[GRASS-SVN] r33224 - in grass/trunk: display/d.geodesic
display/d.histogram display/d.linegraph display/d.rast
display/d.rhumbline include lib/cairodriver lib/driver
lib/htmldriver lib/pngdriver lib/psdriver lib/raster
svn_grass at osgeo.org
Tue Sep 2 14:50:59 EDT 2008
Author: glynn
Date: 2008-09-02 14:50:59 -0400 (Tue, 02 Sep 2008)
New Revision: 33224
Removed:
grass/trunk/lib/cairodriver/Respond.c
grass/trunk/lib/driver/Respond.c
grass/trunk/lib/pngdriver/Respond.c
grass/trunk/lib/psdriver/Respond.c
grass/trunk/display/d.geodesic/plot.c
grass/trunk/display/d.histogram/main.c
grass/trunk/display/d.linegraph/main.c
grass/trunk/display/d.rast/display.c
grass/trunk/display/d.rhumbline/plot.c
grass/trunk/include/raster.h
grass/trunk/lib/cairodriver/Driver.c
grass/trunk/lib/cairodriver/Graph.c
grass/trunk/lib/cairodriver/cairodriver.h
grass/trunk/lib/cairodriver/cairodriver.html
grass/trunk/lib/driver/driver.h
grass/trunk/lib/htmldriver/Driver.c
grass/trunk/lib/pngdriver/Driver.c
grass/trunk/lib/pngdriver/Graph_set.c
grass/trunk/lib/pngdriver/pngdriver.h
grass/trunk/lib/pngdriver/pngdriver.html
grass/trunk/lib/psdriver/Driver.c
grass/trunk/lib/psdriver/psdriver.h
grass/trunk/lib/raster/raster.c
Remove R_flush()
Modified: grass/trunk/display/d.geodesic/plot.c
--- grass/trunk/display/d.geodesic/plot.c 2008-09-02 15:04:26 UTC (rev 33223)
+++ grass/trunk/display/d.geodesic/plot.c 2008-09-02 18:50:59 UTC (rev 33224)
@@ -58,7 +58,6 @@
G_plot_where_xy(lon1, (lat1 + lat2) / 2, &text_x, &text_y);
G_plot_line(lon1, lat1, lon2, lat2);
- R_flush();
distance = G_geodesic_distance(lon1, lat1, lon2, lat2);
sprintf(buf, "%.0f miles\n", METERS_TO_MILES(distance));
@@ -70,7 +69,6 @@
D_move_abs(text_x, text_y);
D_use_color(text_color);
R_text(buf);
- R_flush();
return 0;
Modified: grass/trunk/display/d.histogram/main.c
--- grass/trunk/display/d.histogram/main.c 2008-09-02 15:04:26 UTC (rev 33223)
+++ grass/trunk/display/d.histogram/main.c 2008-09-02 18:50:59 UTC (rev 33224)
@@ -211,7 +211,6 @@
else
bar(&dist_stats, &pcolors);
- R_flush();
R_close_driver();
exit(EXIT_SUCCESS);
Modified: grass/trunk/display/d.linegraph/main.c
--- grass/trunk/display/d.linegraph/main.c 2008-09-02 15:04:26 UTC (rev 33223)
+++ grass/trunk/display/d.linegraph/main.c 2008-09-02 18:50:59 UTC (rev 33224)
@@ -333,8 +333,8 @@
for (i = 0; i <= num_y_files; i++) {
if ((in[i].fp = fopen(in[i].full_name, "r")) == NULL) {
- sprintf(txt, "Could not open input file <%s>.", in[i].full_name);
- death(txt);
+ R_close_driver();
+ G_fatal_error(_("Unable to open input file <%s>"), in[i].full_name);
@@ -352,8 +352,8 @@
/* didn't find a number or hit EOF before our time */
if ((err != 1) || (err == EOF)) {
- sprintf(txt, _("Problem reading X data file at line %d"), line);
- death(txt);
+ R_close_driver();
+ G_fatal_error(_("Problem reading X data file at line %d"), line);
/* for each Y data file, get a value and compute where to draw it */
@@ -362,10 +362,9 @@
if (line < in[i].num_pnts) {
