[GRASS-SVN] r33316 - in grass/trunk/gui/wxpython: gui_modules nviz
svn_grass at osgeo.org
Sun Sep 7 11:23:36 EDT 2008
Author: martinl
Date: 2008-09-07 11:23:36 -0400 (Sun, 07 Sep 2008)
New Revision: 33316
grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
grass/trunk/gui/wxpython/nviz/init.cpp
grass/trunk/gui/wxpython/nviz/nviz.h
wxGUI: bug fix - trac #297 wxNVIZ: crash or failure
use display region settings
(merge from devbr6, r33315)
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py 2008-09-07 15:22:04 UTC (rev 33315)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py 2008-09-07 15:23:36 UTC (rev 33316)
@@ -78,18 +78,21 @@
self.parent = parent # MapFrame
self.init = False
+ self.initView = False
# render mode
self.render = { 'quick' : False,
# do not render vector lines in quick mode
'vlines' : False,
'vpoints' : False }
- # list of loaded map layers
- self.layers = {}
- for type in ('raster', 'vlines', 'vpoints', '3d-raster'):
- self.layers[type] = {}
- self.layers[type]['name'] = []
- self.layers[type]['id'] = []
+ # list of loaded map layers (layer tree items)
+ self.layers = []
+ # use display region instead of computational
+ os.environ['GRASS_REGION'] = self.Map.SetRegion()
# create nviz instance
@@ -101,18 +104,15 @@
time.sleep(.1)
self.nvizClass = self.nvizThread.nvizClass
+ # GRASS_REGION needed only for initialization
+ del os.environ['GRASS_REGION']
# set current display
self.nvizClass.SetDisplay(self)
- # initialize mouse position
- self.lastX = self.x = 30
- self.lastY = self.y = 30
# default values
self.view = copy.deepcopy(UserSettings.Get(group='nviz', key='view')) # copy
@@ -150,9 +150,11 @@
dc = wx.PaintDC(self)
self.SetCurrent()
- if not self.init:
+ if not self.initView:
self.nvizClass.InitView()
+ self.initView = True
+ if not self.init:
self.LoadDataLayers()
self.ResetView()
@@ -171,10 +173,10 @@
# update widgets
win = self.parent.nvizToolWin.FindWindowById( \
self.parent.nvizToolWin.win['vector']['lines']['surface'])
- win.SetItems(self.layers['raster']['name'])
+ win.SetItems(self.GetLayerNames('raster'))
self.init = True
self.UpdateMap()
def OnMouseAction(self, event):
@@ -421,7 +423,7 @@
for sec in data.keys():
for sec1 in data[sec].keys():
for sec2 in data[sec][sec1].keys():
- if sec2 not in ('object', 'all'):
+ if sec2 != 'all':
data[sec][sec1][sec2]['update'] = None
event = wxUpdateProperties(data=data)
@@ -479,12 +481,11 @@
else:
print >> sys.stderr, "Nviz:" + _("Unsupported layer type '%s'") % layer.type
- self.layers[layer.type]['name'].append(layer.name)
- self.layers[layer.type]['id'].append(id)
+ self.layers.append(item)
# set default/workspace layer properties
data = self.SetMapObjProperties(item, id, nvizType)
# update properties
wx.PostEvent(self, event)
@@ -496,7 +497,7 @@
if layer.type == 'raster':
win = toolWin.FindWindowById( \
toolWin.win['vector']['lines']['surface'])
- win.SetItems(self.layers[layer.type]['name'])
+ win.SetItems(self.GetLayerNames(layer.type))
toolWin.UpdatePage(nvizType)
toolWin.SetPage(nvizType)
@@ -549,17 +550,15 @@
data[nvizType].pop('object')
- idx = self.layers[layer.type]['id'].index(id)
- del self.layers[layer.type]['name'][idx]
- del self.layers[layer.type]['id'][idx]
+ self.layers.remove(item)
# update tools window
if hasattr(self.parent, "nvizToolWin") and \
toolWin = self.parent.nvizToolWin
# remove surface page
if toolWin.notebook.GetSelection() == toolWin.page[nvizType]['id']:
@@ -605,8 +604,7 @@
# update layer properties
self.SetMapObjProperties(item, id, type)
- self.layers['v' + type]['name'].append(layer.name)
- self.layers['v' + type]['id'].append(id)
# update properties
data = self.tree.GetPyData(item)[0]['nviz']
@@ -659,10 +657,8 @@
data[vtype].pop('object')
- idx = self.layers['v' + vtype]['id'].index(id)
- del self.layers['v' + vtype]['name'][idx]
- del self.layers['v' + vtype]['id'][idx]
+ self.layers.remove(id)
vecType is None:
@@ -839,9 +835,10 @@
type = 'flat'
map = None
else:
- if len(self.layers['raster']['name']) > 0:
+ rasters = self.GetLayerNames('raster')
+ if len(rasters) > 0:
type = 'surface'
- map = self.layers['raster']['name'][0]
+ map = rasters[0]
else:
type = 'flat'
map = None
@@ -883,8 +880,9 @@
# mode
data['mode'] = { 'type' : 'surface',
