[GRASS-SVN] r34024 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Mon Oct 27 15:20:34 EDT 2008
Author: martinl
Date: 2008-10-27 15:20:31 -0400 (Mon, 27 Oct 2008)
New Revision: 34024
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
wxGUI/vdigit: fix object placement when display region is changed
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2008-10-27 16:12:14 UTC (rev 34023)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2008-10-27 19:20:31 UTC (rev 34024)
@@ -736,6 +736,18 @@
             if item and self.tree.IsItemChecked(item):
                 self.parent.digit.driver.DrawMap()
+            # translate tmp objects (pointer position)
+            if digitToolbar.GetAction() == 'moveLine':
+                if  hasattr(self, "vdigitMove") and \
+                        self.vdigitMove.has_key('beginDiff'):
+                    # move line
+                    for id in self.vdigitMove['id']:
+                        # print self.pdcTmp.GetIdBounds(id)
+                        self.pdcTmp.TranslateId(id,
+                                                self.vdigitMove['beginDiff'][0],
+                                                self.vdigitMove['beginDiff'][1])
+                    del self.vdigitMove['beginDiff']
         # render overlays
@@ -758,6 +770,7 @@
         if len(self.polycoords) > 0:
             self.DrawLines(self.pdcTmp)
         if self.parent.gismanager.georectifying:
             # -> georectifier (redraw GCPs)
             if self.parent.toolbars['georect']:
@@ -781,7 +794,7 @@
         Debug.msg (2, "BufferedWindow.UpdateMap(): render=%s, renderVector=%s -> time=%g" % \
                    (render, renderVector, (stop-start)))
         return True
     def DrawCompRegionExtent(self):
@@ -952,7 +965,7 @@
         if not polycoords:
             polycoords = self.polycoords
         if len(polycoords) > 0:
             self.plineid = wx.ID_NEW + 1
             # convert from EN to XY
@@ -1193,7 +1206,7 @@
                     # add new point to the line
                     self.polycoords.append(self.Pixel2Cell(event.GetPositionTuple()[:]))
                     self.DrawLines(pdc=self.pdcTmp)
             elif digitToolbar.GetAction() == "editLine" and hasattr(self, "vdigitMove"):
                 self.polycoords.append(self.Pixel2Cell(self.mouse['begin']))
                 self.vdigitMove['id'].append(wx.NewId())
@@ -1913,7 +1926,8 @@
         # digitization tool
         if self.mouse["use"] == "pointer" and digitToolbar:
             digitClass = self.parent.digit
-            if (digitToolbar.GetAction() == "addLine" and digitToolbar.GetAction('type') in ["line", "boundary"]) or \
+            if (digitToolbar.GetAction() == "addLine" and \
+                    digitToolbar.GetAction('type') in ["line", "boundary"]) or \
                     digitToolbar.GetAction() == "editLine":
                 # add line or boundary -> remove last point from the line
                 try:
@@ -1984,11 +1998,6 @@
                 dx = self.mouse['end'][0] - self.mouse['begin'][0]
                 dy = self.mouse['end'][1] - self.mouse['begin'][1]
-                if self.vdigitMove.has_key('beginDiff'):
-                    if digitToolbar.GetAction() == 'moveLine':
-                        dx += self.vdigitMove['beginDiff'][0]
-                        dy += self.vdigitMove['beginDiff'][1]
-                    del self.vdigitMove['beginDiff']
                 if len(self.vdigitMove['id']) > 0:
                     # draw lines on new position
@@ -2168,12 +2177,10 @@
             ce = newreg['w'] + (newreg['e'] - newreg['w']) / 2
             cn = newreg['s'] + (newreg['n'] - newreg['s']) / 2
             if hasattr(self, "vdigitMove"):
-                xo = self.Cell2Pixel((self.Map.region['center_easting'], self.Map.region['center_northing']))
-                xn = self.Cell2Pixel((ce, cn))
-                self.vdigitMove['beginDiff'] = (xn[0] - xo[0], xn[1] - xo[1])
-                for id in self.vdigitMove['id']:
-                    self.pdcTmp.RemoveId(id)
+                # xo = self.Cell2Pixel((self.Map.region['center_easting'], self.Map.region['center_northing']))
+                # xn = self.Cell2Pixel(ce, cn))
+                tmp = self.Pixel2Cell(self.mouse['end'])
             # calculate new center point and display resolution
             self.Map.region['center_easting'] = ce
             self.Map.region['center_northing'] = cn
@@ -2181,6 +2188,15 @@
             self.Map.region["nsres"] = (newreg['n'] - newreg['s']) / self.Map.height
             self.Map.AlignExtentFromDisplay()
+            if hasattr(self, "vdigitMove"):
+                tmp1 = self.mouse['end']
+                tmp2 = self.Cell2Pixel(self.vdigitMove['begin'])
+                dx = tmp1[0] - tmp2[0]
+                dy = tmp1[1] - tmp2[1]
+                self.vdigitMove['beginDiff'] = (dx, dy)
+                    self.pdcTmp.RemoveId(id)
             self.ZoomHistory(self.Map.region['n'], self.Map.region['s'],
                              self.Map.region['e'], self.Map.region['w'])
@@ -2890,7 +2906,7 @@
                                                  (e, n, distance_seg, distance_tot), 0)
             else:
                 self.statusbar.SetStatusText("%.2f, %.2f" % (e, n), 0)
         event.Skip()
     def OnDraw(self, event):
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2008-10-27 16:12:14 UTC (rev 34023)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2008-10-27 19:20:31 UTC (rev 34024)
@@ -567,6 +567,10 @@
         else:
             # initialize toolbar
             self.toolbar[0].ToggleTool(self.action['id'], True)
+        # clear tmp canvas
+        if self.action['id'] != id:
+            self.parent.MapWindow.ClearLines(pdc=self.parent.MapWindow.pdcTmp)
     def OnAddPoint(self, event):
         """Add point to the vector map Laier"""
@@ -583,16 +587,18 @@
                         'type' : "line",
                         'id'   : self.addLine }
         self.parent.MapWindow.mouse['box'] = 'line'
-        self.parent.MapWindow.polycoords = [] # reset temp line
+        ### self.parent.MapWindow.polycoords = [] # reset temp line
     def OnAddBoundary(self, event):
         """Add boundary to the vector map layer"""
         Debug.msg (2, "VDigitToolbar.OnAddBoundary()")
+        if self.action['desc'] != 'addLine' or \
+                self.action['type'] != 'boundary':
+            self.parent.MapWindow.polycoords = [] # reset temp line
         self.action = { 'desc' : "addLine",
                         'type' : "boundary",
                         'id'   : self.addBoundary }
     def OnAddCentroid(self, event):
         """Add centroid to the vector map layer"""
