[GRASS-SVN] r33560 - in grass/trunk: lib/python scripts/r.in.aster
scripts/v.db.addcol scripts/v.db.join scripts/v.dissolve
scripts/v.in.e00 scripts/v.in.geonames scripts/v.in.gns
svn_grass at osgeo.org
Fri Sep 26 17:13:14 EDT 2008
Author: glynn
Date: 2008-09-26 17:13:14 -0400 (Fri, 26 Sep 2008)
New Revision: 33560
Added:
grass/trunk/scripts/v.db.addcol/v.db.addcol.py
grass/trunk/scripts/v.db.join/v.db.join.py
grass/trunk/lib/python/grass.py
grass/trunk/scripts/r.in.aster/r.in.aster.py
grass/trunk/scripts/v.dissolve/v.dissolve.py
grass/trunk/scripts/v.in.e00/v.in.e00.py
grass/trunk/scripts/v.in.geonames/v.in.geonames.py
grass/trunk/scripts/v.in.gns/v.in.gns.py
Convert v.db.addcol, v.db.join to Python
Make grass.parser() record original command line (to simplify v.support calls)
Modified: grass/trunk/lib/python/grass.py
--- grass/trunk/lib/python/grass.py 2008-09-26 15:55:45 UTC (rev 33559)
+++ grass/trunk/lib/python/grass.py 2008-09-26 21:13:14 UTC (rev 33560)
@@ -110,6 +110,10 @@
if len(sys.argv) > 1 and sys.argv[1] == "@ARGS_PARSED@":
return _parse_env()
+ cmdline = [basename(sys.argv[0])]
+ cmdline += ['"' + arg + '"' for arg in sys.argv[1:]]
+ os.environ['CMDLINE'] = ' '.join(cmdline)
argv = sys.argv[:]
name = argv[0]
if not os.path.isabs(name):
Modified: grass/trunk/scripts/r.in.aster/r.in.aster.py
--- grass/trunk/scripts/r.in.aster/r.in.aster.py 2008-09-26 15:55:45 UTC (rev 33559)
+++ grass/trunk/scripts/r.in.aster/r.in.aster.py 2008-09-26 21:13:14 UTC (rev 33560)
@@ -164,9 +164,6 @@
srcfile=options['input']
import_aster(proj, srcfile, tempfile, "DEM")
- # write cmd history: Not sure how to replicate this in Python yet
- #r.support "$GIS_OPT_OUTPUT" history="${CMDLINE}"
#cleanup
message("Cleaning up ...")
grass.try_remove(tempfile)
@@ -196,7 +193,9 @@
outfile = options['output'].strip()+'.'+band
grass.run_command("r.in.gdal", overwrite = flags['o'], input = tempfile, output = outfile)
- return
+ # write cmd history
+ grass.run_command('r.support', map = outfile, history = os.environ['CMDLINE'])
+ #r.support "$GIS_OPT_OUTPUT" history="${CMDLINE}"
if __name__ == "__main__":
options, flags = grass.parser()
Added: grass/trunk/scripts/v.db.addcol/v.db.addcol.py
--- grass/trunk/scripts/v.db.addcol/v.db.addcol.py (rev 0)
+++ grass/trunk/scripts/v.db.addcol/v.db.addcol.py 2008-09-26 21:13:14 UTC (rev 33560)
@@ -0,0 +1,91 @@
+#!/usr/bin/env python
+# MODULE: v.db.addcolumn
+# AUTHOR(S): Moritz Lennert
+# Converted to Python by Glynn Clements
+# PURPOSE: interface to db.execute to add a column to the attribute table
+# connected to a given vector map
+# COPYRIGHT: (C) 2005 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%Module
+#% description: Adds one or more columns to the attribute table connected to a given vector map.
+#% keywords: vector, database, attribute table
+#%End
+#%option
+#% key: map
+#% type: string
+#% gisprompt: old,vector,vector
+#% key_desc : name
+#% description: Vector map for which to edit attribute table
+#% required : yes
+#%end
+#%option
+#% key: layer
+#% type: integer
+#% description: Layer where to add column
+#% answer: 1
+#% required : no
+#%end
+#%option
+#% key: columns
+#% type: string
+#% description: Name and type of the new column(s) ('name type [,name type, ...]' - types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE)
+#% required : yes
+#%end
+import sys
+import os
+import grass
+import subprocess
+def main():
+ map = options['map']
+ layer = options['layer']
+ columns = options['columns']
+ columns = [col.strip() for col in columns.split(',')]
+ # does map exist in CURRENT mapset?
