[GRASS-SVN] r33916 -
grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2target
svn_grass at osgeo.org
Thu Oct 16 09:19:19 EDT 2008
Author: hamish
Date: 2008-10-16 09:19:19 -0400 (Thu, 16 Oct 2008)
New Revision: 33916
grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2target/main.c
update to use G_parser, modern ways
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2target/main.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2target/main.c 2008-10-16 13:12:12 UTC (rev 33915)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2target/main.c 2008-10-16 13:19:19 UTC (rev 33916)
@@ -7,17 +7,18 @@
* Bernhard Reiter <bernhard intevation.de>,
* Glynn Clements <glynn gclements.plus.com>,
* Radim Blazek <radim.blazek gmail.com>
- * PURPOSE: allow user to mark control points on an image to be
- * ortho-rectified and then input the coordinates of each point
- * for calculation of rectification parameters
- * COPYRIGHT: (C) 1999-2007 by the GRASS Development Team
+ * Hamish Bowman
+ * PURPOSE: Allow user to mark control points on an image to be
+ * ortho-rectified and then input the coordinates of each point
+ * for calculation of rectification parameters
+ * COPYRIGHT: (C) 1999-2008 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
* for details.
-/* main.c */
#define GLOBAL
#include <unistd.h>
@@ -33,7 +34,10 @@
int main(int argc, char *argv[])
- char *name, *location, *mapset, *camera, msg[100];
+ char mapset[GMAPSET_MAX];
+ char name[GNAME_MAX];
+ char *camera;
struct GModule *module;
struct Option *group_opt, *map_opt, *target_map_opt;
struct Cell_head cellhd;
@@ -43,7 +47,7 @@
G_gisinit(argv[0]);
module = G_define_module();
- module->keywords = _("imagery");
+ module->keywords = _("imagery, orthorectify");
module->description = _("Creates control points on an image "
"to be ortho-rectified.");
@@ -66,13 +70,13 @@
" will be initially drawn on screen.");
if (G_parser(argc, argv))
- exit(1);
+ exit(EXIT_FAILURE);
G_suppress_masking(); /* need to do this for target location */
- name = (char *)G_malloc(40 * sizeof(char));
- location = (char *)G_malloc(80 * sizeof(char));
- mapset = (char *)G_malloc(80 * sizeof(char));
camera = (char *)G_malloc(40 * sizeof(char));
+ strcpy(name, group_opt->answer);
interrupt_char = G_intr_char();
tempfile1 = G_tempfile();
@@ -90,13 +94,10 @@
G_fatal_error(_("No graphics device selected"));
/* get group ref */
- strcpy(group.name, group_opt->answer);
- if (!I_find_group(group.name)) {
- fprintf(stderr, "Group [%s] not found\n", group.name);
- exit(1);
+ strcpy(group.name, name);
+ if (!I_find_group(group.name))
+ G_fatal_error(_("Group [%s] not found"), group.name);
/* get the group ref */
I_get_group_ref(group.name, &group.group_ref);
nfiles = group.group_ref.nfiles;
@@ -106,33 +107,24 @@
/** look for camera info for this group**/
G_suppress_warnings(1);
- if (!I_get_group_camera(group.name, camera)) {
- sprintf(msg, "No camera reference file selected for group [%s]\n",
+ if (!I_get_group_camera(group.name, camera))
+ G_fatal_error(_("No camera reference file selected for group [%s]"),
group.name);
- G_fatal_error(msg);
- if (!I_get_cam_info(camera, &group.camera_ref)) {
- sprintf(msg, "Bad format in camera file for group [%s]\n",
- group.name);
+ if (!I_get_cam_info(camera, &group.camera_ref))
+ G_fatal_error(_("Bad format in camera file for group [%s]"),
+ group.name);
G_suppress_warnings(0);
/* get initial camera exposure station, if any */
- if (!(ok = I_find_initial(group.name))) {
- sprintf(msg, "No initial camera exposure station for group[%s]\n",
+ if (!(ok = I_find_initial(group.name)))
+ G_warning(_("No initial camera exposure station for group [%s]"),
group.name);
- G_warning(msg);
- if (ok)
- if (!I_get_init_info(group.name, &group.camera_exp)) {
- sprintf(msg,
- "Bad format in initial camera exposure station for group [%s]\n",
- group.name);
- G_warning(msg);
+ if (ok && (!I_get_init_info(group.name, &group.camera_exp)) )
+ G_warning(_("Bad format in initial camera exposure station for group [%s]"),
+ group.name);
/* get target info and environment */
@@ -145,11 +137,10 @@
if (!I_get_ref_points(group.name, &group.photo_points)) {
if (group.photo_points.count == 0)
- sprintf(msg, "No photo points for group [%s].\n", group.name);
+ G_fatal_error(_("No photo points for group [%s]"), group.name);
else if (group.ref_equation_stat == 0)
- sprintf(msg, "Poorly placed photo points for group [%s].\n",
- group.name);
+ G_fatal_error(_("Poorly placed photo points for group [%s]"),
+ group.name);
@@ -170,7 +161,7 @@
/* determine transformation equation */
- fprintf(stderr, "Computing equations ...\n");
+ G_message(_("Computing equations ..."));
if (group.control_points.count > 0)
Compute_ortho_equation();
@@ -205,14 +196,14 @@
strcpy(name, map_opt->answer);
strcpy(mapset, ms);
if (G_get_cellhd(name, mapset, &cellhd) < 0) {
- G_fatal_error(_("Unable to read head of %s"), map_opt->answer);
+ G_fatal_error(_("Unable to read raster header of <%s>"), map_opt->answer);
else {
/* ask user for group file to be displayed */
do {
if (!choose_groupfile(name, mapset))
- quit(0);
+ quit(EXIT_SUCCESS);
/* display this file in "map1" */
} while (G_get_cellhd(name, mapset, &cellhd) < 0);
@@ -236,7 +227,7 @@
strcpy(name, target_map_opt->answer);
strcpy(mapset, ms);
@@ -266,7 +257,7 @@
/* go do the work */
driver();
- quit(0);
int quit(int n)
@@ -305,13 +296,13 @@
Curses_write_window(PROMPT_WINDOW, 2, 12, G_mapset());
Beep();
if (fatal)
- sprintf(buf, "ERROR: %s", msg);
+ sprintf(buf, _("ERROR: %s"), msg);
else
- sprintf(buf, "WARNING: %s (click mouse to continue)", msg);
+ sprintf(buf, _("WARNING: %s (click mouse to continue)"), msg);
Menu_msg(buf);
if (fatal)
- quit(1);
+ quit(EXIT_FAILURE);
Mouse_pointer(&x, &y, &button);
Curses_clear_window(PROMPT_WINDOW);
