[GRASS-SVN] r33917 -
grass/branches/develbranch_6/imagery/i.ortho.photo/photo.rectify
svn_grass at osgeo.org
Thu Oct 16 09:43:39 EDT 2008
Author: hamish
Date: 2008-10-16 09:43:39 -0400 (Thu, 16 Oct 2008)
New Revision: 33917
grass/branches/develbranch_6/imagery/i.ortho.photo/photo.rectify/ask_files.c
grass/branches/develbranch_6/imagery/i.ortho.photo/photo.rectify/main.c
update to use G_parser, modern ways
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/photo.rectify/ask_files.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/photo.rectify/ask_files.c 2008-10-16 13:19:19 UTC (rev 33916)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/photo.rectify/ask_files.c 2008-10-16 13:43:39 UTC (rev 33917)
@@ -1,6 +1,7 @@
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
+#include <grass/glocale.h>
#include "global.h"
#include <grass/vask.h>
@@ -32,7 +33,7 @@
ln = 2;
V_clear();
V_line(0,
- "Please select the file(s) you wish to rectify by naming an output file");
+ _("Please select the file(s) you wish to rectify by naming an output file"));
if (!repeat)
for (i = 0; i < NFILES; i++)
result[i][0] = 0;
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/photo.rectify/main.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/photo.rectify/main.c 2008-10-16 13:19:19 UTC (rev 33916)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/photo.rectify/main.c 2008-10-16 13:43:39 UTC (rev 33917)
@@ -6,11 +6,12 @@
* Markus Neteler <neteler itc.it>,
* Bernhard Reiter <bernhard intevation.de>,
* Glynn Clements <glynn gclements.plus.com>,
- * Hamish Bowman <hamish_nospam yahoo.com>
- * PURPOSE: rectifies an image by using the image to photo coordinate
- * transformation matrix
- * COPYRIGHT: (C) 1999-2006 by the GRASS Development Team
+ * Hamish Bowman <hamish_b yahoo.com>
+ * PURPOSE: Rectifies an image by using the image to photo coordinate
+ * transformation matrix
+ * COPYRIGHT: (C) 1999-2008 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
* for details.
@@ -19,56 +20,71 @@
#define GLOBAL
#include <stdlib.h>
#include <string.h>
+#include <grass/gis.h>
#include <grass/imagery.h>
#include "global.h"
int main(int argc, char *argv[])
- char *name, *location, *mapset, *camera, msg[100];
+ char name[GNAME_MAX];
+ char *camera;
int n, nfiles;
char tl[100];
char math_exp[100];
char units[100];
char nd[100];
+ struct GModule *module;
+ struct Option *group_opt;
+ /* must run in a term window */
+ G_putenv("GRASS_UI_TERM", "1");
+ G_gisinit(argv[0]);
+ module = G_define_module();
+ module->keywords = _("imagery, orthorectify");
+ module->description =
+ _("Interactively select or modify the imagery group target.");
+ group_opt = G_define_standard_option(G_OPT_I_GROUP);
+ group_opt->description =
+ _("Name of imagery group for ortho-rectification");
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
#ifdef DEBUG3
+/* slowly convert these to G_debug() */
Bugsr = fopen("ortho_rectify.rst", "w");
- if (Bugsr == NULL) {
- sprintf(msg, "Cant open debug file ortho_rectify\n");
- G_fatal_error(msg);
+ if (Bugsr == NULL)
+ G_fatal_error("Can't open debug file \"ortho_rectify.rst\"");
#endif
- if (argc != 2) {
- fprintf(stderr, "usage: %s group\n", argv[0]);
- exit(1);
- G_gisinit(argv[0]);
G_suppress_masking(); /* need to do this for target location */
- name = (char *)G_malloc(40 * sizeof(char));
- location = (char *)G_malloc(80 * sizeof(char));
- mapset = (char *)G_malloc(80 * sizeof(char));
+ strcpy(name, group_opt->answer);
camera = (char *)G_malloc(40 * sizeof(char));
- elev_layer = (char *)G_malloc(40 * sizeof(char));
- mapset_elev = (char *)G_malloc(40 * sizeof(char));
+ elev_layer = (char *)G_malloc(GNAME_MAX * sizeof(char));
+ mapset_elev = (char *)G_malloc(GMAPSET_MAX * sizeof(char));
/* get group ref */
- name = argv[1];
strcpy(group.name, name);
- if (!I_find_group(group.name)) {
- fprintf(stderr, "Group [%s] not found\n", group.name);
- exit(1);
+ if (!I_find_group(group.name))
+ G_fatal_error(_("Group [%s] not found"), group.name);
/* get the group ref */
I_get_group_ref(group.name, (struct Ref *)&group.group_ref);
nfiles = group.group_ref.nfiles;
- if (nfiles <= 0) {
- sprintf(msg, "No files in this group!\n");
+ if (nfiles <= 0)
+ G_fatal_error(_("No files in this group!"));
ref_list = (int *)G_malloc(nfiles * sizeof(int));
new_name = (char **)G_malloc(nfiles * sizeof(char *));
for (n = 0; n < nfiles; n++)
@@ -80,17 +96,14 @@
/* ask for files to be rectified */
ask_files(group.name);
-#ifdef DEBUG3
- fprintf(Bugsr, "Looking for elevation file in group: %s\n", group.name);
-#endif
+ G_debug(1, "Looking for elevation file in group: <%s>", group.name);
/* get the block elevation layer raster map in target location */
I_get_group_elev(group.name, elev_layer, mapset_elev, tl, math_exp,
units, nd);
-#ifdef DEBUG3
- fprintf(Bugsr, "Block elevation: %s in %s\n", elev_layer, mapset_elev);
-#endif
+ G_debug(1, "Block elevation: <%s> in <%s>", elev_layer, mapset_elev);
/* get the elevation layer header in target location */
select_target_env();
@@ -98,25 +111,19 @@
select_current_env();
/** look for camera info for this block **/
- if (!I_get_group_camera(group.name, camera)) {
- sprintf(msg, "No camera reference file selected for group [%s]\n",
- group.name);
- if (!I_get_cam_info(camera, &group.camera_ref)) {
- sprintf(msg, "Bad format in camera file for group [%s]\n",
- group.name);
+ if (!I_get_group_camera(group.name, camera))
+ G_fatal_error(_("No camera reference file selected for group [%s]"),
+ group.name);
+ if (!I_get_cam_info(camera, &group.camera_ref))
+ G_fatal_error(_("Bad format in camera file for group [%s]"),
+ group.name);
/* get initial camera exposure station, if any */
if (I_find_initial(group.name)) {
- if (!I_get_init_info(group.name, &group.camera_exp)) {
- sprintf(msg,
- "Bad format in initial exposusre station file for group [%s]\n",
- group.name);
- G_warning(msg);
+ if (!I_get_init_info(group.name, &group.camera_exp))
+ G_warning(_("Bad format in initial exposusre station file for group [%s]"),
+ group.name);
/* read the reference points for the group, compute image-to-photo trans. */
@@ -140,5 +147,5 @@
/* go do it */
exec_rectify();
- exit(0);
+ exit(EXIT_SUCCESS);
