
-                if ( Points->x[Points->n_points-1] != Points->x[0] ||
-                     Points->y[Points->n_points-1] != Points->y[0] ||
-                     Points->z[Points->n_points-1] != Points->z[0] )
-                    OGR_G_AddPoint( ring, Points->x[0], Points->y[0], Points->z[0] );
-                OGR_G_AddGeometryDirectly ( Ogr_geometry, ring );
-            else if ( type == GV_POINT )
-                Ogr_geometry = OGR_G_CreateGeometry( wkbPoint );
-                OGR_G_AddPoint( Ogr_geometry, Points->x[0], Points->y[0], Points->z[0] );
-            else  /* GV_LINE or GV_BOUNDARY */
-                Ogr_geometry = OGR_G_CreateGeometry( wkbLineString );
-                    OGR_G_AddPoint( Ogr_geometry, Points->x[j], Points->y[j], Points->z[j] );
-	    OGR_F_SetGeometry( Ogr_feature, Ogr_geometry );
+		/* Area */
+		for (j = 0; j < Points->n_points; j++) {
+		    OGR_G_AddPoint(ring, Points->x[j], Points->y[j],
+				   Points->z[j]);
+		if (Points->x[Points->n_points - 1] != Points->x[0] ||
+		    Points->y[Points->n_points - 1] != Points->y[0] ||
+		    Points->z[Points->n_points - 1] != Points->z[0]) {
+		    OGR_G_AddPoint(ring, Points->x[0], Points->y[0],
+				   Points->z[0]);
+		OGR_G_AddGeometryDirectly(Ogr_geometry, ring);
+	    else if (type == GV_POINT) {
+		Ogr_geometry = OGR_G_CreateGeometry(wkbPoint);
+		OGR_G_AddPoint(Ogr_geometry, Points->x[0], Points->y[0],
+			       Points->z[0]);
+	    else {		/* GV_LINE or GV_BOUNDARY */
+		Ogr_geometry = OGR_G_CreateGeometry(wkbLineString);
+		    OGR_G_AddPoint(Ogr_geometry, Points->x[j], Points->y[j],
+				   Points->z[j]);
+	    OGR_F_SetGeometry(Ogr_feature, Ogr_geometry);
 	    /* Output one feature for each category */
-	    for ( j = -1; j < Cats->n_cats; j++ ) {
-		if ( j == -1 ) {
-		    if ( cat >= 0 ) continue; /* cat(s) exists */
-		} else {
-		    if ( Cats->field[j] == field )
+	    for (j = -1; j < Cats->n_cats; j++) {
+		if (j == -1) {
+		    if (cat >= 0)
+			continue;	/* cat(s) exists */
+		else {
+		    if (Cats->field[j] == field)
 			cat = Cats->cat[j];
-		    else
+		    else
 			continue;
-		mk_att ( cat, Fi, Driver, ncol, keycol, doatt, Ogr_feature);
-	        OGR_L_CreateFeature( Ogr_layer, Ogr_feature );
+		mk_att(cat, Fi, Driver, ncol, keycol, doatt, Ogr_feature);
+		OGR_L_CreateFeature(Ogr_layer, Ogr_feature);
-	    OGR_G_DestroyGeometry( Ogr_geometry );
+	    OGR_G_DestroyGeometry(Ogr_geometry);
     /* Areas (run always to count features of different type) */
-    if ( otype & GV_AREA ) {
-	G_message(_("Exporting %i areas (may take some time) ..."), Vect_get_num_areas(&In) );
-	for ( i = 1; i <= Vect_get_num_areas(&In) ; i++ ) {
-	    G_percent(i,Vect_get_num_areas(&In),1);
-	    centroid = Vect_get_area_centroid ( &In, i );
+    if (otype & GV_AREA) {
+	G_message(_("Exporting %i areas (may take some time) ..."),
+		  Vect_get_num_areas(&In));
+	for (i = 1; i <= Vect_get_num_areas(&In); i++) {
+	    G_percent(i, Vect_get_num_areas(&In), 1);
+	    centroid = Vect_get_area_centroid(&In, i);
 	    cat = -1;
-	    if ( centroid > 0 ) {
-		Vect_read_line (&In, NULL, Cats, centroid );
+	    if (centroid > 0) {
+		Vect_read_line(&In, NULL, Cats, centroid);
-	    G_debug (3, "area = %d centroid = %d ncats = %d", i, centroid, Cats->n_cats );
+	    G_debug(3, "area = %d centroid = %d ncats = %d", i, centroid,
+		    Cats->n_cats);
 		nocatskip++;
-		continue;
+		continue;
-	    Vect_get_area_points ( &In, i, Points );
+	    Vect_get_area_points(&In, i, Points);
 	    /* Geometry */
 	    /* Area */
+			       Points->z[j]);
 	    /* Isles */
-	    for ( k = 0; k < Vect_get_area_num_isles (&In, i); k++ ) {
-		Vect_get_isle_points ( &In, Vect_get_area_isle (&In, i, k), Points );
+	    for (k = 0; k < Vect_get_area_num_isles(&In, i); k++) {
