[GRASS-SVN] r34023 - grass/trunk/scripts/d.out.gpsdrive
svn_grass at osgeo.org
Mon Oct 27 12:12:14 EDT 2008
Author: hamish
Date: 2008-10-27 12:12:14 -0400 (Mon, 27 Oct 2008)
New Revision: 34023
grass/trunk/scripts/d.out.gpsdrive/d.out.gpsdrive
grass/trunk/scripts/d.out.gpsdrive/d.out.gpsdrive.html
* fix parsing of g.region after "cosmetic" change of module output.
* comment on and report convergence angle.
* update to new gpsdrive default map dir.
Modified: grass/trunk/scripts/d.out.gpsdrive/d.out.gpsdrive
--- grass/trunk/scripts/d.out.gpsdrive/d.out.gpsdrive 2008-10-27 16:09:18 UTC (rev 34022)
+++ grass/trunk/scripts/d.out.gpsdrive/d.out.gpsdrive 2008-10-27 16:12:14 UTC (rev 34023)
@@ -9,7 +9,7 @@
# PURPOSE: Export display monitor to a gpsdrive compatible image
-# COPYRIGHT: (c) 2005 The GRASS Development Team
+# COPYRIGHT: (c) 2005-2008 The GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
@@ -33,10 +33,21 @@
# 2817 is maybe someones screen dpi converted to pixels/meter??
# At scales wider than say 1:250,000 the curvatute of the Earth really starts
-# to play havoc with gpsDrive's simple projection system if you are using
+# to play havoc with GpsDrive's simple projection system if you are using
# a UTM or other non-lat/lon projection. Best to use output from a lat/lon
-# location in that case.
+# location in that case. i.e. to avoid distortion, anything more global than
+# 1:150k to 1:500k should use "top_*".
+# Beware if you are using an image originating from a map projection with
+# a significant deviation between true north and the map projection's
+# local +y direction (known as the Convergence Angle). GpsDrive assumes
+# that true north is always directly up! i.e. the Central Meridian of the
+# map projection is located at the map tile's center. For some map projec-
+# tions and areas of the country this can be a really bad assumption and
+# your map will be significantly rotated. This effect is most visible at
+# map scales covering a large area. This does not affect lat/lon maps.
+# The pnmrotate program may help, or gdalwarp to a custom map-centered tmerc.
# A series of 1:50,000 maps may not be so bad.
# This translates to approx a 22.7km x 18.2km image window in the GIS.
# x_ext=scale*(1280/2817.9)
@@ -50,7 +61,9 @@
# export GRASS_HEIGHT=512
# d.mon x0
#%Module
#% description: Export display monitor to a GpsDrive compatible backdrop image
#% keywords: display, export, GPS
@@ -59,7 +72,7 @@
#% key: output
#% type: string
#% gisprompt: new_file,file,output
-#% description: name for new map image (lives in ~/.gpsdrive)
+#% description: name for new map image (lives in ~/.gpsdrive/maps/)
#% required : yes
#%end
#%flag
@@ -98,12 +111,12 @@
export LC_NUMERIC
-if [ ! -d "$HOME/.gpsdrive" ] ; then
- mkdir "$HOME/.gpsdrive"
+if [ ! -d "$HOME/.gpsdrive/maps" ] ; then
+ mkdir -p "$HOME/.gpsdrive/maps"
fi
# GpsDrive scales maps named top_* as lat/lon (1:1) on-screen
-# GpsDrive scales maps named map_* as UTM-like (1:cos(lat) ?) on-screen
+# GpsDrive scales maps named map_* as UTM-like (1:cos(lat) ) on-screen
PROJ=`g.region -p | grep ^proj | cut -f2 -d' '`
if [ "$PROJ" -eq 3 ] ; then
IS_LATLON=1
@@ -112,11 +125,16 @@
IS_LATLON=0
TYPE="map"
if [ "$PROJ" -ne 1 ] ; then
- g.message "GpsDrive assumes northings are not rotated compared to true-geographic north."
- g.message "If you are using a projection with significant curvature away from the central"
- g.message 'meridian, then you will likely end up with a distorted background map!'
- g.message "Keeping the area small will lessen the error, but not eliminate it."
- g.message "Consider output from a Lat/Lon location."
+ g.message message="GpsDrive assumes northings are not rotated compared "\
+"to true-geographic north. If you are using a projection with significant "\
+"curvature away from the central meridian, then you will likely end up with "\
+'a distorted background map! '\
+"Keeping the area small will lessen the error, but not eliminate it. "\
+"Consider output from a Lat/Lon location if the convergence angle is "\
+"more than a couple of degrees."
