[GRASS-SVN] r33562 - in grass/trunk: lib/python scripts/d.correlate
scripts/db.droptable scripts/r.in.aster scripts/r.mask
scripts/v.db.addcol scripts/v.db.join
svn_grass at osgeo.org
Fri Sep 26 21:36:25 EDT 2008
Author: glynn
Date: 2008-09-26 21:36:25 -0400 (Fri, 26 Sep 2008)
New Revision: 33562
Added:
grass/trunk/scripts/d.correlate/d.correlate.py
grass/trunk/lib/python/grass.py
grass/trunk/scripts/db.droptable/db.droptable.py
grass/trunk/scripts/r.in.aster/r.in.aster.py
grass/trunk/scripts/r.mask/r.mask.py
grass/trunk/scripts/v.db.addcol/v.db.addcol.py
grass/trunk/scripts/v.db.join/v.db.join.py
Convert d.correlate to Python
Add, use feed_command, write_command (write to stdin)
Clean up r.in.aster
Modified: grass/trunk/lib/python/grass.py
--- grass/trunk/lib/python/grass.py 2008-09-27 00:06:45 UTC (rev 33561)
+++ grass/trunk/lib/python/grass.py 2008-09-27 01:36:25 UTC (rev 33562)
@@ -54,10 +54,22 @@
kwargs['stdout'] = subprocess.PIPE
return start_command(*args, **kwargs)
+def feed_command(*args, **kwargs):
+ kwargs['stdin'] = subprocess.PIPE
+ return start_command(*args, **kwargs)
def read_command(*args, **kwargs):
ps = pipe_command(*args, **kwargs)
return ps.communicate()[0]
+def write_command(*args, **kwargs):
+ stdin = kwargs['stdin']
+ p = start_command(*args, **kwargs)
+ p.stdin.write(stdin)
+ p.stdin.close()
+ return p.wait()
def exec_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, env = None, **kwargs):
args = make_command(prog, flags, overwrite, quiet, verbose, **kwargs)
if env == None:
@@ -274,10 +286,10 @@
# find a program (replacement for "which")
-def find_program(pgm):
+def find_program(pgm, args = []):
nuldev = file(os.devnull, 'w+')
try:
- subprocess.call([pgm], stdin = nuldev, stdout = nuldev, stderr = nuldev)
+ subprocess.call([pgm] + args, stdin = nuldev, stdout = nuldev, stderr = nuldev)
found = True
except:
found = False
Added: grass/trunk/scripts/d.correlate/d.correlate.py
--- grass/trunk/scripts/d.correlate/d.correlate.py (rev 0)
+++ grass/trunk/scripts/d.correlate/d.correlate.py 2008-09-27 01:36:25 UTC (rev 33562)
@@ -0,0 +1,104 @@
+#!/usr/bin/env python
+# MODULE: d.correlate for GRASS 6; based on dcorrelate.sh for GRASS 4,5
+# AUTHOR(S): CERL - Michael Shapiro; updated to GRASS 6 by Markus Neteler 5/2005
+# Converted to Python by Glynn Clements
+# PURPOSE: prints a graph of the correlation between data layers (in pairs)
+# derived from <grass5>/src.local/d.correlate.sh
+# COPYRIGHT: (C) 2005, 2008 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+# TODO GRASS 7: rename parameters to map1, map2 or better multiple map=map1[,map2[...]]
+#%Module
+#% description: Prints a graph of the correlation between data layers (in pairs).
