[GRASS-SVN] r33317 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Sep 7 13:26:52 EDT 2008
Author: martinl
Date: 2008-09-07 13:26:52 -0400 (Sun, 07 Sep 2008)
New Revision: 33317
grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
wxGUI: text layer bug fixes (trac #301 and #302)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py 2008-09-07 15:23:36 UTC (rev 33316)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py 2008-09-07 17:26:52 UTC (rev 33317)
@@ -451,13 +451,18 @@
self.ovlId = ovlId
self.parent = parent
- if self.ovlId in self.parent.MapWindow.textdict:
- self.currText, self.currFont, self.currClr, self.currRot = self.parent.MapWindow.textdict[drawid]
+ if self.ovlId in self.parent.MapWindow.textdict.keys():
+ self.currText = self.parent.MapWindow.textdict[self.ovlId]['text']
+ self.currFont = self.parent.MapWindow.textdict[self.ovlId]['font']
+ self.currClr = self.parent.MapWindow.textdict[self.ovlId]['color']
+ self.currRot = self.parent.MapWindow.textdict[self.ovlId]['rotation']
+ self.currCoords = self.parent.MapWindow.textdict[self.ovlId]['coords']
else:
self.currClr = wx.BLACK
self.currText = ''
self.currFont = self.GetFont()
self.currRot = 0.0
+ self.currCoords = [10, 10, 10, 10]
sizer = wx.BoxSizer(wx.VERTICAL)
box = wx.GridBagSizer(vgap=5, hgap=5)
@@ -566,8 +571,11 @@
def GetValues(self):
"""Get text properties"""
- return (self.currText, self.currFont,
- self.currClr, self.currRot)
+ return { 'text' : self.currText,
+ 'font' : self.currFont,
+ 'color' : self.currClr,
+ 'rotation' : self.currRot,
+ 'coords' : self.currCoords }
class LoadMapLayersDialog(wx.Dialog):
"""Load selected map layers (raster, vector) into layer tree"""
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2008-09-07 15:23:36 UTC (rev 33316)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2008-09-07 17:26:52 UTC (rev 33317)
@@ -416,42 +416,41 @@
# self.ovlcoords[drawid] = coords
elif pdctype == 'text': # draw text on top of map
- text = img[0]
- rotation = float(img[3])
- w, h = self.GetFullTextExtent(img[0])[0:2]
- pdc.SetFont(img[1])
- pdc.SetTextForeground(img[2])
- coords, w, h = self.TextBounds(img, coords)
+ rotation = float(img['rotation'])
+ w, h = self.GetFullTextExtent(img['text'])[0:2]
+ pdc.SetFont(img['font'])
+ pdc.SetTextForeground(img['color'])
+ coords, w, h = self.TextBounds(img)
if rotation == 0:
- pdc.DrawText(img[0], coords[0], coords[1])
+ pdc.DrawText(img['text'], coords[0], coords[1])
else:
- pdc.DrawRotatedText(img[0], coords[0], coords[1], rotation)
+ pdc.DrawRotatedText(img['text'], coords[0], coords[1], rotation)
pdc.SetIdBounds(drawid, (coords[0], coords[1], w, h))
- # self.ovlcoords[drawid] = coords
pdc.EndDrawing()
self.Refresh()
return drawid
- def TextBounds(self, textinfo, coords):
+ def TextBounds(self, textinfo):
Return text boundary data
@param textinfo text metadata (text, font, color, rotation)
@param coords reference point
- rotation = float(textinfo[3])
+ rotation = float(textinfo['rotation'])
+ coords = textinfo['coords']
Debug.msg (4, "BufferedWindow.TextBounds(): text=%s, rotation=%f" % \
- (textinfo[0], rotation))
+ (textinfo['text'], rotation))
self.Update()
self.Refresh()
- self.SetFont(textinfo[1])
+ self.SetFont(textinfo['font'])
- w, h = self.GetTextExtent(textinfo[0])
+ w, h = self.GetTextExtent(textinfo['text'])
if rotation == 0:
coords[2], coords[3] = coords[0] + w, coords[1] + h
@@ -864,7 +863,10 @@
self.Update()
self.RefreshRect(r, False)
self.lastpos = (event.GetX(), event.GetY())
+ if id > 100: # text
+ self.textdict[id]['coords'] = r2
def MouseDraw(self, pdc=None, begin=None, end=None):
Mouse box or line from 'begin' to 'end'
@@ -3807,51 +3809,44 @@
Handler for text decoration menu selection.
+ if self.MapWindow.dragid > -1:
+ id = self.MapWindow.dragid
+ else:
+ # index for overlay layer in render
+ if len(self.MapWindow.textdict.keys()) > 0:
+ id = self.MapWindow.textdict.keys()[-1] + 1
+ else:
+ id = 101
- id = 2 # index for overlay layer in render
- # default values
- text = ''
- font = self.GetFont()
- color = wx.BLACK
- coords = [10, 10, 10, 10]
- rotation = 0.0
- # if self.MapWindow.currtxtid == None: # text doesn't already exist
- # id = wx.NewId() + 100
- # else: # text already exists
- # id = self.MapWindow.currtxtid
- # textcoords = self.ovlcoords[id]
dlg = gdialogs.TextLayerDialog(parent=self, ovlId=id, title=_('Add text layer'),
size=(400, 200))
- dlg.CenterOnScreen()
+ dlg.CenterOnParent()
# If OK button pressed in decoration control dialog
if dlg.ShowModal() == wx.ID_OK:
- text = dlg.GetValues()[0]
- coords, w, h = self.MapWindow.TextBounds(dlg.GetValues(),
- coords)
- # delete object if it has no text
- if text == '':
- try:
- self.MapWindow.pdc.ClearId(id)
- self.MapWindow.pdc.RemoveId(id)
- del self.MapWindow.textdict[id]
- # del self.ovlcoords[id]
- except:
- pass
- return
+ text = dlg.GetValues()['text']
+ coords, w, h = self.MapWindow.TextBounds(dlg.GetValues())
+ # delete object if it has no text
+ if text == '':
+ try:
+ self.MapWindow.pdc.ClearId(id)
+ self.MapWindow.pdc.RemoveId(id)
+ del self.MapWindow.textdict[id]
+ except:
+ pass
+ return
- self.MapWindow.pdc.SetId(id)
- self.MapWindow.textdict[id] = (text, font, color, rotation)
- self.MapWindow.Draw(self.MapWindow.pdc, img=self.MapWindow.textdict[id],
- drawid=id, pdctype='text', coords=coords)
+ self.MapWindow.pdc.SetId(id)
+ self.MapWindow.textdict[id] = dlg.GetValues()
+ self.MapWindow.Draw(self.MapWindow.pdcDec, img=self.MapWindow.textdict[id],
+ drawid=id, pdctype='text', coords=coords)
+ self.MapWindow.UpdateMap(render=False, renderVector=False)
- self.MapWindow.UpdateMap(render=False, renderVector=False)
def GetOptData(self, dcmd, type, params, propwin):
Callback method for decoration overlay command generated by