+ g.region -n
+ # TODO: add a flag to correct for convergence angle with pnmrotate
fi
fi
@@ -130,7 +148,7 @@
# get rid of no or double extension
output="${TYPE}_`basename $GIS_OPT_OUTPUT .png`.png"
-GRASS_PNGFILE="$HOME/.gpsdrive/$output"
+GRASS_PNGFILE="$HOME/.gpsdrive/maps/$output"
export GRASS_PNGFILE
# As .jpg output will overwrite .png of the same name, we check,
@@ -158,17 +176,17 @@
#export display to PNG driver
dsave=`d.save -a`
-d.mon start=PNG
+d.mon start=PNG --quiet
FRAME_DIMS="`d.info -b | cut -f2- -d' '`"
eval "$dsave"
-d.mon stop=PNG
+d.mon stop=PNG --quiet
#reset
sleep 1
d.mon select="$curr_mon"
if [ "$GIS_FLAG_J" -eq 1 ] ; then
out_jpeg="`basename $output .png`.jpg"
- cd "$HOME/.gpsdrive"
+ cd "$HOME/.gpsdrive/maps/"
sync # sleep 1
pngtopnm "$output" | pnmtojpeg > "$out_jpeg"
rm -f "$output"
@@ -181,28 +199,26 @@
FRAME_HEIGHT="`echo $FRAME_DIMS | awk '{printf("%f", $4 - $3)}'`"
if [ $IS_LATLON -eq 0 ] ; then
- LAT=`g.region -l | grep 'Center lat' | cut -f2 -d'[' | sed -e 's/]$//'`
- LON=`g.region -l | grep 'Center lon' | cut -f2 -d'[' | sed -e 's/]$//'`
+ LAT=`g.region -lg | grep 'center_lat' | cut -f2 -d'='`
+ LON=`g.region -lg | grep 'center_long' | cut -f2 -d'='`
M_PER_PIXEL=`echo $e $w $FRAME_WIDTH | awk '{printf("%f", ($1 - $2) / $3)}'`
else
- LAT=`g.region -c | grep 'northing' | cut -f2 -d':' | awk '{print $1}'`
- LON=`g.region -c | grep 'easting' | cut -f2 -d':' | awk '{print $1}'`
+ LAT=`g.region -cg | grep 'northing' | cut -f2 -d'='`
+ LON=`g.region -cg | grep 'easting' | cut -f2 -d'='`
- EXTENT=`g.region -e | grep 'north-south extent' | cut -f2 -d':' | awk '{print $1}'`
+ EXTENT=`g.region -eg | grep 'ns_extent' | cut -f2 -d'='`
M_PER_PIXEL=`echo $EXTENT $FRAME_HEIGHT | awk '{printf("%f", ($1 * 1852*60.) / $2)}'`
fi
SCALE=`echo $M_PER_PIXEL | awk '{printf("%d", 0.5 + ($1 * 2817.947378) )}'`
if [ $IS_LATLON -eq 0 ] && [ "$SCALE" -ge 125000 ] ; then
- g.message -w "Projected input maps may be somewhat inaccurate at this scale."
+ g.message -w "Projected input maps may be somewhat inaccurate at this scale. Better to use lat/lon"
fi
-echo "$output $LAT $LON $SCALE" >> "$HOME/.gpsdrive/map_koord.txt"
+echo "$output $LAT $LON $SCALE" >> "$HOME/.gpsdrive/maps/map_koord.txt"
-g.message "Center lat,lon is [$LAT,$LON]"
-g.message "Scale is [1:${SCALE}]"
+g.message -v "Center lat,lon is [$LAT,$LON], scale is [1:${SCALE}]"
g.message "Done."
Modified: grass/trunk/scripts/d.out.gpsdrive/d.out.gpsdrive.html
--- grass/trunk/scripts/d.out.gpsdrive/d.out.gpsdrive.html 2008-10-27 16:09:18 UTC (rev 34022)
+++ grass/trunk/scripts/d.out.gpsdrive/d.out.gpsdrive.html 2008-10-27 16:12:14 UTC (rev 34023)
@@ -13,8 +13,9 @@
<P>
<H2>NOTES</H2>
-Maps are saved in the user's <tt>~/.gpsdrive</tt> directory. Geo-referencing
-information is added to the user's <tt>~/.gpsdrive/map_koord.txt</tt> file.
+Maps are saved in the user's <tt>~/.gpsdrive/maps/</tt> directory.
+Geo-referencing information is added to the user's
+<tt>~/.gpsdrive/maps/map_koord.txt</tt> file.
<P>
JPEG output requires the <tt>pngtopnm</tt> and <tt>pnmtojpeg</tt> programs
@@ -25,12 +26,20 @@
meridian, or a map datum with a significant rotational component, then you will
likely end up with a distorted or inexact background map!
-Keeping the area small will lessen the error, but not eliminate it.
+Keeping the area small will lessen the error, but not eliminate it, if
+necessary you could reproject the map into a custom projection (such as tmerc)
+centered directly on the center of your map. You can check the local
+convergence angle (difference between grid north and true north) with
+"<tt>g.region -n</tt>".
<P>
-Best output is created from a Lat/Lon location or by keeping the output area
-small (1:50,000). This translates to approx a 22.7km x 18.2km image window in the
-GIS. [<tt>x_ext=scale*(1280/2817.95)</tt>]
+To avoid distortion, anything more global than 1:150k to 1:500k
+should come from a lat/lon location. Anything more local than that
+will look better coming from a projected system such as UTM.
<P>
+The extent of a map given a target scale can be calculated with
+<tt>x_ext=scale*(1280/2817.95)</tt>. e.g. 1:50,000 translates to approx
+a 22.7km x 18.2km image window in the GIS.
+<P>
For your convenience (calculations are rough, but nominal):
<div class="code"><pre>
1:50,000 uses a region 22.7km x 18.2km.
@@ -108,7 +117,8 @@
<BR>
Note that to get a smoother transition between backdrop maps this script
-creates overlapping tiles.
+creates overlapping tiles. For best results at least 1/3rd overlap should
+be maintained.
<BR><BR>
@@ -135,4 +145,5 @@
New Zealand</i><BR>
<BR>
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