err = fscanf(in[i].fp, "%f", &in[i].value);
if ((in[i].num_pnts >= line) && (err != 1)) {
- sprintf(txt,
- _("Problem reading <%s> data file at line %d"),
- in[i].name, line);
- death(txt);
+ R_close_driver();
+ G_fatal_error(_("Problem reading <%s> data file at line %d"),
+ in[i].name, line);
/* in case the Y file has fewer lines than the X file, we will skip
@@ -554,7 +553,6 @@
D_use_color(title_color);
D_polyline_abs(x_line, y_line, 3);
- R_flush();
R_close_driver();
exit(EXIT_SUCCESS);
@@ -566,11 +564,3 @@
return ((float)(x - y * d));
-/* a function for making an exit after the R_driver is open */
-int death(char *gasp)
- R_flush();
- R_close_driver();
- G_fatal_error("%s", gasp);
Modified: grass/trunk/display/d.rast/display.c
--- grass/trunk/display/d.rast/display.c 2008-09-02 15:04:26 UTC (rev 33223)
+++ grass/trunk/display/d.rast/display.c 2008-09-02 18:50:59 UTC (rev 33224)
@@ -71,7 +71,7 @@
D_cell_draw_end();
- R_flush();
G_percent(nrows, nrows, 2);
/* Wrap up and return */
Modified: grass/trunk/display/d.rhumbline/plot.c
--- grass/trunk/display/d.rhumbline/plot.c 2008-09-02 15:04:26 UTC (rev 33223)
+++ grass/trunk/display/d.rhumbline/plot.c 2008-09-02 18:50:59 UTC (rev 33224)
@@ -39,7 +39,6 @@
- R_flush();
return 0;
Modified: grass/trunk/include/raster.h
--- grass/trunk/include/raster.h 2008-09-02 15:04:26 UTC (rev 33223)
+++ grass/trunk/include/raster.h 2008-09-02 18:50:59 UTC (rev 33224)
@@ -1,7 +1,6 @@
#ifndef _GRASS_RASTER_H
#define _GRASS_RASTER_H
-void R_flush(void);
int R_open_driver(void);
void R_close_driver(void);
Modified: grass/trunk/lib/cairodriver/Driver.c
--- grass/trunk/lib/cairodriver/Driver.c 2008-09-02 15:04:26 UTC (rev 33223)
+++ grass/trunk/lib/cairodriver/Driver.c 2008-09-02 18:50:59 UTC (rev 33224)
@@ -39,7 +39,6 @@
drv.Begin_scaled_raster = Cairo_begin_scaled_raster;
drv.Scaled_raster = Cairo_scaled_raster;
drv.End_scaled_raster = Cairo_end_scaled_raster;
- drv.Respond = Cairo_Respond;
drv.color_rgb = Cairo_color_rgb;
drv.draw_line = Cairo_draw_line;
drv.draw_point = Cairo_draw_point;
Modified: grass/trunk/lib/cairodriver/Graph.c
--- grass/trunk/lib/cairodriver/Graph.c 2008-09-02 15:04:26 UTC (rev 33223)
+++ grass/trunk/lib/cairodriver/Graph.c 2008-09-02 18:50:59 UTC (rev 33224)
@@ -233,9 +233,6 @@
else
ca.bgcolor_a = 1.0;
- p = getenv("GRASS_PNG_AUTO_WRITE");
- ca.auto_write = p && strcmp(p, "TRUE") == 0;
antialias = CAIRO_ANTIALIAS_DEFAULT;
p = getenv("GRASS_ANTIALIAS");
if (p && G_strcasecmp(p, "default") == 0)
Deleted: grass/trunk/lib/cairodriver/Respond.c
--- grass/trunk/lib/cairodriver/Respond.c 2008-09-02 15:04:26 UTC (rev 33223)
+++ grass/trunk/lib/cairodriver/Respond.c 2008-09-02 18:50:59 UTC (rev 33224)
@@ -1,24 +0,0 @@
- \file cairodriver/Respond.c
- \brief GRASS cairo display driver - write image
- (C) 2007-2008 by Lars Ahlzen and the GRASS Development Team
- This program is free software under the GNU General Public License
- (>=v2). Read the file COPYING that comes with GRASS for details.
