[GRASS-SVN] r33245 - in grass-addons/vector: v.buffer2 v.parallel2
svn_grass at osgeo.org
Thu Sep 4 08:29:43 EDT 2008
Author: rmatev
Date: 2008-09-04 08:29:43 -0400 (Thu, 04 Sep 2008)
New Revision: 33245
grass-addons/vector/v.buffer2/dgraph.c
grass-addons/vector/v.buffer2/e_intersect.c
grass-addons/vector/v.buffer2/vlib_buffer.c
grass-addons/vector/v.parallel2/dgraph.c
grass-addons/vector/v.parallel2/e_intersect.c
grass-addons/vector/v.parallel2/vlib_buffer.c
Changed debug levels
Modified: grass-addons/vector/v.buffer2/dgraph.c
--- grass-addons/vector/v.buffer2/dgraph.c 2008-09-04 10:29:48 UTC (rev 33244)
+++ grass-addons/vector/v.buffer2/dgraph.c 2008-09-04 12:29:43 UTC (rev 33245)
@@ -187,7 +187,7 @@
struct seg_intersection_list *il;
struct intersection_point **sorted;
- G_debug(4, "find_all_intersections()");
+ G_debug(3, "find_all_intersections()");
np = Points->n_points;
x = Points->x;
@@ -196,12 +196,12 @@
si = create_si_struct(np-1);
looped = ((x[0] == x[np-1]) && (y[0] == y[np-1]));
- G_debug(4, " looped=%d", looped);
+ G_debug(3, " looped=%d", looped);
- G_debug(4, " finding intersections...");
+ G_debug(3, " finding intersections...");
for (i = 0; i < np-1; i++) {
for (j = i+1; j < np-1; j++) {
- G_debug(3, " checking %d-%d %d-%d", i, i+1, j, j+1);
+ G_debug(4, " checking %d-%d %d-%d", i, i+1, j, j+1);
/*res = segment_intersection_2d_e(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1, &y1, &x2, &y2);*/
res = segment_intersection_2d(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1, &y1, &x2, &y2);
/* res2 = segment_intersection_2d_e(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1_, &y1_, &x2_, &y2_);
@@ -210,7 +210,7 @@
segment_intersection_2d_test(x[i], y[i], x[i+1], y[i+1], x[j], y[j], x[j+1], y[j+1], &x1, &y1, &x2, &y2);
- G_debug(3, " intersection type = %d", res);
+ G_debug(4, " intersection type = %d", res);
if (res == 1) {
add_ipoint(Points, i, j, x1, y1, si);
} else if ((res >= 2) && (res <= 5)) {
@@ -224,9 +224,9 @@
add_ipoint(Points, 0, -1, Points->x[0], Points->y[0], si);
add_ipoint(Points, np-2, -1, Points->x[np-1], Points->y[np-1], si);
- G_debug(4, " finding intersections...done");
+ G_debug(3, " finding intersections...done");
- G_debug(4, " postprocessing...");
+ G_debug(3, " postprocessing...");
if (si->ipallocated > si->ipcount) {
si->ipallocated = si->ipcount;
si->ip = G_realloc(si->ip, (si->ipcount)*sizeof(struct intersection_point));
@@ -273,7 +273,7 @@
si->group_count = group;
- G_debug(4, " postprocessing...done");
+ G_debug(3, " postprocessing...done");
/* output contents of si */
for (i = 0; i < si->ilcount; i++) {
@@ -387,7 +387,7 @@
struct pg_edge *edge;
int i, j, t, v;
- G_debug(4, "pg_create()");
+ G_debug(3, "pg_create()");
si = find_all_intersections(Points);
pg = pg_create_struct(si->group_count, 2*(si->ipcount));
