[GRASS-SVN] r33333 - in grass/trunk: gui/icons gui/icons/grass
gui/icons/grass/vdigit gui/wxpython/icons vector/v.digit
svn_grass at osgeo.org
Mon Sep 8 12:44:02 EDT 2008
Author: martinl
Date: 2008-09-08 12:44:02 -0400 (Mon, 08 Sep 2008)
New Revision: 33333
Added:
grass/trunk/gui/icons/grass/vdigit/
grass/trunk/gui/icons/grass/vdigit/add.vertex.gif
grass/trunk/gui/icons/grass/vdigit/box.xbm
grass/trunk/gui/icons/grass/vdigit/copy.cats.gif
grass/trunk/gui/icons/grass/vdigit/cross.xbm
grass/trunk/gui/icons/grass/vdigit/cross45.xbm
grass/trunk/gui/icons/grass/vdigit/delete.line.gif
grass/trunk/gui/icons/grass/vdigit/display.attributes.gif
grass/trunk/gui/icons/grass/vdigit/display.cats.gif
grass/trunk/gui/icons/grass/vdigit/edit.line.gif
grass/trunk/gui/icons/grass/vdigit/exit.gif
grass/trunk/gui/icons/grass/vdigit/move.line.gif
grass/trunk/gui/icons/grass/vdigit/move.vertex.gif
grass/trunk/gui/icons/grass/vdigit/new.boundary.gif
grass/trunk/gui/icons/grass/vdigit/new.centroid.gif
grass/trunk/gui/icons/grass/vdigit/new.line.gif
grass/trunk/gui/icons/grass/vdigit/new.point.gif
grass/trunk/gui/icons/grass/vdigit/redraw.gif
grass/trunk/gui/icons/grass/vdigit/rm.vertex.gif
grass/trunk/gui/icons/grass/vdigit/settings.gif
grass/trunk/gui/icons/grass/vdigit/split.line.gif
grass/trunk/gui/icons/grass/vdigit/stop.gif
grass/trunk/gui/icons/grass/vdigit/zoom.default.gif
grass/trunk/gui/icons/grass/vdigit/zoom.out.centre.gif
grass/trunk/gui/icons/grass/vdigit/zoom.pan.gif
grass/trunk/gui/icons/grass/vdigit/zoom.region.gif
grass/trunk/gui/icons/grass/vdigit/zoom.window.gif
Removed:
grass/trunk/vector/v.digit/icons/
grass/trunk/gui/icons/Makefile
grass/trunk/gui/wxpython/icons/icon.py
grass/trunk/vector/v.digit/Makefile
grass/trunk/vector/v.digit/driver.c
grass/trunk/vector/v.digit/toolbox.tcl
v.digit icons moved to gui/icons/grass/vdigit
vdigit icons need to be available (for wxGUI) even v.digit is not compiled
(merge from devbr6, r33331)
Modified: grass/trunk/gui/icons/Makefile
--- grass/trunk/gui/icons/Makefile 2008-09-08 16:39:42 UTC (rev 33332)
+++ grass/trunk/gui/icons/Makefile 2008-09-08 16:44:02 UTC (rev 33333)
@@ -6,15 +6,21 @@
if [ ! -d $(ETC)/gui ] ; then $(MKDIR) $(ETC)/gui ; fi
if [ ! -d $(ETC)/gui/icons ] ; then $(MKDIR) $(ETC)/gui/icons ; fi
if [ ! -d $(ETC)/gui/icons/grass ] ; then $(MKDIR) $(ETC)/gui/icons/grass ; fi
+ if [ ! -d $(ETC)/gui/icons/grass/vdigit ] ; then $(MKDIR) $(ETC)/gui/icons/grass/vdigit ; fi
if [ ! -d $(ETC)/gui/icons/silk ] ; then $(MKDIR) $(ETC)/gui/icons/silk ; fi
for icon in grass/*.gif ; do $(INSTALL_DATA) $$icon $(ETC)/gui/icons/grass ; done
+ for icon in grass/vdigit/*.gif ; do $(INSTALL_DATA) $$icon $(ETC)/gui/icons/grass/vdigit ; done
+ for icon in grass/vdigit/*.xbm ; do $(INSTALL_DATA) $$icon $(ETC)/gui/icons/grass/vdigit ; done
