[GRASS-SVN] r33570 - grass/trunk/scripts/v.db.update
svn_grass at osgeo.org
Sat Sep 27 15:15:30 EDT 2008
Author: glynn
Date: 2008-09-27 15:15:30 -0400 (Sat, 27 Sep 2008)
New Revision: 33570
Added:
grass/trunk/scripts/v.db.update/v.db.update.py
Convert v.db.update to Python
Added: grass/trunk/scripts/v.db.update/v.db.update.py
--- grass/trunk/scripts/v.db.update/v.db.update.py (rev 0)
+++ grass/trunk/scripts/v.db.update/v.db.update.py 2008-09-27 19:15:30 UTC (rev 33570)
@@ -0,0 +1,124 @@
+#!/usr/bin/env python
+# MODULE: v.db.update
+# AUTHOR(S): Moritz Lennert
+# extensions by Markus Neteler
+# Converted to Python by Glynn Clements
+# PURPOSE: interface to db.execute to update a column in the attribute table connected to a given map
+# COPYRIGHT: (C) 2005,2007,2008 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%Module
+#% description: Allows to update a column in the attribute table connected to a vector map.
+#% keywords: vector, database, attribute table
+#%End
+#%option
+#% key: map
+#% type: string
+#% gisprompt: old,vector,vector
+#% description: Vector map to edit the attribute table for
+#% required : yes
+#%end
+#%option
+#% key: layer
+#% type: integer
+#% description: Layer to which the table to be changed is connected
+#% answer: 1
+#% required : no
+#%end
+#%option
+#% key: column
+#% type: string
+#% description: Column to update
+#% required : yes
+#%end
+#%option
+#% key: value
+#% type: string
+#% description: Value to update the column with, can be (combination of) other column(s)
+#% required : no
+#%end
+#%option
+#% key: qcolumn
+#% type: string
+#% description: Column to query
+#% required : no
+#%end
+#%option
+#% key: where
+#% type: string
+#% description: WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/col2>1)
+#% required : no
+#%end
+import sys
+import os
+import grass
+def main():
+ map = options['map']
+ layer = options['layer']
+ column = options['column']
+ value = options['value']
+ qcolumn = options['qcolumn']
+ where = options['where']
+ mapset = grass.gisenv()['MAPSET']
+ # does map exist in CURRENT mapset?
+ if not grass.find_file(map, element = 'vector', mapset = mapset)['file']:
+ grass.fatal("Vector map '$GIS_OPT_MAP' not found in current mapset")
+ s = grass.read_command('v.db.connect', flags = 'g', map = map, layer = layer)
+ f = s.rstrip('\r\n').split(' ')
+ if len(s) < 2:
+ grass.fatal('There is no table connected to this map. Run v.db.connect or v.db.addtable first.')
+ table = f[1]
+ database = f[3]
+ driver = f[4]
+ # checking column types
+ coltype = None
+ s = grass.read_command('v.info', flags = 'c', map = map, quiet = True)
+ for l in s.splitlines():
+ f = l.split('|')
+ if len(f) < 2:
+ continue
+ if f[1] == column:
+ coltype = f[0]
+ if not coltype:
+ grass.fatal('column <%s> not found' % column)
+ if qcolumn:
+ if value:
+ grass.fatal('value= and qcolumn= are mutually exclusive')
+ # special case: we copy from another column
+ value = qcolumn
+ else:
+ if not value:
+ grass.fatal('Either value= or qcolumn= must be given')
+ # we insert a value
+ if coltype.upper() not in ["INTEGER", "DOUBLE PRECISION"]:
+ value = "'%s'" % value
+ cmd = "UPDATE %s SET %s=%s" % (table, column, value)
+ if where:
+ cmd += " WHERE " + where
+ grass.write_command('db.execute', database = database, driver = driver, stdin = cmd)
+ # write cmd history:
+ grass.run_command('v.support', map = map, cmdhist = os.environ['CMDLINE'])
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Property changes on: grass/trunk/scripts/v.db.update/v.db.update.py
___________________________________________________________________