Modified: grass-addons/vector/v.buffer2/e_intersect.c
--- grass-addons/vector/v.buffer2/e_intersect.c 2008-09-04 10:29:48 UTC (rev 33244)
+++ grass-addons/vector/v.buffer2/e_intersect.c 2008-09-04 12:29:43 UTC (rev 33245)
@@ -556,6 +556,7 @@
int segment_intersection_2d(double ax1, double ay1, double ax2, double ay2, double bx1, double by1, double bx2, double by2,
double *x1, double *y1, double *x2, double *y2)
+ const DLEVEL = 4;
double t;
double max_ax, min_ax, max_ay, min_ay;
double max_bx, min_bx, max_by, min_by;
@@ -564,7 +565,7 @@
double d, da, db;
/* TODO: Works for points ? */
- G_debug(3, "segment_intersection_2d()");
+ G_debug(DLEVEL, "segment_intersection_2d()");
G_debug(4, " ax1 = %.18f, ay1 = %.18f", ax1, ay1);
G_debug(4, " ax2 = %.18f, ay2 = %.18f", ax2, ay2);
G_debug(4, " bx1 = %.18f, by1 = %.18f", bx1, by1);
@@ -577,35 +578,35 @@
/* Check for identical segments */
if ((f11 && f22) || (f12 && f21)) {
- G_debug (3, " identical segments" );
+ G_debug(DLEVEL, " identical segments" );
*x1 = ax1; *y1 = ay1;
*x2 = ax2; *y2 = ay2;
return 5;
/* Check for identical endpoints */
if (f11 || f12) {
- G_debug (3, " connected by endpoints" );
+ G_debug(DLEVEL, " connected by endpoints" );
return 1;
if (f21 || f22) {
+ G_debug (DLEVEL, " connected by endpoints" );
*x1 = ax2; *y1 = ay2;
return 1;
if ((fmax(ax1, ax2) < fmin(bx1, bx2)) || (fmax(bx1, bx2) < fmin(ax1, ax2))) {
- G_debug(3, " no intersection (disjoint bounding boxes)");
+ G_debug(DLEVEL, " no intersection (disjoint bounding boxes)");
return 0;
if ((fmax(ay1, ay2) < fmin(by1, by2)) || (fmax(by1, by2) < fmin(ay1, ay2))) {
return 0;
d = D;
if (d != 0) {
- G_debug(3, " general position");
+ G_debug(DLEVEL, " general position");
da = DA;
@@ -619,36 +620,36 @@
if (d > 0) {
if ((da < 0) || (da > d)) {
- G_debug(3, " no intersection");
+ G_debug(DLEVEL, " no intersection");
return 0;
db = DB;
if ((db < 0) || (db > d)) {
return 0;
else { /* if d < 0 */
if ((da > 0) || (da < d)) {
return 0;
db = DB;
if ((db > 0) || (db < d)) {
return 0;
- /*G_debug(3, " ra=%.17g rb=%.17g", mpf_get_d(dda)/mpf_get_d(dd), mpf_get_d(ddb)/mpf_get_d(dd));*/
- /*G_debug(3, " sgn_d=%d sgn_da=%d sgn_db=%d cmp(dda,dd)=%d cmp(ddb,dd)=%d", sgn_d, sgn_da, sgn_db, mpf_cmp(dda, dd), mpf_cmp(ddb, dd));*/
+ /*G_debug(DLEVEL, " ra=%.17g rb=%.17g", mpf_get_d(dda)/mpf_get_d(dd), mpf_get_d(ddb)/mpf_get_d(dd));*/
+ /*G_debug(DLEVEL, " sgn_d=%d sgn_da=%d sgn_db=%d cmp(dda,dd)=%d cmp(ddb,dd)=%d", sgn_d, sgn_da, sgn_db, mpf_cmp(dda, dd), mpf_cmp(ddb, dd));*/
*x1 = ax1 + (ax2 - ax1)*da/d;
*y1 = ay1 + (ay2 - ay1)*da/d;
- G_debug(3, " intersection %.16g, %.16g", *x1, *y1);
+ G_debug(DLEVEL, " intersection %.16g, %.16g", *x1, *y1);
return 1;
@@ -657,7 +658,7 @@
db = DB;
if ((da != 0) || (db != 0)) {
/* segments are parallel */
- G_debug(3, " parallel segments");
