[GRASS-SVN] r34063 - grass/branches/develbranch_6/locale/po
svn_grass at osgeo.org
Wed Oct 29 10:49:51 EDT 2008
Author: cdavilam
Date: 2008-10-29 10:49:51 -0400 (Wed, 29 Oct 2008)
New Revision: 34063
grass/branches/develbranch_6/locale/po/grassmods_el.po
translation by Vasilis Antoniou
Modified: grass/branches/develbranch_6/locale/po/grassmods_el.po
--- grass/branches/develbranch_6/locale/po/grassmods_el.po 2008-10-29 13:40:09 UTC (rev 34062)
+++ grass/branches/develbranch_6/locale/po/grassmods_el.po 2008-10-29 14:49:51 UTC (rev 34063)
@@ -2,19 +2,22 @@
# Greek translation of grassmods.pot
# This file is distributed under the same license as the GRASS package.
# Copyright (C) 2007 GRASS Development Team
# Carlos Davila <carluti at users.sourceforge.net>, 2007.
+# Vasilios Antoniou <antoniou_v at yahoo.gr>, 2008.
+# Vasilios Antoniou <vantoniou at gmail.com>, 2008.
msgid ""
msgstr ""
"Project-Id-Version: grassmods_el\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2008-10-11 14:54+0200\n"
-"PO-Revision-Date: 2007-03-23 16:35+0100\n"
-"Last-Translator: Carlos Davila <carluti at users.sourceforge.net>\n"
+"PO-Revision-Date: 2008-10-29 10:26+0200\n"
+"Last-Translator: Vasilios Antoniou <vantoniou at gmail.com>\n"
"Language-Team: Greek <grass-translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=ISO-8859-7\n"
"Content-Transfer-Encoding: 8bit\n"
+"X-Generator: KBabel 1.11.4\n"
#: ../db/base/execute.c:60 ../db/base/createdb.c:43 ../db/base/dropdb.c:43
#: ../db/base/tables.c:46 ../db/base/droptable.c:44 ../db/base/select.c:62
@@ -27,197 +30,199 @@
#: ../display/d.thematic.area/main.c:230
#, c-format
msgid "Unable to start driver <%s>"
-msgstr ""
+msgstr "Áäõíáìßá åêêßíçóçò ôïõ ïäçãïý <%s>"
#: ../db/base/execute.c:66 ../db/base/tables.c:51 ../db/base/select.c:68
#: ../db/base/describe.c:57 ../display/d.vect/main.c:504
#: ../display/d.thematic.area/main.c:235
#, c-format
msgid "Unable to open database <%s>"
-msgstr ""
+msgstr "Áäõíáìßá áíïßãìáôïò âÜóçò äåäïìåíùí <%s>"
#: ../db/base/execute.c:76 ../db/base/execute.c:81
#, c-format
msgid "Error while executing: '%s'"
-msgstr ""
+msgstr "ÓöÜëìá êáôÜ ôçí åêôÝëåóç: '%s'"
#: ../db/base/execute.c:106 ../db/base/copy.c:34 ../db/base/select.c:230
msgid "database, attribute table, SQL"
-msgstr ""
+msgstr "ÂÜóç äåäïìÝíùí, ðßíáêáò éäéïôÞôùí, SQL"
#: ../db/base/execute.c:107
msgid "Executes any SQL statement."
-msgstr ""
+msgstr "Åêôåëåß ïðïéáäÞðïôå SQL åíôïëÞ"
#: ../db/base/execute.c:111
msgid "Name of file containing SQL statements"
-msgstr ""
+msgstr "¼íïìá ôïõ áñ÷åßïõ ðïõ ðåñéÝ÷åé SQL åíôïëÝò"
#: ../db/base/execute.c:124
msgid "Ignore SQL errors and continue"
-msgstr ""
+msgstr "Áãíïåß ôá SQL ëÜèç êáé óõíå÷ßæåé"
#: ../db/base/execute.c:150
msgid "Use db.select for SELECT SQL statements"
-msgstr ""
+msgstr "×ñçóéìïðïéÞóôå sb.select ãéá SELECT SQL åíôïëÝò"
#: ../db/base/createdb.c:71 ../db/base/dropdb.c:71 ../db/base/droptable.c:78
#: ../db/base/databases.c:90 ../db/db.login/main.c:43
msgid "database, SQL"
-msgstr ""
+msgstr "ÂÜóç äåäïìÝíùí, SQL"
#: ../db/base/createdb.c:72
msgid "Creates an empty database."
-msgstr ""
+msgstr "Äçìéïõñãåß ìßá êåíÞ âÜóç äåäïìÝíùí"
#: ../db/base/copy.c:35
msgid "Copy a table."
-msgstr ""
+msgstr "ÁíôéãñÜöåé Ýíá ðßíáêá"
#: ../db/base/copy.c:37
msgid ""
"Either 'from_table' (optionally with 'where') can be used or 'select' "
"option, but not 'from_table' and 'select' at the same time."
msgstr ""
+"Åßôå 'from_table' (êáô' åðéëïãÞ ìå 'where') ìðïñåß íá ÷ñçóéìïðïéçèåß Þ 'select' "
+"åðéëïãÞ, áëëÜ ü÷é 'from_table' êáé 'select' ôçí ßäéá óôéãìÞ."
#: ../db/base/copy.c:43
msgid "Input driver name"
-msgstr ""
+msgstr "ÅéóáãùãÞ üíïìá ïäçãïý"
#: ../db/base/copy.c:49
msgid "Input database name"
-msgstr ""
+msgstr "ÅéóáãùãÞ üíïìá âÜóçò äåäïìÝíùí"
#: ../db/base/copy.c:56
msgid "Input table name (only, if 'select' is not used)"
-msgstr ""
+msgstr "ÅéóáãùãÞò âÜóçò äåäïìÝíùí (ìüíï åÜí 'select' äåí ÷ñçóéìïðïéåßôáé)"
#: ../db/base/copy.c:62
msgid "Output driver name"
-msgstr ""
+msgstr "ÅîáãùãÞ üíïìá ïäçãïý"
#: ../db/base/copy.c:68
msgid "Output database name"
-msgstr ""
+msgstr "ÅîáãùãÞ üíïìá âÜóçò äåäïìÝíùí"
#: ../db/base/copy.c:75
msgid "Output table name"
-msgstr ""
+msgstr "ÅîáãùãÞ ïíüìáôïò ðßíáêá"
#: ../db/base/copy.c:84
msgid "Full select statement (only, if 'from_table' and 'where' is not used)"
-msgstr ""
+msgstr "ÐëÞñçò select äÞëùóç (ìüíï, åÜí 'from_table' êáé 'where' is äåí ÷ñçóéìïðïéïýíôáé)"
#: ../db/base/copy.c:85
msgid "E.g.: SELECT dedek FROM starobince WHERE obec = 'Frimburg'"
-msgstr ""
+msgstr "ÐáñÜäåéãìá.: SELECT dedek FROM starobince WHERE obec = 'Frimburg'"
#: ../db/base/copy.c:93
msgid "Cannot combine 'from_table' and 'select' options"
-msgstr ""
+msgstr "Äåí ìðïñåß íá óõíäõáóôåß 'from_table' êáé 'select' åðéëïãÝò"
#: ../db/base/copy.c:111
msgid "Either 'from_table' or 'select' option must be given."
-msgstr ""
+msgstr "Åßôå 'from_table' Þ 'select' åðéëïãÞ ðñÝðåé íá äùèåß."
#: ../db/base/copy.c:114
msgid "Cannot combine 'select' and 'where' options"
-msgstr ""
+msgstr "Äåí óõíäõÜæïíôáé 'select' êáé 'where' åðéëïãÝò"
#: ../db/base/copy.c:124
msgid "Copy table failed"
-msgstr ""
+msgstr "ÁíôéãñáöÞ ðßíáêá áðÝôõ÷å"
#: ../db/base/dropdb.c:72
msgid "Removes a database."
-msgstr ""
+msgstr "Áöáéñåß ìßá âÜóç äåäïìÝíùí"
#: ../db/base/tables.c:87
msgid "Print tables and exit"
-msgstr ""
+msgstr "Ôõðþíåé ôïí ðßíáêá êáé êëåéíåé (Ýîïäïò)"
#: ../db/base/tables.c:91
msgid "System tables instead of user tables"
-msgstr ""
+msgstr "Ðßíáêåò óõóôÞìáôïò áíôß ðßíáêåò ÷ñçóôþí"
#: ../db/base/tables.c:95 ../db/base/drivers.c:74 ../db/base/columns.c:92
#: ../db/base/describe.c:125 ../db/base/connect.c:45
msgid "database, attribute table"
-msgstr ""
+msgstr "âÜóç äåäïìÝíùí, ðßíáêáò éäéïôÞôùí"
#: ../db/base/tables.c:96
msgid "Lists all tables for a given database."
-msgstr ""
+msgstr "Äßíåé ôç ëßóôá üëùí ôùí ðéíÜêùí ãéá ìßá äåäïìÝíç âÜóç äåäïìÝíùí."
#: ../db/base/droptable.c:79
msgid "Removes a table from database."
-msgstr ""
+msgstr "Áöáéñåß Ýíá ðßíáêá áðü ôçí âÜóç äåäïìÝíùí"
#: ../db/base/drivers.c:41
msgid "Error trying to read dbmscap file\n"
-msgstr ""
+msgstr "ÓöÜëìá êáôÜ ôçí ðñïóðÜèåéá áíÜãíùóçò ôïõ áñ÷åßïõ dbmscap\n"
#: ../db/base/drivers.c:66
msgid "Full output"
-msgstr ""
+msgstr "ÐëÞñåò output"
#: ../db/base/drivers.c:70
msgid "print drivers and exit"
-msgstr ""
+msgstr "ôõðþíåé ôïõò ïäçãïýò êáé Ýîïäïò"
#: ../db/base/drivers.c:75
msgid "List all database drivers."
-msgstr ""
+msgstr "Äßíåé ôç ëßóôá ãéá üëïõò ôïõò ïäçãïýò âÜóåùí äåäïìÝíùí"
#: ../db/base/select.c:190
msgid "SQL select statement"
-msgstr ""
+msgstr "SQL select åíôïëÞ"
#: ../db/base/select.c:192
msgid "For example: 'select * from rybniky where kapri = 'hodne'"
-msgstr ""
+msgstr "Ãéá ðáñÜäåéãìá: 'select * from rybniky where kapri = 'hodne'"
#: ../db/base/select.c:195 ../raster/r.distance/parse.c:50
#: ../raster/r.stats/main.c:108 ../raster/r.cats/main.c:72
#: ../vector/v.db.select/main.c:63
msgid "Output field separator"
-msgstr ""
+msgstr "Äéá÷ùñéóôÞò ðåäßùí åîüäïõ"
#: ../db/base/select.c:199 ../vector/v.db.select/main.c:68
msgid "Output vertical record separator"
-msgstr ""
+msgstr "ÊÜèåôïò äéá÷ùñéóôÞò åããñáöþí åîüäïõ"
#: ../db/base/select.c:206 ../vector/v.db.select/main.c:76
msgid "Null value indicator"
-msgstr ""
+msgstr "Äåßêôçò êåíÞò ôéìÞò"
#: ../db/base/select.c:210
msgid "Name of file with sql statement"
-msgstr ""
+msgstr "¼íïìá áñ÷åßïõ ìå sql åíôïëÞ"
#: ../db/base/select.c:214 ../vector/v.db.select/main.c:86
msgid "Do not include column names in output"
-msgstr ""
+msgstr "Ìçí óõìðåñéëÜâåôáé ôá ïíüìáôá ôùí óôçëþí óôçí Ýîïäï"
#: ../db/base/select.c:218
msgid "Describe query only (don't run it)"
-msgstr ""
+msgstr "ÐåñéãñÜöç ìüíï ôï åñþôçìá (äåí ôï ôñÝ÷åé)"
#: ../db/base/select.c:222 ../vector/v.db.select/main.c:91
msgid "Vertical output (instead of horizontal)"
-msgstr ""
+msgstr "Ïñéæüíôéá Ýîïäïò (áíôß ãéá êáôáêüñõöç)"
#: ../db/base/select.c:226
msgid "Only test query, do not execute"
-msgstr ""
+msgstr "Åñþôçìá ìüíï ãéá ôåóô, ìçí ôï åêôåëÝóåôå"
#: ../db/base/select.c:231
msgid "Selects data from table."
-msgstr ""
+msgstr "ÅðéëÝãåé äåäïìÝíá áðü ôïí ðßíáêá/"
#: ../db/base/columns.c:93
msgid "List all columns for a given table."
-msgstr ""
+msgstr "Äßíåé ëßóôá üëùí ôùí óôçëþí ãéá Ýíá äåäïìÝíï ðßíáêá."
#: ../db/base/describe.c:63 ../vector/v.db.connect/main.c:199
#: ../vector/v.in.ascii/in.c:402 ../vector/v.patch/main.c:139
@@ -226,60 +231,59 @@
#: ../vector/v.out.ogr/main.c:332 ../doc/vector/v.example/main.c:134
#, c-format
msgid "Unable to describe table <%s>"
-msgstr ""
+msgstr "Áäõíáìßá ðåñéãñáöÞò ðßíáêá <%s>"
#: ../db/base/describe.c:104
msgid "Print column names only instead of full column descriptions"
-msgstr ""
+msgstr "Åêôýðùóç ìüíï ôùí ïíïìÜôùí óôçëþí áíôß ôùí áíáëõôéêþí ðåñéãñáöþí"
#: ../db/base/describe.c:109
msgid "Print table structure"
-msgstr ""
+msgstr "Ôýðùìá ôçò äïìÞ ôïõ ðßíáêá"
#: ../db/base/describe.c:126
msgid "Describes a table in detail."
-msgstr ""
+msgstr "ËåðôïìåñÞò ðåñéãñáöÞ ðßíáêá"
#: ../db/base/databases.c:56
msgid "Unable to list databases"
-msgstr ""
+msgstr "Áäõíáìßá ëßóôáò âÜóåùí äåäïìÝíùí"
#: ../db/base/databases.c:85
msgid "Location name"
-msgstr ""
+msgstr "¼íïìá ôïðïèåóßá"
#: ../db/base/databases.c:92
msgid "List all databases for a given driver and location."
-msgstr ""
+msgstr "Äßíåé ôç ëßóôá üëùí ôùí âÜóåùí äåäïìÝíùí ãéá Ýíá äùóìÝíï ïäçãü êáé ôïðïèåóßá"
#: ../db/base/connect.c:47
msgid "Prints/sets general DB connection for current mapset and exits."