for icon in silk/*.png ; do $(INSTALL_DATA) $$icon $(ETC)/gui/icons/silk ; done
for icon in *.ico ; do $(INSTALL_DATA) $$icon $(ETC)/gui/icons ; done
if [ ! -d $(GISBASE)/docs ] ; then $(MKDIR) $(GISBASE)/docs ; fi
if [ ! -d $(GISBASE)/docs/html ] ; then $(MKDIR) $(GISBASE)/docs/html ; fi
if [ ! -d $(GISBASE)/docs/html/icons ] ; then $(MKDIR) $(GISBASE)/docs/html/icons ; fi
if [ ! -d $(GISBASE)/docs/html/icons/grass ] ; then $(MKDIR) $(GISBASE)/docs/html/icons/grass ; fi
+ if [ ! -d $(GISBASE)/docs/html/icons/grass/vdigit ] ; then $(MKDIR) $(GISBASE)/docs/html/icons/grass/vdigit ; fi
if [ ! -d $(GISBASE)/docs/html/icons/silk ] ; then $(MKDIR) $(GISBASE)/docs/html/icons/silk ; fi
for icon in grass/*.gif ; do $(INSTALL_DATA) $$icon $(GISBASE)/docs/html/icons/grass ; done
+ for icon in grass/vdigit/*.gif ; do $(INSTALL_DATA) $$icon $(GISBASE)/docs/html/icons/grass/vdigit ; done
+ for icon in grass/vdigit/*.xbm ; do $(INSTALL_DATA) $$icon $(GISBASE)/docs/html/icons/grass/vdigit ; done
for icon in silk/*.png ; do $(INSTALL_DATA) $$icon $(GISBASE)/docs/html/icons/silk ; done
Copied: grass/trunk/gui/icons/grass/vdigit (from rev 33331, grass/branches/develbranch_6/gui/icons/grass/vdigit)
Deleted: grass/trunk/gui/icons/grass/vdigit/add.vertex.gif
(Binary files differ)
Copied: grass/trunk/gui/icons/grass/vdigit/add.vertex.gif (from rev 33331, grass/branches/develbranch_6/gui/icons/grass/vdigit/add.vertex.gif)
Deleted: grass/trunk/gui/icons/grass/vdigit/box.xbm
--- grass/branches/develbranch_6/gui/icons/grass/vdigit/box.xbm 2008-09-08 15:25:04 UTC (rev 33331)
+++ grass/trunk/gui/icons/grass/vdigit/box.xbm 2008-09-08 16:44:02 UTC (rev 33333)
@@ -1,5 +0,0 @@
-#define box_width 9
-#define box_height 9
-static unsigned char box_bits[] = {
- 0xff, 0x01, 0xff, 0x01, 0xff, 0x01, 0xc7, 0x01, 0xc7, 0x01, 0xc7, 0x01,
- 0xff, 0x01, 0xff, 0x01, 0xff, 0x01 };
Copied: grass/trunk/gui/icons/grass/vdigit/box.xbm (from rev 33331, grass/branches/develbranch_6/gui/icons/grass/vdigit/box.xbm)
--- grass/trunk/gui/icons/grass/vdigit/box.xbm (rev 0)
@@ -0,0 +1,5 @@
+#define box_width 9
+#define box_height 9
+static unsigned char box_bits[] = {
+ 0xff, 0x01, 0xff, 0x01, 0xff, 0x01, 0xc7, 0x01, 0xc7, 0x01, 0xc7, 0x01,
+ 0xff, 0x01, 0xff, 0x01, 0xff, 0x01 };
Deleted: grass/trunk/gui/icons/grass/vdigit/copy.cats.gif
Copied: grass/trunk/gui/icons/grass/vdigit/copy.cats.gif (from rev 33331, grass/branches/develbranch_6/gui/icons/grass/vdigit/copy.cats.gif)
Deleted: grass/trunk/gui/icons/grass/vdigit/cross.xbm
--- grass/branches/develbranch_6/gui/icons/grass/vdigit/cross.xbm 2008-09-08 15:25:04 UTC (rev 33331)
+++ grass/trunk/gui/icons/grass/vdigit/cross.xbm 2008-09-08 16:44:02 UTC (rev 33333)
@@ -1,5 +0,0 @@
-#define cross_width 9
-#define cross_height 9
-static unsigned char cross_bits[] = {
