[GRASS-SVN] r33594 - in grass/trunk/scripts: db.dropcol
v.db.dropcol v.db.join v.db.renamecol
svn_grass at osgeo.org
Mon Sep 29 11:33:08 EDT 2008
Author: glynn
Date: 2008-09-29 11:33:08 -0400 (Mon, 29 Sep 2008)
New Revision: 33594
Added:
grass/trunk/scripts/v.db.renamecol/v.db.renamecol.py
grass/trunk/scripts/db.dropcol/db.dropcol.py
grass/trunk/scripts/v.db.dropcol/v.db.dropcol.py
grass/trunk/scripts/v.db.join/v.db.join.py
Convert v.db.renamecol to Python
Fix bugs in parsing "db.describe -c" output
Modified: grass/trunk/scripts/db.dropcol/db.dropcol.py
--- grass/trunk/scripts/db.dropcol/db.dropcol.py 2008-09-29 14:21:41 UTC (rev 33593)
+++ grass/trunk/scripts/db.dropcol/db.dropcol.py 2008-09-29 15:33:08 UTC (rev 33594)
@@ -84,12 +84,13 @@
#echo "Using special trick for SQLite"
# http://www.sqlite.org/faq.html#q13
colnames = []
- coldef = []
+ coltypes = []
s = grass.read_command('db.describe', flags = 'c', table = table)
for l in s.splitlines():
if not l.startswith('Column '):
continue
f = l.split(':')
+ f[1] = f[1].lstrip()
if f[1] == column:
continue
colnames.append(f[1])
Modified: grass/trunk/scripts/v.db.dropcol/v.db.dropcol.py
--- grass/trunk/scripts/v.db.dropcol/v.db.dropcol.py 2008-09-29 14:21:41 UTC (rev 33593)
+++ grass/trunk/scripts/v.db.dropcol/v.db.dropcol.py 2008-09-29 15:33:08 UTC (rev 33594)
@@ -86,12 +86,13 @@
colnames = []
- coldef = []
+ coltypes = []
continue
f = l.split(':')
if f[1] == column:
continue
Modified: grass/trunk/scripts/v.db.join/v.db.join.py
--- grass/trunk/scripts/v.db.join/v.db.join.py 2008-09-29 14:21:41 UTC (rev 33593)
+++ grass/trunk/scripts/v.db.join/v.db.join.py 2008-09-29 15:33:08 UTC (rev 33594)
@@ -98,12 +98,13 @@
template = string.Template("UPDATE $table SET $colname=(%s);" % select)
for col in cols:
- colname = col[0]
- if len(col) > 2:
- coltype = "%s(%s)" % col[1:3]
+ colname = col[1].lstrip()
+ if len(col) > 3:
+ coltype = "%s(%s)" % (col[2], col[3])
else:
- coltype = "%s" % col[1]
+ coltype = "%s" % col[2]
colspec = "%s %s" % (colname, coltype)
if grass.run_command('v.db.addcol', map = map, col = colspec) != 0:
grass.fatal("Error creating column <%s>." % colname)
@@ -111,15 +112,11 @@
otable = otable, ocolumn = ocolumn,
colname = colname)
- p = grass.feed_command('db.execute')
- p.stdin.write(stmt)
- p.stdin.close()
- p.wait()
- if p.returncode != 0:
+ if grass.write_command('db.execute', stdin = stmt) != 0:
grass.fatal("Error filling column <%s>." % colname)
# write cmd history:
- grass.run_command('v.support', map = map, cmdhist = cmdline)
+ grass.run_command('v.support', map = map, cmdhist = os.environ['CMDLINE'])
if __name__ == "__main__":
options, flags = grass.parser()
Property changes on: grass/trunk/scripts/v.db.join/v.db.join.py
___________________________________________________________________
Added: grass/trunk/scripts/v.db.renamecol/v.db.renamecol.py
--- grass/trunk/scripts/v.db.renamecol/v.db.renamecol.py (rev 0)
+++ grass/trunk/scripts/v.db.renamecol/v.db.renamecol.py 2008-09-29 15:33:08 UTC (rev 33594)
@@ -0,0 +1,126 @@
+#!/usr/bin/env python
+# MODULE: v.db.renamecol
+# AUTHOR(S): Markus Neteler
+# Converted to Python by Glynn Clements
+# PURPOSE: interface to db.execute to drop a column from the
+# attribute table connected to a given vector map
+# - Based on v.db.dropcol
+# - with special trick for SQLite and DBF (here the new col is
+# added/values copied/old col deleted)
+# COPYRIGHT: (C) 2007 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+# TODO: MySQL untested
+#%Module
+#% description: Renames a column in the attribute table connected to a given vector map.