-msgstr ""
+msgstr "Åêôõðþíåé/óåôÜñåé ãåíéêÞ DB óýíäåóç ãéá ôï ôñÝ÷ùí maps êáé êëåßíåé"
#: ../db/base/connect.c:52
msgid "Print current connection parameters and exit"
-msgstr ""
+msgstr "Åêôõðþíåé ôéò ôñÝ÷ïõóåò ðáñáìÝôñïõò óýíäåóçò êáé êëåßíåé"
#: ../db/base/connect.c:57
msgid "Check connection parameters, set if uninitialized, and exit"
-msgstr ""
+msgstr "ÅëÝã÷åéò ôéò ôñÝ÷ïõóåò ðáñáìÝôñïõò óýíäåóçò, óåôÜñåéò Üí äåí Ý÷ïõí îåêéíÞóåéò êáé êëåßíåé"
#: ../db/base/connect.c:72
msgid "Database schema"
-msgstr ""
+msgstr "Ç äéÜôáîç ôçò âÜóçò äåäïìÝíùí"
#: ../db/base/connect.c:73
-msgid ""
-"Do not use this option if schemas are not supported by driver/database server"
-msgstr ""
+msgid "Do not use this option if schemas are not supported by driver/database server"
+msgstr "Ìçí ÷ñçóéìïðïéÞóåôå áõôÞ ôçí åðéëïãÞ Üí ç äéÜôáîç äåí õðïóôçñßæåôáé áðü ôïí åîõðçñåôçôÞ ïäçãü/âÜóç äåäïìÝíùí"
#: ../db/base/connect.c:82
msgid "Default group of database users to which select privilege is granted"
-msgstr ""
+msgstr "ÐñïåðéëåãìÝíï ãêñïõð ÷ñçóôþí âÜóçò äåäïìÝíùí óôï ïðïßï Ý÷ïõí ôá äéêáéþìáôá"
#: ../db/base/connect.c:117
msgid "Database connection not defined. Run db.connect."
-msgstr ""
+msgstr "Äåí Ý÷åé êáèïñéóèåß ç óýíäåóç ìå ôç âÜóç äåäïìÝíùí. ÔñÝîôå ôï db.connect."
#: ../db/base/connect.c:137
#, c-format
@@ -288,26 +292,29 @@
"driver: %s\n"
"database: %s"
msgstr ""
+"ÐñïåðéëåãìÝíïò ïäçãüò / ç âÜóç äåäïìÝíùí Ý÷åé:\n"
+"driver: %s\n"
+"database: %s"
#: ../db/base/connect.c:144
msgid "Default driver is not set"
-msgstr ""
+msgstr "Ï ðñïåðéëåãìÝíïò ïäçãüò äåí Ý÷åé êáèïñéóôåß"
#: ../db/base/connect.c:147
msgid "Default database is not set"
-msgstr ""
+msgstr "Ç ðñïåðéëåãìÝíç âÜóç äåäïìÝíùí äåí Ý÷åé êáèïñéóôåß"
#: ../db/db.login/main.c:44
msgid "Sets user/password for driver/database."
-msgstr ""
+msgstr "Êáèïñßæåé ôï üíïìá ÷ñÞóôç/êùäéêü ãéá ôïí ïäçãü/ âÜóç äåäïìÝíùí"
#: ../db/db.login/main.c:60
msgid "Username"
-msgstr ""
+msgstr "¼íïìá ÷ñÞóôç"
#: ../db/db.login/main.c:67
msgid "Password"
-msgstr ""
+msgstr "Êùäéêüò"
#: ../db/db.login/main.c:83
#, c-format
@@ -316,152 +323,156 @@
"Enter database password for connection\n"
"<%s:%s:user=%s>\n"
msgstr ""
+"\n"
+"Äþóôå ôïí êùäéêü ôçò âÜóçò äåäïìÝíùí ãéá ôç óýíäåóç\n"
+"<%s:%s:user=%s>\n"
#: ../db/db.login/main.c:85
#, c-format
+#, fuzzy
msgid "Hit RETURN to cancel request\n"
-msgstr ""
+msgstr "ÐáôÞóôå ôï ðëÞêôñï RETURN ãéá íá áêõñþóåôå ôçí åíôïëÞ\n"
#: ../db/db.login/main.c:93
msgid "Exiting. Not changing current settings"
-msgstr ""
+msgstr "Êëåßóéìï åöáñìïãÞò, ÷ùñßò íá áëëÜîïõí ïé ôñÝ÷ïõóåò åðéëïãÝò"
#: ../db/db.login/main.c:97
msgid "New password set"
-msgstr ""
+msgstr "Ï íÝïò êùäéêüò äçìéïõñãÞèçêå"
#: ../db/db.login/main.c:106
msgid "Unable to set user/password"
-msgstr ""
+msgstr "Äåí åßíáé äõíáôÞ ç áëëáãÞ ÷ñÞóôç/êùäéêïý"
#: ../db/db.login/main.c:110
msgid "The password was stored in file"
-msgstr ""
+msgstr "Ï êùäéêüò áðïèçêåýôçêå óôï áñ÷åßï"
#: ../db/drivers/sqlite/describe.c:159
#, c-format
msgid "SQLite driver: column '%s', SQLite type %d is not supported"
-msgstr ""
+msgstr "SQLite driver: óôÞëç '%s', SQLite ôýðïò %d äåí õðïóôçñßæåôáé"
#: ../db/drivers/mysql/listtab.c:36
msgid "Cannot get list of tables:\n"
-msgstr ""
+msgstr "Äåí ìðïñþ íá äù ëßóôá ôùí ðéíÜêùí:\n"
#: ../db/drivers/mysql/parse.c:60
msgid "Wrong port number in MySQL database definition: "
-msgstr ""
+msgstr "ËÜèïò íïýìåñï ðüñôáò óôçí MySQL ðåñéãñáöÞ ôçò âÜóçò: "
#: ../db/drivers/mysql/parse.c:71 ../db/drivers/postgres/parse.c:55
msgid "'user' in database definition is not supported, use db.login"
-msgstr ""
+msgstr "'user' óôç âÜóç äåäïìÝíùí äåí õðïóôçñßæåôáé, ÷ñçóéìïðïéÞóôå db."
#: ../db/drivers/mysql/parse.c:75 ../db/drivers/postgres/parse.c:59
msgid "'password' in database definition is not supported, use db.login"
-msgstr ""
+msgstr "'password' óôç âÜóç äåäïìÝíùí äåí õðïóôçñßæåôáé, ÷ñçóéìïðïéÞóôå db.login"
#: ../db/drivers/mysql/parse.c:79
msgid "Unknown option in database definition for "
-msgstr ""
+msgstr "¶ãíùóôç åðéëïãÞ óôïí ïñéóìüò ôçò âÜóçò äåäïìÝíùí ãéá "
#: ../db/drivers/mysql/cursor.c:46
msgid "Cannot allocate cursor."
-msgstr ""
+msgstr "Äåí ãßíåôáé ç ìåôáêßíçóç ôïõ êÝñóïñá."
#: ../db/drivers/mysql/cursor.c:55
msgid "Cannot ad new token."
-msgstr ""
+msgstr "Áäýíáôç ç ðñïóèÞêç new token"
#: ../db/drivers/mysql/select.c:43
msgid "Cannot select data: \n"
-msgstr ""
+msgstr "Áäýíáôç ç åðéëïãÞ äåäïìÝíùí: \n"
#: ../db/drivers/mysql/describe.c:120
#, c-format
msgid "MySQL driver: column '%s', type %d is not supported"
-msgstr ""
+msgstr "MySQL ïäçãüò: óôÞëç '%s', ôýðïò %d äåí õðïóôçñßæåôáé"
#: ../db/drivers/mysql/describe.c:126
#, c-format
msgid ""
"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
"damaged"
-msgstr ""
+msgstr "óôÞëç '%s' : ôýðïò BIGINT Ý÷åé áðïèçêåõôåß ùò áêÝñáéïò (4 bytes) ïñéóìÝíá äåäïìÝíá ìðïñåß íá Ý÷ïõí êáôáóôñáöåß"
#: ../db/drivers/mysql/db.c:67
msgid "Cannot connect to MySQL: "
-msgstr ""
+msgstr "Áäõíáìßá óýíäåóçò óôçí MySQL: "
#: ../db/drivers/mysql/db.c:83
msgid "Cannot parse MySQL embedded database name"
-msgstr ""
+msgstr "Áäõíáìßá ðåñÜóìáôïò' MySQL ïíüìáôïò âÜóçò"
#: ../db/drivers/mysql/db.c:99
msgid "Cannot initialize MySQL embedded server"
-msgstr ""
+msgstr "Äåí åéíáé äõíáôÞ ç áñ÷éêïðïßçóç ìå ôïí åíóùìáôùìÝíï MySQL åîõðçñåôçôÞ"
#: ../db/drivers/mysql/db.c:118
msgid "Cannot connect to MySQL embedded server: "
-msgstr ""
+msgstr "Äåí åéíáé äõíáôÞ ç óýíäåóç ìå ôïí åíóùìáôùìÝíï MySQL åîõðçñåôçôÞ"
#: ../db/drivers/mysql/fetch.c:34
msgid "Cursor not found"
-msgstr ""
+msgstr "Ï êÝñóïñáò äåí âñÝèçêå"
#: ../db/drivers/mysql/fetch.c:52
msgid "Cursor position is not supported by MySQL driver"
-msgstr ""
+msgstr "Ç èÝóç ôïõ êÝñóïåá äåí õðïóôçñßæåôáé áðü ôïí ïäçãü MySQL"
#: ../db/drivers/mysql/fetch.c:190
msgid "Cannot scan timestamp: "
-msgstr ""
+msgstr "Áäõíáìßá óêáíáñßóìáôïò timestamp: "
#: ../db/drivers/mysql/fetch.c:198
msgid "Unknown timestamp format: "
-msgstr ""
+msgstr "¶ãíùóôç ìïñöÞ timestamp: "
#: ../db/drivers/mysql/fetch.c:212
msgid "Cannot scan date: "
-msgstr ""
+msgstr "Áäõíáìßá óêáíáñßóìáôïò çìåñïìçíßáò:"
#: ../db/drivers/mysql/fetch.c:225
msgid "Cannot scan time: "
-msgstr ""
+msgstr "Áäõíáìßá óêáíáñßóìáôïò ÷ñüíïõ: "
#: ../db/drivers/mysql/fetch.c:240
msgid "Cannot scan datetime: "
-msgstr ""
+msgstr "Áäõíáìßá óêáíáñßóìáôïò çìåñïìçíßáò-÷ñüíïõ: "
#: ../db/drivers/mysql/error.c:29
msgid "DBMI-MySQL driver error:\n"
-msgstr ""
+msgstr "DBMI-MySQL óöÜëìá ïäçãïý:\n"
#: ../db/drivers/postgres/parse.c:63
msgid "Unknown option in database definition for PostgreSQL: "
-msgstr ""
+msgstr "¶ãíùóôç åðéëïãÞ óôçí ðåñéãñáöÞ âÜóçò äåäïìÝíùí ãéá PostgreSQL: "
#: ../db/drivers/postgres/describe.c:103
#, c-format
msgid "pg driver: PostGIS column '%s', type 'geometry' will not be converted"
-msgstr ""
+msgstr "pg driver: PostGIS óôÞëç '%s', ôýðïò 'geometry' äåí èá ìåôáôñáðåß"
#: ../db/drivers/postgres/describe.c:109
#, c-format
msgid "pg driver: column '%s', type %d is not supported"
-msgstr ""
+msgstr "pg driver: óôÞëç '%s', ôýðïò %d äåí õðïóôçñßæåôáé"
#: ../db/drivers/postgres/describe.c:116
#, c-format
msgid ""
"column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data "
"may be damaged"
-msgstr ""
+msgstr "óôÞëç '%s' : ôýðïò int8 (bigint) Ý÷åé áðïèçêåõôåß ùò áêÝñáéïò (4 bytes) ïñéóìÝíá äåäïìÝíá ìðïñåß íá Ý÷ïõí êáôáóôñáöåß"
#: ../db/drivers/postgres/describe.c:120
#, c-format
msgid ""
"column '%s' : type character varying is stored as varchar(250) some data may "
"be lost"
-msgstr ""
+msgstr "óôÞëç '%s' : ï ôýðïò ÷áñáêôÞñá ìåôáâÜëëåôáé Ý÷åé áðïèçêåõôåß ùò varchar(250) ïñéóìÝíá äåäïìÝíá èá ÷áèïýí"
#: ../db/drivers/postgres/describe.c:126
#, c-format
@@ -469,15 +480,17 @@
"column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 "
"(true)"
msgstr ""
+"óôÞëç '%s' : ôýðïò bool (boolean) Ý÷åé áðïèçêåõôÝé ùò char(1), ôéìÝò: 0 (false), 1 "
+"(true)"
#: ../db/drivers/postgres/fetch.c:172
msgid "Cannot recognize boolean value"
-msgstr ""
+msgstr "Äåí ìðïñåß íá áíáãíùñéóôÞ ç ôéìÞ boolean"
#: ../db/drivers/ogr/describe.c:93
#, c-format
msgid "OGR driver: column '%s', OGR type %d is not supported"
-msgstr ""
+msgstr "OGR driver: óôÞëç '%s', OGR ôýðïò %d äåí õðïóôçñßæåôáé"
#: ../db/drivers/ogr/describe.c:153
#, c-format
@@ -485,174 +498,177 @@
"column '%s', type 'string': unknown width -> stored as varchar(250) some "
"data may be lost"
msgstr ""
+"óôÞëç '%s', ôýðïò 'string': Üãíùóôï åýñïò -> óùóìÝíï ùò varchar(250) ïñéóìÝíá "
+"äåäïìÝíá ìðïñåß íá ÷áèïýí"
#: ../db/drivers/ogr/describe.c:161 ../db/drivers/ogr/fetch.c:129
msgid "Unknown type"
-msgstr ""
+msgstr "¶ãíùóôïò ôýðïò"
#: ../raster3d/r3.in.ascii/main.c:79
msgid "Ascii raster map to be imported"
-msgstr ""
+msgstr "Ascii ñÜóôåñ ÷Üñôçò ðïõ èá åéóá÷èåß"
#: ../raster3d/r3.in.ascii/main.c:90
msgid "String representing NULL value data cell (use 'none' if no such value)"
-msgstr ""
+msgstr "Ï ÷áñáêôÞñáò áíôéðñïóùðåýåé NULL ôéìÞ äåäïìÝíùí êåëéïý (÷ñçóéìïðïéÞóôå 'none' áí äåí õðÜñ÷åé ôÝôïéá ôéìÞ)"
#: ../raster3d/r3.in.ascii/main.c:174
#, c-format
msgid "Loading data ... (%dx%dx%d)"
-msgstr ""
+msgstr "Öüñôùóç äåäïìÝíùí... (%dx%dx%d)"
#: ../raster3d/r3.in.ascii/main.c:190
msgid "End of file reached while still loading data."