+ mapset = grass.gisenv()['MAPSET']
+ exists = bool(grass.find_file(map, element = 'vector', mapset = mapset)['file'])
+ if not exists:
+ grass.fatal("Vector map <%s> not found in current mapset" % map)
+ s = grass.read_command('v.db.connect', flags = 'g', map = map, layer = layer)
+ if not s:
+ grass.fatal("There is no table connected to this map. Run v.db.connect or v.db.addtable first.")
+ f = s.split()
+ table = f[1]
+ database = f[3]
+ driver = f[4]
+ colnum = len(columns)
+ for col in columns:
+ if not col:
+ grass.fatal("There is an empty column. Did you leave a trailing comma?")
+ p = grass.start_command('db.execute', database = database, driver = driver, stdin = subprocess.PIPE)
+ p.stdin.write("ALTER TABLE %s ADD COLUMN %s" % (table, col))
+ p.stdin.close()
+ if p.wait() != 0:
+ grass.fatal("Unable to add column <%s>." % col)
+ # write cmd history:
+ grass.run_command('v.support', map = map, cmdhist = os.environ['CMDLINE'])
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Property changes on: grass/trunk/scripts/v.db.addcol/v.db.addcol.py
___________________________________________________________________
Added: grass/trunk/scripts/v.db.join/v.db.join.py
--- grass/trunk/scripts/v.db.join/v.db.join.py (rev 0)
+++ grass/trunk/scripts/v.db.join/v.db.join.py 2008-09-26 21:13:14 UTC (rev 33560)
@@ -0,0 +1,126 @@
+# MODULE: v.db.join
+# AUTHOR(S): Markus Neteler
+# PURPOSE: Join a table to a map table
+# COPYRIGHT: (C) 2007 by Markus Neteler and the GRASS Development Team
+# for details.
+#%Module
+#% description: Allows to join a table to a vector map table.
+#%End
+#%option
+#% key: map
+#% type: string
+#% key_desc : name
+#% description: Vector map to which to join other table
+#% required : yes
+#%end
+#%option
+#% key: layer
+#% type: integer
+#% description: Layer where to join
+#% answer: 1
+#% required : no
+#%end
+#%option
+#% key: column
+#% type: string
+#% description: Join column in map table
+#% required : yes
+#%end
+#%option
+#% key: otable
+#% type: string
+#% description: Other table name
+#% required : yes
+#%end
+#%option
+#% key: ocolumn
+#% type: string
+#% description: Join column in other table
+#% required : yes
+#%end
+import sys
+import os
+import subprocess
+import grass
+def main():
+ column = options['column']
+ otable = options['otable']
+ ocolumn = options['ocolumn']
+ f = s.split()
+ maptable = f[1]
+ database = f[3]
+ driver = f[4]
+ if driver == 'dbf':
+ grass.fatal("JOIN is not supported for tables stored in DBF format.")
+ if not maptable:
+ grass.fatal("There is no table connected to this map. Cannot join any column.")