- 0x38, 0x00, 0x38, 0x00, 0x38, 0x00, 0xff, 0x01, 0xff, 0x01, 0xff, 0x01,
- 0x38, 0x00, 0x38, 0x00, 0x38, 0x00 };
Copied: grass/trunk/gui/icons/grass/vdigit/cross.xbm (from rev 33331, grass/branches/develbranch_6/gui/icons/grass/vdigit/cross.xbm)
--- grass/trunk/gui/icons/grass/vdigit/cross.xbm (rev 0)
@@ -0,0 +1,5 @@
+#define cross_width 9
+#define cross_height 9
+static unsigned char cross_bits[] = {
+ 0x38, 0x00, 0x38, 0x00, 0x38, 0x00, 0xff, 0x01, 0xff, 0x01, 0xff, 0x01,
+ 0x38, 0x00, 0x38, 0x00, 0x38, 0x00 };
Deleted: grass/trunk/gui/icons/grass/vdigit/cross45.xbm
--- grass/branches/develbranch_6/gui/icons/grass/vdigit/cross45.xbm 2008-09-08 15:25:04 UTC (rev 33331)
+++ grass/trunk/gui/icons/grass/vdigit/cross45.xbm 2008-09-08 16:44:02 UTC (rev 33333)
@@ -1,5 +0,0 @@
-#define cross45_width 9
-#define cross45_height 9
-static unsigned char cross45_bits[] = {
- 0x82, 0x00, 0xc7, 0x01, 0xee, 0x00, 0x7c, 0x00, 0x38, 0x00, 0x7c, 0x00,
- 0xee, 0x00, 0xc7, 0x01, 0x82, 0x00 };
Copied: grass/trunk/gui/icons/grass/vdigit/cross45.xbm (from rev 33331, grass/branches/develbranch_6/gui/icons/grass/vdigit/cross45.xbm)
--- grass/trunk/gui/icons/grass/vdigit/cross45.xbm (rev 0)
@@ -0,0 +1,5 @@
+#define cross45_width 9
+#define cross45_height 9
+static unsigned char cross45_bits[] = {
+ 0x82, 0x00, 0xc7, 0x01, 0xee, 0x00, 0x7c, 0x00, 0x38, 0x00, 0x7c, 0x00,
+ 0xee, 0x00, 0xc7, 0x01, 0x82, 0x00 };
Deleted: grass/trunk/gui/icons/grass/vdigit/delete.line.gif
Copied: grass/trunk/gui/icons/grass/vdigit/delete.line.gif (from rev 33331, grass/branches/develbranch_6/gui/icons/grass/vdigit/delete.line.gif)
Deleted: grass/trunk/gui/icons/grass/vdigit/display.attributes.gif
Copied: grass/trunk/gui/icons/grass/vdigit/display.attributes.gif (from rev 33331, grass/branches/develbranch_6/gui/icons/grass/vdigit/display.attributes.gif)
Deleted: grass/trunk/gui/icons/grass/vdigit/display.cats.gif
Copied: grass/trunk/gui/icons/grass/vdigit/display.cats.gif (from rev 33331, grass/branches/develbranch_6/gui/icons/grass/vdigit/display.cats.gif)
Deleted: grass/trunk/gui/icons/grass/vdigit/edit.line.gif
Copied: grass/trunk/gui/icons/grass/vdigit/edit.line.gif (from rev 33331, grass/branches/develbranch_6/gui/icons/grass/vdigit/edit.line.gif)
Deleted: grass/trunk/gui/icons/grass/vdigit/exit.gif
Copied: grass/trunk/gui/icons/grass/vdigit/exit.gif (from rev 33331, grass/branches/develbranch_6/gui/icons/grass/vdigit/exit.gif)
Deleted: grass/trunk/gui/icons/grass/vdigit/move.line.gif
Copied: grass/trunk/gui/icons/grass/vdigit/move.line.gif (from rev 33331, grass/branches/develbranch_6/gui/icons/grass/vdigit/move.line.gif)
Deleted: grass/trunk/gui/icons/grass/vdigit/move.vertex.gif
Copied: grass/trunk/gui/icons/grass/vdigit/move.vertex.gif (from rev 33331, grass/branches/develbranch_6/gui/icons/grass/vdigit/move.vertex.gif)