+#% keywords: vector, database, attribute table
+#%End
+#%option
+#% key: map
+#% type: string
+#% gisprompt: old,vector,vector
+#% key_desc : name
+#% description: Vector map for which to rename attribute column
+#% required : yes
+#%end
+#%option
+#% key: layer
+#% type: integer
+#% description: Layer where to rename column
+#% answer: 1
+#% required : no
+#%end
+#%option
+#% key: column
+#% type: string
+#% description: Old and new name of the column (old,new)
+#% required : yes
+#% multiple: yes
+#% key_desc: oldcol,newcol
+#%end
+import sys
+import os
+import grass
+def error():
+def main():
+ map = options['map']
+ layer = options['layer']
+ column = options['column']
+ mapset = grass.gisenv()['MAPSET']
+ if not grass.find_file(map, element = 'vector', mapset = mapset):
+ grass.fatal("Vector map <%s> not found in current mapset" % map)
+ s = grass.read_command('v.db.connect', flags = 'g', map = map, layer = layer);
+ if not s:
+ grass.fatal("An error occured while running v.db.connect")
+ f = s.split()
+ table = f[1]
+ keycol = f[2]
+ database = f[3]
+ driver = f[4]
+ if not table:
+ grass.fatal("There is no table connected to the input vector map. Cannot rename any column")
+ cols = column.split(',')
+ oldcol = cols[0]
+ newcol = cols[1]
+ if $driver == "dbf":
+ if len(newcol) > 10:
+ grass.fatal("Column name <%s> too long. The DBF driver supports column names not longer than 10 characters" % newcol)
+ if oldcol == keycol:
+ grass.fatal("Cannot rename column <%s> as it is needed to keep table <%s> connected to the input vector map" % (oldcol, table))
+ # describe old col
+ oldcoltype = None
+ s = grass.read_command('db.describe', flags = 'c', table = table)
+ for l in s.splitlines():
+ if not l.startswith('Column '):
+ continue
+ f = l.split(':')
+ if f[1].lstrip() != oldcol:
+ continue
+ oldcoltype = f[2]
+ oldcollength = f[3]
+ # old col there?
+ if not oldcol:
+ grass.fatal("Column <%s> not found in table <%s>" % (coldcol, table))
+ # some tricks
+ if driver in ['sqlite', 'dbf']:
+ if oldcoltype.upper() == "CHARACTER":
+ colspec = "%s varchar(%s)" % (newcol, oldcollength)
+ else:
+ colspec = "%s %s" % (newcol, oldcoltype)
+ grass.run_command('v.db.addcol', map = map, layer = layer, column = colspec)
+ sql = "UPDATE %s SET %s=%s" % (table, newcol, oldcol)
+ grass.write_command('db.execute', database = database, driver = driver, stdin = sql)
+ grass.run_command('v.db.dropcol', map = map, layer = layer, column = oldcol)
+ else:
+ sql = "ALTER TABLE %s RENAME %s TO %s" % (table, oldcol, newcol)
+ # write cmd history:
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Property changes on: grass/trunk/scripts/v.db.renamecol/v.db.renamecol.py