-msgstr ""
+msgstr "¸öôáóå ôï ôÝëïò áñ÷åßïõ åíþ áêüìá öïñôþíïíôáé äåäïìÝíá"
#: ../raster3d/r3.in.ascii/main.c:209
#, c-format
-msgid ""
-"Data exists in input file after fully importing expected data. [%.4f ...]"
-msgstr ""
+msgid "Data exists in input file after fully importing expected data. [%.4f ...]"
+msgstr "Ôá äåäïìÝíá õðÜñ÷ïõí óôï áñ÷åßï åéóáãùãÞò ìåôÜ ôçí ðëÞñç åéóáãùãÞ ôùí áíáìåíþìåíùí áñ÷åßùí [%.4f ...]"
#: ../raster3d/r3.in.ascii/main.c:240
msgid "raster3d, voxel, import"
-msgstr ""
+msgstr "raster3d, voxel, åéóÜãåôáé"
#: ../raster3d/r3.in.ascii/main.c:242
msgid "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
-msgstr ""
+msgstr "ÌåôáôñïðÞ åíüò 3Ä ASCII ñÜóôåñ áñ÷åßïõ óå (binary) 3Ä ñÜóôåñ åðßðåäï"
#: ../raster3d/r3.in.ascii/main.c:268 ../raster3d/r3.out.ascii/main.c:268
#: ../raster3d/r3.in.v5d/main.c:215 ../raster3d/r3.out.v5d/main.c:315
#: ../raster/r.to.rast3elev/main.c:483 ../raster/r.to.rast3/main.c:309
msgid "Error opening 3d raster map"
-msgstr ""
+msgstr "ÓöÜëìá êáôÜ ôï Üíïéìá 3Ä ñÜóôåñ ÷Üñôç"
#: ../raster3d/r3.in.ascii/main.c:274
msgid "Error closing new 3d raster map"
-msgstr ""
+msgstr "ÓöÜëìá êáôÜ ôï êëåßóåéìï 3Ä ñÜóôåñ ÷Üñôç"
#: ../raster3d/r3.in.ascii/main.c:284
msgid "Error closing ascii file"
-msgstr ""
+msgstr "ÓöÜëìá êáôÜ ôï êëåßóïìï ascii áñ÷åßïõ"
#: ../raster3d/r3.out.ascii/main.c:58 ../raster3d/r3.out.ascii/main.c:300
#: ../raster3d/r3.in.v5d/main.c:220 ../raster3d/r3.out.v5d/main.c:329
#: ../raster3d/base/r3.info.main.c:421 ../raster3d/r3.to.rast/main.c:390
#: ../raster/r.to.rast3elev/main.c:546 ../raster/r.to.rast3/main.c:341
msgid "Error closing 3d raster map"
-msgstr ""
+msgstr "ÓöÜëìá êáôÜ ôï êëåßóéìï 3Ä ñÜóôåñ áñ÷åßïõ"
#: ../raster3d/r3.out.ascii/main.c:76
msgid "3d raster map to be converted to ASCII"
-msgstr ""
+msgstr "Ôï 3Ä ñÜóôåñ áñ÷åßï èá ìåôáôñáðåß óå ASCII"
#: ../raster3d/r3.out.ascii/main.c:83
msgid "Name for ASCII output file"
-msgstr ""
+msgstr "¼íïìá ôïõ ASCII åîáãþìåíïõ áñ÷åßïõ"
#: ../raster3d/r3.out.ascii/main.c:92
msgid "Number of decimal places for floats"
-msgstr ""
+msgstr "Áñéèìüò ôùí äåäáäéêþí øçößùí ãéá ôïõò áñéèìïýò õðïäéáóôïëÞò"
#: ../raster3d/r3.out.ascii/main.c:98 ../raster/r.transect/main.c:85
#: ../raster/r.what/main.c:117
msgid "Char string to represent no data cell"
-msgstr ""
+msgstr "Ôï óôïé÷åßï char áíôéðñïóùðåýåé êåëü ÷ùñßò äåäïìÝíá"
#: ../raster3d/r3.out.ascii/main.c:103 ../raster/r.out.ascii/main.c:104
#: ../raster/r.out.arc/main.c:88
msgid "Suppress printing of header information"
-msgstr ""
+msgstr "Áðïóéþðçóç åêôýðùóçò ðëçñïöïñéþí header"
#: ../raster3d/r3.out.ascii/main.c:107 ../raster3d/r3.to.rast/main.c:90
#: ../raster/r.to.rast3elev/main.c:232
msgid "Use G3D mask (if exists) with input map"
-msgstr ""
+msgstr "×ñçóéìïðïéÞóôå G3D mask (áí õðÜñ÷åé) ìå åéóáãþìåíï ÷Üñôç"
#: ../raster3d/r3.out.ascii/main.c:244
msgid "raster3d, voxel, export"
-msgstr ""
+msgstr "ñÜóôåñ 3D, voxel, åîáãùãÞ"
#: ../raster3d/r3.out.ascii/main.c:246
msgid "Converts a 3D raster map layer into an ASCII text file"
-msgstr ""
+msgstr "ÌåôáôñÝðåé Ýíá 3Ä åðßðåäï ñÜóôåñ ÷Üñôç óå Ýíá ASCII áñ÷åßï êåéìÝíïõ"
#: ../raster3d/r3.out.ascii/main.c:259 ../raster3d/r3.out.v5d/main.c:310
#: ../raster3d/base/r3.null.main.c:106 ../raster3d/base/r3.mask.main.c:78
msgid "Requested 3d raster map not found"
-msgstr ""
+msgstr "Ï æçôïýìåíïò 3Ä ñÜóôåñ ÷Üñôçò äåí âñÝèçêå"
#: ../raster3d/r3.out.ascii/main.c:305
msgid "Error closing new ASCII file"
-msgstr ""
+msgstr "ÓöÜëìá êáôÜ ôï êëåßóéìïõ íÝïõ ASCII áñ÷åßïõ"
#: ../raster3d/r3.stats/main.c:568 ../raster/r.univar2/r3.univar_main.c:79
msgid "raster3d, statistics"
-msgstr ""
+msgstr "ñÜóôåñ 3Ä, óôáôéóôéêÜ"
#: ../raster3d/r3.stats/main.c:569
msgid "Generates volume statistics for raster3d maps."
-msgstr ""
+msgstr "ÐáñÜãåé óôáôéóôéêÜ üãêïõ ãéá 3Ä ñÜóôåñ ÷Üñôåò."
#: ../raster3d/r3.stats/main.c:580
msgid "Number of sub-ranges to collect stats from"
-msgstr ""
+msgstr "Íïýìåñï ôùí õðïðåñéï÷þí ãéá óõëëïãÞ óôáôéóôéêþí áðü áõôÜ"
#: ../raster3d/r3.stats/main.c:586
msgid "Calculate statistics based on equal value groups"
-msgstr ""
+msgstr "Õðïëïãßæåé óôáôéóôéêÜ âáóéóìÝíá óå ßóçò ôéìÞò ãêñïõð"
#: ../raster3d/r3.stats/main.c:606
msgid "The number of subranges has to be equal or greater than 1"
-msgstr ""
+msgstr "Ï áñéèìüò ôùí õðïðåñéï÷þí ðñÝðåé íá åßíáé ìåãáëýôåñïò Þ ßóïò ôïõ 1"
#: ../raster3d/r3.stats/main.c:611 ../raster/r.univar2/r3.univar_main.c:104
#, c-format
+#, fuzzy
msgid "Requested g3d map <%s> not found"
-msgstr ""
+msgstr "Ï ÷Üñôçò g3d <%s> äåí âñÞèçêå"
#: ../raster3d/r3.stats/main.c:618 ../raster3d/r3.gwflow/main.c:371
#: ../raster/r.univar2/r3.univar_main.c:112
#, c-format
+#, fuzzy
msgid "Error opening g3d map <%s>"
-msgstr ""
+msgstr "ÓöÜëìá êáôÜ ôï Üíïéãìá ôïõ g3d ÷Üñôç <%s>"
#: ../raster3d/r3.stats/main.c:664
msgid "Sort non-null values"
-msgstr ""
+msgstr "ÓïñôÜñéóìá ìç êåíþí ôéìþí"
#: ../raster3d/r3.cross.rast/main.c:55
msgid "Could not close G3D map"
-msgstr ""
+msgstr "Äåí ãßíåôáé íá êëåßóåé ï G3Ä ÷Üñôçò"
#: ../raster3d/r3.cross.rast/main.c:77 ../raster3d/r3.cross.rast/main.c:392
#: ../raster3d/r3.to.rast/main.c:194
msgid "Unable to close output map"
-msgstr ""
+msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ åîáãüìåíïõ ÷Üñôç"
#: ../raster3d/r3.cross.rast/main.c:91
msgid "Input 3D raster map for cross section."
-msgstr ""
+msgstr "Ï 3Ä åéóáãþìåíïò ÷Üñôçò ãéá ôïìÞ"
#: ../raster3d/r3.cross.rast/main.c:98
msgid "2D elevation map used to create the cross section map"
-msgstr ""
+msgstr "2Ä õøïìåôñéêüò ÷Üñôçò ðïõ ÷ñçóéìïðïéÞèçêå ãéá ôçí ôïìÞ"
#: ../raster3d/r3.cross.rast/main.c:105
msgid "Resulting cross section 2D raster map"
-msgstr ""
+msgstr "Ôï áðïôÝëåóìá ôïìÞò 2Ä ñÜóôåñ ÷Üñôç"
#: ../raster3d/r3.cross.rast/main.c:110
msgid "Use g3d mask (if exists) with input map"
-msgstr ""
+msgstr "×ñçóéìïðïéÞóôå g3d ìÜóêá (áí õðÜñ÷åé) ìå ôïí ÷Üñôç"
#: ../raster3d/r3.cross.rast/main.c:162
msgid "Unable to get elevation raster row"
-msgstr ""
+msgstr "Áäõíáìßá ëÞøçò ãñáììÞò õøïìÝôñùí áðü ñÜóôåñ"
#: ../raster3d/r3.cross.rast/main.c:230 ../raster3d/r3.cross.rast/main.c:237
msgid "Could not write raster row"
-msgstr ""
+msgstr "Äåí Þôáí äõíáôÞ ç åããñáöÞ ãñáììÞò ñÜóôåñ"
#: ../raster3d/r3.cross.rast/main.c:270 ../raster3d/r3.in.v5d/main.c:193
#: ../raster3d/r3.mkdspf/main.c:75 ../raster3d/r3.out.v5d/main.c:289
@@ -661,105 +677,105 @@
#: ../raster3d/base/r3.timestamp.main.c:43 ../raster3d/r3.out.vtk/main.c:376
#: ../raster3d/r3.to.rast/main.c:215
msgid "raster3d, voxel"
-msgstr ""
+msgstr "ñÜóôåñ 3Ä, voxel"
#: ../raster3d/r3.cross.rast/main.c:272
msgid ""
"Creates cross section 2D raster map from 3d raster map based on 2D elevation "
"map"
-msgstr ""
+msgstr "Äçìéïõñãåß ôïìÞ 2Ä ñÜóôåñ ÷Üñôç áðü 3Ä ñÜóôåñ ÷Üñôç âáóéóìÝíï óôïí 2Ä ÷Üñôç õøïìÝôñùí"
#: ../raster3d/r3.cross.rast/main.c:284 ../raster3d/r3.to.rast/main.c:228
#: ../visualization/nviz2/cmd/volume.c:42
#, c-format
msgid "3d raster map <%s> not found"
-msgstr ""
+msgstr "Ï 3Ä ñÜóôåñ ÷Üñôçò <%s> äåí âñÝèçêå"
#: ../raster3d/r3.cross.rast/main.c:298 ../raster/r.to.rast3elev/main.c:462
#: ../raster/r.to.rast3/main.c:222
msgid ""
"The 2d and 3d region settings are different. I will use the g3d settings to "
"adjust the 2d region."
-msgstr ""
+msgstr "Ç 2Ä êáé 3Ä ñõèìßóåéò ðåñéï÷çò åßíáé äéáöïñåôéêÞ, èá ÷ñçóéìïðïéÞóù ôçí 3Ä ãéá íá ñõèìßóù ôçí 2Ä"
#: ../raster3d/r3.cross.rast/main.c:318 ../raster3d/r3.out.vtk/main.c:209
#: ../raster3d/r3.out.vtk/main.c:293 ../raster3d/r3.out.vtk/main.c:516
#: ../raster3d/r3.to.rast/main.c:243 ../raster3d/r3.to.rast/main.c:284
#, c-format
msgid "Error opening 3d raster map <%s>"
-msgstr ""
+msgstr "ÓöÜëìá áíïßãìáôïò 3Ä ñÜóôåñ ÷Üñôç <%s>"
#: ../raster3d/r3.cross.rast/main.c:333
msgid "Elevation map not found"
-msgstr ""
+msgstr "Ï ÷Üñôçò õøïìÝôñùí äåí âñÝèçêå"
#: ../raster3d/r3.cross.rast/main.c:338
msgid "Unable to open elevation map"
-msgstr ""
+msgstr "Áäõíáìßá áíïßãìáôïò ÷Üñôç õøïìÝôñùí"
#: ../raster3d/r3.cross.rast/main.c:349 ../raster3d/r3.to.rast/main.c:302
#: ../raster/r.to.rast3/main.c:239
msgid "Illegal output file name"
-msgstr ""
+msgstr "Ìç åðéôñåðôü üíïìá åîáãþìåíïõ ÷Üñôç"
#: ../raster3d/r3.cross.rast/main.c:352
msgid "Output map already exists. Will be overwritten!"
-msgstr ""
+msgstr "Ï åîáãþìåíïò ÷Üñôçò Þäç õðÜñ÷åé. Èá áíôéêáôáóôáèåß!"
#: ../raster3d/r3.cross.rast/main.c:358 ../raster3d/r3.cross.rast/main.c:364
msgid "Unable to create raster map"
-msgstr ""
+msgstr "Áäõíáìßá äçìéïõñãßáò ñÜóôåñ ÷Üñôç"
#: ../raster3d/r3.cross.rast/main.c:394
msgid "Unable to close elevation map"
-msgstr ""
+msgstr "Áäõíáìßá êëåéóßìáôïò ÷Üñôç õøïìÝôñùí"
#: ../raster3d/r3.cross.rast/main.c:399
msgid "Wrong G3D Datatype! Cannot create raster map."
-msgstr ""
+msgstr "ËÜèïò G3D ôýðïò! Äåí ìðïñåß íá äçìéïõñãçèåß ñÜóôåñ ÷Üñôçò."