+ G_debug(DLEVEL, " parallel segments");
return 0;
@@ -686,19 +687,19 @@
SWAP(bx2, by2);
- G_debug(3, " collinear segments");
+ G_debug(DLEVEL, " collinear segments");
if ((bx2 < ax1) || (bx1 > ax2)) {
return 0;
/* there is overlap or connected end points */
- G_debug(3, " overlap");
+ G_debug(DLEVEL, " overlap");
/* a contains b */
if ((ax1 < bx1) && (ax2 > bx2)) {
- G_debug(3, " a contains b");
+ G_debug(DLEVEL, " a contains b");
if (!vertical) {
*x1 = bx1; *y1 = by1;
*x2 = bx2; *y2 = by2;
@@ -712,7 +713,7 @@
/* b contains a */
if ((ax1 > bx1) && (ax2 < bx2)) {
- G_debug(3, " b contains a");
+ G_debug(DLEVEL, " b contains a");
if (!vertical) {
@@ -725,7 +726,7 @@
/* general overlap, 2 intersection points */
- G_debug(3, " partial overlap");
+ G_debug(DLEVEL, " partial overlap");
if ((bx1 > ax1) && (bx1 < ax2)) { /* b1 is in a */
if (!vertical) {
@@ -868,23 +869,23 @@
if (sgn_d > 0) {
if ((sgn_da < 0) || (mpf_cmp(dda, dd) > 0)) {
return 0;
if ((sgn_db < 0) || (mpf_cmp(ddb, dd) > 0)) {
return 0;
else { /* if sgn_d < 0 */
if ((sgn_da > 0) || (mpf_cmp(dda, dd) < 0)) {
return 0;
if ((sgn_db > 0) || (mpf_cmp(ddb, dd) < 0)) {
return 0;
Modified: grass-addons/vector/v.buffer2/vlib_buffer.c
--- grass-addons/vector/v.buffer2/vlib_buffer.c 2008-09-04 10:29:48 UTC (rev 33244)
+++ grass-addons/vector/v.buffer2/vlib_buffer.c 2008-09-04 12:29:43 UTC (rev 33245)
@@ -160,7 +160,7 @@
double cosa, sina, r;
int inner_corner, turns360;
- G_debug(4, "parallel_line()");
+ G_debug(3, "parallel_line()");
if (looped && 0) {
/* start point != end point */
@@ -312,8 +312,7 @@
double angle0, angle1;
- G_debug(3, "convolution_line()");
- G_debug(3, " side = %d", side);
+ G_debug(3, "convolution_line() side = %d", side);
x = Points->x;
@@ -463,7 +462,7 @@
double opt_angle, tangle;
int opt_j, opt_side, opt_flag;
- G_debug(4, "extract_contour(): v1=%d, v2=%d, side=%d, stop_at_line_end=%d", first->v1, first->v2, side, stop_at_line_end);
+ G_debug(3, "extract_contour(): v1=%d, v2=%d, side=%d, stop_at_line_end=%d", first->v1, first->v2, side, stop_at_line_end);
Vect_reset_line(nPoints);
@@ -582,7 +581,7 @@
double min_x, min_angle, ta;
- G_debug(4, "extract_outer_contour()");
+ G_debug(3, "extract_outer_contour()");
if (side != 0) {
G_fatal_error(" side != 0 feature not implemented");
@@ -626,7 +625,7 @@
int i, w;
- G_debug(4, "extract_inner_contour()");
+ G_debug(3, "extract_inner_contour()");
for (i = 0; i < pg->ecount; i++) {
edge = &(pg->e[i]);
@@ -663,6 +662,8 @@
double vx, vy, wx, wy, mx, my, nx, ny;
double len, tx, ty, d, da2;
+ G_debug(3, "point_in_buf()");
dalpha *= PI/180; /* convert dalpha from degrees to radians */
@@ -775,7 +776,7 @@
int allocated = 0;
double px, py;
- G_debug(4, "buffer_lines()");
+ G_debug(3, "buffer_lines()");
auto_side = (side == 0);
@@ -868,7 +869,7 @@
int more = 8;
int isles_allocated = 0;