+#% keywords: display, diagram
+#%End
+#%option
+#% key: layers
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: raster input map
+#% required: yes
+#% multiple: yes
+#%end
+import sys
+import os
+import grass
+def main():
+ layers = options['layers'].split(',')
+ if len(layers) < 2:
+ grass.error("At least 2 layers are required")
+ tmpfile = grass.tempfile()
+ for map in layers:
+ if not grass.find_file(map, element = 'cell')['file']:
+ grass.fatal("Input map <%s> not found" % map)
+ grass.write_command('d.text', color = 'black', size = 4, line = 1, stdin = "CORRELATION")
+ colors = "red black blue green gray violet".split()
+ line = 2
+ iloop = 0
+ jloop = 0
+ for iloop, i in enumerate(layers):
+ for jloop, j in enumerate(layers):
+ if i != j and iloop <= jloop:
+ color = colors[0]
+ colors = colors[1:]
+ colors.append(color)
+ grass.write_command('d.text', color = color, size = 4, line = line, stdin = "%s %s" % (i, j))
+ line += 1
+ ofile = file(tmpfile, 'w')
+ grass.run_command('r.stats', flags = 'cnA', input = (i, j), stdout = ofile)
+ ofile.close()
+ ifile = file(tmpfile, 'r')
+ first = True
+ for l in ifile:
+ f = l.rstrip('\r\n').split(' ')
+ x = float(f[0])
+ y = float(f[1])
+ if first:
+ minx = maxx = x
+ miny = maxy = y
+ first = False
+ if minx > x: minx = x
+ if maxx < x: maxx = x
+ if miny > y: miny = y
+ if maxy < y: maxy = y
+ ifile.close()
+ kx = 100.0/(maxx-minx+1)
+ ky = 100.0/(maxy-miny+1)
+ p = grass.feed_command('d.graph', color = color)
+ ofile = p.stdin
+ for l in ifile:
+ x = float(f[0])
+ y = float(f[1])
+ ofile.write("icon + 0.1 %f %f\n" % ((x-minx+1) * kx, (y-miny+1) * ky))
+ ifile.close()
+ ofile.close()
+ p.wait()
+ grass.try_remove(tmpfile)
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Property changes on: grass/trunk/scripts/d.correlate/d.correlate.py
___________________________________________________________________
Modified: grass/trunk/scripts/db.droptable/db.droptable.py
--- grass/trunk/scripts/db.droptable/db.droptable.py 2008-09-27 00:06:45 UTC (rev 33561)
+++ grass/trunk/scripts/db.droptable/db.droptable.py 2008-09-27 01:36:25 UTC (rev 33562)
@@ -37,7 +37,6 @@
import sys
import os
import grass
-import subprocess
def main():
table = options['table']
@@ -84,8 +83,7 @@
grass.message("You must use the force flag to actually remove it. Exiting.")
sys.exit(0)
- p = grass.start_command('db.execute', database = database, driver = driver,
- stdin = subprocess.PIPE)
+ p = grass.feed_command('db.execute', database = database, driver = driver)
p.stdin.write("DROP TABLE " + table)
p.stdin.close()
p.wait()
Modified: grass/trunk/scripts/r.in.aster/r.in.aster.py
--- grass/trunk/scripts/r.in.aster/r.in.aster.py 2008-09-27 00:06:45 UTC (rev 33561)
+++ grass/trunk/scripts/r.in.aster/r.in.aster.py 2008-09-27 01:36:25 UTC (rev 33562)
@@ -101,38 +101,16 @@
-def _message(msg, *args):
- subprocess.call(["g.message", "message=%s" % msg] + list(args))
-def debug(msg):
- _message(msg, '-d')
-def message(msg):
- _message(msg)
-def error(msg):
- _message(msg, '-e')
- sys.exit(1)
def main():
+ input = options['input']
+ proctype = options['proctype']
+ output = options['output']
+ band = options['band']
#check whether gdalwarp is in path and executable
- p = None
- try:
- p = subprocess.call(['gdalwarp', '--version'])
- except:
- pass
- if p == None or p != 0:
- error("gdalwarp is not in the path and executable")
+ if not grass.find_command('gdalwarp', ['--version']):
+ grass.fatal("gdalwarp is not in the path and executable")
- #initialize variables
- dataset = ''
- srcfile = ''
- proj = ''
- band = ''
- outfile = ''
- bandlist = []
#create temporary file to hold gdalwarp output before importing to GRASS
tempfile = grass.read_command("g.tempfile", pid = os.getpid()).strip() + '.tif'
@@ -141,41 +119,41 @@
#currently only runs in projected location
if "XY location" in proj:
- error ("This module needs to be run in a projected location (found: %s)" % proj)
+ grass.fatal("This module needs to be run in a projected location (found: %s)" % proj)
#process list of bands
allbands = ['1','2','3n','3b','4','5','6','7','8','9','10','11','12','13','14']
- if options['band'].strip() == 'all':
+ if band == 'all':
bandlist = allbands
else:
- bandlist = options['band'].split(',')
+ bandlist = band.split(',')
#initialize datasets for L1A and L1B
- if options['proctype'] in ["L1A", "L1B"]:
+ if proctype in ["L1A", "L1B"]:
for band in bandlist:
if band in allbands:
- dataset = bands[options['proctype']][band]
- srcfile = "HDF4_EOS:EOS_SWATH:%s:%s" % (options['input'], dataset)
+ dataset = bands[proctype][band]
+ srcfile = "HDF4_EOS:EOS_SWATH:%s:%s" % (input, dataset)
import_aster(proj, srcfile, tempfile, band)
else:
- error('band %s is not an available Terra/ASTER band' % band)
- elif options['proctype'] == "DEM":
- srcfile=options['input']
+ grass.fatal('band %s is not an available Terra/ASTER band' % band)
+ elif proctype == "DEM":
+ srcfile = input
import_aster(proj, srcfile, tempfile, "DEM")
#cleanup
- message("Cleaning up ...")
