[GRASS-SVN] r33244 - in grass-addons/vector: v.buffer2 v.parallel2
svn_grass at osgeo.org
Thu Sep 4 06:29:49 EDT 2008
Author: rmatev
Date: 2008-09-04 06:29:48 -0400 (Thu, 04 Sep 2008)
New Revision: 33244
grass-addons/vector/v.buffer2/vlib_buffer.c
grass-addons/vector/v.parallel2/vlib_buffer.c
Fixed "extra islands" bug
Modified: grass-addons/vector/v.buffer2/vlib_buffer.c
--- grass-addons/vector/v.buffer2/vlib_buffer.c 2008-09-04 10:02:31 UTC (rev 33243)
+++ grass-addons/vector/v.buffer2/vlib_buffer.c 2008-09-04 10:29:48 UTC (rev 33244)
@@ -794,19 +794,12 @@
res = extract_inner_contour(pg2, &winding, cPoints);
while (res != 0) {
if (winding == 0) {
- if (round) {
- add_line_to_array(cPoints, &arrPoints, &count, &allocated, more);
- cPoints = Vect_new_line_struct();
- else {
- /* fixes some problems for straight corners buffers... */
- if (!Vect_point_in_poly(cPoints->x[0], cPoints->y[0], area_outer)) {
- if (Vect_get_point_in_poly(cPoints, &px, &py) != 0)
- G_fatal_error("Vect_get_point_in_poly() failed.");
- if (!point_in_buf(area_outer, px, py, da, db, dalpha)) {
+ if (!Vect_point_in_poly(cPoints->x[0], cPoints->y[0], area_outer)) {
+ if (Vect_get_point_in_poly(cPoints, &px, &py) != 0)
+ G_fatal_error("Vect_get_point_in_poly() failed.");
+ if (!point_in_buf(area_outer, px, py, da, db, dalpha)) {
+ add_line_to_array(cPoints, &arrPoints, &count, &allocated, more);
+ cPoints = Vect_new_line_struct();
@@ -839,30 +832,6 @@
pg_destroy_struct(pg2);
-/* for (i = 0; i < count2; i++) {
- res = Vect_line_check_intersection(tPoints, arrPoints2[i], 0);
- if (res != 0)
- continue;
- res = Vect_point_in_poly(arrPoints2[i]->x[0], arrPoints2[i]->y[0], tPoints);
- if (res == 0)
- continue;
- res = Vect_get_point_in_poly(arrPoints2[i], &px, &py);
- if (res != 0)
- if (point_in_buf(tPoints, px, py, da, db, dalpha))
- continue;
- if (allocated == count) {
- allocated += more;
- arrPoints = G_realloc(arrPoints, allocated*sizeof(struct line_pnts *));
- arrPoints[count] = Vect_new_line_struct();
- Vect_copy_xyz_to_pnts(arrPoints[count], arrPoints2[i]->x, arrPoints2[i]->y, arrPoints2[i]->z, arrPoints2[i]->n_points);
- count++;
arrPoints = G_realloc(arrPoints, count*sizeof(struct line_pnts *));
Modified: grass-addons/vector/v.parallel2/vlib_buffer.c
--- grass-addons/vector/v.parallel2/vlib_buffer.c 2008-09-04 10:02:31 UTC (rev 33243)
+++ grass-addons/vector/v.parallel2/vlib_buffer.c 2008-09-04 10:29:48 UTC (rev 33244)
while (res != 0) {
if (winding == 0) {
- if (round) {
- else {
- if (res != 0)
- continue;
- if (res == 0)
- continue;
- if (res != 0)
- continue;
- count++;
