[GRASS-SVN] r33902 -
grass/branches/develbranch_6/imagery/i.ortho.photo/photo.elev
svn_grass at osgeo.org
Thu Oct 16 06:05:43 EDT 2008
Author: hamish
Date: 2008-10-16 06:05:43 -0400 (Thu, 16 Oct 2008)
New Revision: 33902
grass/branches/develbranch_6/imagery/i.ortho.photo/photo.elev/main.c
update to use G_parser and modern ways
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/photo.elev/main.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/photo.elev/main.c 2008-10-16 09:40:30 UTC (rev 33901)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/photo.elev/main.c 2008-10-16 10:05:43 UTC (rev 33902)
@@ -15,7 +15,6 @@
* for details.
-/* main.c */
/* read the target for the block and cast it into the alternate GRASS env */
#define MAIN
@@ -23,7 +22,9 @@
#include <stdio.h>
#include <unistd.h>
#include <string.h>
+#include <grass/gis.h>
#include <grass/imagery.h>
+#include <grass/glocale.h>
#include "orthophoto.h"
#include "elev.h"
@@ -38,55 +39,68 @@
int main(int argc, char *argv[])
- char *group, *location, *mapset, buf[100];
+ struct GModule *module;
+ struct Option *group_opt;
+ char location[GMAPSET_MAX];
+ char mapset[GMAPSET_MAX];
+ char group[GNAME_MAX];
+ char buf[100];
int stat;
- location = (char *)G_malloc(80 * sizeof(char));
- mapset = (char *)G_malloc(80 * sizeof(char));
- elev_layer = (char *)G_malloc(80 * sizeof(char));
- mapset_elev = (char *)G_malloc(80 * sizeof(char));
+ /* must run in a term window */
+ G_putenv("GRASS_UI_TERM", "1");
+ G_gisinit(argv[0]);
+ module = G_define_module();
+ module->keywords = _("imagery, orthorectify");
+ module->description =
+ _("Interactively select or modify the target elevation model.");
+ group_opt = G_define_standard_option(G_OPT_I_GROUP);
+ group_opt->description =
+ _("Name of imagery group for ortho-rectification");
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ elev_layer = (char *)G_malloc(GNAME_MAX * sizeof(char));
+ mapset_elev = (char *)G_malloc(GMAPSET_MAX * sizeof(char));
tl = (char *)G_malloc(80 * sizeof(char));
math_exp = (char *)G_malloc(80 * sizeof(char));
units = (char *)G_malloc(80 * sizeof(char));
nd = (char *)G_malloc(80 * sizeof(char));
- group = (char *)G_malloc(80 * sizeof(char));
- *location = 0;
- *mapset = 0;
*elev_layer = 0;
*mapset_elev = 0;
*tl = 0;
*math_exp = 0;
*units = 0;
*nd = 0;
- *group = 0;
- if (argc != 2) {
- fprintf(stderr, "Usage: %s group\n", argv[0]);
- exit(1);
+ strcpy(group, group_opt->answer);
- G_gisinit(argv[0]);
- strcpy(group, argv[1]);
G_suppress_warnings(1);
if (!I_get_target(group, location, mapset)) {
- sprintf(buf, "Target information for group [%s] missing\n", group);
+ sprintf(buf, _("Target information for group [%s] missing\n"), group);
goto error;
G_suppress_warnings(0);
sprintf(buf, "%s/%s", G_gisdbase(), location);
if (access(buf, 0) != 0) {
- sprintf(buf, "Target location [%s] not found\n", location);
+ sprintf(buf, _("Target location [%s] not found\n"), location);
goto error;
I_get_group_elev(group, elev_layer, mapset_elev, tl, math_exp, units, nd);
G__create_alt_env();
G__setenv("LOCATION_NAME", location);
stat = G__mapset_permissions(mapset);
if (stat > 0) {
G__setenv("MAPSET", mapset);
@@ -101,20 +115,24 @@
/* select current location */
select_current_env();
- I_put_group_elev(group, elev_layer, mapset_elev, tl, math_exp, units,
- nd);
- return 0;
+ I_put_group_elev(group, elev_layer, mapset_elev, tl,
+ math_exp, units, nd);
+ exit(EXIT_SUCCESS);
- sprintf(buf, "Mapset [%s] in target location [%s] - ", mapset, location);
- strcat(buf, stat == 0 ? "permission denied\n" : "not found\n");
+ sprintf(buf, _("Mapset [%s] in target location [%s] - "), mapset, location);
+ strcat(buf, stat == 0 ? _("permission denied\n") : _("not found\n"));
error:
- strcat(buf, "Please select a target for group");
+ strcat(buf, _("Please select a target for group"));
strcat(buf, group);
G_fatal_error(buf);
int select_current_env(void)
if (which_env != 0) {