+ found = False
+ s = grass.read_command('v.info', flags = 'c', map = map, layer = layer, quiet = True)
+ for line in s.splitlines():
+ f = line.split('|')
+ if len(f) > 1 and f[1] == column:
+ found = True
+ if not found:
+ grass.fatal("Column <%> not found in table <%s> at layer <%s>" % (column, map, layer))
+ s = grass.read_command('db.describe', flags = 'c', driver = driver,
+ database = database, table = otable)
+ cols = [l.split(':') for l in s.splitlines() if l.startswith('Column ')]
+ select = "SELECT $colname FROM $otable WHERE $otable.$ocolumn=$table.$column"
+ template = Template("UPDATE $table SET $colname=(%s);" % select)
+ for col in cols:
+ colname = col[0]
+ if len(col) > 2:
+ coltype = "%s(%s)" % col[1:3]
+ else:
+ coltype = "%s" % col[1]
+ colspec = "%s %s" % (colname, coltype)
+ if grass.run_command('v.db.addcol', map = map, col = colspec) != 0:
+ grass.fatal("Error creating column <%s>." % colname)
+ stmt = template.substitute(table = maptable, column = column,
+ otable = otable, ocolumn = ocolumn,
+ colname = colname)
+ p = grass.start_command('db.execute', stdin = subprocess.PIPE)
+ p.stdin.write(stmt)
+ p.stdin.close()
+ p.wait()
+ if p.returncode != 0:
+ grass.fatal("Error filling column <%s>." % colname)
+ grass.run_command('v.support', map = map, cmdhist = cmdline)
+ main()
Modified: grass/trunk/scripts/v.dissolve/v.dissolve.py
--- grass/trunk/scripts/v.dissolve/v.dissolve.py 2008-09-26 15:55:45 UTC (rev 33559)
+++ grass/trunk/scripts/v.dissolve/v.dissolve.py 2008-09-26 21:13:14 UTC (rev 33560)
@@ -66,15 +66,6 @@
- # save command line
- cmdline = grass.basename(sys.argv[0])
- cmdline += ' input=' + input
- cmdline += ' output=' + output
- if layer:
- cmdline += ' layer=' + layer
- if column:
- cmdline += ' column=' + column
#### setup temporary file
tmp = str(os.getpid())
@@ -110,7 +101,7 @@
output = output, type = 'area', layer = layer)
- grass.run_command('v.support', map = output, cmdhist = cmdline)
+ grass.run_command('v.support', map = output, cmdhist = os.environ['CMDLINE'])
Modified: grass/trunk/scripts/v.in.e00/v.in.e00.py
--- grass/trunk/scripts/v.in.e00/v.in.e00.py 2008-09-26 15:55:45 UTC (rev 33559)
+++ grass/trunk/scripts/v.in.e00/v.in.e00.py 2008-09-26 21:13:14 UTC (rev 33560)
@@ -63,13 +63,6 @@
type = options['type']
vect = options['vect']
- cmdline += ' file=' + filename
- cmdline += ' type=' + type
- if vect:
- cmdline += ' vect=' + vect
e00tmp = str(os.getpid())
#### check for avcimport
@@ -175,7 +168,7 @@
grass.message("Done.")
- grass.run_command('v.support', map = name, cmdhist = cmdline)
+ grass.run_command('v.support', map = name, cmdhist = os.environ['CMDLINE'])
Modified: grass/trunk/scripts/v.in.geonames/v.in.geonames.py
--- grass/trunk/scripts/v.in.geonames/v.in.geonames.py 2008-09-26 15:55:45 UTC (rev 33559)
+++ grass/trunk/scripts/v.in.geonames/v.in.geonames.py 2008-09-26 21:13:14 UTC (rev 33560)
@@ -51,12 +51,6 @@
infile = options['input']
- if infile:
- cmdline += ' input=' + infile
- if outfile:
- cmdline += ' output=' + outfile
tmpfile = grass.tempfile()
@@ -151,7 +145,7 @@
grass.try_remove(tmpfile)
- grass.run_command('v.support', map = outfile, cmdhist = cmdline)
+ grass.run_command('v.support', map = outfile, cmdhist = os.environ['CMDLINE'])
Modified: grass/trunk/scripts/v.in.gns/v.in.gns.py
--- grass/trunk/scripts/v.in.gns/v.in.gns.py 2008-09-26 15:55:45 UTC (rev 33559)
+++ grass/trunk/scripts/v.in.gns/v.in.gns.py 2008-09-26 21:13:14 UTC (rev 33560)
@@ -51,13 +51,6 @@
fileorig = options['file']
filevect = options['vect']
- if fileorig:
- cmdline += ' file=' + fileorig
- if filevect:
- cmdline += ' vect=' + filevect
if not filevect:
filevect = grass.basename(fileorig, 'txt')
@@ -154,7 +147,7 @@
- grass.run_command('v.support', map = filevect, cmdhist = cmdline)
+ grass.run_command('v.support', map = filevect, cmdhist = os.environ['CMDLINE'])
