[GRASS-SVN] r33199 - grass/trunk/gui/wxpython/vdigit
svn_grass at osgeo.org
Mon Sep 1 12:49:12 EDT 2008
Author: martinl
Date: 2008-09-01 12:49:11 -0400 (Mon, 01 Sep 2008)
New Revision: 33199
grass/trunk/gui/wxpython/vdigit/driver_select.cpp
wxGUI/vdigit: bug fix in GetRegionSelected()
(merge from devbr6, r33197, r33198)
Modified: grass/trunk/gui/wxpython/vdigit/driver_select.cpp
--- grass/trunk/gui/wxpython/vdigit/driver_select.cpp 2008-09-01 16:47:44 UTC (rev 33198)
+++ grass/trunk/gui/wxpython/vdigit/driver_select.cpp 2008-09-01 16:49:11 UTC (rev 33199)
@@ -415,7 +415,7 @@
std::vector<int> DisplayDriver::GetRegionSelected()
- int line, area;
+ int line, area, nareas;
std::vector<int> region;
@@ -437,7 +437,7 @@
int type;
bool found;
- for (int line = 1; line < Vect_get_num_lines(mapInfo); line++) {
+ for (int line = 1; line <= Vect_get_num_lines(mapInfo); line++) {
type = Vect_read_line (mapInfo, NULL, cats, line);
if (!(type & (GV_POINTS | GV_LINES)))
continue;
@@ -457,11 +457,12 @@
list = selected.values;
+ nareas = Vect_get_num_areas(mapInfo);
for (int i = 0; i < list->n_values; i++) {
line = list->value[i];
area = Vect_get_centroid_area(mapInfo, line);
- if (area > 0) {
+ if (area > 0 && area <= nareas) {
if (!Vect_get_area_box(mapInfo, area, &line_box))
continue;