Deleted: grass/trunk/gui/icons/grass/vdigit/new.boundary.gif
Copied: grass/trunk/gui/icons/grass/vdigit/new.boundary.gif (from rev 33331, grass/branches/develbranch_6/gui/icons/grass/vdigit/new.boundary.gif)
Deleted: grass/trunk/gui/icons/grass/vdigit/new.centroid.gif
Copied: grass/trunk/gui/icons/grass/vdigit/new.centroid.gif (from rev 33331, grass/branches/develbranch_6/gui/icons/grass/vdigit/new.centroid.gif)
Deleted: grass/trunk/gui/icons/grass/vdigit/new.line.gif
Copied: grass/trunk/gui/icons/grass/vdigit/new.line.gif (from rev 33331, grass/branches/develbranch_6/gui/icons/grass/vdigit/new.line.gif)
Deleted: grass/trunk/gui/icons/grass/vdigit/new.point.gif
Copied: grass/trunk/gui/icons/grass/vdigit/new.point.gif (from rev 33331, grass/branches/develbranch_6/gui/icons/grass/vdigit/new.point.gif)
Deleted: grass/trunk/gui/icons/grass/vdigit/redraw.gif
Copied: grass/trunk/gui/icons/grass/vdigit/redraw.gif (from rev 33331, grass/branches/develbranch_6/gui/icons/grass/vdigit/redraw.gif)
Deleted: grass/trunk/gui/icons/grass/vdigit/rm.vertex.gif
Copied: grass/trunk/gui/icons/grass/vdigit/rm.vertex.gif (from rev 33331, grass/branches/develbranch_6/gui/icons/grass/vdigit/rm.vertex.gif)
Deleted: grass/trunk/gui/icons/grass/vdigit/settings.gif
Copied: grass/trunk/gui/icons/grass/vdigit/settings.gif (from rev 33331, grass/branches/develbranch_6/gui/icons/grass/vdigit/settings.gif)
Deleted: grass/trunk/gui/icons/grass/vdigit/split.line.gif
Copied: grass/trunk/gui/icons/grass/vdigit/split.line.gif (from rev 33331, grass/branches/develbranch_6/gui/icons/grass/vdigit/split.line.gif)
Deleted: grass/trunk/gui/icons/grass/vdigit/stop.gif
Copied: grass/trunk/gui/icons/grass/vdigit/stop.gif (from rev 33331, grass/branches/develbranch_6/gui/icons/grass/vdigit/stop.gif)
Deleted: grass/trunk/gui/icons/grass/vdigit/zoom.default.gif
Copied: grass/trunk/gui/icons/grass/vdigit/zoom.default.gif (from rev 33331, grass/branches/develbranch_6/gui/icons/grass/vdigit/zoom.default.gif)
Deleted: grass/trunk/gui/icons/grass/vdigit/zoom.out.centre.gif
Copied: grass/trunk/gui/icons/grass/vdigit/zoom.out.centre.gif (from rev 33331, grass/branches/develbranch_6/gui/icons/grass/vdigit/zoom.out.centre.gif)
Deleted: grass/trunk/gui/icons/grass/vdigit/zoom.pan.gif
Copied: grass/trunk/gui/icons/grass/vdigit/zoom.pan.gif (from rev 33331, grass/branches/develbranch_6/gui/icons/grass/vdigit/zoom.pan.gif)
Deleted: grass/trunk/gui/icons/grass/vdigit/zoom.region.gif
Copied: grass/trunk/gui/icons/grass/vdigit/zoom.region.gif (from rev 33331, grass/branches/develbranch_6/gui/icons/grass/vdigit/zoom.region.gif)
Deleted: grass/trunk/gui/icons/grass/vdigit/zoom.window.gif
Copied: grass/trunk/gui/icons/grass/vdigit/zoom.window.gif (from rev 33331, grass/branches/develbranch_6/gui/icons/grass/vdigit/zoom.window.gif)