- \author Lars Ahlzen <lars ahlzen.com> (original contibutor)
- \author Glynn Clements
-#include "cairodriver.h"
- \brief Write image
-void Cairo_Respond(void)
- if (ca.auto_write)
- cairo_write_image();
Modified: grass/trunk/lib/cairodriver/cairodriver.h
--- grass/trunk/lib/cairodriver/cairodriver.h 2008-09-02 15:04:26 UTC (rev 33223)
+++ grass/trunk/lib/cairodriver/cairodriver.h 2008-09-02 18:50:59 UTC (rev 33224)
@@ -53,7 +53,6 @@
int file_type;
int width, height, stride;
unsigned char *grid;
- int auto_write;
double bgcolor_r, bgcolor_g, bgcolor_b, bgcolor_a;
int modified;
int mapped;
@@ -82,7 +81,6 @@
extern void Cairo_Polygon(const double *, const double *, int);
extern void Cairo_Polyline(const double *, const double *, int);
extern void Cairo_Polydots(const double *, const double *, int);
-extern void Cairo_Respond(void);
extern void Cairo_draw_text(const char *);
extern void Cairo_text_box(const char *, double *, double *, double *, double *);
extern void Cairo_set_font(const char *);
Modified: grass/trunk/lib/cairodriver/cairodriver.html
--- grass/trunk/lib/cairodriver/cairodriver.html 2008-09-02 15:04:26 UTC (rev 33223)
+++ grass/trunk/lib/cairodriver/cairodriver.html 2008-09-02 18:50:59 UTC (rev 33224)
@@ -69,13 +69,6 @@
<LI><B>GRASS_TRANSPARENT=[TRUE|FALSE]</B><BR>
sets transparent background on (TRUE) or off (FALSE, default).
</LI>
- <LI><B>GRASS_AUTO_WRITE=[TRUE|FALSE]</B><BR>
- if set to <tt>TRUE</tt>, the image file will be written after each
- operation (i.e. whenever a client disconnects), rather than
- only being written out when the driver terminates.<BR>
- (Note: This only applies to bitmap formats - vector formats
- are always written directly to file).
- </LI>
<LI><B>GRASS_PNG_READ</B><BR>
if <tt>TRUE</tt>, the Cairo driver will initialize the image from
the contents of GRASS_PNGFILE.<BR>
Deleted: grass/trunk/lib/driver/Respond.c
--- grass/trunk/lib/driver/Respond.c 2008-09-02 15:04:26 UTC (rev 33223)
+++ grass/trunk/lib/driver/Respond.c 2008-09-02 18:50:59 UTC (rev 33224)
@@ -1,9 +0,0 @@
-#include "driver.h"
-#include "driverlib.h"
-void COM_Respond(void)
- if (driver->Respond)
- (*driver->Respond) ();
Modified: grass/trunk/lib/driver/driver.h
--- grass/trunk/lib/driver/driver.h 2008-09-02 15:04:26 UTC (rev 33223)
+++ grass/trunk/lib/driver/driver.h 2008-09-02 18:50:59 UTC (rev 33224)
@@ -35,7 +35,6 @@
const unsigned char *,
const unsigned char *, const unsigned char *);
void (*End_scaled_raster)(void);
- void (*Respond)(void);
void (*color_rgb)(int, int, int);
void (*draw_line)(double, double, double, double);
@@ -112,9 +111,6 @@
extern void COM_end_scaled_raster(void);
-/* Respond.c */
-extern void COM_Respond(void);
/* Set_window.c */
extern void COM_Set_window(double, double, double, double);
extern void COM_Get_window(double *, double *, double *, double *);
Modified: grass/trunk/lib/htmldriver/Driver.c
--- grass/trunk/lib/htmldriver/Driver.c 2008-09-02 15:04:26 UTC (rev 33223)
+++ grass/trunk/lib/htmldriver/Driver.c 2008-09-02 18:50:59 UTC (rev 33224)
@@ -37,7 +37,6 @@
drv.Begin_scaled_raster = NULL;
drv.Scaled_raster = NULL;
drv.End_scaled_raster = NULL;
- drv.Respond = NULL;
drv.color_rgb = NULL;
drv.draw_line = NULL;
drv.draw_point = NULL;
Modified: grass/trunk/lib/pngdriver/Driver.c
--- grass/trunk/lib/pngdriver/Driver.c 2008-09-02 15:04:26 UTC (rev 33223)
+++ grass/trunk/lib/pngdriver/Driver.c 2008-09-02 18:50:59 UTC (rev 33224)
@@ -39,7 +39,6 @@
drv.Begin_scaled_raster = PNG_begin_scaled_raster;
drv.Scaled_raster = PNG_scaled_raster;
- drv.Respond = PNG_Respond;
drv.color_rgb = PNG_color_rgb;
drv.draw_line = PNG_draw_line;
