[GRASS-SVN] r33456 - grass/trunk/swig/python/interfaces
Tue Sep 16 01:09:36 EDT 2008
Author: hamish
Date: 2008-09-16 01:09:36 -0400 (Tue, 16 Sep 2008)
New Revision: 33456
Removed:
   grass/trunk/swig/python/interfaces/gis.i
   grass/trunk/swig/python/interfaces/Makefile
crude attempt at cleansing gis.h (merge from devbr6)
Modified: grass/trunk/swig/python/interfaces/Makefile
--- grass/trunk/swig/python/interfaces/Makefile	2008-09-16 04:57:56 UTC (rev 33455)
+++ grass/trunk/swig/python/interfaces/Makefile	2008-09-16 05:09:36 UTC (rev 33456)
@@ -15,7 +15,12 @@
 	cat ../../../include/gisdefs.h | \
 		sed -e '/\.\.\..*;/d' -e '/\.\.\./,/;/d' \
 		-e '/^#/d' >> gisdefs.i
-#	gis.h  (gis.i based on gis.h c.12/17/04 (r16393)
+	echo $(HEADER_LINE1) >  gis.i
+	echo $(HEADER_LINE2) >> gis.i
+	echo >> gis.i
+	cat ../../../include/gis.h | \
+		sed -e 'N;N;N;N;N;N;N;N;N; s/_Color_Rule_[ \t\n]*{[ \t\n]*\(.*}\) low.*/_Color_Rule_\n{\n    \1 low;\n    \1 high;\n/' \
+		>> gis.i
 vector:
 	echo $(HEADER_LINE1) >  dig_structs.i
@@ -37,5 +42,5 @@
 #	imagery.h
 distclean:
-	-rm -f gisdefs.i dig_structs.i vect.i
-	# gis.i dig_types.i imagedefs.h imagery.h
+	-rm -f gisdefs.i gis.i dig_structs.i vect.i
+	# dig_types.i imagedefs.h imagery.h
Deleted: grass/trunk/swig/python/interfaces/gis.i
--- grass/trunk/swig/python/interfaces/gis.i	2008-09-16 04:57:56 UTC (rev 33455)
+++ grass/trunk/swig/python/interfaces/gis.i	2008-09-16 05:09:36 UTC (rev 33456)
@@ -1,405 +0,0 @@
-#define TRUE 1
-#define FALSE 0
-#define MAXEDLINES  50
-#define RECORD_LEN  80
-#define NEWLINE     '\n'
-#define RECLASS_TABLE 1
-#define RECLASS_RULES 2
-#define RECLASS_SCALE 3
-#define METERS    1
-#define FEET      2
-#define DEGREES   3
-#define CELL_TYPE 0
-#define FCELL_TYPE 1
-#define DCELL_TYPE 2
-#define PROJECTION_XY  0
-#define PROJECTION_UTM 1
-#define PROJECTION_SP  2
-#define PROJECTION_LL  3
-#define PROJECTION_OTHER  99
-#define PROJECTION_FILE "PROJ_INFO"
-#define UNIT_FILE "PROJ_UNITS"
-#define G_VAR_GISRC    0
-#define G_VAR_MAPSET   1
-#define G_GISRC_MODE_FILE     0
-#define G_GISRC_MODE_MEMORY   1
-#define TYPE_INTEGER  1
-#define TYPE_DOUBLE   2
-#define TYPE_STRING   3
-#define YES           1
-#define NO            0
-typedef enum {
-    G_OPT_DB_WHERE,
-    G_OPT_R_INPUT,
-    G_OPT_R_OUTPUT,
-    G_OPT_R_MAP,
-    G_OPT_V_INPUT,
-    G_OPT_V_OUTPUT,
-    G_OPT_V_MAP,
-    G_OPT_V_TYPE,
-    G_OPT_V_FIELD,
-    G_OPT_V_CAT,
-    G_OPT_V_CATS
-} STD_OPT;
-#define G_INFO_FORMAT_STANDARD 0
-#define G_INFO_FORMAT_GUI      1
-#define G_ICON_CROSS  0
-#define G_ICON_BOX    1
-#define G_ICON_ARROW  2
-#define DEFAULT_FG_COLOR "black"
-#define DEFAULT_BG_COLOR "white"
-typedef int CELL;
-typedef double DCELL;
-typedef float FCELL;
-/*extern CELL CELL_NODATA; Sajith */
-typedef int RASTER_MAP_TYPE;
-struct Cell_head
-    int format;
-    int compressed;
-    int rows;
-    int rows3;
-    int cols;
-    int cols3;
-    int depths;
-    int proj;
-    int zone;
-    double ew_res;
-    double ew_res3;
-    double ns_res;
-    double ns_res3;
-    double tb_res;
-    double north;
-    double south;
-    double east;
-    double west;
-    double top;
-    double bottom;
-struct _Color_Rule_
-    struct
-    	DCELL value;
-	unsigned char red;
-	unsigned char grn;
-	unsigned char blu;
-    }  high;
-    struct
-    	DCELL value;
-    }  low;
-/*    struct _Color_Rule_ *next;
-    struct _Color_Rule_ *prev;  Commented By sajith I am confued here....*/
-struct _Color_Info_
-    struct _Color_Rule_ *rules;
-    int n_rules;
-    struct
-    	unsigned char *red;
-	unsigned char *grn;
-	unsigned char *blu;
-	unsigned char *set;
-	int nalloc;
-	int active;
-    } lookup;
-    struct
-        DCELL *vals;
-	struct _Color_Rule_ **rules;
-	int nalloc;
-	int active;
-    } fp_lookup;
-    DCELL min, max;
-struct Colors
-    int version;
-    DCELL shift;