Modified: grass/trunk/gui/wxpython/icons/icon.py
--- grass/trunk/gui/wxpython/icons/icon.py 2008-09-08 16:39:42 UTC (rev 33332)
+++ grass/trunk/gui/wxpython/icons/icon.py 2008-09-08 16:44:02 UTC (rev 33333)
@@ -40,7 +40,7 @@
iconpath = None
iconpath_default = os.path.join(globalvar.ETCDIR, "gui", "icons", "grass")
-iconpath_vdigit = os.path.join(globalvar.ETCDIR, "v.digit")
+iconpath_vdigit = os.path.join(globalvar.ETCDIR, "gui", "icons", "grass", "vdigit")
icons_default = {
# map display
Modified: grass/trunk/vector/v.digit/Makefile
--- grass/trunk/vector/v.digit/Makefile 2008-09-08 16:39:42 UTC (rev 33332)
+++ grass/trunk/vector/v.digit/Makefile 2008-09-08 16:44:02 UTC (rev 33333)
@@ -13,12 +13,10 @@
AUXDIR := $(GISBASE)/etc/v.digit
TCLFILES := $(patsubst %,$(AUXDIR)/%,$(wildcard *.tcl))
-GIFFILES := $(patsubst icons/%,$(AUXDIR)/%,$(wildcard icons/*.gif))
-XBMFILES := $(patsubst icons/%,$(AUXDIR)/%,$(wildcard icons/*.xbm))
pre: $(AUXDIR)
-default: cmd $(TCLFILES) $(GIFFILES) $(XBMFILES)
+default: cmd $(TCLFILES)
$(AUXDIR):
if [ ! -d $(ETC) ]; then $(MKDIR) $(ETC); fi
@@ -27,9 +25,3 @@
$(AUXDIR)/%.tcl: %.tcl
$(INSTALL_DATA) $< $@
-$(AUXDIR)/%.gif: icons/%.gif
- $(INSTALL_DATA) $< $@
-$(AUXDIR)/%.xbm: icons/%.xbm
Modified: grass/trunk/vector/v.digit/driver.c
--- grass/trunk/vector/v.digit/driver.c 2008-09-08 16:39:42 UTC (rev 33332)
+++ grass/trunk/vector/v.digit/driver.c 2008-09-08 16:44:02 UTC (rev 33333)
@@ -70,7 +70,7 @@
yi = (int) floor(D_u_to_d_row(y));
sprintf(buf,
- ".screen.canvas create bitmap %d %d -bitmap @$vdpath/%s.xbm -foreground %s -anchor center",
+ ".screen.canvas create bitmap %d %d -bitmap @$iconpath/%s.xbm -foreground %s -anchor center",
xi, yi, icon, color);
if (Tcl_Eval(Toolbox, buf) != TCL_OK)
G_warning("driver_plot_icon: %s", Toolbox->result);
Modified: grass/trunk/vector/v.digit/toolbox.tcl
--- grass/trunk/vector/v.digit/toolbox.tcl 2008-09-08 16:39:42 UTC (rev 33332)
+++ grass/trunk/vector/v.digit/toolbox.tcl 2008-09-08 16:44:02 UTC (rev 33333)
@@ -8,6 +8,7 @@
DynamicHelp::configure -font balloon-help -fg black -bg "#FFFF77"
set vdpath $env(GISBASE)/etc/v.digit/
+set iconpath $env(GISBASE)/etc/gui/icons/grass/vdigit/
source $vdpath/settings.tcl
source $vdpath/cats.tcl
source $vdpath/form.tcl
@@ -35,7 +36,7 @@
proc create_screen {} {
- global vdpath map_name map_mapset
+ global vdpath iconpath map_name map_mapset
if {[winfo exists .screen]} return
toplevel .screen
@@ -48,9 +49,9 @@
wm deiconify .screen
update
- image create bitmap cross -file "$vdpath/cross.xbm"
- image create bitmap cross45 -file "$vdpath/cross45.xbm"
- image create bitmap box -file "$vdpath/box.xbm"
+ image create bitmap cross -file "$iconpath/cross.xbm"
+ image create bitmap cross45 -file "$iconpath/cross45.xbm"
