[GRASS-SVN] r33596 - grass/trunk/scripts/v.db.univar
svn_grass at osgeo.org
Mon Sep 29 12:25:56 EDT 2008
Author: glynn
Date: 2008-09-29 12:25:56 -0400 (Mon, 29 Sep 2008)
New Revision: 33596
Added:
grass/trunk/scripts/v.db.univar/v.db.univar.py
Convert v.db.univar to Python
(aside: why v.db.univar rather than db.univar?)
Added: grass/trunk/scripts/v.db.univar/v.db.univar.py
--- grass/trunk/scripts/v.db.univar/v.db.univar.py (rev 0)
+++ grass/trunk/scripts/v.db.univar/v.db.univar.py 2008-09-29 16:25:56 UTC (rev 33596)
@@ -0,0 +1,201 @@
+#!/usr/bin/env python
+# MODULE: v.db.univar (formerly called v.univar.sh)
+# AUTHOR(S): Michael Barton, Arizona State University
+# Converted to Python by Glynn Clements
+# PURPOSE: Calculates univariate statistics from a GRASS vector map attribute column.
+# Based on r.univar.sh by Markus Neteler
+# COPYRIGHT: (C) 2005, 2007, 2008 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%Module
+#% description: Calculates univariate statistics on selected table column for a GRASS vector map.
+#% keywords: vector, statistics
+#%End
+#%flag
+#% key: e
+#% description: Extended statistics (quartiles and 90th percentile)
+#%END
+#%option
+#% key: table
+#% type: string
+#% gisprompt: old,vector,vector
+#% description: Name of data table
+#% required : yes
+#%End
+#%option
+#% key: column
+#% type: string
+#% description: Column on which to calculate statistics (must be numeric)
+#% required : yes
+#%end
+#%option
+#% key: database
+#% type: string
+#% description: Database/directory for table
+#% required : no
+#%end
+#%option
+#% key: driver
+#% type: string
+#% description: Database driver
+#% required : no
+#%end
+#%option
+#% key: where
+#% type: string
+#% description: WHERE conditions of SQL statement without 'where' keyword
+#% required : no
+#%end
+import sys
+import os
+import atexit
+import math
+import grass
+def cleanup():
+ for ext in ['', '.sort']:
+ grass.try_remove(tmp + ext)
+def sortfile(infile, outfile):
+ inf = file(infile, 'r')
+ outf = file(outfile, 'w')
+ if grass.find_program('sort', ['-n']):
+ grass.run_command('sort', flags = 'n', stdin = inf, stdout = outf)
+ else:
+ # FIXME: we need a large-file sorting function
+ grass.warning("'sort' not found: sorting in memory")
+ lines = inf.readlines()
+ for i in range(len(lines)):
+ lines[i] = float(lines[i].rstrip('\r\n'))
+ lines.sort()
+ for line in lines:
+ outf.write(str(line) + '\n')
+ inf.close()
+ outf.close()
+def main():
+ global tmp
+ tmp = grass.tempfile()
+ extend = flags['e']
+ table = options['table']
+ column = options['column']
+ database = options['database']
+ driver = options['driver']
+ where = options['where']
+ grass.message("Calculation for column <%s> of table <%s>..." % (column, table))
+ grass.message("Reading column values...")
+ sql = "SELECT %s FROM %s" % (column, table)
+ if where:
+ sql += " WHERE " + where
+ if not database:
+ database = None
+ if not driver:
+ driver = None
+ tmpf = file(tmp, 'w')
+ grass.run_command('db.select', flags = 'c', table = table,
+ database = database, driver = driver, sql = sql,
+ stdout = tmpf)
+ tmpf.close()
+ # check if result is empty
+ tmpf = file(tmp)
+ if tmpf.read(1) == '':
+ grass.fatal("Table <%s> contains no data.", table)
+ tmpf.close()
+ # calculate statistics
+ grass.message("Calculating statistics...")
+ N = 0
+ sum = 0.0
+ sum2 = 0.0
+ sum3 = 0.0
+ minv = 1e300
+ maxv = -1e300
+ tmpf = file(tmp)
+ for line in tmpf:
+ x = float(line.rstrip('\r\n'))
+ N += 1
+ sum += x
+ sum2 += x * x
+ sum3 += abs(x)
+ maxv = max(maxv, x)
+ minv = min(minv, x)
+ tmpf.close()
+ if N <= 0:
+ grass.fatal("No non-null values found")
+ print ""
+ print "Number of values:", N
+ print "Minimum:", minv
+ print "Maximum:", maxv
+ print "Range:", maxv - minv
+ print "-----"
+ print "Mean:", sum/N
+ print "Arithmetic mean of absolute values:", sum3/N
+ print "Variance:", (sum2 - sum*sum/N)/N
+ print "Standard deviation:", math.sqrt((sum2 - sum*sum/N)/N)
+ print "Coefficient of variation:", (math.sqrt((sum2 - sum*sum/N)/N))/(math.sqrt(sum*sum)/N)
+ print "-----"
+ if not extend:
+ return
+ #preparations:
+ sortfile(tmp, tmp + ".sort")
+ number = N
+ odd = N % 2
+ eostr = ['even','odd'][odd]
+ q25pos = round(N * 0.25)
+ q50apos = round(N * 0.50)
+ q50bpos = q50apos + (1 - odd)
+ q75pos = round(N * 0.75)
+ q90pos = round(N * 0.90)
+ inf = file(tmp + ".sort")
+ l = 1
+ for line in inf:
+ if l == q25pos:
+ q25 = float(line.rstrip('\r\n'))
+ if l == q50apos:
+ q50a = float(line.rstrip('\r\n'))
+ if l == q50bpos:
+ q50b = float(line.rstrip('\r\n'))
+ if l == q75pos:
+ q75 = float(line.rstrip('\r\n'))
+ if l == q90pos:
+ q90 = float(line.rstrip('\r\n'))
+ l += 1
+ q50 = (q50a + q50b) / 2
+ print "1st Quartile: %f" % q25
+ print "Median (%s N): %f" % (eostr, q50)
+ print "3rd Quartile: %f" % q75
+ print "90th Percentile: %f" % q90
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ atexit.register(cleanup)
+ main()
Property changes on: grass/trunk/scripts/v.db.univar/v.db.univar.py
___________________________________________________________________
