[GRASS-SVN] r33273 - grass/branches/develbranch_6/display/d.thematic.area
Fri Sep 5 06:45:27 EDT 2008
Author: mlennert
Date: 2008-09-05 06:45:27 -0400 (Fri, 05 Sep 2008)
New Revision: 33273
   grass/branches/develbranch_6/display/d.thematic.area/main.c
bug fix and code cleanup
(backport of 33246 and 33272 from trunk)
Modified: grass/branches/develbranch_6/display/d.thematic.area/main.c
--- grass/branches/develbranch_6/display/d.thematic.area/main.c	2008-09-05 10:21:18 UTC (rev 33272)
+++ grass/branches/develbranch_6/display/d.thematic.area/main.c	2008-09-05 10:45:27 UTC (rev 33273)
@@ -67,8 +67,7 @@
     dbCatValArray cvarr;
     struct Cell_head window;
     BOUND_BOX box;
-    double overlap, *breakpoints, min = 0, max = 0, *data = NULL, class_info =
-	0.0;
+    double overlap, *breakpoints, *data = NULL, class_info = 0.0;
     struct GASTATS stats;
     FILE *fd;
@@ -108,7 +107,7 @@
 			       "std;standard deviations;"
 			       "qua;quantiles;"
 			       "equ;equiprobable (normal distribution);");
-/*currently disabled because of bugs       "dis;discontinuities");*/
+    /*currently disabled because of bugs       "dis;discontinuities"); */
     nbclass_opt = G_define_option();
     nbclass_opt->key = "nbclasses";
@@ -263,6 +262,28 @@
 		 val.d));
+    /*Get the sorted data */
+    ret = db_CatValArray_sort_by_value(&cvarr);
+    if (ret == DB_FAILED)
+	G_fatal_error("Could not sort array of values..");
+    data = (double *)G_malloc((nrec) * sizeof(double));
+    for (i = 0; i < nrec; i++)
+	data[i] = 0.0;
+    ctype = cvarr.ctype;
+    if (ctype == DB_C_TYPE_INT) {
+	    data[i] = cvarr.value[i].val.i;
+    else {
+	    data[i] = cvarr.value[i].val.d;
+    db_CatValArray_sort(&cvarr);
     /*Get the list of relevant cats if where option is given */
     if (where_opt->answer) {
 	ncat = db_select_int(driver, fi->table, fi->key, where_opt->answer,
@@ -323,38 +344,7 @@
 	if (algo_opt->answer && nbclass_opt->answer) {
-	    ret = db_CatValArray_sort_by_value(&cvarr);
-	    if (ret == DB_FAILED)
-		G_fatal_error("Could not sort array of values..");
-	    data = (double *)G_malloc((nrec) * sizeof(double));
-	    for (i = 0; i < nrec; i++)
-		data[i] = 0.0;
-	    ctype = cvarr.ctype;
-	    if (ctype == DB_C_TYPE_INT) {
-		    data[i] = cvarr.value[i].val.i;
-	    else {
-		    data[i] = cvarr.value[i].val.d;
-	    /* min and max are needed later for the legend */
-	    if (cvarr.ctype == DB_C_TYPE_INT) {
-		min = cvarr.value[0].val.i;
-		max = cvarr.value[cvarr.n_values - 1].val.i;
-	    else {
-		min = cvarr.value[0].val.d;
-		max = cvarr.value[cvarr.n_values - 1].val.d;
-	    db_CatValArray_sort(&cvarr);
 	    nclass = atoi(nbclass_opt->answer);
 	    nbreaks = nclass - 1;	/* we need one less classbreaks (min and
 					 * max exluded) than classes */
@@ -456,7 +446,7 @@
 	frequencies[i] = 0.0;
     class_frequencies(data, nrec, nbreaks, breakpoints, frequencies);
-    /*Get basic statistics about the data*/
+    /*Get basic statistics about the data */
     basic_stats(data, nrec, &stats);
     if (legend_flag->answer) {
@@ -484,8 +474,8 @@
 	fprintf(stdout, "%f|%f|%i|%d:%d:%d\n",
-		stats.min, breakpoints[0], frequencies[0], colors[0].r, colors[0].g,
-		colors[0].b);
+		stats.min, breakpoints[0], frequencies[0], colors[0].r,
+		colors[0].g, colors[0].b);
 	for (i = 1; i < nbreaks; i++) {
@@ -506,7 +496,7 @@
 	fprintf(fd, "symbol basic/box %i 5 %i black %d:%d:%d\n", boxsize,
 		ypos, colors[0].r, colors[0].g, colors[0].b);
 	fprintf(fd, "move 8 %f \n", ypos - textsize / 2.5);
-	fprintf(fd, "text %f - %f | %i\n", min, breakpoints[0],
+	fprintf(fd, "text %f - %f | %i\n", stats.min, breakpoints[0],
 		frequencies[0]);
 	    ypos = 10 + i * 6;
@@ -521,8 +511,8 @@
 		ypos, colors[nbreaks].r, colors[nbreaks].g,
 		colors[nbreaks].b);
 	fprintf(fd, "move 8 %f\n", ypos - textsize / 2.5);
-	fprintf(fd, "text %f - %f | %i\n", breakpoints[nbreaks - 1], max,
-		frequencies[nbreaks]);
+	fprintf(fd, "text %f - %f | %i\n", breakpoints[nbreaks - 1],
+		stats.max, frequencies[nbreaks]);
 	fclose(fd);