+ image create bitmap box -file "$iconpath/box.xbm"
# GVariable stores variables by key, this variables are (should be) synchronized with
@@ -106,58 +107,58 @@
set bbox2 [ButtonBox .bbox2 -spacing 1 -padx 1 -pady 1]
# --- Draw new ---
-$bbox2 add -image [image create photo -file "$vdpath/new.point.gif"] \
+$bbox2 add -image [image create photo -file "$iconpath/new.point.gif"] \
-command "c_next_tool new_point" \
-highlightthickness 0 -takefocus 0 -relief raised -borderwidth 1 \
-helptext [G_msg "Digitize new point"]
-$bbox2 add -image [image create photo -file "$vdpath/new.line.gif"] \
+$bbox2 add -image [image create photo -file "$iconpath/new.line.gif"] \
-command "c_next_tool new_line" \
-helptext [G_msg "Digitize new line"]
-$bbox2 add -image [image create photo -file "$vdpath/new.boundary.gif"] \
+$bbox2 add -image [image create photo -file "$iconpath/new.boundary.gif"] \
-command "c_next_tool new_boundary" \
-helptext [G_msg "Digitize new boundary"]
-$bbox2 add -image [image create photo -file "$vdpath/new.centroid.gif"] \
+$bbox2 add -image [image create photo -file "$iconpath/new.centroid.gif"] \
-command "c_next_tool new_centroid" \
-helptext [G_msg "Digitize new centroid"]
# --- Edit old ---
-$bbox2 add -image [image create photo -file "$vdpath/move.vertex.gif"] \
+$bbox2 add -image [image create photo -file "$iconpath/move.vertex.gif"] \
-command "c_next_tool move_vertex" \
-helptext [G_msg "Move vertex"]
-$bbox2 add -image [image create photo -file "$vdpath/add.vertex.gif"] \
+$bbox2 add -image [image create photo -file "$iconpath/add.vertex.gif"] \
-command "c_next_tool add_vertex" \
-helptext [G_msg "Add vertex"]
-$bbox2 add -image [image create photo -file "$vdpath/rm.vertex.gif"] \
+$bbox2 add -image [image create photo -file "$iconpath/rm.vertex.gif"] \
-command "c_next_tool rm_vertex" \
-helptext [G_msg "Remove vertex"]
-$bbox2 add -image [image create photo -file "$vdpath/split.line.gif"] \
+$bbox2 add -image [image create photo -file "$iconpath/split.line.gif"] \
-command "c_next_tool split_line" \
-helptext [G_msg "Split line"]
-$bbox2 add -image [image create photo -file "$vdpath/edit.line.gif"] \
+$bbox2 add -image [image create photo -file "$iconpath/edit.line.gif"] \
-command "c_next_tool edit_line" \
-helptext [G_msg "Edit line/boundary"]
-$bbox2 add -image [image create photo -file "$vdpath/move.line.gif"] \
+$bbox2 add -image [image create photo -file "$iconpath/move.line.gif"] \
-command "c_next_tool move_line" \
-helptext [G_msg "Move point, line, boundary, or centroid"]
-$bbox2 add -image [image create photo -file "$vdpath/delete.line.gif"] \
+$bbox2 add -image [image create photo -file "$iconpath/delete.line.gif"] \
-command "c_next_tool delete_line" \
-helptext [G_msg "Delete point, line, boundary, or centroid"]
