[GRASS-SVN] r33561 - in grass/trunk/scripts: r.blend v.db.join
svn_grass at osgeo.org
Fri Sep 26 20:06:45 EDT 2008
Author: glynn
Date: 2008-09-26 20:06:45 -0400 (Fri, 26 Sep 2008)
New Revision: 33561
Added:
grass/trunk/scripts/r.blend/r.blend.py
grass/trunk/scripts/v.db.join/v.db.join.py
Convert r.blend to Python
Fix bug in v.db.join
Added: grass/trunk/scripts/r.blend/r.blend.py
--- grass/trunk/scripts/r.blend/r.blend.py (rev 0)
+++ grass/trunk/scripts/r.blend/r.blend.py 2008-09-27 00:06:45 UTC (rev 33561)
@@ -0,0 +1,101 @@
+#!/usr/bin/env python
+# MODULE: r.blend for GRASS 5.7; based on blend.sh for GRASS 5
+# AUTHOR(S): CERL?; updated to GRASS 5.7 by Michael Barton
+# Converted to Python by Glynn Clements
+# PURPOSE: To redraw current displayed maps to 24 bit PNG output
+# COPYRIGHT: (C) 2004 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%Module
+#% description: Blends color components of two raster maps by a given ratio.
+#% keywords: raster
+#%End
+#%option
+#% key: first
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: Name of first raster map for blending
+#% key_desc : name
+#% required : yes
+#%end
+#%option
+#% key: second
+#% type: string
+#% description: Name of second raster map for blending
+#% key_desc : name
+#% required : yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% description: Base name for red, green and blue output maps containing the blend
+#% key_desc : name
+#% required : yes
+#%end
+#%option
+#% key: percent
+#% type: integer
+#% answer: 50
+#% options : 1-99
+#% description: Percentage weight of first map for color blending
+#% required : no
+#%end
+import sys
+import os
+import string
+import grass
+def main():
+ first = options['first']
+ second = options['second']
+ output = options['output']
+ percent = options['percent']
+ mapset = grass.gisenv()['MAPSET']
+ if not grass.overwrite():
+ for ch in ['r','g','b']:
+ map = '%s.%s' % (output, ch)
+ if grass.find_file(map, element = 'cell', mapset = mapset)['file']:
+ grass.fatal("Raster map <%s> already exists." % map)
+ percent = int(percent)
+ perc_inv = 100 - percent
+ frac1 = percent / 100.0
+ frac2 = perc_inv / 100.0
+ grass.message("Calculating the three component maps...")
+ template = string.Template("$output.$$ch = $frac1 * $$ch#$first + $frac2 * $$ch#$second")
+ s = template.substitute(output = output,
+ first = first, second = second,
+ frac1 = frac1, frac2 = frac2)
+ template = string.Template(s)
+ map = "%s.%s" % (output, ch)
+ grass.run_command('r.mapcalc', expr = template.substitute(ch = ch))
+ grass.run_command('r.colors', map = map, color = 'grey255')
+ grass.run_command('r.support', map = map,
+ title = "Color blend of %s and %s" % (first, second), history="")
+ history = "r.blend %s channel." % ch)
+ history = " %d%% of %s, %d%% of %s" % (percent, first, perc_inv, second))
+ grass.run_command('r.support', map = map, history = os.environ['CMDLINE'])
+ grass.message("Done. Use the following command to visualize the result:")
+ grass.message("d.rgb r=%s.r g=%s.g b=%s.b" % (output, output, output))
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Property changes on: grass/trunk/scripts/r.blend/r.blend.py
___________________________________________________________________
Modified: grass/trunk/scripts/v.db.join/v.db.join.py
--- grass/trunk/scripts/v.db.join/v.db.join.py 2008-09-26 21:13:14 UTC (rev 33560)
+++ grass/trunk/scripts/v.db.join/v.db.join.py 2008-09-27 00:06:45 UTC (rev 33561)
@@ -60,6 +60,7 @@
import sys
import os
import subprocess
+import string
import grass
def main():
@@ -95,7 +96,7 @@
cols = [l.split(':') for l in s.splitlines() if l.startswith('Column ')]
select = "SELECT $colname FROM $otable WHERE $otable.$ocolumn=$table.$column"
- template = Template("UPDATE $table SET $colname=(%s);" % select)
+ template = string.Template("UPDATE $table SET $colname=(%s);" % select)
for col in cols:
colname = col[0]
