[GRASS-SVN] r33455 -
grass/branches/develbranch_6/swig/python/interfaces
svn_grass at osgeo.org
Tue Sep 16 00:57:56 EDT 2008
Author: hamish
Date: 2008-09-16 00:57:56 -0400 (Tue, 16 Sep 2008)
New Revision: 33455
Removed:
grass/branches/develbranch_6/swig/python/interfaces/gis.i
crude attempt at cleansing gis.h (2)
Deleted: grass/branches/develbranch_6/swig/python/interfaces/gis.i
--- grass/branches/develbranch_6/swig/python/interfaces/gis.i 2008-09-16 03:53:41 UTC (rev 33454)
+++ grass/branches/develbranch_6/swig/python/interfaces/gis.i 2008-09-16 04:57:56 UTC (rev 33455)
@@ -1,406 +0,0 @@
-#define TRUE 1
-#define FALSE 0
-#define MAXEDLINES 50
-#define RECORD_LEN 80
-#define NEWLINE '\n'
-#define RECLASS_TABLE 1
-#define RECLASS_RULES 2
-#define RECLASS_SCALE 3
-#define METERS 1
-#define FEET 2
-#define DEGREES 3
-#define CELL_TYPE 0
-#define FCELL_TYPE 1
-#define DCELL_TYPE 2
-#define PROJECTION_XY 0
-#define PROJECTION_UTM 1
-#define PROJECTION_SP 2
-#define PROJECTION_LL 3
-#define PROJECTION_OTHER 99
-#define PROJECTION_FILE "PROJ_INFO"
-#define UNIT_FILE "PROJ_UNITS"
-#define G_VAR_GISRC 0
-#define G_VAR_MAPSET 1
-#define G_GISRC_MODE_FILE 0
-#define G_GISRC_MODE_MEMORY 1
-#define TYPE_INTEGER 1
-#define TYPE_DOUBLE 2
-#define TYPE_STRING 3
-#define YES 1
-#define NO 0
-typedef enum
- G_OPT_WHERE,
- G_OPT_R_INPUT,
- G_OPT_R_OUTPUT,
- G_OPT_R_MAP,
- G_OPT_V_INPUT,
- G_OPT_V_OUTPUT,
- G_OPT_V_MAP,
- G_OPT_V_TYPE,
- G_OPT_V_FIELD,
- G_OPT_V_CAT,
- G_OPT_V_CATS
-} STD_OPT;
-#define G_INFO_FORMAT_STANDARD 0
-#define G_INFO_FORMAT_GUI 1
-#define G_ICON_CROSS 0
-#define G_ICON_BOX 1
-#define G_ICON_ARROW 2
-#define DEFAULT_FG_COLOR "black"
-#define DEFAULT_BG_COLOR "white"
-typedef int CELL;
-typedef double DCELL;
-typedef float FCELL;
-/*extern CELL CELL_NODATA; Sajith */
-typedef int RASTER_MAP_TYPE;
-struct Cell_head
- int format;
- int compressed;
- int rows;
- int rows3;
- int cols;
- int cols3;
- int depths;
- int proj;
- int zone;
- double ew_res;
- double ew_res3;
- double ns_res;
- double ns_res3;
- double tb_res;
- double north;
- double south;
- double east;
- double west;
- double top;
- double bottom;
-struct _Color_Rule_
- struct
- DCELL value;
- unsigned char red;
- unsigned char grn;
- unsigned char blu;
- } high;
- struct
- DCELL value;
- } low;
- /* struct _Color_Rule_ *next;
- struct _Color_Rule_ *prev; Commented By sajith I am confued here.... */
-struct _Color_Info_
- struct _Color_Rule_ *rules;
- int n_rules;
- struct
- unsigned char *red;
- unsigned char *grn;
- unsigned char *blu;
- unsigned char *set;
- int nalloc;
- int active;
- } lookup;
- struct
- DCELL *vals;
- struct _Color_Rule_ **rules;
- int nalloc;
- int active;
- } fp_lookup;
- DCELL min, max;
-struct Colors
- int version;
- DCELL shift;
- int invert;
- int is_float;
- int null_set;
- unsigned char null_red;
- unsigned char null_grn;
- unsigned char null_blu;
- int undef_set;
- unsigned char undef_red;
- unsigned char undef_grn;
- unsigned char undef_blu;
- struct _Color_Info_ fixed;
- struct _Color_Info_ modular;
- DCELL cmin;
