[GRASS-SVN] r33223 - in grass/trunk/gui/wxpython: gui_modules icons
Tue Sep 2 11:04:26 EDT 2008
Author: martinl
Date: 2008-09-02 11:04:26 -0400 (Tue, 02 Sep 2008)
New Revision: 33223
   grass/trunk/gui/wxpython/gui_modules/dbm.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/toolbars.py
   grass/trunk/gui/wxpython/icons/icon.py
wxGUI: various vector map query tool oriented fixes
(merge from devbr6, r33222)
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py	2008-09-02 15:03:10 UTC (rev 33222)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py	2008-09-02 15:04:26 UTC (rev 33223)
@@ -1124,8 +1124,11 @@
             columnName.append(list.GetColumn(i).GetText())
         # maximal category number
-        maxCat = max(list.itemCatsMap.values())
+        if len(list.itemCatsMap.values()) > 0:
+            maxCat = max(list.itemCatsMap.values())
+        else:
+            maxCat = 0 # starting category '1'
         # key column must be always presented
         if keyColumn not in columnName:
             columnName.insert(0, keyColumn) # insert key column on first position
@@ -1197,7 +1200,11 @@
                 del values[0]
             # add new item to the list
-            index = max(list.itemIndexMap) + 1
+            if len(list.itemIndexMap) > 0:
+                index = max(list.itemIndexMap) + 1
+            else:
+                index = 0
             list.itemIndexMap.append(index)
             list.itemDataMap[index] = values
             list.itemCatsMap[index] = cat
@@ -2108,7 +2115,7 @@
                              'key': (wx.StaticText(parent=self.addPanel, id=wx.ID_ANY,
                                                    label='%s:' % _("Key column")),
                                      wx.TextCtrl(parent=self.addPanel, id=wx.ID_ANY,
-                                                 value='',
+                                                 value='cat',
                                                  style=wx.TE_PROCESS_ENTER))}
         # events
         self.tableWidgets['table'][1].Bind(wx.EVT_TEXT_ENTER, self.OnCreateTable)
@@ -2496,6 +2503,13 @@
                                     "Table name or key column name is missing."),
                           caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
             return
+        if table in self.addLayerWidgets['table'][1].GetItems():
+            wx.MessageBox(parent=self,
+                          message=_("Unable to create new table. "
+                                    "Table <%s> already exists in the database.") % table,
+                          caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+            return
         # create table
         sql = 'CREATE TABLE %s (%s INTEGER)' % (table, key)
@@ -2950,81 +2964,85 @@
                                 self.mapDBInfo.tables[table][name]['values'].append(None)
                 else: # change status 'add' -> 'update'
                     self.action = "update"
-            # use scrolled panel instead (and fix initial max height of the window to 480px)
-            ### panel = wx.Panel(parent=self.notebook, id=wx.ID_ANY)
-            panel = scrolled.ScrolledPanel(parent=self.notebook, id=wx.ID_ANY,
-                                           size=(-1, 150))
-            panel.SetupScrolling(scroll_x=False)
-            self.notebook.AddPage(page=panel, text=" %s %d " % (_("Layer"), layer))
-            # notebook body
-            border = wx.BoxSizer(wx.VERTICAL)
             table   = self.mapDBInfo.layers[layer]["table"]
             key   = self.mapDBInfo.layers[layer]["key"]
             columns = self.mapDBInfo.tables[table]
             # value
-            if len(columns[key]['values']) == 0: # no cats
-                sizer  = wx.BoxSizer(wx.VERTICAL)
-                txt = wx.StaticText(parent=panel, id=wx.ID_ANY,
-                                    label=_("No database record available."))
-                sizer.Add(txt, proportion=1,
-                          flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_CENTER | wx.EXPAND)
-                border.Add(item=sizer, proportion=1,
-                           flag=wx.ALL | wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_CENTER,
-                           border=10)
-                panel.SetSizer(border)
-                continue
+            #             if len(columns[key]['values']) == 0: # no cats
+            #                 self.notebook.AddPage(page=panel, text=" %s %d / %s %d" % (_("Layer"), layer,
+            #        _("Category"), cat))
+            #                 sizer  = wx.BoxSizer(wx.VERTICAL)
+            #                 txt = wx.StaticText(parent=panel, id=wx.ID_ANY,
+            #                                     label=_("No database record available."))