'surface' : '', }
- data['mode']['surface'] = self.layers['raster']['name'][0]
+ data['mode']['surface'] = rasters[0]
# height
data['height'] = { 'value' : UserSettings.Get(group='nviz', key='vector',
@@ -897,7 +895,15 @@
def Reset(self):
"""Reset (unload data)"""
- self.nvizClass.Reset()
+ for item in self.layers:
+ type = self.tree.GetPyData(item)[0]['maplayer'].type
+ if type == 'raster':
+ self.UnloadRaster(item)
+ elif type == '3d-raster':
+ self.UnloadRaster3d(item)
+ elif type == 'vector':
+ self.UnloadVector(item)
self.init = False
def OnZoomToMap(self, event):
@@ -1122,19 +1128,18 @@
if data['color'].has_key('update') or \
data['width'].has_key('update') or \
data['mode'].has_key('update'):
- width = data['width']
- color = data['color']
+ width = data['width']['value']
+ color = data['color']['value']
if data['mode']['type'] == 'flat':
flat = True
if data.has_key('surface'):
data.pop('surface')
else:
flat = False
- if not 'vector:lines:surface' in update:
- update.append('vector:lines:surface')
self.nvizClass.SetVectorLineMode(id, color,
width, flat)
if data['color'].has_key('update'):
data['color'].pop('update')
if data['width'].has_key('update'):
@@ -1145,15 +1150,15 @@
# height
if data['height'].has_key('update'):
self.nvizClass.SetVectorLineHeight(id,
- data['height'])
+ data['height']['value'])
data['height'].pop('update')
# surface
if data['mode'].has_key('update'):
- idx = self.layers['raster']['name'].index(data['mode']['surface'])
- if idx > -1:
- self.nvizClass.SetVectorLineSurface(id,
- self.layers['raster']['id'][idx])
+ sid = self.GetLayerId(type='raster', name=data['mode']['surface'])
+ if sid > -1:
+ self.nvizClass.SetVectorLineSurface(id, sid)
data['mode'].pop('update')
def UpdateVectorPointsProperties(self, id, data):
@@ -1188,8 +1193,34 @@
# surface
- if idx > -1:
- self.nvizClass.SetVectorPointSurface(id,
+ if sid > -1:
+ self.nvizClass.SetVectorPointSurface(id, sid)
+ def GetLayerNames(self, type):
+ """Return list of map layer names of given type"""
+ layerName = []
+ layerName.append(self.tree.GetPyData(item)[0]['maplayer'].GetName())
+ return layerName
+ def GetLayerId(self, type, name):
+ """Get layer object id or -1"""
+ mapName = self.tree.GetPyData(item)[0]['maplayer'].GetName()
+ data = self.tree.GetPyData(item)[0]['nviz']
+ return data['surface']['object']['id']
+ elif type == 'vpoint':
+ return data['vector']['points']['object']['id']
+ elif type == 'vline':
+ return data['vector']['lines']['object']['id']
+ return data['volume']['object']['id']
+ return -1
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2008-09-07 15:22:04 UTC (rev 33315)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_tools.py 2008-09-07 15:23:36 UTC (rev 33316)
@@ -2478,11 +2478,12 @@
else:
display.SetSelection(0)
- if data[vtype]['mode']['type'] == 'surface' and \
- len(self.mapWindow.layers['raster']['name']) > 0:
+ if data[vtype]['mode']['type'] == 'surface':
+ rasters = self.mapWindow.GetLayerNames('raster')
surface = self.FindWindowById(self.win['vector'][vtype]['surface'])
- surface.SetItems(self.mapWindow.layers['raster']['name'])
- surface.SetStringSelection(data[vtype]['mode']['surface'])
+ surface.SetItems(rasters)
+ surface.SetStringSelection(data[vtype]['mode']['surface'])
for type in ('slider', 'spin'):
win = self.FindWindowById(self.win['vector']['lines']['height'][type])
Modified: grass/trunk/gui/wxpython/nviz/init.cpp
--- grass/trunk/gui/wxpython/nviz/init.cpp 2008-09-07 15:22:04 UTC (rev 33315)
+++ grass/trunk/gui/wxpython/nviz/init.cpp 2008-09-07 15:23:36 UTC (rev 33316)
@@ -112,24 +112,6 @@
return;
- \brief Reset session
- Unload all data layers
- @todo vector, volume
-void Nviz::Reset()
- int i;
- int *surf_list, nsurfs;
- surf_list = GS_get_surf_list(&nsurfs);
- for (i = 0; i < nsurfs; i++) {
- GS_delete_surface(surf_list[i]);
void swap_gl()
return;
Modified: grass/trunk/gui/wxpython/nviz/nviz.h
--- grass/trunk/gui/wxpython/nviz/nviz.h 2008-09-07 15:22:04 UTC (rev 33315)
+++ grass/trunk/gui/wxpython/nviz/nviz.h 2008-09-07 15:23:36 UTC (rev 33316)
@@ -57,7 +57,6 @@
/* init.cpp */
int SetDisplay(void *);
void InitView();
- void Reset();
void SetBgColor(const char *);
/* lights.cpp */