- DCELL cmax;
-struct Reclass
- char name[50];
- char mapset[50];
- int type;
- int num;
- CELL min;
- CELL max;
- CELL *table;
-struct FPReclass_table
- DCELL dLow;
- DCELL dHigh;
- DCELL rLow;
- DCELL rHigh;
-struct FPReclass
- int defaultDRuleSet;
- int defaultRRuleSet;
- int infiniteLeftSet;
- int infiniteRightSet;
- int rRangeSet;
- int maxNofRules;
- int nofRules;
- DCELL defaultDMin;
- DCELL defaultDMax;
- DCELL defaultRMin;
- DCELL defaultRMax;
- DCELL infiniteDLeft;
- DCELL infiniteDRight;
- DCELL infiniteRLeft;
- DCELL infiniteRRight;
- DCELL dMin;
- DCELL dMax;
- DCELL rMin;
- DCELL rMax;
- struct FPReclass_table *table;
-struct Quant_table
- DCELL dLow;
- DCELL dHigh;
- CELL cLow;
- CELL cHigh;
-struct Quant
- int truncate_only;
- int round_only;
- int defaultCRuleSet;
- int cRangeSet;
- int maxNofRules;
- int nofRules;
- CELL defaultCMin;
- CELL defaultCMax;
- CELL infiniteCLeft;
- CELL infiniteCRight;
- DCELL dMin;
- DCELL dMax;
- CELL cMin;
- CELL cMax;
- struct Quant_table *table;
- struct
- DCELL *vals;
- struct Quant_table **rules;
- int nalloc;
- int active;
- DCELL inf_dmin;
- DCELL inf_dmax;
- CELL inf_min;
- CELL inf_max;
- } fp_lookup;
-struct Categories
- CELL ncats;
- CELL num;
- char *title;
- char *fmt;
- float m1;
- float a1;
- float m2;
- float a2;
- struct Quant q;
- char **labels;
- int *marks;
- int nalloc;
- int last_marked_rule;
-struct History
- char mapid[RECORD_LEN];
- char title[RECORD_LEN];
- char mapset[RECORD_LEN];
- char creator[RECORD_LEN];
- char maptype[RECORD_LEN];
- char datsrc_1[RECORD_LEN];
- char datsrc_2[RECORD_LEN];
- char keywrd[RECORD_LEN];
- int edlinecnt;
- char edhist[MAXEDLINES][RECORD_LEN];
-struct Cell_stats
- struct Cell_stats_node
- int idx;
- long *count;
- int left;
- int right;
- } *node;
- int tlen;
- int N;
- int curp;
- long null_data_count;
- int curoffset;
-struct Histogram
- int num;
- struct Histogram_list
- CELL cat;
- long count;
- } *list;
-struct Range
- CELL min;
- CELL max;
- int first_time;
-struct FPRange
- DCELL min;
- DCELL max;
- int first_time;
-struct G_3dview
- char pgm_id[40];
- float from_to[2][3];
- float fov;
- float twist;
- float exag;
- int mesh_freq;
- int poly_freq;
- int display_type;
- int lightson;
- int dozero;
- int colorgrid;
- int shading;
- int fringe;
- int surfonly;
- int doavg;
- char grid_col[40];
- char bg_col[40];
- char other_col[40];
- float lightpos[4];
- float lightcol[3];
- float ambient;
- float shine;
- struct Cell_head vwin;
-struct Key_Value
- int nitems;
- int nalloc;
- char **key;
- char **value;
-struct Option
- char *key;
- int type;
- int required;
- int multiple;
- char *options;
- char **opts;
- char *key_desc;
- char *label;
- char *description;
- char *descriptions;
- char **descs;
- char *answer;
- char *def;
- char **answers;
- struct Option *next_opt;
- char *gisprompt;
- int (*checker) ();
- int count;
-struct Flag
- char key;
- char answer;
- char *label;
- struct Flag *next_flag;
-struct GModule
- char *label;
- int overwrite;
-struct TimeStamp
- DateTime dt[2];
- int count;