-    int invert;
-    int is_float;
-    int null_set;
-    unsigned char null_red;
-    unsigned char null_grn;
-    unsigned char null_blu;
-    int undef_set;
-    unsigned char undef_red;
-    unsigned char undef_grn;
-    unsigned char undef_blu;
-    struct _Color_Info_ fixed;
-    struct _Color_Info_ modular;
-    DCELL cmin;
-    DCELL cmax;
-struct Reclass
-    char name[50];
-    char mapset[50];
-    int type;
-    int num;
-    CELL min;
-    CELL max;
-    CELL *table;
-struct FPReclass_table
-    DCELL dLow;
-    DCELL dHigh;
-    DCELL rLow;
-    DCELL rHigh;
-struct FPReclass
-    int defaultDRuleSet;
-    int defaultRRuleSet;
-    int infiniteLeftSet;
-    int infiniteRightSet;
-    int rRangeSet;
-    int maxNofRules;
-    int nofRules;
-    DCELL defaultDMin;
-    DCELL defaultDMax;
-    DCELL defaultRMin;
-    DCELL defaultRMax;
-    DCELL infiniteDLeft;
-    DCELL infiniteDRight;
-    DCELL infiniteRLeft;
-    DCELL infiniteRRight;
-    DCELL dMin;
-    DCELL dMax;
-    DCELL rMin;
-    DCELL rMax;
-    struct FPReclass_table *table;
-struct Quant_table
-    DCELL dLow;
-    DCELL dHigh;
-    CELL cLow;
-    CELL cHigh;
-struct Quant
-    int truncate_only;
-    int round_only;
-    int defaultCRuleSet;
-    int cRangeSet;
-    int maxNofRules;
-    int nofRules;
-    CELL defaultCMin;
-    CELL defaultCMax;
-    CELL infiniteCLeft;
-    CELL infiniteCRight;
-    DCELL dMin;
-    DCELL dMax;
-    CELL cMin;
-    CELL cMax;
-    struct Quant_table *table;
-    struct
-	DCELL *vals;
-	struct Quant_table **rules;
-	int nalloc;
-	int active;
-	DCELL inf_dmin;
-	DCELL inf_dmax;
-	CELL inf_min;
-	CELL inf_max;
-    } fp_lookup;
-struct Categories
-    CELL ncats;
-    CELL num;
-    char *title;
-    char *fmt;
-    float m1;
-    float a1;
-    float m2;
-    float a2;
-    struct Quant q;
-    char **labels;
-    int *marks;
-    int nalloc;
-    int last_marked_rule;
-struct History
-    char    mapid[RECORD_LEN];
-    char    title[RECORD_LEN];
-    char    mapset[RECORD_LEN];
-    char    creator[RECORD_LEN];
-    char    maptype[RECORD_LEN];
-    char    datsrc_1[RECORD_LEN];
-    char    datsrc_2[RECORD_LEN];
-    char    keywrd[RECORD_LEN];
-    int     edlinecnt;
-    char    edhist[MAXEDLINES][RECORD_LEN];
-struct Cell_stats
-    struct Cell_stats_node
-	int idx;
-	long *count;
-	int left;
-	int right;
-    } *node ;
-    int tlen ;
-    int N;
-    int curp;
-    long null_data_count;
-    int curoffset;
-struct Histogram
-    int num;
-    struct Histogram_list
-	CELL cat;
-	long count;
-    } *list;
-struct Range
-    CELL min;
-    CELL max;
-    int first_time;
-struct FPRange
-    DCELL min;
-    DCELL max;
-    int first_time;
-struct G_3dview
-    char pgm_id[40];
-    float from_to[2][3];
-    float fov;
-    float twist;
-    float exag;
-    int mesh_freq;
-    int poly_freq;
-    int display_type;
-    int lightson;
-    int dozero;
-    int colorgrid;
-    int shading;
-    int fringe;
-    int surfonly;
-    int doavg;
-    char grid_col[40];
-    char bg_col[40];
-    char other_col[40];
-    float lightpos[4];
-    float lightcol[3];
-    float ambient;
-    float shine;
-    struct Cell_head vwin;
-struct Key_Value
-    int nitems;
-    int nalloc;
-    char **key;
-    char **value;
-struct Option
-    char *key;
-    int type;
-    int required;
-    int multiple;
-    char *options;
-    char **opts;
-    char *key_desc;
-    char *label;
-    char *description;
-    char *descriptions;
-    char **descs;
-    char *answer;
-    char *def;
-    char **answers;
-    struct Option *next_opt;
-    char *gisprompt;
-    int (*checker)();
-    int count;
-struct Flag
-    char key;
-    char answer;
-    char *label;
-    struct Flag *next_flag;
-struct GModule
-    char *label;
-    int overwrite;
-struct TimeStamp
-    DateTime dt[2];
-    int count;