#: ../raster3d/r3.cross.rast/main.c:404
#, c-format
msgid "Could not close G3D map <%s>"
-msgstr ""
+msgstr "Äåí ìðïñåß íá êëåßóåé ï G3D ÷Üñôçò <%s>"
#: ../raster3d/r3.mkdspf/main.c:77
msgid ""
"Creates a display file from an existing grid3 file according to specified "
"threshold levels."
-msgstr ""
+msgstr "Äçìéïõñãåß Ýíá áñ÷åßï ðáñïõóßáóçò áðü Ýíá õöéóôÜìåíï grid3 áñ÷åßï óýìöùíá ìå ôá äåäïìÝíá threshold levels."
#: ../raster3d/r3.mkdspf/main.c:85
msgid "Name of an existing 3d raster map"
-msgstr ""
+msgstr "¼íïìá õðÜñ÷ïíôùò 3Ä ñÜóôåñ ÷Üñôç"
#: ../raster3d/r3.mkdspf/main.c:91
msgid "Name of output display file"
-msgstr ""
+msgstr "¼íïìá åîáãþìåíïõ áñ÷åßïõ ðáñïõóßáóçò"
#: ../raster3d/r3.mkdspf/main.c:98
msgid "List of thresholds for isosurfaces"
-msgstr ""
+msgstr "Ëßóôá ôùí thresholds ãéá éóïåðéöÜíåéåò"
#: ../raster3d/r3.mkdspf/main.c:104
msgid "Minimum isosurface level"
-msgstr ""
+msgstr "ÅëÜ÷éóôï åðßðåäï éóïåðéöáíåéþí"
#: ../raster3d/r3.mkdspf/main.c:110
msgid "Maximum isosurface level"
-msgstr ""
+msgstr "ÌÝãéóôï åðßðåäï éóïåðéöáíåéþí"
#: ../raster3d/r3.mkdspf/main.c:116
msgid "Positive increment between isosurface levels"
-msgstr ""
+msgstr "Èåôéêü âÞìá ìåôáîý éóïåðéöáíåéþí"
#: ../raster3d/r3.mkdspf/main.c:123
msgid "Number of isosurface threshold levels"
-msgstr ""
+msgstr "Áñéèìüò åðéðÝäùí threshold éóïåðéöáíåéþí"
#: ../raster3d/r3.mkdspf/main.c:127
msgid "Suppress progress report & min/max information"
-msgstr ""
+msgstr "Åëá÷éóôïðïßçóç ôçò ðñïüäïõ áðïôåëåóìÜôùí & ìÝãéóôï/åëÜ÷éóôï ðëçñïöïñéþí"
#: ../raster3d/r3.mkdspf/main.c:131
msgid "Use flat shading rather than gradient"
@@ -768,51 +784,51 @@
#: ../raster3d/r3.mkdspf/main.c:139
#, c-format
msgid "Region from getWindow: %d %d %d"
-msgstr ""
+msgstr "Ðåñéï÷Þ áðü getWindow: %d %d %d"
#: ../raster3d/r3.mkdspf/main.c:151
#, c-format
msgid "Not able to find grid3 file for [%s]"
-msgstr ""
+msgstr "Äåí Þôáí äõíáôÞ ç åýñåóç grid3 áñ÷åßïõ ãéá [%s]"
#: ../raster3d/r3.mkdspf/main.c:163 ../raster3d/base/r3.info.main.c:128
#, c-format
msgid "Error opening grid3 file [%s]"
-msgstr ""
+msgstr "ÓöÜëìá êáôÜ ôï Üíïéãìá ôïõ áñ÷åßïõ grid3 [%s]"
#: ../raster3d/r3.mkdspf/main.c:166 ../raster3d/base/r3.info.main.c:287
#: ../raster3d/base/r3.info.main.c:349
#, c-format
msgid "Error reading range for [%s]"
-msgstr ""
+msgstr "ÓöÜëìá êáôÜ ôçí áíÜãíùóç ôïõ åýñïõò ãéá [%s]"
#: ../raster3d/r3.mkdspf/main.c:195
#, c-format
msgid "Error opening display file [%s]"
-msgstr ""
+msgstr "ÓöÜëìá êáôÜ ôï Üíïéãìá ôïõ áñ÷åßïõ ðáñïõóßáóçò [%s]"
#: ../raster3d/r3.mkdspf/main.c:216
#, c-format
msgid "Writing %s from %s..."
-msgstr ""
+msgstr "ÅããñáöÞ %s áðü %s..."
#: ../raster3d/r3.out.v5d/main.c:72
msgid "3d raster map to be converted to Vis5d (v5d) file"
-msgstr ""
+msgstr "3Ä ñÜóôåñ ÷Üñôçò èá ìåôáôñáðåß óå áñ÷åßï Vis5d (v5d)"
#: ../raster3d/r3.out.v5d/main.c:79
msgid "Name for v5d output file"
-msgstr ""
+msgstr "¼íïìá ãéá ôï åîáãþìåíï v5d áñ÷åßï"
#: ../raster3d/r3.out.v5d/main.c:149
#, c-format
msgid "Viz5D allows %d cols, you have %d cols"
-msgstr ""
+msgstr "Viz5D åðéôñÝðåé %d cols, Ý÷åôå %d cols"
#: ../raster3d/r3.out.v5d/main.c:152
#, c-format
msgid "Viz5D allows %d rows, you have %d rows"
-msgstr ""
+msgstr "Viz5D allows %d ãñáììÝò, Ý÷åôå %d ãñáììÝò"
#: ../raster3d/r3.out.v5d/main.c:202 ../raster3d/r3.to.rast/main.c:299
#: ../raster/r.li/r.li.daemon/list.c:47 ../raster/r.gwflow/main.c:380
@@ -832,77 +848,76 @@
#: ../vector/v.surf.rst/main.c:838 ../vector/v.mapcalc/list.c:54
#: ../vector/v.mapcalc/list.c:501 ../imagery/i.ask/popup.c:174
msgid "Out of memory"
-msgstr ""
+msgstr "Åêôüò ìíÞìçò"
#: ../raster3d/r3.out.v5d/main.c:262
#, c-format
msgid "Error: couldn't create %s"
-msgstr ""
+msgstr "ÓöÜëìá: äåí Þôáí äõíáôÞ ç äçìéïõñãßá %s"
#: ../raster3d/r3.out.v5d/main.c:267
msgid "Error while writing grid. Disk full?"
-msgstr ""
+msgstr "ÓöÜëìá êáôÜ ôçí åããñáöÞ ôïõ grid. Äßóêïò ãåìÜôïò;"
#: ../raster3d/r3.out.v5d/main.c:291
msgid "Export of GRASS 3D raster map to 3-dimensional Vis5D file."
-msgstr ""
+msgstr "ÅîáãùãÞ ôïõ GRASS 3Ä ñÜóôåñ ÷Üñôç óå 3 äéÜóôáôï Vis5D áñ÷åßï"
#: ../raster3d/r3.out.v5d/main.c:298
msgid "Use map coordinates instead of xyz coordinates"
-msgstr ""
+msgstr "×ñçóéìïðïéÞóôå óõíôåôáãìÝíåò ÷Üñôç áíôß ÷øæ óõíôåôáãìÝíåò"
#: ../raster3d/r3.gwflow/main.c:55 ../raster/r.gwflow/main.c:58
msgid "The initial piezometric head in [m]"
-msgstr ""
+msgstr "Ç áñ÷éêÞ ðéåæïìåôñéêÞ óôÞëç óå [m]"
#: ../raster3d/r3.gwflow/main.c:63
msgid "The status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
-msgstr ""
+msgstr "Ç êáôÜóôáóç êÜèå êåëéïý, = 0 - inactive, 1 - active, 2 - dirichlet"
#: ../raster3d/r3.gwflow/main.c:71
msgid "The x-part of the hydraulic conductivity tensor in [m/s]"
-msgstr ""
+msgstr "Ôï x-ìÝñïò ôçò õäñáõëéêÞò áãùãéìüôçôáò óå [m/s]"
#: ../raster3d/r3.gwflow/main.c:79
msgid "The y-part of the hydraulic conductivity tensor in [m/s]"
-msgstr ""
+msgstr "Ôï y-ìÝñïò ôçò õäñáõëéêÞò áãùãéìüôçôáò óå [m/s]"
#: ../raster3d/r3.gwflow/main.c:87
msgid "The z-part of the hydraulic conductivity tensor in [m/s]"
-msgstr ""
+msgstr "Ôï z-ìÝñïò ôçò õäñáõëéêÞò áãùãéìüôçôáò óå [m/s]"
#: ../raster3d/r3.gwflow/main.c:94
msgid "Sources and sinks in [m^3/s]"
-msgstr ""
+msgstr "Sources and sinks in [m^3/s]"
#: ../raster3d/r3.gwflow/main.c:101
msgid "Specific yield in 1/m"
-msgstr ""
+msgstr "Specific yield in 1/m"
#: ../raster3d/r3.gwflow/main.c:108
msgid "Recharge raster map in m^3/s"
-msgstr ""
+msgstr "×Üñôçò åðáíáöüñôéóçò óå m^3/s"
#: ../raster3d/r3.gwflow/main.c:116
msgid ""
"The piezometric head result of the numerical calculation will be written to "
"this map"
-msgstr ""
+msgstr "Ç ðéåæïìåôñéêÞ óôÞëç, áðïôÝëåóìá ôùí áñéèìçôéêþí õðïëïãéóìþí èá ãñáöôåß óå áõôü ôï ÷Üñôç"
#: ../raster3d/r3.gwflow/main.c:124
msgid ""
"Calculate the groundwater distance velocity vector field and write the x, y, "
"and z components to maps named name_[xyz]. Name is basename for the new "
"raster3d maps"
-msgstr ""
+msgstr "Õðïëïãßóôå ôçí ôá÷ýôçôá ôïõ õðïãåéïõ íåñïý (äéáíõóìáôéêü ìåñïò) êáé ãñÜøôå ôá ÷ , ø êáé æ óôïé÷åßá óôï ÷Üñôç ìå üíïìá name_[xyz]. Ôï üíïìá åßíáé ôï âáóéêü üíïìá ãéá ôïõò íÝïõò ñÜóôåñ 3Ä ÷Üñôåò"
#: ../raster3d/r3.gwflow/main.c:135
msgid "Use G3D mask (if exists)"
-msgstr ""
+msgstr "×ñçóéìïðïéÞóôå G3D ìÜóêá (åÜí õðÜñ÷åé)"
#: ../raster3d/r3.gwflow/main.c:140
-msgid ""
-"Use a sparse linear equation system, only available with iterative solvers"
+msgid "Use a sparse linear equation system, only available with iterative solvers"
msgstr ""
#: ../raster3d/r3.gwflow/main.c:170
@@ -933,8 +948,9 @@
msgstr ""
#: ../raster3d/r3.gwflow/main.c:417
+#, fuzzy
msgid "Error closing g3d file"
-msgstr ""
+msgstr "ÓöÜëìá êáôÜ ôï êëåßóéìï ôïõ g3d áñ÷åßïõ"
#: ../raster3d/base/r3.null.main.c:58
msgid "3d raster map for which to modify null values"
@@ -1106,8 +1122,9 @@
#: ../general/g.region/main.c:450 ../general/g.region/main.c:793
#: ../general/g.region/main.c:801 ../general/g.mremove/do_remove.c:50
#, c-format
+#, fuzzy
msgid "Raster map <%s> not found"
-msgstr ""
+msgstr "Ï ÷Üñôçò raster <%s> äåí âñÝèçêå"
#: ../raster3d/base/r3.info.main.c:158 ../raster3d/base/r3.info.main.c:166
#: ../raster3d/base/r3.info.main.c:172 ../raster3d/base/r3.info.main.c:177
@@ -1189,8 +1206,9 @@
msgstr ""
#: ../raster3d/base/r3.timestamp.main.c:59 ../raster/r.timestamp/main.c:45
+#, fuzzy
msgid "Datetime, datetime1/datetime2, or none"
-msgstr ""
+msgstr "êáíÝíá"
#: ../raster3d/base/r3.timestamp.main.c:74
#, c-format
@@ -1248,8 +1266,7 @@
msgstr ""
#: ../raster3d/r3.out.vtk/parameters.c:82
-msgid ""
-"Three (r,g,b) 3d raster maps to create rgb values [redmap,greenmap,bluemap]"
+msgid "Three (r,g,b) 3d raster maps to create rgb values [redmap,greenmap,bluemap]"
msgstr ""
#: ../raster3d/r3.out.vtk/parameters.c:92
@@ -1468,8 +1485,9 @@
#: ../imagery/i.his.rgb/openfiles.c:17 ../imagery/i.his.rgb/openfiles.c:19
#: ../imagery/i.smap/shapiro/opencell.c:30 ../imagery/i.pca/main.c:392
#, c-format
+#, fuzzy
msgid "Unable to create raster map <%s>"
-msgstr ""
+msgstr "Áäõíáìßá äçìéïõñãßáò raster ÷Üñôç <%s>"
#: ../raster3d/r3.to.rast/main.c:216
msgid "Converts 3D raster maps to 2D raster maps"
@@ -1588,8 +1606,9 @@
#: ../raster/r.cross/main.c:89 ../raster/r.series/main.c:150
#: ../raster/r.buffer/main.c:91 ../imagery/i.smap/shapiro/parse.c:42
#: ../imagery/i.maxlik/main.c:89
+#, fuzzy
msgid "Run quietly"
-msgstr ""
+msgstr "ÔñÝ÷åé ÷ùñßò ìçíýìáôá"
#: ../raster/r.describe/main.c:115 ../raster/r.rescale.eq/main.c:107
#: ../raster/r.coin/cmd_parms.c:88 ../raster/r.out.png/r.out.png.c:146
@@ -1748,8 +1767,9 @@
#: ../display/d.his/main.c:141 ../display/d.his/main.c:164
#: ../display/d.nviz/main.c:186
#, c-format
+#, fuzzy
msgid "Unable to open raster map <%s>"
-msgstr ""
+msgstr "Áäõíáìßá áíïßãìáôïò ôïõ ÷Üñôç raster <%s>"
#: ../raster/r.resamp.stats/main.c:374 ../raster/r.resamp.interp/main.c:320
#: ../raster/r.colors/main.c:365
@@ -2060,8 +2080,9 @@
msgstr ""
#: ../raster/r.proj.seg/readcell.c:56
+#, fuzzy
msgid "Unable to open temporary file"
-msgstr ""
+msgstr "Áäõíáìßá áíïßãìáôïò ðñïóùñéíïý áñ÷åßïõ"
#: ../raster/r.proj.seg/readcell.c:62 ../raster/r.proj/readcell.c:22
msgid "Allocating memory and reading input map..."
