[GRASS-SVN] r33272 - grass/trunk/display/d.thematic.area
svn_grass at osgeo.org
Fri Sep 5 06:21:18 EDT 2008
Author: mlennert
Date: 2008-09-05 06:21:18 -0400 (Fri, 05 Sep 2008)
New Revision: 33272
grass/trunk/display/d.thematic.area/main.c
we need the data array in any case, not only when algo= is used
Modified: grass/trunk/display/d.thematic.area/main.c
--- grass/trunk/display/d.thematic.area/main.c 2008-09-05 08:26:32 UTC (rev 33271)
+++ grass/trunk/display/d.thematic.area/main.c 2008-09-05 10:21:18 UTC (rev 33272)
@@ -230,6 +230,28 @@
val.d));
+ /*Get the sorted data */
+ ret = db_CatValArray_sort_by_value(&cvarr);
+ if (ret == DB_FAILED)
+ G_fatal_error("Could not sort array of values..");
+ data = (double *)G_malloc((nrec) * sizeof(double));
+ for (i = 0; i < nrec; i++)
+ data[i] = 0.0;
+ ctype = cvarr.ctype;
+ if (ctype == DB_C_TYPE_INT) {
+ data[i] = cvarr.value[i].val.i;
+ else {
+ data[i] = cvarr.value[i].val.d;
+ db_CatValArray_sort(&cvarr);
/*Get the list of relevant cats if where option is given */
if (where_opt->answer) {
ncat = db_select_int(driver, fi->table, fi->key, where_opt->answer,
@@ -290,27 +312,7 @@
if (algo_opt->answer && nbclass_opt->answer) {
- ret = db_CatValArray_sort_by_value(&cvarr);
- if (ret == DB_FAILED)
- G_fatal_error("Could not sort array of values..");
- data = (double *)G_malloc((nrec) * sizeof(double));
- for (i = 0; i < nrec; i++)
- data[i] = 0.0;
- ctype = cvarr.ctype;
- if (ctype == DB_C_TYPE_INT) {
- data[i] = cvarr.value[i].val.i;
- else {
- data[i] = cvarr.value[i].val.d;
- db_CatValArray_sort(&cvarr);
nclass = atoi(nbclass_opt->answer);
nbreaks = nclass - 1; /* we need one less classbreaks (min and
* max exluded) than classes */
