[GRASS-SVN] r33201 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Sep 1 12:54:48 EDT 2008
Author: martinl
Date: 2008-09-01 12:54:48 -0400 (Mon, 01 Sep 2008)
New Revision: 33201
grass/trunk/gui/wxpython/gui_modules/dbm.py
wxGUI: removed unused code (merge from devbr6, r33200)
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-09-01 16:53:19 UTC (rev 33200)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-09-01 16:54:48 UTC (rev 33201)
@@ -1879,101 +1879,6 @@
self.manageLayerBook.modifyLayerWidgets['layer'][1].SetItems(listOfLayers)
self.manageLayerBook.OnChangeLayer(event=None)
-# def OnMapClick(self, event):
-# Gets coordinates from mouse clicking on display window
-# Debug.msg(3, "VirtualAttributeList.OnMapClick()")
-# # map coordinates
-# x, y = self.mapdisp.MapWindow.Pixel2Cell(event.GetPositionTuple()[:])
-# category = ""
-# for line in os.popen("v.what east_north=%f,%f map=%s" %\
-# (x,y,self.vectmap)).readlines():
-# if "Category:" in line:
-# category = line.strip().split(" ")[1]
-# #print category
-# for idx in range(self.GetItemCount()):
-# item = self.GetItem(idx, 0)
-# if item.GetText() == category:
-# #print idx
-# # self.Select(idx,True)
-# self.EnsureVisible( idx )
-# self.SetItemState(idx, wx.LIST_STATE_SELECTED, wx.LIST_STATE_SELECTED)
-# else:
-# # self.SetItemState(idx, wx.LIST_STATE_DESELECTED, wx.LIST_STATE_DESELECTED)
-# self.Select(idx,False)
-# # try:
-# # os.environ["GRASS_MESSAGE_FORMAT"] = "gui"
-# # cmd = "v.what -a east_north=%d,%d distance=%d map=%@%" % (x,y,100,self.tablename, self.self.mapset)
-# # self.cmd_output.write(cmd+"\n----------\n")
-# # p = Popen(cmd +" --verbose", shell=True, stdin=PIPE, stdout=PIPE, stderr=PIPE, close_fds=True)
-# # oline = p.stderr.readline()
-# # while oline:
-# # oline = oline.strip()
-# # if oline.find("GRASS_INFO_MESSAGE")>-1:
-# # self.cmd_output.write(string.split(oline,maxsplit=1)[1]+"\n")
-# # elif oline.find("GRASS_INFO_WARNING")>-1:
-# # self.cmd_output.write("WARNING: "+string.split(oline,maxsplit=1)[1]+"\n")
-# # elif oline.find("GRASS_INFO_ERROR")>-1:
-# # self.cmd_output.write("ERROR: "+string.split(oline,maxsplit=1)[1]+"\n")
-# # oline = p.stdout.readline()
-# # while oline:
-# # self.cmd_output.write(oline+"\n")
-# # print oline+"\n"
-# # print >> sys.stderr, oline
-# # if p.stdout < 0:
-# # print >> sys.stderr, "Child was terminated by signal", p.stdout
-# # elif p.stdout > 0:
-# # print >> sys.stderr, p.stdout
-# # pass
-# # except OSError, e:
-# # print >> sys.stderr, "Execution failed:", e
-# # try:
-# # while oline:
-# # while oline:
-# # pass
class TableListCtrl(wx.ListCtrl,
listmix.ListCtrlAutoWidthMixin):
# listmix.TextEditMixin):