@@ -2101,8 +2122,7 @@
msgstr ""
#: ../raster/r.coin/inter.c:36
-msgid ""
-"This utility will allow you to compare the coincidence of two map layers\n"
+msgid "This utility will allow you to compare the coincidence of two map layers\n"
msgstr ""
#: ../raster/r.coin/inter.c:53
@@ -2170,8 +2190,7 @@
#: ../raster/r.coin/inter.c:118
#, c-format
-msgid ""
-"Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
+msgid "Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
msgstr ""
#: ../raster/r.coin/inter.c:127
@@ -2183,8 +2202,7 @@
#: ../raster/r.coin/inter.c:143
#, c-format
-msgid ""
-"Do you wish to run this report with a different unit of measure? (y/n) [y] "
+msgid "Do you wish to run this report with a different unit of measure? (y/n) [y] "
msgstr ""
#: ../raster/r.coin/print_coin.c:44
@@ -2329,8 +2347,9 @@
#: ../swig/perl/R_slope_aspect/r_slope_aspect/opennew.c:11
#: ../general/manage/cmd/rename.c:84 ../general/manage/cmd/copy.c:88
#, c-format
+#, fuzzy
msgid "<%s> is an illegal file name"
-msgstr ""
+msgstr "<%s> åßíáé ìç åðéôñåðôü üíïìá áñ÷åßïõ"
#: ../raster/r.surf.fractal/interface.c:98
#, c-format
@@ -2504,8 +2523,7 @@
msgstr ""
#: ../raster/r.los/main.c:243
-msgid ""
-"Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
+msgid "Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
msgstr ""
#: ../raster/r.los/main.c:248
@@ -2627,8 +2645,9 @@
#: ../display/d.path/main.c:193 ../general/g.region/main.c:518
#: ../general/g.mremove/do_remove.c:34
#, c-format
+#, fuzzy
msgid "Vector map <%s> not found"
-msgstr ""
+msgstr "Ï äéáíõóìáôéêüò ÷Üñôçò <%s> äåí âñÝèçêå"
#: ../raster/r.drain/main.c:221
msgid "Failed to guess site file format"
@@ -2715,8 +2734,7 @@
msgstr ""
#: ../raster/r.in.ascii/main.c:74
-msgid ""
-"ASCII raster file to be imported. If not given reads from standard input"
+msgid "ASCII raster file to be imported. If not given reads from standard input"
msgstr ""
#: ../raster/r.in.ascii/main.c:85 ../raster/r.in.bin/main.c:166
@@ -2914,8 +2932,9 @@
msgstr ""
#: ../raster/r.carve/main.c:101
+#, fuzzy
msgid "Stream width (in meters). Default is raster cell width"
-msgstr ""
+msgstr "ÐñïåðéëïãÞ"
#: ../raster/r.carve/main.c:107
msgid "Additional stream depth (in meters)"
@@ -2944,8 +2963,7 @@
msgstr ""
#: ../raster/r.carve/enforce_ds.c:173
-msgid ""
-"Vect runs out of region and re-enters - this case is not yet implemented."
+msgid "Vect runs out of region and re-enters - this case is not yet implemented."
msgstr ""
#: ../raster/r.profile/input.c:29 ../raster/r.profile/input.c:46
@@ -3010,8 +3028,9 @@
msgstr ""
#: ../raster/r.profile/main.c:183
+#, fuzzy
msgid " [RGB Color]"
-msgstr ""
+msgstr "×ñþìá"
#: ../raster/r.profile/main.c:193
#, c-format
@@ -3300,8 +3319,7 @@
msgstr ""
#: ../raster/r.sun/main.c:236
-msgid ""
-"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
+msgid "Name of the Linke atmospheric turbidity coefficient input raster map [-]"
msgstr ""
#: ../raster/r.sun/main.c:247
@@ -3687,8 +3705,9 @@
msgstr ""
#: ../raster/r.lake/main.c:277
+#, fuzzy
msgid "G_malloc: out of memory"
-msgstr ""
+msgstr "G_malloc: åêôüò ìíÞìçò"
#: ../raster/r.lake/main.c:303
msgid ""
@@ -3717,8 +3736,9 @@
#: ../raster/r.lake/main.c:407
#, c-format
+#, fuzzy
msgid "Unable to read color file of raster map <%s>"
-msgstr ""
+msgstr "Áäõíáìßá áíÜãíùóçò áñ÷åßïõ ÷ñþìáôïò ãéá ôïí ñÜóôåñ ÷Üñôç <%s>"
#: ../raster/r.out.gdal/main.c:48
#, c-format
@@ -3802,8 +3822,7 @@
msgstr ""
#: ../raster/r.out.gdal/main.c:445
-msgid ""
-"Creation option to the output format driver. Multiple options may be listed."
+msgid "Creation option to the output format driver. Multiple options may be listed."
msgstr ""
#: ../raster/r.out.gdal/main.c:453
@@ -4129,8 +4148,7 @@
msgstr ""
#: ../raster/r.surf.idw2/main.c:80
-msgid ""
-"Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
+msgid "Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
msgstr ""
#: ../raster/r.surf.idw2/main.c:87 ../vector/v.surf.idw/main.c:135
@@ -4158,8 +4176,7 @@
msgstr ""
#: ../raster/r.transect/main.c:56
-msgid ""
-"Outputs raster map layer values lying along user defined transect line(s)."
+msgid "Outputs raster map layer values lying along user defined transect line(s)."
msgstr ""
#: ../raster/r.transect/main.c:60
@@ -4304,8 +4321,9 @@
#: ../raster/simwe/r.sim.water/main.c:270
#: ../raster/simwe/r.sim.water/main.c:278
#: ../raster/simwe/r.sim.water/main.c:287
+#, fuzzy
msgid "Parameters"
-msgstr ""
+msgstr "ÐáñÜìåôñïé"
#: ../raster/simwe/r.sim.sediment/main.c:221
#: ../raster/simwe/r.sim.water/main.c:235
@@ -4630,8 +4648,9 @@
msgstr ""
#: ../raster/r.to.rast3elev/main.c:171 ../raster/r.to.rast3/main.c:378
+#, fuzzy
msgid "Unable to close input map"
-msgstr ""
+msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ ÷Üñôç input"
#: ../raster/r.to.rast3elev/main.c:183 ../raster/r.to.rast3/main.c:58
msgid "Could not close the map"
@@ -5195,8 +5214,7 @@
msgstr ""
#: ../raster/r.li/r.li.patchnum/main.c:33
-msgid ""
-"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
msgstr ""
#: ../raster/r.li/r.li.padrange/padrange.c:39
@@ -5226,8 +5244,7 @@
msgstr ""
#: ../raster/r.li/r.li.patchdensity/main.c:32
-msgid ""
-"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
msgstr ""
#: ../raster/r.li/r.li.mps/mps.c:40
@@ -5421,8 +5438,7 @@
msgstr ""
#: ../raster/r.li/r.li.edgedensity/edgedensity.c:38
-msgid ""
-"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
msgstr ""
#: ../raster/r.li/r.li.shannon/shannon.c:38
@@ -5591,8 +5607,9 @@
#: ../vector/v.voronoi/dt_main.c:92 ../vector/v.voronoi/dt_main.c:98
#: ../vector/v.voronoi/vo_main.c:164 ../doc/vector/v.example/main.c:96
#, c-format
+#, fuzzy
msgid "Unable to create vector map <%s>"
-msgstr ""
+msgstr "Áäõíáìßá äçìéïõñãßáò äéáíõóìáôéêïý ÷Üñôç <%s>"
#: ../raster/r.flow/io.c:197
msgid "Cannot reset current region"
@@ -6107,12 +6124,14 @@
#: ../raster/r.random/main.c:57 ../raster/r.resamp.rst/main.c:167
#: ../raster/r.out.bin/main.c:73 ../raster/r.water.outlet/main.c:54
#: ../imagery/i.zc/main.c:69
+#, fuzzy
msgid "Name of input raster map"
-msgstr ""
+msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç "
#: ../raster/r.random/main.c:62 ../raster/r.median/main.c:58
+#, fuzzy
msgid "Name of cover raster map"
-msgstr ""
+msgstr "¼íïìá åéóáãþìåíùí ñÜóôåñ ÷áñôþí"
#: ../raster/r.random/main.c:69
msgid "The number of points to allocate"
@@ -6277,8 +6296,9 @@
msgstr ""
#: ../raster/r.sunmask/main.c:137
+#, fuzzy
msgid "Name of elevation raster map"
-msgstr ""
+msgstr "¼íïìá ñÜóôåñ ÷Üñôç õøïìÝôñïõ"
#: ../raster/r.sunmask/main.c:145
msgid "Output raster map having shadows"
@@ -6544,8 +6564,9 @@
#: ../display/d.rgb/main.c:111 ../display/d.his/main.c:152
#: ../display/d.his/main.c:171 ../display/d.his/main.c:196
#, c-format
+#, fuzzy
msgid "Color file for <%s> not available"
-msgstr ""
+msgstr "×ñþìá"
#: ../raster/r.his/main.c:243
msgid "Error reading 'hue' map"
@@ -6596,8 +6617,9 @@
msgstr ""
#: ../raster/r.topmodel/main.c:122
+#, fuzzy
msgid "(i) TOPMODEL Parameters file"
-msgstr ""
#: ../raster/r.topmodel/main.c:129
msgid "(i) Rainfall and potential evapotranspiration data file"
@@ -6710,8 +6732,9 @@
msgstr ""
#: ../raster/r.median/main.c:54
+#, fuzzy
msgid "Name of base raster map"
-msgstr ""
+msgstr "¼íïìá ÷Üñôç õðïâÜèñïõ ñÜóôåñ"
#: ../raster/r.median/main.c:71
#, c-format
@@ -6990,8 +7013,9 @@
#: ../raster/r.stats/main.c:197
#, c-format
+#, fuzzy
msgid "Unable to open file <%s> for writing"
-msgstr ""
+msgstr "Áäõíáìßá áíïßãìáôïò áñ÷åßïõ <%s> ãéá åããñáöÞ"
#: ../raster/r.stats/main.c:203
#, c-format
@@ -7025,8 +7049,9 @@
#: ../raster/r.stats/main.c:304
#, c-format
+#, fuzzy
msgid "Unable to read fp range of raster map <%s>"
-msgstr ""
+msgstr "Áäõíáìßá äéáâÜóìáôïò åýñïõò fp ãéá ôïí ñáóôåñ ÷Üñôç <%s>"
#: ../raster/r.stats/main.c:324 ../raster/r.recode/read_rules.c:34
#, c-format
@@ -7154,8 +7179,7 @@
msgstr ""
#: ../raster/r.in.xyz/main.c:474
-msgid ""
-"If input is not from a file it is only possible to perform a single pass."
+msgid "If input is not from a file it is only possible to perform a single pass."
msgstr ""
#: ../raster/r.in.xyz/main.c:480
@@ -7245,8 +7269,9 @@
#: ../raster/r.slope.aspect/main.c:193
#: ../swig/perl/R_slope_aspect/r_slope_aspect/r_slope_aspect.c:198
+#, fuzzy
msgid "Type of output aspect and slope maps"
-msgstr ""
+msgstr "Ôýðïò"
#: ../raster/r.slope.aspect/main.c:203
msgid "Name for output profile curvature raster map"
@@ -7278,13 +7303,11 @@
msgstr ""
#: ../raster/r.slope.aspect/main.c:223
-msgid ""
-"Name for output first order partial derivative dx (E-W slope) raster map"
+msgid "Name for output first order partial derivative dx (E-W slope) raster map"
msgstr ""
#: ../raster/r.slope.aspect/main.c:233
-msgid ""
-"Name for output first order partial derivative dy (N-S slope) raster map"
+msgid "Name for output first order partial derivative dy (N-S slope) raster map"
msgstr ""
#: ../raster/r.slope.aspect/main.c:243
@@ -7431,8 +7454,9 @@
msgstr ""
#: ../raster/r.colors/main.c:181
+#, fuzzy
msgid "Type of color table"
-msgstr ""
+msgstr "Ôýðïò"
#: ../raster/r.colors/main.c:183 ../raster/r.colors/main.c:197
#: ../raster/r.colors/main.c:215 ../raster/r.colors/main.c:220
@@ -7539,8 +7563,9 @@
#: ../raster/r.colors/main.c:390
#, c-format
+#, fuzzy
msgid "Color table for <%s> set to %s"
-msgstr ""
+msgstr "×ñþìá"
#: ../raster/r.colors/rules.c:42
#, c-format
@@ -7596,8 +7621,9 @@
#: ../raster/r.colors/rules.c:136
#, c-format
+#, fuzzy
msgid "bad rule (%s): [%s]"
-msgstr ""
+msgstr "ÅóöáëìÝíïò êáíüíáò (%s): [%s]"
#: ../raster/r.out.ppm/main.c:56
msgid ""
@@ -8132,13 +8158,11 @@
msgstr ""
#: ../raster/r.out.vtk/parameters.c:66
-msgid ""
-"Create VTK point data instead of VTK cell data (if no elevation map is given)"
+msgid "Create VTK point data instead of VTK cell data (if no elevation map is given)"
msgstr ""
#: ../raster/r.out.vtk/parameters.c:76
-msgid ""
-"Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
+msgid "Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
msgstr ""
#: ../raster/r.out.vtk/parameters.c:86
@@ -8154,8 +8178,7 @@
msgstr ""
#: ../raster/r.out.vtk/parameters.c:123
-msgid ""
-"Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
+msgid "Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
msgstr ""
#: ../raster/r.out.vtk/parameters.c:129
@@ -8256,8 +8279,7 @@
msgstr ""
#: ../raster/r.out.vtk/main.c:381
-msgid ""
-"Wrong vector maps. Maps should have the same type! Vector output not added!"
+msgid "Wrong vector maps. Maps should have the same type! Vector output not added!"
msgstr ""
#: ../raster/r.support/modcolr/modcolr.c:38
@@ -8266,8 +8288,9 @@
#: ../raster/r.support/modcolr/modcolr.c:53
#, c-format
+#, fuzzy
msgid "Color table for <%s> updated"
-msgstr ""
+msgstr "×ñþìá"
#: ../raster/r.support/modhead/modhead.c:70
#, c-format
@@ -8862,8 +8885,9 @@
msgstr ""
#: ../raster/r.in.gridatb/main.c:53
+#, fuzzy
msgid "Name for output raster map"
-msgstr ""
+msgstr "¼íïìá åîáãüìåíïõ ñÜóôåñ ÷Üñôç"
#: ../raster/r.in.gridatb/main.c:67
#, c-format
@@ -8970,8 +8994,9 @@
#: ../ps/ps.map/catval.c:54 ../ps/ps.map/catval.c:116
#: ../ps/ps.map/catval.c:182
#, c-format
+#, fuzzy
msgid "Unable to open database <%s> by driver <%s>"
-msgstr ""
+msgstr "Áäõíáìßá áíïßãìáôïò ôçò âÜóçò äåäïìÝíùí <%s> ìå ôïí ïäçãü <%s>"
#: ../raster/r.to.vect/main.c:192 ../raster/r.contour/main.c:195
#: ../vector/v.in.dxf/write_vect.c:207 ../vector/lidar/lidarlib/raster.c:84
@@ -9336,8 +9361,7 @@
msgstr ""
#: ../raster/r.univar2/r.univar_main.c:77
-msgid ""
-"Calculates univariate statistics from the non-null cells of a raster map."