- G_debug(4, "Vect_line_buffer()");
+ G_debug(2, "Vect_line_buffer()");
/* initializations */
tPoints = Vect_new_line_struct();
@@ -906,7 +907,7 @@
double max = fmax(da, db);
- G_debug(4, "Vect_area_buffer()");
+ G_debug(2, "Vect_area_buffer()");
@@ -960,6 +961,8 @@
double angular_tol, angular_step, phi1;
int j, nsegments;
+ G_debug(2, "Vect_point_buffer()");
*oPoints = Vect_new_line_struct();
@@ -983,6 +986,8 @@
/* close the output line */
Vect_append_point(*oPoints, (*oPoints)->x[0], (*oPoints)->y[0], (*oPoints)->z[0]);
+ return;
@@ -998,7 +1003,7 @@
void Vect_line_parallel2(struct line_pnts *InPoints, double da, double db, double dalpha, int side, int round, double tol, struct line_pnts *OutPoints )
- G_debug(4, "Vect_line_parallel(): npoints = %d, da = %f, db = %f, dalpha = %f, side = %d, round_corners = %d, tol = %f",
+ G_debug(2, "Vect_line_parallel(): npoints = %d, da = %f, db = %f, dalpha = %f, side = %d, round_corners = %d, tol = %f",
InPoints->n_points, da, db, dalpha, side, round, tol);
parallel_line(InPoints, da, db, dalpha, side, round, 1, NON_LOOPED_LINE, tol, OutPoints);
Modified: grass-addons/vector/v.parallel2/dgraph.c
--- grass-addons/vector/v.parallel2/dgraph.c 2008-09-04 10:29:48 UTC (rev 33244)
+++ grass-addons/vector/v.parallel2/dgraph.c 2008-09-04 12:29:43 UTC (rev 33245)
@@ -187,7 +187,7 @@
x = Points->x;
@@ -210,7 +210,7 @@
if (res == 1) {
@@ -224,9 +224,9 @@
@@ -273,7 +273,7 @@
@@ -387,7 +387,7 @@
int i, j, t, v;
Modified: grass-addons/vector/v.parallel2/e_intersect.c
--- grass-addons/vector/v.parallel2/e_intersect.c 2008-09-04 10:29:48 UTC (rev 33244)
+++ grass-addons/vector/v.parallel2/e_intersect.c 2008-09-04 12:29:43 UTC (rev 33245)
@@ -556,6 +556,7 @@
+ const DLEVEL = 4;
double t;
@@ -564,7 +565,7 @@
double d, da, db;
return 5;
if (f11 || f12) {
return 1;
if (f21 || f22) {
return 1;
return 0;
return 0;
d = D;
if (d != 0) {
da = DA;
if (d > 0) {
return 0;
db = DB;
return 0;
return 0;
db = DB;
return 0;
return 1;
@@ -657,7 +658,7 @@
db = DB;
return 0;
SWAP(bx2, by2);
return 0;
/* a contains b */
if (!vertical) {
@@ -712,7 +713,7 @@
/* b contains a */
if (!vertical) {
@@ -725,7 +726,7 @@
if (!vertical) {
if (sgn_d > 0) {
return 0;
return 0;
return 0;
return 0;
Modified: grass-addons/vector/v.parallel2/vlib_buffer.c
--- grass-addons/vector/v.parallel2/vlib_buffer.c 2008-09-04 10:29:48 UTC (rev 33244)
+++ grass-addons/vector/v.parallel2/vlib_buffer.c 2008-09-04 12:29:43 UTC (rev 33245)
@@ -160,7 +160,7 @@
if (looped && 0) {
@@ -312,8 +312,7 @@
x = Points->x;
@@ -463,7 +462,7 @@
@@ -582,7 +581,7 @@
if (side != 0) {
@@ -626,7 +625,7 @@
int i, w;
edge = &(pg->e[i]);
@@ -663,6 +662,8 @@
@@ -775,7 +776,7 @@
int allocated = 0;
double px, py;
@@ -868,7 +869,7 @@
int more = 8;
@@ -906,7 +907,7 @@
@@ -960,6 +961,8 @@
int j, nsegments;
@@ -983,6 +986,8 @@
+ return;