+ grass.message("Cleaning up ...")
grass.try_remove(tempfile)
- message("Done.")
+ grass.message("Done.")
return
def import_aster(proj, srcfile, tempfile, band):
#run gdalwarp with selected options (must be in $PATH)
#to translate aster image to geotiff
- message("Georeferencing aster image ...")
- debug("gdalwarp -t_srs %s %s %s" % (proj, srcfile, tempfile))
+ grass.message("Georeferencing aster image ...")
+ grass.debug("gdalwarp -t_srs %s %s %s" % (proj, srcfile, tempfile))
if platform.system() == "Darwin":
cmd = ["arch", "-i386", "gdalwarp", "-t_srs", proj, srcfile, tempfile ]
@@ -189,8 +167,8 @@
#p = subprocess.call(["gdal_translate", srcfile, tempfile])
#import geotiff to GRASS
- message("Importing into GRASS ...")
- outfile = options['output'].strip()+'.'+band
+ grass.message("Importing into GRASS ...")
+ outfile = "%s.%s" % (output, band)
grass.run_command("r.in.gdal", overwrite = flags['o'], input = tempfile, output = outfile)
# write cmd history
Modified: grass/trunk/scripts/r.mask/r.mask.py
--- grass/trunk/scripts/r.mask/r.mask.py 2008-09-27 00:06:45 UTC (rev 33561)
+++ grass/trunk/scripts/r.mask/r.mask.py 2008-09-27 01:36:25 UTC (rev 33562)
@@ -45,7 +45,6 @@
import os
import grass
import atexit
-import subprocess
def cleanup():
if tmp:
@@ -73,8 +72,7 @@
if exists and not grass.overwrite():
grass.fatal("MASK already found in current mapset. Delete first or overwrite")
- p = grass.start_command('r.reclass', input = input, output = 'MASK', overwrite = True,
+ p = grass.feed_command('r.reclass', input = input, output = 'MASK', overwrite = True)
p.stdin.write("%s = 1" % maskcats)
p.stdin.close()
p.wait()
Modified: grass/trunk/scripts/v.db.addcol/v.db.addcol.py
--- grass/trunk/scripts/v.db.addcol/v.db.addcol.py 2008-09-27 00:06:45 UTC (rev 33561)
+++ grass/trunk/scripts/v.db.addcol/v.db.addcol.py 2008-09-27 01:36:25 UTC (rev 33562)
@@ -48,7 +48,6 @@
import sys
import os
import grass
-import subprocess
def main():
map = options['map']
@@ -77,7 +76,7 @@
if not col:
grass.fatal("There is an empty column. Did you leave a trailing comma?")
- p = grass.start_command('db.execute', database = database, driver = driver, stdin = subprocess.PIPE)
p.stdin.write("ALTER TABLE %s ADD COLUMN %s" % (table, col))
p.stdin.close()
if p.wait() != 0:
Modified: grass/trunk/scripts/v.db.join/v.db.join.py
--- grass/trunk/scripts/v.db.join/v.db.join.py 2008-09-27 00:06:45 UTC (rev 33561)
+++ grass/trunk/scripts/v.db.join/v.db.join.py 2008-09-27 01:36:25 UTC (rev 33562)
@@ -59,7 +59,6 @@
import sys
import os
-import subprocess
import string
import grass
@@ -112,7 +111,7 @@
otable = otable, ocolumn = ocolumn,
colname = colname)
- p = grass.start_command('db.execute', stdin = subprocess.PIPE)
+ p = grass.feed_command('db.execute')
p.stdin.write(stmt)
p.stdin.close()
p.wait()