+msgid "Calculates univariate statistics from the non-null cells of a raster map."
msgstr ""
#: ../raster/r.univar2/r.univar_main.c:121
@@ -9561,18 +9585,15 @@
msgstr ""
#: ../raster/r.watershed/shed/com_line.c:81
-msgid ""
-"depression map indicates all the locations in the current map window where"
+msgid "depression map indicates all the locations in the current map window where"
msgstr ""
#: ../raster/r.watershed/shed/com_line.c:82
-msgid ""
-"water accumulates and does not leave by the edge of the map. Lakes without"
+msgid "water accumulates and does not leave by the edge of the map. Lakes without"
msgstr ""
#: ../raster/r.watershed/shed/com_line.c:83
-msgid ""
-"outlet streams and sinkholes are examples of `depressions'. If you wish to"
+msgid "outlet streams and sinkholes are examples of `depressions'. If you wish to"
msgstr ""
#: ../raster/r.watershed/shed/com_line.c:84
@@ -9584,8 +9605,7 @@
msgstr ""
#: ../raster/r.watershed/shed/com_line.c:86
-msgid ""
-"Hit <return> by itself for the next question if there is no depression map."
+msgid "Hit <return> by itself for the next question if there is no depression map."
msgstr ""
#: ../raster/r.watershed/shed/com_line.c:97
@@ -9596,8 +9616,7 @@
msgstr ""
#: ../raster/r.watershed/shed/com_line.c:99
-msgid ""
-"watershed basins. The number of watershed basins is indirectly determined"
+msgid "watershed basins. The number of watershed basins is indirectly determined"
msgstr ""
#: ../raster/r.watershed/shed/com_line.c:100
@@ -9612,18 +9631,15 @@
msgstr ""
#: ../raster/r.watershed/shed/com_line.c:103
-msgid ""
-"`exterior drainage basins'. An exterior drainage basin does not have any"
+msgid "`exterior drainage basins'. An exterior drainage basin does not have any"
msgstr ""
#: ../raster/r.watershed/shed/com_line.c:104
-msgid ""
-"drainage basins flowing into it. Interior drainage basin size is determined"
+msgid "drainage basins flowing into it. Interior drainage basin size is determined"
msgstr ""
#: ../raster/r.watershed/shed/com_line.c:105
-msgid ""
-"by the surface flow going into stream segments between stream interceptions."
+msgid "by the surface flow going into stream segments between stream interceptions."
msgstr ""
#: ../raster/r.watershed/shed/com_line.c:106
@@ -9636,18 +9652,15 @@
msgstr ""
#: ../raster/r.watershed/shed/com_line.c:109
-msgid ""
-"(i.e., areas with low infiltration capacities will need smaller areas to"
+msgid "(i.e., areas with low infiltration capacities will need smaller areas to"
msgstr ""
#: ../raster/r.watershed/shed/com_line.c:110
-msgid ""
-"develop stream channels than neighboring areas with high infiltration rates)."
+msgid "develop stream channels than neighboring areas with high infiltration rates)."
msgstr ""
#: ../raster/r.watershed/shed/com_line.c:111
-msgid ""
-"The user can create a map layer with potential overland flow values, and"
+msgid "The user can create a map layer with potential overland flow values, and"
msgstr ""
#: ../raster/r.watershed/shed/com_line.c:112
@@ -9753,8 +9766,7 @@
msgstr ""
#: ../raster/r.watershed/shed/com_line.c:293
-msgid ""
-"ability to generate several variables in the Revised Universal Soil Loss"
+msgid "ability to generate several variables in the Revised Universal Soil Loss"
msgstr ""
#: ../raster/r.watershed/shed/com_line.c:294
@@ -9779,8 +9791,9 @@
msgstr ""
#: ../raster/r.watershed/shed/com_line.c:349
+#, fuzzy
msgid "Type <return> if you do not have a disturbed land map layer."
-msgstr ""
+msgstr "Ôýðïò<return>."
#: ../raster/r.watershed/shed/com_line.c:361
msgid ""
@@ -9816,8 +9829,7 @@
msgstr ""
#: ../raster/r.watershed/shed/com_line.c:381
-msgid ""
-"that prevents the surface flow distance from getting too long. Normally,"
+msgid "that prevents the surface flow distance from getting too long. Normally,"
msgstr ""
#: ../raster/r.watershed/shed/com_line.c:382
@@ -9831,8 +9843,7 @@
msgstr ""
#: ../raster/r.watershed/shed/com_line.c:398
-msgid ""
-"slope length. You may input a raster map indicating the locations of these"
+msgid "slope length. You may input a raster map indicating the locations of these"
msgstr ""
#: ../raster/r.watershed/shed/com_line.c:399
@@ -9840,8 +9851,7 @@
msgstr ""
#: ../raster/r.watershed/shed/com_line.c:400
-msgid ""
-"Hit <return> by itself for the next question if there is no blocking map."
+msgid "Hit <return> by itself for the next question if there is no blocking map."
msgstr ""
#: ../raster/r.watershed/shed/file_in.c:15
@@ -10173,8 +10183,7 @@
msgstr ""
#: ../raster/r.contour/main.c:92
-msgid ""
-"Produces a vector map layer of specified contours from a raster map layer."
+msgid "Produces a vector map layer of specified contours from a raster map layer."
msgstr ""
#: ../raster/r.contour/main.c:104
@@ -10317,8 +10326,9 @@
msgstr ""
#: ../raster/r.cats/main.c:91
+#, fuzzy
msgid "Default label or format string for dynamic labeling"
-msgstr ""
#: ../raster/r.cats/main.c:93
msgid "Used when no explicit label exists for the category"
@@ -10468,10 +10478,11 @@
msgstr ""
#: ../raster/r.out.tiff/r.out.tiff.c:183
+#, fuzzy
msgid ""
"Color map for palette must have less than 256 colors for the available range "
"of data"
-msgstr ""
+msgstr "×ñþìá"
#: ../raster/r.out.tiff/r.out.tiff.c:198
#, c-format
@@ -10520,8 +10531,9 @@
msgstr ""
#: ../raster/r.out.mpeg/main.c:406
+#, fuzzy
msgid "Name for output file"
-msgstr ""
+msgstr "¼íïìá áñ÷åßïõ åîáãùãÞò"
#: ../raster/r.out.mpeg/main.c:416
msgid "Quality factor (1 = highest quality, lowest compression)"
@@ -10841,8 +10853,9 @@
#: ../raster/r.mapcalc/map.c:442
#, c-format
+#, fuzzy
msgid "Unable to open raster map <%s@%s>"
-msgstr ""
+msgstr "Áäõíáìßá áíïßãìáôïò ôïõ ÷Üñôç raster <%s@%s>"
#: ../raster/r.mapcalc/map.c:515
msgid "Failed writing raster map row"
@@ -10947,8 +10960,7 @@
msgstr ""
#: ../raster/r.composite/main.c:74
-msgid ""
-"Combines red, green and blue map layers into a single composite raster map."
+msgid "Combines red, green and blue map layers into a single composite raster map."
msgstr ""
#: ../raster/r.composite/main.c:91
@@ -11217,13 +11229,11 @@
msgstr ""
#: ../raster/wildfire/r.spread/main.c:153
-msgid ""
-"Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
+msgid "Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
msgstr ""
#: ../raster/wildfire/r.spread/main.c:161
-msgid ""
-"Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
+msgid "Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
msgstr ""
#: ../raster/wildfire/r.spread/main.c:169
@@ -11428,8 +11438,9 @@
msgstr ""
#: ../raster/r.to.rast3/main.c:117
+#, fuzzy
msgid "Could not get raster row"
-msgstr ""
+msgstr "Áäõíáìßá áíÜãíùóçò ôçò ãñáììÞò (row) ôïõ ÷Üñôç"
#: ../raster/r.to.rast3/main.c:194
msgid "raster, volume, conversion"
@@ -11580,8 +11591,9 @@
#: ../vector/v.surf.rst/main.c:675 ../vector/v.surf.rst/main.c:764
#: ../doc/vector/v.example/main.c:85 ../display/d.what.vect/main.c:126
#, c-format
+#, fuzzy
msgid "Unable to open vector map <%s>"
-msgstr ""
+msgstr "Áäõíáìßá áíïßãìáôïò äéáíõóìáôéêïý ÷Üñôç <%s>"
#: ../vector/v.net.visibility/main.c:98
#, c-format
@@ -11659,8 +11671,7 @@
#: ../vector/v.db.connect/main.c:175
#, c-format
-msgid ""
-"layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgid "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
msgstr ""
#: ../vector/v.db.connect/main.c:184 ../vector/v.edit/select.c:506
@@ -11672,8 +11683,9 @@
#: ../vector/v.to.rast/support.c:277 ../vector/v.to.rast/vect2rast.c:51
#: ../vector/v.extract/main.c:270 ../doc/vector/v.example/main.c:103
#, c-format
+#, fuzzy
msgid "Database connection not defined for layer %d"
-msgstr ""
+msgstr "Äåí Ý÷åé êáèïñéóôåß ç óýíäåóç ìå ôç âÜóç äåäïìÝíùí ãéá ôï åðßðåäï (layer) %d"
#: ../vector/v.db.connect/main.c:237
#, c-format
@@ -12279,13 +12291,15 @@
#: ../vector/v.in.dxf/write_vect.c:214 ../vector/v.in.ascii/in.c:499
#: ../vector/v.in.sites/main.c:174
#, c-format
+#, fuzzy
msgid "Unable to create index for table <%s>, key <%s>"
-msgstr ""
+msgstr "Áäõíáìßá äçìéïõñãßáò êáôáëüãïõ ãéá ôïí ðßíáêá <%s>, êëåéäß <%s>"
#: ../vector/v.in.dxf/write_vect.c:219
#, c-format
+#, fuzzy
msgid "Unable to add database link for vector map <%s>"
-msgstr ""
+msgstr "Áäõíáìßá ðñïóèÞêçò óýíäåóçò ìå âÜóç äåäïìÝíùí ãéá ôïí äéáíõóìáôéêü ÷Üñôç <%s>"
#: ../vector/v.in.dxf/read_dxf.c:57
msgid "end of file while looking for HEADER"
@@ -12844,8 +12858,7 @@
#: ../vector/lidar/v.surf.bspline/main.c:234
#, c-format
-msgid ""
-"No vector map to interpolate. Interpolation will be done with <%s> vector map"
+msgid "No vector map to interpolate. Interpolation will be done with <%s> vector map"
msgstr ""
#: ../vector/lidar/v.surf.bspline/main.c:240
@@ -13021,8 +13034,7 @@
msgstr ""
#: ../vector/v.distance/main.c:200
-msgid ""
-"Column name(s) where values specified by 'upload' option will be uploaded"
+msgid "Column name(s) where values specified by 'upload' option will be uploaded"
msgstr ""
#: ../vector/v.distance/main.c:206
@@ -13191,8 +13203,9 @@
#: ../vector/v.reclass/main.c:135 ../vector/v.what.rast/main.c:155
#: ../vector/v.to.rast/support.c:311 ../vector/v.to.rast/vect2rast.c:64
#, c-format
+#, fuzzy
msgid "Column <%s> not found"
-msgstr ""
+msgstr "Ç óôÞëç <%s> äåí âñÝèçêå"
#: ../vector/v.reclass/main.c:182
msgid "Cannot select records from database"
@@ -13342,18 +13355,15 @@
msgstr ""
#: ../vector/v.in.ascii/in.c:102
-msgid ""
-"Number of column used as x coordinate (first column is 1) for points mode"
+msgid "Number of column used as x coordinate (first column is 1) for points mode"
msgstr ""
#: ../vector/v.in.ascii/in.c:112
-msgid ""
-"Number of column used as y coordinate (first column is 1) for points mode"
+msgid "Number of column used as y coordinate (first column is 1) for points mode"
msgstr ""
#: ../vector/v.in.ascii/in.c:122
-msgid ""
-"Number of column used as z coordinate (first column is 1) for points mode"
+msgid "Number of column used as z coordinate (first column is 1) for points mode"
msgstr ""
#: ../vector/v.in.ascii/in.c:124
@@ -13365,8 +13375,7 @@
msgstr ""
#: ../vector/v.in.ascii/in.c:136
-msgid ""
-"If 0, unique category is assigned to each row and written to new column 'cat'"
+msgid "If 0, unique category is assigned to each row and written to new column 'cat'"
msgstr ""
#: ../vector/v.in.ascii/in.c:140
@@ -13433,13 +13442,11 @@
msgstr ""
#: ../vector/v.in.ascii/in.c:265
-msgid ""
-"z column number > minimum last column number (incorrect field separator?)"
+msgid "z column number > minimum last column number (incorrect field separator?)"
msgstr ""
#: ../vector/v.in.ascii/in.c:270
-msgid ""
-"cat column number > minimum last column number (incorrect field separator?)"
+msgid "cat column number > minimum last column number (incorrect field separator?)"
msgstr ""
#: ../vector/v.in.ascii/in.c:276
@@ -13464,8 +13471,7 @@
#: ../vector/v.in.ascii/in.c:411
#, c-format
-msgid ""
-"Number of columns defined (%d) does not match number of columns (%d) in input"
+msgid "Number of columns defined (%d) does not match number of columns (%d) in input"
msgstr ""
#: ../vector/v.in.ascii/in.c:439
@@ -13754,8 +13760,7 @@
msgstr ""
#: ../vector/v.db.select/main.c:82
-msgid ""
-"Print minimal region extent of selected vector features instead of attributes"
+msgid "Print minimal region extent of selected vector features instead of attributes"
msgstr ""
#: ../vector/v.db.select/main.c:128
@@ -13771,8 +13776,9 @@
#: ../vector/v.db.select/main.c:184
#, c-format
+#, fuzzy
msgid "Unable to fetch data from table <%s>"
-msgstr ""
+msgstr "Áäõíáìßá öüñôùóçò äåäïìÝíùí ðßíáêá <%s>"
#: ../vector/v.db.select/main.c:230
#, c-format
@@ -14319,8 +14325,9 @@
#: ../vector/v.sample/main.c:216 ../vector/v.patch/main.c:285
#, c-format
+#, fuzzy
msgid "Unable to create table <%s>"
-msgstr ""
+msgstr "Áäõíáìßá äçìéïõñãßáò ðßíáêá <%s>"
#: ../vector/v.sample/main.c:227
msgid "Checking vector points..."