+		Vect_get_isle_points(&In, Vect_get_area_isle(&In, i, k),
+				     Points);
+				   Points->z[j]);
-		if ( j == -1 ) {
-		} else {
+		if (j == -1) {
+		    if (cat >= 0)
+		else {
 			cat = Cats->cat[j];
-		    else
+		    else
 			continue;
     /* Faces (run always to count features of different type)  - Faces are similar to lines */
-    if ( otype & GV_FACE ) {
-	G_message(_("Exporting %i faces (may take some time) ..."), Vect_get_num_faces(&In) );
-	for ( i = 1; i <= Vect_get_num_faces(&In) ; i++ ) {
-	    G_percent(i,Vect_get_num_faces(&In),1);
+    if (otype & GV_FACE) {
+	G_message(_("Exporting %i faces (may take some time) ..."),
+		  Vect_get_num_faces(&In));
+	for (i = 1; i <= Vect_get_num_faces(&In); i++) {
+	    G_percent(i, Vect_get_num_faces(&In), 1);
 	    G_debug(3, "line type = %d", type);
 	    cat = -1;
-	    G_debug (3, "face = %d ncats = %d", i, Cats->n_cats );
+	    G_debug(3, "face = %d ncats = %d", i, Cats->n_cats);
 		nocatskip++;
-		continue;
+		continue;
-	    if ( type & GV_FACE ) {
+	    if (type & GV_FACE) {
 		/* Geometry */
-		Ogr_geometry = OGR_G_CreateGeometry( wkbPolygon25D );
+		Ogr_geometry = OGR_G_CreateGeometry(wkbPolygon25D);
 		/* Face */
+				   Points->z[j]);
-		  if ( j == -1 ) {
-		  } else {
-			cat = Cats->cat[j];
-		    else
-			continue;
+		    if (j == -1) {
+			if (cat >= 0)
+		    else {
+			    cat = Cats->cat[j];
+			else
+			    continue;
-            } /* if type & GV_FACE */
+	    }			/* if type & GV_FACE */
-	} /* for */
+	}			/* for */
-    OGR_F_Destroy( Ogr_feature );
-    OGR_DS_Destroy( Ogr_ds );
-    Vect_close (&In);
-    if ( doatt ) {
+    OGR_F_Destroy(Ogr_feature);
+    OGR_DS_Destroy(Ogr_ds);
+    Vect_close(&In);
+    if (doatt) {
 	db_close_database(Driver);
 	db_shutdown_driver(Driver);
     /* Summary */
     G_message(_("%d features written"), fout);
-    if ( nocat > 0 ) G_warning ( "%d features without category written", nocat);
-    if ( noatt > 0 ) G_warning ( "%d features without attributes written", noatt);
-    if ( nocatskip > 0 ) G_warning ( "%d features found without category skip", nocatskip);
+    if (nocat > 0)
+	G_warning("%d features without category written", nocat);
+    if (noatt > 0)
+	G_warning("%d features without attributes written", noatt);
+    if (nocatskip > 0)
+	G_warning("%d features found without category skip", nocatskip);
     /* Enable this? May be confusing that for area type are not reported all boundaries/centroids.
-    *  OTOH why should be reported? */
+     *  OTOH why should be reported? */
-    if ( ((otype & GV_POINTS) || (otype & GV_LINES)) && fskip > 0 )
-	G_warning ( "%d features of different type skip", fskip);
-    exit(EXIT_SUCCESS) ;
+       if ( ((otype & GV_POINTS) || (otype & GV_LINES)) && fskip > 0 )
+       G_warning ( "%d features of different type skip", fskip);
+    exit(EXIT_SUCCESS);
 int
-mk_att ( int cat, struct field_info *Fi, dbDriver *Driver, int ncol, int keycol, int doatt,
+mk_att(int cat, struct field_info *Fi, dbDriver * Driver, int ncol,
-    int      j;
-    char     buf[2000];
-    int      colsqltype, colctype, more;
-    dbTable  *Table;
+    int j;
+    char buf[2000];
+    int colsqltype, colctype, more;
+    dbTable *Table;
     dbString dbstring;
     dbColumn *Column;
     dbCursor cursor;
-    dbValue  *Value;
+    dbValue *Value;
-    G_debug (2, "mk_att() cat = %d, doatt = %d", cat, doatt );
+    G_debug(2, "mk_att() cat = %d, doatt = %d", cat, doatt);
     /* Attributes */
     /* Reset */
-    if ( doatt ) {
-	for (j = 0; j < ncol; j++) OGR_F_UnsetField(Ogr_feature, j);
-    } else {
+    if (doatt) {
+	for (j = 0; j < ncol; j++)
+	    OGR_F_UnsetField(Ogr_feature, j);
+    else {
 	OGR_F_UnsetField(Ogr_feature, 0);
     /* Read & set attributes */
-    if( cat >= 0 ) { /* Line with category */
-	if ( doatt ) {