drv.draw_point = PNG_draw_point;
Modified: grass/trunk/lib/pngdriver/Graph_set.c
--- grass/trunk/lib/pngdriver/Graph_set.c 2008-09-02 15:04:26 UTC (rev 33223)
+++ grass/trunk/lib/pngdriver/Graph_set.c 2008-09-02 18:50:59 UTC (rev 33224)
@@ -71,9 +71,6 @@
G_message("PNG: GRASS_TRUECOLOR status: %s",
png.true_color ? "TRUE" : "FALSE");
- png.auto_write = p && strcmp(p, "TRUE") == 0;
p = getenv("GRASS_PNG_MAPPED");
do_map = p && strcmp(p, "TRUE") == 0;
Deleted: grass/trunk/lib/pngdriver/Respond.c
--- grass/trunk/lib/pngdriver/Respond.c 2008-09-02 15:04:26 UTC (rev 33223)
+++ grass/trunk/lib/pngdriver/Respond.c 2008-09-02 18:50:59 UTC (rev 33224)
@@ -1,8 +0,0 @@
-#include "pngdriver.h"
-void PNG_Respond(void)
- if (png.auto_write)
- write_image();
Modified: grass/trunk/lib/pngdriver/pngdriver.h
--- grass/trunk/lib/pngdriver/pngdriver.h 2008-09-02 15:04:26 UTC (rev 33223)
+++ grass/trunk/lib/pngdriver/pngdriver.h 2008-09-02 18:50:59 UTC (rev 33224)
@@ -15,7 +15,6 @@
char *file_name;
int current_color;
int true_color;
- int auto_write;
int has_alpha;
int mapped;
@@ -60,7 +59,6 @@
extern int PNG_scaled_raster(int, int, const unsigned char *,
const unsigned char *, const unsigned char *,
-extern void PNG_Respond(void);
extern void PNG_Set_window(double, double, double, double);
extern void PNG_color_rgb(int, int, int);
extern void PNG_draw_bitmap(int, int, int, const unsigned char *);
Modified: grass/trunk/lib/pngdriver/pngdriver.html
--- grass/trunk/lib/pngdriver/pngdriver.html 2008-09-02 15:04:26 UTC (rev 33223)
+++ grass/trunk/lib/pngdriver/pngdriver.html 2008-09-02 18:50:59 UTC (rev 33224)
@@ -43,10 +43,6 @@
sets true-color support. Default is TRUE</LI>
<LI><B>GRASS_PNG_COMPRESSION=[0|1|9]</B><BR>
compression level of PNG files (0 = none, 1 = fastest, 9 = best, default is 6)</LI>
- <LI><B>GRASS_PNG_AUTO_WRITE=[TRUE|FALSE]</B><BR>
- only being written out when the driver terminates.</LI>
if <tt>TRUE</tt>, the PNG driver will initialize the image from
the contents of GRASS_PNGFILE.</LI>
Modified: grass/trunk/lib/psdriver/Driver.c
--- grass/trunk/lib/psdriver/Driver.c 2008-09-02 15:04:26 UTC (rev 33223)
+++ grass/trunk/lib/psdriver/Driver.c 2008-09-02 18:50:59 UTC (rev 33224)
@@ -39,7 +39,6 @@
drv.Begin_scaled_raster = PS_begin_scaled_raster;
drv.Scaled_raster = PS_scaled_raster;
drv.End_scaled_raster = PS_end_scaled_raster;
- drv.Respond = PS_Respond;
drv.color_rgb = PS_color_rgb;
drv.draw_line = PS_draw_line;
drv.draw_point = PS_draw_point;
Deleted: grass/trunk/lib/psdriver/Respond.c
--- grass/trunk/lib/psdriver/Respond.c 2008-09-02 15:04:26 UTC (rev 33223)
+++ grass/trunk/lib/psdriver/Respond.c 2008-09-02 18:50:59 UTC (rev 33224)
@@ -1,7 +0,0 @@
-#include "psdriver.h"
-void PS_Respond(void)
- fflush(ps.outfp);
Modified: grass/trunk/lib/psdriver/psdriver.h
--- grass/trunk/lib/psdriver/psdriver.h 2008-09-02 15:04:26 UTC (rev 33223)
+++ grass/trunk/lib/psdriver/psdriver.h 2008-09-02 18:50:59 UTC (rev 33224)
@@ -32,7 +32,6 @@
extern void PS_Graph_close(void);
extern int PS_Graph_set(void);
extern void PS_Line_width(double);
-extern void PS_Respond(void);
extern void PS_Set_window(double, double, double, double);
extern void PS_color_rgb(int, int, int);
extern void PS_draw_bitmap(int, int, int, const unsigned char *);
Modified: grass/trunk/lib/raster/raster.c
--- grass/trunk/lib/raster/raster.c 2008-09-02 15:04:26 UTC (rev 33223)
+++ grass/trunk/lib/raster/raster.c 2008-09-02 18:50:59 UTC (rev 33224)
@@ -71,16 +71,10 @@
return 0;
-void R_flush(void)
- COM_Respond();
const char *cmd = getenv("GRASS_NOTIFY");
- COM_Respond();
COM_Graph_close();
if (cmd)