+            #                 sizer.Add(txt, proportion=1,
+            #                           flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_CENTER | wx.EXPAND)
+            #                 border.Add(item=sizer, proportion=1,
+            #                            flag=wx.ALL | wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_CENTER,
+            #                            border=10)
+            #                 panel.SetSizer(border)
+            #                 continue
             for idx in range(len(columns[key]['values'])):
+                for name in columns.keys():
+                    if name == key:
+                        cat = int(columns[name]['values'][idx])
+                        break
+                # use scrolled panel instead (and fix initial max height of the window to 480px)
+                panel = scrolled.ScrolledPanel(parent=self.notebook, id=wx.ID_ANY,
+                                               size=(-1, 150))
+                panel.SetupScrolling(scroll_x=False)
+                self.notebook.AddPage(page=panel, text=" %s %d / %s %d" % (_("Layer"), layer,
+        _("Category"), cat))
+                # notebook body
+                border = wx.BoxSizer(wx.VERTICAL)
                 flexSizer = wx.FlexGridSizer (cols=4, hgap=3, vgap=3)
                 flexSizer.AddGrowableCol(3)
-                # columns
+                # columns (sorted by index)
+                names = [''] * len(columns.keys())
+                    names[columns[name]['index']] = name
+                for name in names:
+                    if name == key: # skip key column (category)
+                        continue
                     vtype  = columns[name]['type']
                     if columns[name]['values'][idx] is not None:
                         value = str(columns[name]['values'][idx])
                     else:
                         value = ''
-                    if name == key:
-                        box    = wx.StaticBox (parent=panel, id=wx.ID_ANY,
-                                               label=" %s %s " % (_("Category"), value))
-                        boxFont = self.GetFont()
-                        boxFont.SetWeight(wx.FONTWEIGHT_BOLD)
-                        box.SetFont(boxFont)
-                        sizer  = wx.StaticBoxSizer(box, wx.VERTICAL)
-                        colValue = box
-                    else:
-                        colName = wx.StaticText(parent=panel, id=wx.ID_ANY,
-                                                label=name)
-                        colType = wx.StaticText(parent=panel, id=wx.ID_ANY,
-                                                label="[" + vtype.lower() + "]")
-                        delimiter = wx.StaticText(parent=panel, id=wx.ID_ANY, label=":")
-                        colValue = wx.TextCtrl(parent=panel, id=wx.ID_ANY, value=value) # TODO: validator
-                        colValue.SetName(name)
-                        self.Bind(wx.EVT_TEXT, self.OnSQLStatement, colValue)
-                        flexSizer.Add(colName, proportion=0,
-                                      flag=wx.FIXED_MINSIZE | wx.ALIGN_CENTER_VERTICAL)
-                        flexSizer.Add(colType, proportion=0,
-                        flexSizer.Add(delimiter, proportion=0,
-                        flexSizer.Add(colValue, proportion=1,
-                                      flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL)
+                    colName = wx.StaticText(parent=panel, id=wx.ID_ANY,
+                                            label=name)
+                    colType = wx.StaticText(parent=panel, id=wx.ID_ANY,
+                                            label="[" + vtype.lower() + "]")
+                    delimiter = wx.StaticText(parent=panel, id=wx.ID_ANY, label=":")
+                    colValue = wx.TextCtrl(parent=panel, id=wx.ID_ANY, value=value) # TODO: validator
+                    colValue.SetName(name)
+                    self.Bind(wx.EVT_TEXT, self.OnSQLStatement, colValue)
+                    flexSizer.Add(colName, proportion=0,
+                                  flag=wx.FIXED_MINSIZE | wx.ALIGN_CENTER_VERTICAL)
+                    flexSizer.Add(colType, proportion=0,
+                    flexSizer.Add(delimiter, proportion=0,
+                    flexSizer.Add(colValue, proportion=1,
+                                  flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL)
                     # add widget reference to self.columns
