[GRASS-SVN] r33332 - in grass/branches/develbranch_6/gui/wxpython:
. gui_modules
svn_grass at osgeo.org
Mon Sep 8 12:39:43 EDT 2008
Author: martinl
Date: 2008-09-08 12:39:42 -0400 (Mon, 08 Sep 2008)
New Revision: 33332
grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
grass/branches/develbranch_6/gui/wxpython/wxgui.py
wxGUI: cosmetics in 'Command Output' tab, switch only if necessary
Cosmetics in Map Display positioning
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py 2008-09-08 15:25:04 UTC (rev 33331)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py 2008-09-08 16:39:42 UTC (rev 33332)
@@ -390,8 +390,14 @@
type = event.type
# switch to 'Command output'
+ ### if self.parent.notebook.GetSelection() != self.parent.goutput.pageid:
+ ### self.parent.notebook.SetSelection(self.parent.goutput.pageid)
- self.parent.notebook.SetSelection(self.parent.goutput.pageid)
+ textP = self.parent.notebook.GetPageText(self.parent.goutput.pageid)
+ if textP[-1] != ')':
+ textP += ' (...)'
+ self.parent.notebook.SetPageText(self.parent.goutput.pageid,
+ textP)
# message prefix
if type == 'warning':
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2008-09-08 15:25:04 UTC (rev 33331)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2008-09-08 16:39:42 UTC (rev 33332)
@@ -788,6 +788,10 @@
if cmd[0][0:2] != "d.":
# Send any non-display command to parent window (probably wxgui.py)
# put to parents
+ # switch to 'Command output'
+ if self.notebookpanel.notebook.GetSelection() != self.notebookpanel.goutputId:
+ self.notebookpanel.notebook.SetSelection(self.notebookpanel.goutputId)
try:
self.goutput.RunCmd(cmd)
except AttributeError,e:
@@ -915,10 +919,12 @@
if self.parent.get_dcmd is None:
self.goutput = goutput.GMConsole(parent=self, margin=False,
pageid=self.notebook.GetPageCount())
+ self.goutputId = self.notebook.GetPageCount()
self.outpage = self.notebook.AddPage(self.goutput, text=_("Command output") )
else:
self.goutput = None
+ self.goutputId = -1
self.manual_tab = helpPanel(parent = self.notebook, grass_command = self.task.name)
self.manual_tabsizer = wx.BoxSizer(wx.VERTICAL)
self.notebook.AddPage(self.manual_tab, text=_("Manual"))
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py 2008-09-08 15:25:04 UTC (rev 33331)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py 2008-09-08 16:39:42 UTC (rev 33332)
@@ -95,8 +95,9 @@
self.reorder = False # layer change requires a reordering
# init associated map display
+ pos = wx.Point(self.disp_idx * 25, self.disp_idx * 25)
self.mapdisplay = mapdisp.MapFrame(self,
- id=wx.ID_ANY, pos=wx.Point(50,50),
+ id=wx.ID_ANY, pos=pos,
size=globalvar.MAP_WINDOW_SIZE,
style=wx.DEFAULT_FRAME_STYLE,
tree=self, notebook=self.notebook,
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py 2008-09-08 15:25:04 UTC (rev 33331)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py 2008-09-08 16:39:42 UTC (rev 33332)
@@ -310,8 +310,9 @@
self.outpage = self.notebook.AddPage(self.goutput, text=_("Command output"))
# bingings
- self.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CHANGED, self.onCBPageChanged, self.gm_cb)
- self.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CLOSING, self.onCBPageClosed, self.gm_cb)
+ self.gm_cb.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CHANGED, self.OnCBPageChanged)
+ self.notebook.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CHANGED, self.OnPageChanged)
+ self.gm_cb.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CLOSING, self.OnCBPageClosed)
sizer.Add(item=self.goutput, proportion=1,
@@ -375,23 +376,32 @@
pass
- # choicebook methods
- def onCBPageChanged(self, event):
- """Page in notebook changed"""
+ def OnCBPageChanged(self, event):
+ """Page in notebook (display) changed"""
old_pgnum = event.GetOldSelection()
new_pgnum = event.GetSelection()
self.curr_page = self.gm_cb.GetCurrentPage()
self.curr_pagenum = self.gm_cb.GetSelection()
try:
self.curr_page.maptree.mapdisplay.SetFocus()
self.curr_page.maptree.mapdisplay.Raise()
except:
pass
+ event.Skip()
+ def OnPageChanged(self, event):
+ """Page in notebook changed"""
+ page = event.GetSelection()
+ if page == self.goutput.pageid:
+ # remove '(...)'
+ self.notebook.SetPageText(page, _("Command output"))
event.Skip()
- def onCBPageClosed(self, event):
+ def OnCBPageClosed(self, event):
Page of notebook closed
Also close associated map display
@@ -406,6 +416,10 @@
cmd = event.GetString()
+ if self.notebook.GetSelection() != self.goutput.pageid:
+ self.notebook.SetSelection(self.goutput.pageid)
self.OnUpdateStatusBar(None)