-	    sprintf ( buf, "SELECT * FROM %s WHERE %s = %d", Fi->table,  Fi->key, cat);
-	    G_debug (2, "SQL: %s", buf);
+    if (cat >= 0) {		/* Line with category */
+	if (doatt) {
+	    sprintf(buf, "SELECT * FROM %s WHERE %s = %d", Fi->table, Fi->key,
+		    cat);
+	    G_debug(2, "SQL: %s", buf);
 	    db_set_string(&dbstring, buf);
-	    if ( db_open_select_cursor(Driver, &dbstring, &cursor, DB_SEQUENTIAL) != DB_OK ) {
-		G_fatal_error ( _("Cannot select attributes for cat = %d"), cat);
-	    } else {
-		if(db_fetch (&cursor, DB_NEXT, &more) != DB_OK) G_fatal_error (_("Unable to fetch data from table"));
+	    if (db_open_select_cursor
+		(Driver, &dbstring, &cursor, DB_SEQUENTIAL) != DB_OK) {
+		G_fatal_error(_("Cannot select attributes for cat = %d"),
+			      cat);
+	    else {
+		if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK)
+		    G_fatal_error(_("Unable to fetch data from table"));
 		if (!more) {
 		    /* G_warning ("No database record for cat = %d", cat); */
 		    /* Set at least key column to category */
-		    OGR_F_SetFieldInteger ( Ogr_feature, keycol, cat );
+		    OGR_F_SetFieldInteger(Ogr_feature, keycol, cat);
 		    noatt++;
-		} else {
-		    Table = db_get_cursor_table (&cursor);
-		    for (j = 0; j < ncol; j++) {
-			Column = db_get_table_column (Table, j);
-			Value  = db_get_column_value(Column);
-			db_convert_column_value_to_string (Column, &dbstring); /* for debug only */
-			G_debug (2, "col %d : val = %s", j, db_get_string (&dbstring) );
+		else {
+		    Table = db_get_cursor_table(&cursor);
+		    for (j = 0; j < ncol; j++) {
+			Column = db_get_table_column(Table, j);
+			Value = db_get_column_value(Column);
+			db_convert_column_value_to_string(Column, &dbstring);	/* for debug only */
+			G_debug(2, "col %d : val = %s", j,
+				db_get_string(&dbstring));
-			G_debug (2, "  colctype = %d", colctype );
-				OGR_F_SetFieldInteger( Ogr_feature, j, db_get_value_int(Value) );
-				break;
-				OGR_F_SetFieldDouble( Ogr_feature, j, db_get_value_double(Value) );
-				break;
-				OGR_F_SetFieldString( Ogr_feature, j, db_get_value_string(Value) );
-				break;
-				OGR_F_SetFieldString( Ogr_feature, j, db_get_string (&dbstring) );
-				break;
+			G_debug(2, "  colctype = %d", colctype);
+			    OGR_F_SetFieldInteger(Ogr_feature, j,
+						  db_get_value_int(Value));
+			    break;
+			    OGR_F_SetFieldDouble(Ogr_feature, j,
+						 db_get_value_double(Value));
+			    break;
+			    OGR_F_SetFieldString(Ogr_feature, j,
+						 db_get_value_string(Value));
+			    break;
+							      &dbstring);
+			    break;
-	} else { /* Use cat only */
-	    OGR_F_SetFieldInteger( Ogr_feature, 0, cat );
-    } else {
+	else {			/* Use cat only */
+	    OGR_F_SetFieldInteger(Ogr_feature, 0, cat);
+    else {
 	/* G_warning ( "Line without cat of layer %d", field); */
 	nocat++;
@@ -657,31 +725,30 @@
 /* to print available drivers in help text */
-char *
-OGR_list_write_drivers(void)
+char *OGR_list_write_drivers(void)
     int drn, i;
     char buf[2000];
     /* Open OGR DSN */
     OGRRegisterAll();
     drn = -1;
-        /* only fetch read/write drivers */
-	if (OGR_Dr_TestCapability( OGRGetDriver(i),ODrCCreateDataSource) )
-	  G_debug (2, "driver %d/%d : %s", i, OGRGetDriverCount(), OGR_Dr_GetName ( Ogr_driver) );
-	  strcat (OGRdrivers, buf);
-	  if (i < OGRGetDriverCount() - 1 )
-	     strcat (OGRdrivers, ",");
+	/* only fetch read/write drivers */
+	if (OGR_Dr_TestCapability(OGRGetDriver(i), ODrCCreateDataSource)) {
+	    G_debug(2, "driver %d/%d : %s", i, OGRGetDriverCount(),
+		    OGR_Dr_GetName(Ogr_driver));
+	    strcat(OGRdrivers, buf);
+	    if (i < OGRGetDriverCount() - 1)
+		strcat(OGRdrivers, ",");
-    G_debug (2, "all drivers: %s",OGRdrivers);
+    G_debug(2, "all drivers: %s", OGRdrivers);
     return OGRdrivers;