@@ -14463,8 +14470,9 @@
#: ../vector/v.generalize/main.c:468
#, c-format
+#, fuzzy
msgid "Unable to calculate centroid for area %d"
-msgstr ""
+msgstr "Áäõíáìßá õðïëïãéóìïý êÝíôñùí ðïëõãþíïõ ãéá ôçí åðéöÜíåéá %d"
#: ../vector/v.generalize/main.c:493
#, c-format
@@ -14487,8 +14495,9 @@
#: ../vector/v.generalize/misc.c:174
#, c-format
+#, fuzzy
msgid "Unable to copy table <%s>"
-msgstr ""
+msgstr "Áäõíáìßá áíôéãñáöÞò ðßíáêá <%s>"
#: ../vector/v.in.region/main.c:39
msgid "Create a new vector from the current region."
@@ -14571,8 +14580,9 @@
#: ../vector/v.info/main.c:247
#, c-format
+#, fuzzy
msgid " Type of Map: %s (level: %i) "
-msgstr ""
+msgstr "Ôýðïò "
#: ../vector/v.info/main.c:255
#, c-format
@@ -14749,8 +14759,9 @@
#: ../vector/v.in.ogr/main.c:335
#, c-format
+#, fuzzy
msgid "Vector map <%s> already exists and will be overwritten"
-msgstr ""
+msgstr "Ï äéáíõóìáôéêüò ÷Üñôçò <%s> õðÜñ÷åé Þäç êáé èá áíôéêáôáóôáèåß (overwritten)"
#: ../vector/v.in.ogr/main.c:379
msgid "Select either the current region flag or the spatial option, not both"
@@ -15014,8 +15025,7 @@
msgstr ""
#: ../vector/v.patch/main.c:84
-msgid ""
-"Append files to existing file (overwriting existing files must be activated)"
+msgid "Append files to existing file (overwriting existing files must be activated)"
msgstr ""
#: ../vector/v.patch/main.c:89
@@ -15130,8 +15140,7 @@
#: ../vector/v.digit/main.c:157
#, c-format
-msgid ""
-"Map <%s> does not exist in current mapset. Add flag -n to create a new map."
+msgid "Map <%s> does not exist in current mapset. Add flag -n to create a new map."
msgstr ""
#: ../vector/v.surf.idw/read_sites.c:86
@@ -15151,8 +15160,7 @@
msgstr ""
#: ../vector/v.surf.idw/main.c:106
-msgid ""
-"Power parameter; greater values assign greater influence to closer points"
+msgid "Power parameter; greater values assign greater influence to closer points"
msgstr ""
#: ../vector/v.surf.idw/main.c:110
@@ -15195,8 +15203,7 @@
msgstr ""
#: ../vector/v.vol.rst/user1.c:126
-msgid ""
-"Column type of smooth column is not supported (must be integer or double)"
+msgid "Column type of smooth column is not supported (must be integer or double)"
msgstr ""
#: ../vector/v.vol.rst/main.c:204
@@ -15316,8 +15323,9 @@
msgstr ""
#: ../vector/v.vol.rst/main.c:548
+#, fuzzy
msgid "Vector is not 3D"
-msgstr ""
+msgstr "Ôï äéÜíõóìá äåí åßíáé 3Ä"
#: ../vector/v.vol.rst/main.c:600
#, c-format
@@ -15667,8 +15675,7 @@
msgstr ""
#: ../vector/v.category/main.c:133
-msgid ""
-"Database connection and attribute tables for concerned layers are not changed"
+msgid "Database connection and attribute tables for concerned layers are not changed"
msgstr ""
#: ../vector/v.category/main.c:156
@@ -15792,8 +15799,9 @@
#: ../vector/v.convert/att.c:72
#, c-format
+#, fuzzy
msgid "Cannot open database %s"
-msgstr ""
+msgstr "Äåí ìðïñþ íá áíïßîù ôçí âÜóç äåäïìÝíùí %s"
#: ../vector/v.convert/att.c:105
#, c-format
@@ -16085,8 +16093,7 @@
msgstr ""
#: ../vector/v.net.path/main.c:65
-msgid ""
-"Name of file containing start and end points. If not given, read from stdin"
+msgid "Name of file containing start and end points. If not given, read from stdin"
msgstr ""
#: ../vector/v.net.path/main.c:73 ../display/d.path/main.c:82
@@ -16197,8 +16204,9 @@
#: ../vector/v.label.sa/labels.c:145 ../vector/v.label/main.c:297
#: ../display/d.vect/plot1.c:294
+#, fuzzy
msgid "Unable to read vector map"
-msgstr ""
+msgstr "Áäõíáìßá áíÜãíùóçò äéáíõóìáôéêïý ÷Üñôç"
#: ../vector/v.label.sa/labels.c:248
#, c-format
@@ -16259,8 +16267,9 @@
#: ../vector/v.label.sa/main.c:197 ../vector/v.label/main.c:188
#: ../vector/v.lrs/v.lrs.label/main.c:228 ../display/d.path/main.c:116
#: ../general/g.pnmcomp/main.c:334
+#, fuzzy
msgid "Background color"
-msgstr ""
+msgstr "×ñþìá öüíôïõ"
#: ../vector/v.label.sa/main.c:208 ../vector/v.label/main.c:201
msgid "Opaque to vector (only relevant if background color is selected)"
@@ -16277,13 +16286,17 @@
#: ../vector/v.label.sa/font.c:54
#, c-format
+#, fuzzy
msgid "%s: Unable to read font definition file; use the default"
msgstr ""
+"%s: Áäõíáìßá áíÜãíùóçò ôïõ áñ÷åßïõ ãñáììáôïóåéñÜò, ÷ñçóéìïðïéÞóôå ôï "
+"ðñïåðéëåãìÝíï"
#: ../vector/v.label.sa/font.c:60
#, c-format
+#, fuzzy
msgid "%s: No font definition file"
-msgstr ""
+msgstr "%s: Äåí õðáñ÷åéï áñ÷åßï ãñáììáôïóåéñÜò"
#: ../vector/v.clean/main.c:45
msgid "Toolset for cleaning topology of vector map."
@@ -16318,8 +16331,7 @@
msgstr ""
#: ../vector/v.clean/main.c:95
-msgid ""
-"Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
+msgid "Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
msgstr ""
#: ../vector/v.clean/main.c:101
@@ -16743,8 +16755,9 @@
#: ../vector/v.what/what.c:170
#, c-format
+#, fuzzy
msgid "Type: %s"
-msgstr ""
+msgstr "Ôýðïò"
#: ../vector/v.what/what.c:171
#, c-format
@@ -16770,15 +16783,17 @@
#: ../vector/v.what/what.c:206
#, c-format
+#, fuzzy
msgid ""
"Type: Area\n"
"Area height: %f\n"
-msgstr ""
+msgstr "Ôýðïò"
#: ../vector/v.what/what.c:210
#, c-format
+#, fuzzy
msgid "Type: Area\n"
-msgstr ""
+msgstr "Ôýðïò"
#: ../vector/v.what/what.c:217
#, c-format
@@ -17024,14 +17039,16 @@
msgstr ""
#: ../vector/v.to.db/parse.c:37
+#, fuzzy
msgid ""
"Type of elements (for coor valid point/centroid, for length valid line/"
"boundary)"
-msgstr ""
+msgstr "Ôýðïò"
#: ../vector/v.to.db/parse.c:39
+#, fuzzy
msgid "Type of elements"
-msgstr ""
+msgstr "Ôýðïò"
#: ../vector/v.to.db/parse.c:45
msgid "Query layer (used by 'query' option)"
@@ -17120,8 +17137,7 @@
msgstr ""
#: ../vector/v.out.vtk/writeVTK.c:187
-msgid ""
-"No coordinates to generate the output! Maybe an empty vector type chosen?"
+msgid "No coordinates to generate the output! Maybe an empty vector type chosen?"
msgstr ""
#: ../vector/v.out.vtk/writeVTK.c:575 ../vector/v.out.ogr/main.c:696
@@ -17160,8 +17176,9 @@
msgstr ""
#: ../vector/v.out.vtk/main.c:83
+#, fuzzy
msgid "Layer number"
-msgstr ""
+msgstr "Íïýìåñï åðéðÝäïõ"
#: ../vector/v.out.vtk/main.c:93
msgid "Export numeric attribute table fields as VTK scalar variables"
@@ -17220,8 +17237,7 @@
msgstr ""
#: ../vector/v.support/main.c:118
-msgid ""
-"Command line to store into vector map history file (used for vector scripts)"
+msgid "Command line to store into vector map history file (used for vector scripts)"
msgstr ""
#: ../vector/v.support/main.c:122
@@ -17230,8 +17246,9 @@
#: ../vector/v.support/main.c:188
#, c-format
+#, fuzzy
msgid "Unable to open history file for vector map <%s>"
-msgstr ""
+msgstr "Áäõíáìßá áíïßãìáôïò ôïõ éóôïñéêïý ôïõ äéáíõóìáôéêïý ÷Üñôç <%s>"
#: ../vector/v.select/main.c:134
msgid "Select features from ainput by features from binput"
@@ -17365,8 +17382,7 @@
msgstr ""
#: ../vector/v.label/main.c:252
-msgid ""
-"size and space options vary significantly which may lead to crummy output"
+msgid "size and space options vary significantly which may lead to crummy output"
msgstr ""
#: ../vector/v.label/main.c:260
@@ -17481,8 +17497,7 @@
msgstr ""
#: ../vector/v.surf.rst/main.c:313
-msgid ""
-"Maximum distance between points on isoline (to insert additional points)"
+msgid "Maximum distance between points on isoline (to insert additional points)"
msgstr ""
#: ../vector/v.surf.rst/main.c:322
@@ -17570,8 +17585,7 @@
msgstr ""
#: ../vector/v.in.db/main.c:54
-msgid ""
-"Creates new vector (points) map from database table containing coordinates."
+msgid "Creates new vector (points) map from database table containing coordinates."
msgstr ""
#: ../vector/v.in.db/main.c:58
@@ -17596,14 +17610,14 @@
#: ../vector/v.in.db/main.c:129
#, c-format
-msgid ""
-"Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
+msgid "Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
msgstr ""
#: ../vector/v.in.db/main.c:162
#, c-format
+#, fuzzy
msgid "Unable to open select cursor: '%s'"
-msgstr ""
+msgstr "Áäõíáìßá áíïßãìáôïò êÝñóïñá '%s'"
#: ../vector/v.in.db/main.c:174
msgid "Key column must be integer"
@@ -17708,8 +17722,9 @@
msgstr ""
#: ../vector/v.to.rast/support.c:175
+#, fuzzy
msgid "Color set to [200:200:200]"
-msgstr ""
+msgstr "×ñþìá"
#: ../vector/v.to.rast/support.c:180
#, c-format
@@ -17809,8 +17824,9 @@
msgstr ""
#: ../vector/v.to.rast/vect2rast.c:209
+#, fuzzy
msgid "Color can be updated from database only if use=attr"
-msgstr ""
+msgstr "×ñþìá"
#: ../vector/v.drape/main.c:61
msgid "vector, geometry, sampling"
@@ -17878,12 +17894,14 @@
msgstr ""
#: ../vector/v.out.ogr/main.c:137
+#, fuzzy
msgid "OGR dataset creation option (format specific, NAME=VALUE)"
-msgstr ""
+msgstr "ÏÍÏÌÁ"
#: ../vector/v.out.ogr/main.c:147
+#, fuzzy
msgid "OGR layer creation option (format specific, NAME=VALUE)"
-msgstr ""
+msgstr "ÏÍÏÌÁ"
#: ../vector/v.out.ogr/main.c:152
msgid ""
@@ -17910,8 +17928,9 @@
#: ../vector/v.out.ogr/main.c:263
#, c-format
+#, fuzzy
msgid "Unable to open OGR data source '%s'"
-msgstr ""
+msgstr "Áäõíáìßá áíïßãìáôïò OGR ðçãÞ äåäïìÝíùí '%s'"
#: ../vector/v.out.ogr/main.c:284 ../vector/v.out.ogr/main.c:291
#, c-format
@@ -17935,14 +17954,12 @@
#: ../vector/v.out.ogr/main.c:386
#, c-format
-msgid ""
-"%d point(s) found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d point(s) found, but not requested to be exported. Verify 'type' parameter."
msgstr ""
#: ../vector/v.out.ogr/main.c:391
#, c-format
-msgid ""
-"%d line(s) found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d line(s) found, but not requested to be exported. Verify 'type' parameter."
msgstr ""
#: ../vector/v.out.ogr/main.c:397
@@ -17961,14 +17978,12 @@
#: ../vector/v.out.ogr/main.c:408
#, c-format
-msgid ""
-"%d areas found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d areas found, but not requested to be exported. Verify 'type' parameter."
msgstr ""
#: ../vector/v.out.ogr/main.c:413
#, c-format
-msgid ""
-"%d faces found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d faces found, but not requested to be exported. Verify 'type' parameter."
msgstr ""
#: ../vector/v.out.ogr/main.c:421
@@ -18043,8 +18058,7 @@
#: ../vector/v.net.steiner/main.c:527
#, c-format
-msgid ""
-"[%d] (not reachable) nodes removed from list of Steiner point candidates"
+msgid "[%d] (not reachable) nodes removed from list of Steiner point candidates"
msgstr ""
#: ../vector/v.net.steiner/main.c:532
@@ -18382,8 +18396,7 @@
msgstr ""
#: ../vector/v.lrs/v.lrs.create/main.c:179
-msgid ""
-"Column containing offset from milepost for the beginning of next segment"
+msgid "Column containing offset from milepost for the beginning of next segment"
msgstr ""
#: ../vector/v.lrs/v.lrs.create/main.c:188
@@ -18550,8 +18563,7 @@
msgstr ""
#: ../vector/v.buffer/main.c:256
-msgid ""
-"Creates a buffer around features of given type (areas must contain centroid)."
+msgid "Creates a buffer around features of given type (areas must contain centroid)."
msgstr ""
#: ../vector/v.buffer/main.c:271
@@ -19025,8 +19037,7 @@
msgstr ""
#: ../ps/ps.map/main.c:121
-msgid ""
-"File containing mapping instructions (or use input=- to enter from keyboard)"
+msgid "File containing mapping instructions (or use input=- to enter from keyboard)"
msgstr ""
#: ../ps/ps.map/main.c:129
@@ -19051,11 +19062,15 @@
#: ../ps/ps.map/main.c:263
#, c-format
+#, fuzzy
msgid ""
"\n"
"ERROR: Required parameter <%s> not set:\n"
" (%s).\n"
msgstr ""
+"\n"
+"ÓÖÁËÌÁ: Ç áðáéôïýìåíç ðáñÜìåôñïò <%s> äåí Ý÷åé êáèïñéóôåß:\n"
+" (%s).\n"
#: ../ps/ps.map/main.c:274
msgid "Current region cannot be set."