                     columns[name]['ids'].append(colValue.GetId()) # name, type, values, id
                 # for each attribute (including category) END
-                sizer.Add(item=flexSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=1)
-                border.Add(item=sizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
+                border.Add(item=flexSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
+                panel.SetSizer(border)
             # for each category END
         # for each layer END
         self.Layout()
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2008-09-02 15:03:10 UTC (rev 33222)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2008-09-02 15:04:26 UTC (rev 33223)
@@ -1353,7 +1353,10 @@
         elif self.mouse["use"] == "queryVector":
             # editable mode for vector map layers
-            self.parent.QueryVector(self.mouse['begin'][0],self.mouse['begin'][1])
+            self.parent.QueryVector(self.mouse['begin'][0], self.mouse['begin'][1])
+            # clear temp canvas
+            self.UpdateMap(render=False, renderVector=False)
         elif self.mouse["use"] in ["measure", "profile"]:
             # measure or profile
@@ -3269,7 +3272,8 @@
         self.toolbars['map'].action['desc'] = 'modifyAttrb'
         self.MapWindow.mouse['use'] = "queryVector"
-        self.MapWindow.mouse['box'] = "point"
+        self.MapWindow.mouse['box'] = "box"
+        self.MapWindow.pen = wx.Pen(colour='Red', width=2, style=wx.SHORT_DASH)
         self.MapWindow.zoomtype = 0
         # change the cursor
@@ -3422,7 +3426,7 @@
         toolsmenu = wx.Menu()
         # Add items to the menu
         display = wx.MenuItem(parentMenu=toolsmenu, id=wx.ID_ANY,
-                              text=Icons["queryDisplay"].GetLabel(),
+                              text=_("Query raster/vector map(s) (display mode)"),
                               kind=wx.ITEM_CHECK)
         toolsmenu.AppendItem(display)
         self.Bind(wx.EVT_MENU, self.OnQueryDisplay, display)
@@ -3430,7 +3434,7 @@
             display.Check(True)
         modify = wx.MenuItem(parentMenu=toolsmenu, id=wx.ID_ANY,
-                             text=Icons["queryModify"].GetLabel(),
+                             text=_("Query vector map (edit mode)"),
                              kind=wx.ITEM_CHECK)
         toolsmenu.AppendItem(modify)
         self.Bind(wx.EVT_MENU, self.OnQueryModify, modify)
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py	2008-09-02 15:03:10 UTC (rev 33222)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py	2008-09-02 15:04:26 UTC (rev 33223)
@@ -192,8 +192,8 @@
             (self.pointer, "pointer", Icons["pointer"].GetBitmap(),
              wx.ITEM_CHECK, Icons["pointer"].GetLabel(), Icons["pointer"].GetDesc(),
              self.mapdisplay.OnPointer),
-            (self.query, "queryDisplay", Icons["queryDisplay"].GetBitmap(),
-             wx.ITEM_CHECK, Icons["queryDisplay"].GetLabel(), Icons["queryDisplay"].GetDesc(),
+            (self.query, "query", Icons["query"].GetBitmap(),
+             wx.ITEM_CHECK, Icons["query"].GetLabel(), Icons["query"].GetDesc(),
              self.mapdisplay.OnQuery),
             (self.pan, "pan", Icons["pan"].GetBitmap(),
              wx.ITEM_CHECK, Icons["pan"].GetLabel(), Icons["pan"].GetDesc(),
Modified: grass/trunk/gui/wxpython/icons/icon.py
--- grass/trunk/gui/wxpython/icons/icon.py	2008-09-02 15:03:10 UTC (rev 33222)
+++ grass/trunk/gui/wxpython/icons/icon.py	2008-09-02 15:04:26 UTC (rev 33223)
@@ -242,12 +242,9 @@
     "pan"        : MetaIcon (img=icons_img["pan"],
                              label=_("Pan"),
                              desc=_("Drag with mouse to pan")),
-    "queryDisplay" : MetaIcon (img=icons_img["query"],
-                               label=_("Query raster/vector map(s) (display mode)"),
-                               desc=_("Query selected raster/vector map(s)")),
-    "queryModify" : MetaIcon (img=icons_img["query"],
-                              label=_("Query vector map (editable mode)"),
-                             desc=_("Query selected vector map in editable mode")),
+    "query" : MetaIcon (img=icons_img["query"],
+                        label=_("Query raster/vector map(s)"),
+                        desc=_("Query selected raster/vector map(s)")),
     "zoom_back"  : MetaIcon (img=icons_img["zoom_back"],
                              label=_("Return to previous zoom")),
     "zoommenu"   : MetaIcon (img=icons_img["zoommenu"],
