[GRASS-SVN] r33200 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Mon Sep 1 12:53:19 EDT 2008
Author: martinl
Date: 2008-09-01 12:53:19 -0400 (Mon, 01 Sep 2008)
New Revision: 33200
   grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
wxGUI: removed unused code
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py	2008-09-01 16:49:11 UTC (rev 33199)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py	2008-09-01 16:53:19 UTC (rev 33200)
@@ -1879,101 +1879,6 @@
         self.manageLayerBook.modifyLayerWidgets['layer'][1].SetItems(listOfLayers)
         self.manageLayerBook.OnChangeLayer(event=None)
-#     def OnMapClick(self, event):
-#         Gets coordinates from mouse clicking on display window
-#         Debug.msg(3, "VirtualAttributeList.OnMapClick()")
-#         # map coordinates
-#         x, y = self.mapdisp.MapWindow.Pixel2Cell(event.GetPositionTuple()[:])
-#         category = ""
-#         for line in os.popen("v.what east_north=%f,%f map=%s" %\
-#                 (x,y,self.vectmap)).readlines():
-#             if "Category:" in line:
-#                 category = line.strip().split(" ")[1]
-#         #print category
-#         for idx in range(self.GetItemCount()):
-#             item = self.GetItem(idx, 0)
-#             if item.GetText() == category:
-#                 #print idx
-#                 # self.Select(idx,True)
-#                 self.EnsureVisible( idx )
-#                 self.SetItemState(idx, wx.LIST_STATE_SELECTED, wx.LIST_STATE_SELECTED)
-#             else:
-#                 # self.SetItemState(idx, wx.LIST_STATE_DESELECTED, wx.LIST_STATE_DESELECTED)
-#                 self.Select(idx,False)
-#                 #        try:
-#                 #            os.environ["GRASS_MESSAGE_FORMAT"] = "gui"
-#                 #            cmd = "v.what -a east_north=%d,%d distance=%d map=%@%" % (x,y,100,self.tablename, self.self.mapset)
-#                 #            self.cmd_output.write(cmd+"\n----------\n")
-#                 #            p = Popen(cmd +" --verbose", shell=True, stdin=PIPE, stdout=PIPE, stderr=PIPE, close_fds=True)
-#                 #            oline = p.stderr.readline()
-#                 #            while oline:
-#                 #                oline = oline.strip()
-#                 #                if oline.find("GRASS_INFO_MESSAGE")>-1:
-#                 #                    self.cmd_output.write(string.split(oline,maxsplit=1)[1]+"\n")
-#                 #                elif oline.find("GRASS_INFO_WARNING")>-1:
-#                 #                    self.cmd_output.write("WARNING: "+string.split(oline,maxsplit=1)[1]+"\n")
-#                 #                elif oline.find("GRASS_INFO_ERROR")>-1:
-#                 #                    self.cmd_output.write("ERROR: "+string.split(oline,maxsplit=1)[1]+"\n")
-#                 #            oline = p.stdout.readline()
-#                 #            while oline:
-#                 #                self.cmd_output.write(oline+"\n")
-#                 #                print oline+"\n"
-#                 #                print >> sys.stderr, oline
-#                 #            if p.stdout < 0:
-#                 #                print >> sys.stderr, "Child was terminated by signal", p.stdout
-#                 #            elif p.stdout > 0:
-#                 #                print >> sys.stderr, p.stdout
-#                 #                pass
-#                 #        except OSError, e:
-#                 #            print >> sys.stderr, "Execution failed:", e
-#                 #        try:
-#                 #            while oline:
-#                 #            while oline:
-#                 #                pass
 class TableListCtrl(wx.ListCtrl,
                     listmix.ListCtrlAutoWidthMixin):
                     #                    listmix.TextEditMixin):
