[GRASS-SVN] r33903 - in grass/branches/develbranch_6: include
lib/gis raster/r.colors
svn_grass at osgeo.org
Thu Oct 16 06:08:44 EDT 2008
Author: neteler
Date: 2008-10-16 06:08:44 -0400 (Thu, 16 Oct 2008)
New Revision: 33903
grass/branches/develbranch_6/include/gis.h
grass/branches/develbranch_6/include/gisdefs.h
grass/branches/develbranch_6/lib/gis/color_xform.c
grass/branches/develbranch_6/raster/r.colors/local_proto.h
grass/branches/develbranch_6/raster/r.colors/main.c
grass/branches/develbranch_6/raster/r.colors/stats.c
glynn: Add struct FP_stats;
Add G_histogram_eq_colors_fp;
Change r.colors to use G_histogram_eq_colors_fp() for FP maps (merge from trunk, r33889)
Modified: grass/branches/develbranch_6/include/gis.h
--- grass/branches/develbranch_6/include/gis.h 2008-10-16 10:05:43 UTC (rev 33902)
+++ grass/branches/develbranch_6/include/gis.h 2008-10-16 10:08:44 UTC (rev 33903)
@@ -529,6 +529,15 @@
int first_time; /* whether or not range was updated */
+struct FP_stats {
+ int geometric;
+ int flip;
+ int count;
+ DCELL min, max;
+ unsigned long *stats;
+ unsigned long total;
** Structure for I/O of 3dview files (view.c)
Modified: grass/branches/develbranch_6/include/gisdefs.h
--- grass/branches/develbranch_6/include/gisdefs.h 2008-10-16 10:05:43 UTC (rev 33902)
+++ grass/branches/develbranch_6/include/gisdefs.h 2008-10-16 10:08:44 UTC (rev 33903)
@@ -381,6 +381,8 @@
/* color_xform.c */
int G_histogram_eq_colors(struct Colors *, struct Colors *,
struct Cell_stats *);
+void G_histogram_eq_colors_fp(struct Colors *,
+ struct Colors *, struct FP_stats *);
int G_log_colors(struct Colors *, struct Colors *, int);
/* commas.c */
Modified: grass/branches/develbranch_6/lib/gis/color_xform.c
--- grass/branches/develbranch_6/lib/gis/color_xform.c 2008-10-16 10:05:43 UTC (rev 33902)
+++ grass/branches/develbranch_6/lib/gis/color_xform.c 2008-10-16 10:08:44 UTC (rev 33903)
@@ -89,8 +89,6 @@
prev = 0;
first = 1;
- G_get_d_raster_color(&min, &red, &grn, &blu, src);
G_rewind_cell_stats(statf);
while (G_next_cell_stat(&cat, &count, statf)) {
int red2, grn2, blu2;
@@ -118,6 +116,75 @@
+ * \brief make histogram-stretched version of existing color table (FP version)
+ * Generates a histogram
+ * contrast-stretched color table that goes from the histogram
+ * information in the FP_stats structure <b>statf.</b> (See
+ * Raster_Histograms).
+ * \param dst
+ * \param src
+ * \param statf
+ * \return void
+void G_histogram_eq_colors_fp(struct Colors *dst,
+ struct Colors *src, struct FP_stats *statf)
+ DCELL min, max;
+ int red, grn, blu;
+ unsigned long sum;
+ DCELL val;
+ int first;
+ int i;
+ G_init_colors(dst);
+ G_get_d_color_range(&min, &max, src);
+ G_get_default_color(&red, &grn, &blu, src);
+ G_set_default_color(red, grn, blu, dst);
+ G_get_null_value_color(&red, &grn, &blu, src);
+ G_set_null_value_color(red, grn, blu, dst);
+ if (!statf->total)
+ return;
+ sum = 0;
+ first = 1;
+ for (i = 0; i <= statf->count; i++) {
+ int red2, grn2, blu2;
+ DCELL val2, x;
+ val2 = statf->min + (statf->max - statf->min) * i / statf->count;
+ if (statf->geometric)
+ val2 = exp(val2);
+ if (statf->flip)
+ val2 = -val2;
+ x = min + (max - min) * sum / statf->total;
+ G_get_d_raster_color(&x, &red2, &grn2, &blu2, src);
+ if (!first)
+ G_add_d_raster_color_rule(&val, red, grn, blu, &val2, red2, grn2, blu2, dst);