@@ -168,27 +169,27 @@
# --- Zoom / Display ---
-$bbox1 add -image [image create photo -file "$vdpath/redraw.gif"] \
+$bbox1 add -image [image create photo -file "$iconpath/redraw.gif"] \
-command "c_next_tool redraw" \
-helptext [G_msg "Redraw"]
-$bbox1 add -image [image create photo -file "$vdpath/zoom.window.gif"] \
+$bbox1 add -image [image create photo -file "$iconpath/zoom.window.gif"] \
-command "c_next_tool zoom_window" \
-helptext [G_msg "Zoom in by window"]
-$bbox1 add -image [image create photo -file "$vdpath/zoom.out.centre.gif"] \
+$bbox1 add -image [image create photo -file "$iconpath/zoom.out.centre.gif"] \
-command "c_next_tool zoom_out_centre" \
-helptext [G_msg "Zoom out"]
-$bbox1 add -image [image create photo -file "$vdpath/zoom.pan.gif"] \
+$bbox1 add -image [image create photo -file "$iconpath/zoom.pan.gif"] \
-command "c_next_tool zoom_pan" \
-helptext [G_msg "Pan"]
-$bbox1 add -image [image create photo -file "$vdpath/zoom.default.gif"] \
+$bbox1 add -image [image create photo -file "$iconpath/zoom.default.gif"] \
-command "c_next_tool zoom_default" \
-helptext [G_msg "Zoom to default region"]
@@ -201,40 +202,40 @@
-$bbox1 add -image [image create photo -file "$vdpath/zoom.region.gif"] \
+$bbox1 add -image [image create photo -file "$iconpath/zoom.region.gif"] \
-command "zoom_region" \
-helptext [G_msg "Zoom to saved region"]
# --- Attributes ---
-$bbox1 add -image [image create photo -file "$vdpath/display.cats.gif"] \
+$bbox1 add -image [image create photo -file "$iconpath/display.cats.gif"] \
-command "c_next_tool display_cats" \
-helptext [G_msg "Display categories"]
-$bbox1 add -image [image create photo -file "$vdpath/copy.cats.gif"] \
+$bbox1 add -image [image create photo -file "$iconpath/copy.cats.gif"] \
-command "c_next_tool copy_cats" \
-helptext [G_msg "Copy categories"]
-$bbox1 add -image [image create photo -file "$vdpath/display.attributes.gif"] \
+$bbox1 add -image [image create photo -file "$iconpath/display.attributes.gif"] \
-command "c_next_tool display_attributes" \
-helptext [G_msg "Display attributes"]
# --- Stop ---
-#$bbox1 add -image [image create photo -file "$vdpath/stop.gif"] \
+#$bbox1 add -image [image create photo -file "$iconpath/stop.gif"] \
# -command "c_cancel" \
# -highlightthickness 0 -takefocus 0 -relief raised -borderwidth 1 \
# -helptext "Quit running tool"
# --- Others ---
-$bbox1 add -image [image create photo -file "$vdpath/settings.gif"] \
+$bbox1 add -image [image create photo -file "$iconpath/settings.gif"] \
-command "c_next_tool settings" \
-helptext [G_msg "Open settings"]
-$bbox1 add -image [image create photo -file "$vdpath/exit.gif"] \
+$bbox1 add -image [image create photo -file "$iconpath/exit.gif"] \
-command "c_next_tool exit" \
-bg white \
