[GRASS-SVN] r34062 - grass/branches/develbranch_6/scripts/d.out.file
svn_grass at osgeo.org
Wed Oct 29 09:40:09 EDT 2008
Author: hamish
Date: 2008-10-29 09:40:09 -0400 (Wed, 29 Oct 2008)
New Revision: 34062
grass/branches/develbranch_6/scripts/d.out.file/d.out.file
add flag to skip white margin crop. TODO: crop other formats
Modified: grass/branches/develbranch_6/scripts/d.out.file/d.out.file
--- grass/branches/develbranch_6/scripts/d.out.file/d.out.file 2008-10-29 13:39:12 UTC (rev 34061)
+++ grass/branches/develbranch_6/scripts/d.out.file/d.out.file 2008-10-29 13:40:09 UTC (rev 34062)
@@ -135,6 +135,11 @@
#% description: Set paper orientation to landscape (for PostScript output)
#% guisection: PostScript
#%end
+#%flag
+#% key: m
+#% description: Do not crop away margins
+#% guisection: GeoTIFF
+#%end
if [ -z "$GISBASE" ] ; then
@@ -347,7 +352,8 @@
d.mon start=$GRAPHICS_DRIVER --quiet
# 'd.info -b' for white band removal
BOX=`d.info -b | cut -f2 -d':'`
- # use 'd.info -g' here for GeoTIFF bbox with no white band removal
+ # 'd.info -g' to get GeoTIFF bounds when keeping white margin bands
+ eval `d.info -g`
eval "$dsave"
d.mon stop=$GRAPHICS_DRIVER --quiet
@@ -398,17 +404,24 @@
geotiff)
g.message "Translating to GeoTIFF format"
- eval `g.region -g`
+ if [ $GIS_FLAG_M -eq 0 ] ; then
+ # chop off out of region borders
+ eval `g.region -g`
- # chop off out of region borders
- BOX_L=`echo $BOX | cut -f1 -d' '`
- BOX_R=`echo $BOX | cut -f2 -d' '`
- BOX_T=`echo $BOX | cut -f3 -d' '`
- BOX_B=`echo $BOX | cut -f4 -d' '`
- BOX_WIDTH=`echo $BOX_R $BOX_L | awk '{print $1 - $2}'`
- BOX_HEIGHT=`echo $BOX_B $BOX_T | awk '{print $1 - $2}'`
- g.message "Image crop [$BOX_WIDTH x $BOX_HEIGHT]"
+ BOX_L=`echo $BOX | cut -f1 -d' '`
+ BOX_R=`echo $BOX | cut -f2 -d' '`
+ BOX_T=`echo $BOX | cut -f3 -d' '`
+ BOX_B=`echo $BOX | cut -f4 -d' '`
+ BOX_WIDTH=`echo $BOX_R $BOX_L | awk '{print $1 - $2}'`
+ BOX_HEIGHT=`echo $BOX_B $BOX_T | awk '{print $1 - $2}'`
+ CROP_PARAM="-srcwin $BOX_L $BOX_T $BOX_WIDTH $BOX_HEIGHT"
+ g.message "Image crop [$BOX_WIDTH x $BOX_HEIGHT]"
+ else
+ CROP_PARAM=""
+ fi
PROJ_WKT="`g.proj -wf`"
CO=""
if [ -n "$GIS_OPT_CREATEOPT" ] ; then
@@ -426,8 +439,7 @@
fi
unset IFS
- gdal_translate -of GTIFF -a_ullr $w $n $e $s -quiet \
- -srcwin $BOX_L $BOX_T $BOX_WIDTH $BOX_HEIGHT \
+ gdal_translate -of GTIFF -a_ullr $w $n $e $s -quiet $CROP_PARAM \
-a_srs "$PROJ_WKT" $CO $MO "$output" "$outname"
EXITCODE=$?