@@ -19830,8 +19845,7 @@
msgstr ""
#: ../imagery/i.rectify/main.c:83
-msgid ""
-"Use curr. region settings in target location (def.=calculate smallest area)"
+msgid "Use curr. region settings in target location (def.=calculate smallest area)"
msgstr ""
#: ../imagery/i.rectify/main.c:87
@@ -20471,13 +20485,11 @@
msgstr ""
#: ../imagery/i.cluster/main.c:315
-msgid ""
-"Not enough sample points. Please run again and choose a larger sample size"
+msgid "Not enough sample points. Please run again and choose a larger sample size"
msgstr ""
#: ../imagery/i.cluster/main.c:319
-msgid ""
-"Not enough non-zero sample data points. Check your current region (and mask)"
+msgid "Not enough non-zero sample data points. Check your current region (and mask)"
msgstr ""
#: ../imagery/i.cluster/main.c:332
@@ -20528,8 +20540,7 @@
msgstr ""
#: ../imagery/i.ortho.photo/photo.2target/main.c:65
-msgid ""
-"Name of a map from target mapset which will be initially drawn on screen."
+msgid "Name of a map from target mapset which will be initially drawn on screen."
msgstr ""
#: ../imagery/i.ortho.photo/photo.2target/main.c:208
@@ -20871,8 +20882,9 @@
msgstr ""
#: ../visualization/nviz/src/nviz_init.c:68
+#, fuzzy
msgid "Name of raster map(s) for Color"
-msgstr ""
+msgstr "×ñþìá"
#: ../visualization/nviz/src/nviz_init.c:77
msgid "Name of vector lines/areas overlay map(s)"
@@ -20986,8 +20998,9 @@
#: ../visualization/nviz2/cmd/surface.c:126
#, c-format
+#, fuzzy
msgid "Color attribute not defined, using default <%s>"
-msgstr ""
+msgstr "×ñþìá"
#: ../visualization/nviz2/cmd/surface.c:203
#, c-format
@@ -21043,8 +21056,9 @@
msgstr ""
#: ../visualization/nviz2/cmd/args.c:132
+#, fuzzy
msgid "Color value(s)"
-msgstr ""
+msgstr "×ñþìá"
#: ../visualization/nviz2/cmd/args.c:141
msgid "Name of raster map(s) for mask"
@@ -21285,8 +21299,9 @@
msgstr ""
#: ../display/d.histogram/main.c:90
+#, fuzzy
msgid "Color for text and axes"
-msgstr ""
+msgstr "×ñþìá"
#: ../display/d.histogram/main.c:98
msgid "Indicate if cell counts or map areas should be displayed"
@@ -21335,20 +21350,22 @@
msgstr ""
#: ../display/d.mapgraph/main.c:67
+#, fuzzy
msgid ""
"Color to draw with, either a standard GRASS color or R:G:B triplet "
"(separated by colons)"
-msgstr ""
+msgstr "×ñþìá"
#: ../display/d.erase/main.c:34
msgid "Erase the contents of the active display frame with user defined color"
msgstr ""
#: ../display/d.erase/main.c:42
+#, fuzzy
msgid ""
"Color to erase with, either a standard GRASS color or R:G:B triplet "
-msgstr ""
+msgstr "×ñþìá"
#: ../display/d.erase/main.c:47 ../display/d.frame/frame.c:74
msgid "Remove all frames and erase the screen"
@@ -21476,8 +21493,9 @@
#: ../display/d.what.vect/what.c:231
#, c-format
+#, fuzzy
msgid "Line: %d Type: %s Left: %d Right: %d "
-msgstr ""
+msgstr "Ôýðïò "
#: ../display/d.what.vect/what.c:251
#, c-format
@@ -21647,8 +21665,7 @@
#: ../display/d.font/main.c:126
#, c-format
-msgid ""
-"Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
+msgid "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
msgstr ""
#: ../display/d.rast.num/number.c:86
@@ -21658,12 +21675,14 @@
msgstr ""
#: ../display/d.rast.num/number.c:99
+#, fuzzy
msgid "Color for drawing grid, or \"none\""
-msgstr ""
+msgstr "×ñþìá êáíÝíá"
#: ../display/d.rast.num/number.c:108
+#, fuzzy
msgid "Color for drawing text"
-msgstr ""
+msgstr "×ñþìá"
#: ../display/d.rast.num/number.c:121
msgid "Get text color from cell color value"
@@ -21747,12 +21766,14 @@
msgstr ""
#: ../display/d.linegraph/linegraph.c:139
+#, fuzzy
msgid "Color for Y data"
-msgstr ""
+msgstr "×ñþìá"
#: ../display/d.linegraph/linegraph.c:148
+#, fuzzy
msgid "Color for axis, tics, numbers, and title"
-msgstr ""
+msgstr "×ñþìá"
#: ../display/d.linegraph/linegraph.c:156
msgid "Title for X data"
@@ -21835,8 +21856,7 @@
msgstr ""
#: ../display/d.title/main.c:47
-msgid ""
-"Create a TITLE for a raster map in a form suitable for display with d.text."
+msgid "Create a TITLE for a raster map in a form suitable for display with d.text."
msgstr ""
#: ../display/d.title/main.c:58
@@ -21884,8 +21904,9 @@
msgstr ""
#: ../display/d.geodesic/main.c:70
+#, fuzzy
msgid "Text color or \"none\""
-msgstr ""
+msgstr "êáíÝíá"
#: ../display/d.geodesic/main.c:78 ../display/d.rhumbline/main.c:79
#, c-format
@@ -21949,8 +21970,9 @@
#: ../display/d.graph/main.c:103 ../display/d.text.freetype/main.c:842
#: ../display/d.rast/display.c:32 ../display/d.paint.labels/color.c:66
#, c-format
+#, fuzzy
msgid "[%s]: No such color"
-msgstr ""
+msgstr "[%s]: Äåí õðÜñ÷åé ôÝôïéï ÷ñþìá"
#: ../display/d.text/main.c:177
#, c-format
@@ -22087,12 +22109,14 @@
msgstr ""
#: ../display/d.legend/main.c:373 ../display/d.legend/main.c:531
+#, fuzzy
msgid "Color range exceeds lower limit of actual data"
-msgstr ""
+msgstr "×ñþìá"
#: ../display/d.legend/main.c:379 ../display/d.legend/main.c:535
+#, fuzzy
msgid "Color range exceeds upper limit of actual data"
-msgstr ""
+msgstr "×ñþìá"
#: ../display/d.legend/main.c:436
#, c-format
@@ -22174,8 +22198,7 @@
msgstr ""
#: ../display/d.graph/main.c:56
-msgid ""
-"Program for generating and displaying simple graphics on the display monitor."
+msgid "Program for generating and displaying simple graphics on the display monitor."
msgstr ""
#: ../display/d.graph/main.c:63
@@ -22185,8 +22208,9 @@
msgstr ""
#: ../display/d.graph/main.c:71
+#, fuzzy
msgid "Color to draw with, either a standard GRASS color or R:G:B triplet"
-msgstr ""
+msgstr "×ñþìá"
#: ../display/d.graph/main.c:78
msgid "Coordinates are given in map units"
@@ -22203,16 +22227,18 @@
msgstr ""
#: ../display/d.vect/plot1.c:210
+#, fuzzy
msgid "Color definition column not specified"
-msgstr ""
+msgstr "×ñþìá"
#: ../display/d.vect/plot1.c:220 ../display/d.vect/area.c:78
#: ../display/d.thematic.area/plot1.c:216
#, c-format
+#, fuzzy
msgid ""
"Color definition column (%s) not a string. Column must be of form RRR:GGG:"
"BBB where RGB values range 0-255."
-msgstr ""
+msgstr "×ñþìá."
#: ../display/d.vect/plot1.c:225 ../display/d.vect/plot1.c:253
#: ../display/d.vect/area.c:84 ../display/d.vect/area.c:112
@@ -22249,8 +22275,7 @@
#: ../display/d.vect/plot1.c:465 ../display/d.vect/area.c:344
#: ../display/d.thematic.area/plot1.c:440
#, c-format
-msgid ""
-"Error in line width column (%s), element %d with cat %d: line width [%d]"
+msgid "Error in line width column (%s), element %d with cat %d: line width [%d]"
msgstr ""
#: ../display/d.vect/plot1.c:530
@@ -22283,8 +22308,9 @@
#: ../display/d.vect/main.c:166 ../display/d.vect/main.c:176
#: ../display/d.vect/main.c:264 ../display/d.vect/main.c:274
+#, fuzzy
msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
-msgstr ""
+msgstr "Äþóôå Ýíá óôáíôáñ ÷ñþìá GRASS, óõíäõáóìü R:G:B Þ \"none\""
#: ../display/d.vect/main.c:172
msgid "Area fill color"
@@ -22295,8 +22321,9 @@
msgstr ""
#: ../display/d.vect/main.c:189
+#, fuzzy
msgid "Type of color table (for use with -z flag)"
-msgstr ""
+msgstr "Ôýðïò"
#: ../display/d.vect/main.c:198 ../display/d.vect/main.c:203
#: ../display/d.vect/main.c:211
@@ -22348,8 +22375,9 @@
msgstr ""
#: ../display/d.vect/main.c:254
+#, fuzzy
msgid "Either a standard color name or R:G:B triplet"
-msgstr ""
+msgstr "Åßôå Ýíá óôáíôáñ üíïìá ÷ñþìáôïò Þ óõíäõáóìüò R:G:B"
#: ../display/d.vect/main.c:261
msgid "Label background color"
@@ -22372,13 +22400,11 @@
msgstr ""
#: ../display/d.vect/main.c:310
-msgid ""
-"Minimum region size (average from height and width) when map is displayed"
+msgid "Minimum region size (average from height and width) when map is displayed"
msgstr ""
#: ../display/d.vect/main.c:318
-msgid ""
-"Maximum region size (average from height and width) when map is displayed"
+msgid "Maximum region size (average from height and width) when map is displayed"
msgstr ""
#: ../display/d.vect/main.c:328 ../display/d.thematic.area/main.c:157
@@ -22452,8 +22478,7 @@
msgstr ""
#: ../display/d.vect/main.c:645 ../display/d.thematic.area/main.c:408
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn."
+msgid "The bounding box of the map is outside the current region, nothing drawn."
msgstr ""
#: ../display/d.vect/main.c:679
@@ -22469,13 +22494,13 @@
msgstr ""
#: ../display/d.vect/area.c:68 ../display/d.thematic.area/plot1.c:206
+#, fuzzy
msgid "Color definition column not specified."
-msgstr ""
+msgstr "×ñþìá."
#: ../display/d.vect/area.c:277
#, c-format
-msgid ""
-"Error in color definition column (%s), area %d with cat %d: colorstring [%s]"
+msgid "Error in color definition column (%s), area %d with cat %d: colorstring [%s]"
msgstr ""
#: ../display/d.vect/area.c:283
@@ -22498,8 +22523,7 @@
msgstr ""
#: ../display/d.vect.chart/main.c:65
-msgid ""
-"Displays charts of vector data in the active frame on the graphics monitor."
+msgid "Displays charts of vector data in the active frame on the graphics monitor."
msgstr ""
#: ../display/d.vect.chart/main.c:82
@@ -22560,24 +22584,29 @@
msgstr ""
#: ../display/d.rast.arrow/arrow.c:129
+#, fuzzy
msgid "Type of existing raster aspect map"
-msgstr ""
+msgstr "Ôýðïò"
#: ../display/d.rast.arrow/arrow.c:137
+#, fuzzy
msgid "Color for drawing arrows"
-msgstr ""
+msgstr "×ñþìá"
#: ../display/d.rast.arrow/arrow.c:145
+#, fuzzy
msgid "Color for drawing grid or \"none\""
-msgstr ""
#: ../display/d.rast.arrow/arrow.c:153
+#, fuzzy
msgid "Color for drawing X's (Null values)"
-msgstr ""
+msgstr "×ñþìá"
#: ../display/d.rast.arrow/arrow.c:161
+#, fuzzy
msgid "Color for showing unknown information"
-msgstr ""
+msgstr "×ñþìá"
#: ../display/d.rast.arrow/arrow.c:168
msgid "Draw arrow every Nth grid cell"
@@ -22616,8 +22645,7 @@
msgstr ""
#: ../display/d.menu/main.c:68
-msgid ""
-"Creates and displays a menu within the active frame on the graphics monitor."
+msgid "Creates and displays a menu within the active frame on the graphics monitor."
msgstr ""
#: ../display/d.menu/main.c:77
@@ -23074,9 +23102,9 @@
msgstr ""
#: ../display/d.barscale/main.c:89
-msgid ""
-"Background color, either a standard GRASS color, R:G:B triplet, or \"none\""
-msgstr ""
+#, fuzzy
+msgid "Background color, either a standard GRASS color, R:G:B triplet, or \"none\""
+msgstr "êáíÝíá"
#: ../display/d.barscale/main.c:109
msgid ""
@@ -23110,8 +23138,9 @@
msgstr ""
#: ../display/d.text.new/main.c:326
+#, fuzzy
msgid "Invalid coordinates"
-msgstr ""
+msgstr "ËÜèïò óõíôåôáãìÝíåò"
#: ../display/d.text.new/main.c:393
#, c-format
@@ -23328,8 +23357,9 @@
#: ../display/d.grid/main.c:76 ../display/d.grid/main.c:81
#: ../display/d.grid/main.c:87
+#, fuzzy
msgid "Color"
-msgstr ""
+msgstr "×ñþìá"
#: ../display/d.grid/main.c:95
msgid "Font size for gridline coordinate labels"
@@ -24248,8 +24278,7 @@
msgstr ""
#: ../general/g.proj/main.c:93
-msgid ""
-"Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
+msgid "Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
msgstr ""
#: ../general/g.proj/main.c:102
@@ -24558,8 +24587,9 @@
#: ../general/g.region/main.c:478 ../general/g.mremove/do_remove.c:55
#, c-format
+#, fuzzy
msgid "3D raster map <%s> not found"
-msgstr ""
+msgstr "Ï 3Ä ÷Üñôçò raster <%s> äåí âñÝèçêå"
#: ../general/g.region/main.c:481
#, c-format
@@ -24697,8 +24727,9 @@
msgstr ""
#: ../general/g.gui/main.c:44
+#, fuzzy
msgid "Default value: GRASS_GUI if defined otherwise tcltk"
-msgstr ""
#: ../general/g.gui/main.c:45
msgid ""
@@ -25101,3 +25132,4 @@
#: ../general/g.mremove/main.c:158
msgid "You must use the force flag to actually remove them. Exiting."
msgstr ""