+ first = 0;
+ if (i == statf->count)
+ break;
+ sum += statf->stats[i];
+ val = val2;
+ red = red2;
+ grn = grn2;
+ blu = blu2;
* \brief make logarithmically-scaled version of an existing color table
* \param dst
Modified: grass/branches/develbranch_6/raster/r.colors/local_proto.h
--- grass/branches/develbranch_6/raster/r.colors/local_proto.h 2008-10-16 10:05:43 UTC (rev 33902)
+++ grass/branches/develbranch_6/raster/r.colors/local_proto.h 2008-10-16 10:08:44 UTC (rev 33903)
@@ -23,7 +23,10 @@
#include <grass/gis.h>
/* stats.c */
-int get_stats(char *, char *, struct Cell_stats *);
+int get_stats(const char *, const char *, struct Cell_stats *);
+void get_fp_stats(const char *name, const char *mapset,
+ struct FP_stats *statf,
+ DCELL min, DCELL max, int geometric);
/* main.c */
int main(int, char *[]);
Modified: grass/branches/develbranch_6/raster/r.colors/main.c
--- grass/branches/develbranch_6/raster/r.colors/main.c 2008-10-16 10:05:43 UTC (rev 33902)
+++ grass/branches/develbranch_6/raster/r.colors/main.c 2008-10-16 10:08:44 UTC (rev 33903)
@@ -372,9 +372,16 @@
G_invert_colors(&colors);
if (flag.e->answer) {
- if (!have_stats)
- have_stats = get_stats(name, mapset, &statf);
- G_histogram_eq_colors(&colors_tmp, &colors, &statf);
+ if (fp) {
+ struct FP_stats fpstats;
+ get_fp_stats(name, mapset, &fpstats, min, max, flag.g->answer);
+ G_histogram_eq_colors_fp(&colors_tmp, &colors, &fpstats);
+ else {
+ if (!have_stats)
+ have_stats = get_stats(name, mapset, &statf);
+ G_histogram_eq_colors(&colors_tmp, &colors, &statf);
colors = colors_tmp;
Modified: grass/branches/develbranch_6/raster/r.colors/stats.c
--- grass/branches/develbranch_6/raster/r.colors/stats.c 2008-10-16 10:05:43 UTC (rev 33902)
+++ grass/branches/develbranch_6/raster/r.colors/stats.c 2008-10-16 10:08:44 UTC (rev 33903)
@@ -17,11 +17,13 @@
+#include <math.h>
#include <stdlib.h>
#include <grass/glocale.h>
+#include "local_proto.h"
-int get_stats(char *name, char *mapset, struct Cell_stats *statf)
+int get_stats(const char *name, const char *mapset, struct Cell_stats *statf)
CELL *cell;
int row, nrows, ncols;
@@ -48,3 +50,72 @@
return 1;
+ DCELL *dcell;
+ int row, col, nrows, ncols;
+ int fd;
+ if ((fd = G_open_cell_old(name, mapset)) < 0)
+ G_fatal_error("error opening map <%s@%s>", name, mapset);
+ dcell = G_allocate_d_raster_buf();
+ nrows = G_window_rows();
+ ncols = G_window_cols();
+ statf->geometric = geometric;
+ statf->flip = 0;
+ if (statf->geometric) {
+ if (min * max < 0)
+ G_fatal_error(_("Cannot use logarithmic scaling if range includes zero"));
+ if (min < 0) {
+ statf->flip = 1;
+ min = -min;
+ max = -max;
+ min = log(min);
+ max = log(max);
+ statf->count = 1000;
+ statf->min = min;
+ statf->max = max;
+ statf->stats = G_calloc(statf->count, sizeof(unsigned long));
+ statf->total = 0;
+ G_message(_("Reading %s ..."), name);
+ for (row = 0; row < nrows; row++) {
+ G_percent(row, nrows, 2);
+ if (G_get_d_raster_row(fd, dcell, row) < 0)
+ G_fatal_error("error reading map <%s@%s>", name, mapset);
+ for (col = 0; col < ncols; col++) {
+ DCELL x;
+ int i;
+ if (G_is_d_null_value(&dcell[col]))
+ continue;
+ x = dcell[col];
+ if (statf->flip)
+ x = -x;
+ x = log(x);
+ i = (int) floor(statf->count * (x - statf->min) / (statf->max - statf->min));
+ statf->stats[i]++;
+ statf->total++;
+ G_close_cell(fd);
+ G_free(dcell);
