[GRASS-SVN] r33571 - grass/trunk/scripts/i.landsat.rgb
svn_grass at osgeo.org
Sat Sep 27 16:01:28 EDT 2008
Author: glynn
Date: 2008-09-27 16:01:28 -0400 (Sat, 27 Sep 2008)
New Revision: 33571
Added:
grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py
Convert i.landsat.rgb to Python
Added: grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py
--- grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py (rev 0)
+++ grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py 2008-09-27 20:01:28 UTC (rev 33571)
@@ -0,0 +1,139 @@
+#!/usr/bin/env python
+# MODULE: i.landsat.rgb
+# AUTHOR(S): Markus Neteler. <neteler itc it>
+# Hamish Bowman, scripting enhancements
+# Converted to Python by Glynn Clements
+# PURPOSE: create pretty LANDSAT RGBs: the trick is to remove outliers
+# using percentiles (area under the histogram curve)
+# COPYRIGHT: (C) 2006,2008 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+# TODO: implement better brightness control
+#%Module
+#% description: Auto-balancing of colors for LANDSAT images
+#% keywords: raster, imagery, colors
+#%End
+#%option
+#% key: red
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: LANDSAT red channel
+#% required : yes
+#%end
+#%option
+#% key: green
+#% type: string
+#% description: LANDSAT green channel
+#% required : yes
+#%end
+#%option
+#% key: blue
+#% type: string
+#% description: LANDSAT blue channel
+#% required : yes
+#%end
+#%option
+#% key: strength
+#% type: integer
+#% description: Cropping intensity (upper brightness level)
+#% options: 0-100
+#% answer : 98
+#% required : no
+#%end
+#%flag
+#% key: f
+#% description: Extend colors to full range of data on each channel
+#%end
+#%flag
+#% key: p
+#% description: Preserve relative colors, adjust brightness only
+#%end
+#%flag
+#% key: r
+#% description: Reset to standard color range
+#%end
+import sys
+import os
+import string
+import grass
+def get_percentile(map, percentile):
+ s = grass.read_command('r.univar', flags = 'ge', map = map, percentile = percentile)
+ kv = grass.parse_key_val(s)
+ return float(kv['percentile_%s' % percentile])
+def set_colors(map, v0, v1):
+ rules = [
+ "0% black\n",
+ "%f black\n" % v0,
+ "%f white\n" % v1,
+ "100% white\n"
+ rules = ''.join(rules)
+ grass.write_command('r.colors', map = map, rules = '-', stdin = rules)
+def main():
+ red = options['red']
+ green = options['green']
+ blue = options['blue']
+ brightness = options['strength']
+ full = flags['f']
+ preserve = flags['p']
+ reset = flags['r']
+ # 90 or 98? MAX value controls brightness
+ # think of percent (0-100), must be positive or 0
+ # must be more than "2" ?
+ if full:
+ for i in [red, green, blue]:
+ grass.run_command('r.colors', map = i, color = 'grey')
+ sys.exit(0)
+ if reset:
+ grass.run_command('r.colors', map = i, color = 'grey255')
+ sys.exit(0)
+ if not preserve:
+ grass.message("Processing <%s> ..." % i)
+ v0 = get_percentile(i, 2)
+ v1 = get_percentile(i, brightness)
+ grass.debug("<%s>: min=%f max=%f" % (i, v0, v1))
+ set_colors(i, v0, v1)
+ else:
+ all_max = 0
+ all_min = 255
+ all_min = min(all_min, v0)
+ all_max = max(all_max, v1)
+ grass.debug("all_min=%f all_max=%f" % (all_min, all_max))
+ # write cmd history:
+ grass.run_command('r.support', map = i, history = os.environ['CMDLINE'])
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Property changes on: grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py
___________________________________________________________________
