[GRASS-SVN] r33620 - grass/trunk/scripts/m.proj
svn_grass at osgeo.org
Tue Sep 30 12:28:49 EDT 2008
Author: glynn
Date: 2008-09-30 12:28:49 -0400 (Tue, 30 Sep 2008)
New Revision: 33620
Added:
grass/trunk/scripts/m.proj/m.proj.py
Convert m.proj to Python
Added: grass/trunk/scripts/m.proj/m.proj.py
--- grass/trunk/scripts/m.proj/m.proj.py (rev 0)
+++ grass/trunk/scripts/m.proj/m.proj.py 2008-09-30 16:28:49 UTC (rev 33620)
@@ -0,0 +1,202 @@
+#!/usr/bin/env python
+# MODULE: m.proj
+# AUTHOR: M. Hamish Bowman, Dept. Marine Science, Otago Univeristy,
+# New Zealand
+# Converted to Python by Glynn Clements
+# PURPOSE: cs2cs reprojection frontend for a list of coordinates.
+# Replacement for m.proj2 from GRASS 5
+# COPYRIGHT: (c) 2006,2008 Hamish Bowman, and the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+# notes:
+# - cs2cs expects "x y" data so be sure to send it "lon lat" not "lat lon"
+# - if you send cs2cs a third data column, beware it might be treated as "z"
+#%Module
+#% description: Convert coordinates from one projection to another (cs2cs frontend).
+#% keywords: miscellaneous, projection
+#%End
+#%option
+#% key: input
+#% type: string
+#% gisprompt: old_file,file,file
+#% description: Input coordinate file (omit to read from stdin)
+#% required : no
+#% key_desc : filename
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new_file,file,file
+#% description: Output coordinate file (omit to send to stdout)
+#% required : no
+#%end
+#%option
+#% key: fs
+#% type: string
+#% description: Field separator
+#% required : no
+#% key_desc : character
+#% answer : |
+#%end
+#%option
+#% key: proj_in
+#% type: string
+#% description: Input projection parameters (PROJ.4 style)
+#% required : no
+#%end
+#%option
+#% key: proj_out
+#% type: string
+#% description: Output projection parameters (PROJ.4 style)
+#% required : no
+#%end
+#%flag
+#% key: i
+#% description: Use LL WGS84 as input and current location as output projection
+#%end
+#%flag
+#% key: o
+#% description: Use current location as input and LL WGS84 as output projection
+#%end
+#%flag
+#% key: d
+#% description: Output long/lat in decimal degrees or other projections with many decimal places
+#%end
+import sys
+import os
+import subprocess
+import grass
+def main():
+ input = options['input']
+ output = options['output']
+ fs = options['fs']
+ proj_in = options['proj_in']
+ proj_out = options['proj_out']
+ ll_in = flags['i']
+ ll_out = flags['o']
+ decimal = flags['d']
+ #### check for cs2cs
+ if not grass.find_program('cs2cs'):
+ grass.fatal("cs2cs program not found, install PROJ.4 first: http://proj.maptools.org")
+ #### check for overenthusiasm
+ if proj_in and ll_in:
+ grass.fatal("Chose only one input parameter method")
+ if proj_out and ll_out:
+ grass.fatal("Chose only one output parameter method")
+ if ll_in and ll_out:
+ grass.fatal("Chose only one auto-projection parameter method")
+ if output and not grass.overwrite() and os.path.exists(output):
+ grass.fatal("Output file already exists")
+ #### parse field separator
+ if fs.lower() in ["space", "tab"]:
+ fs = ' '
+ else:
+ fs = fs[0]
+ #### set up projection params
+ s = grass.read_command("g.proj", flags='j')
+ kv = grass.parse_key_val(s)
+ if "XY location" in kv['+proj'] and (ll_in or ll_out):
+ grass.fatal("Cannot project to or from a XY location.")
+ in_proj = None
+ if ll_in:
+ in_proj = "+proj=longlat +datum=WGS84"
+ grass.verbose("Assuming LL WGS84 as input, current projection as output.")
+ if ll_out:
+ in_proj = grass.read_command('g.proj', flags = 'jf')
+ if proj_in:
+ in_proj = proj_in
+ if not in_proj:
+ grass.fatal("Missing input projection parameters.")
+ in_proj = in_proj.strip()
+ out_proj = None
+ if ll_out:
+ out_proj = "+proj=longlat +datum=WGS84"
+ grass.verbose("Assuming current projection as input, LL WGS84 as output.")
+ if ll_in:
+ out_proj = grass.read_command('g.proj', flags = 'jf')
+ if proj_out:
+ out_proj = proj_out
+ if not out_proj:
+ grass.fatal("Missing output projection parameters.")
+ out_proj = out_proj.strip()
+ grass.verbose("output parameters=[%s]" % out_proj)
+ #### set up input file
+ if input in ['', '-']:
+ infile = None
+ inf = sys.stdin
+ else:
+ infile = input
+ if not os.path.exists(infile):
+ grass.fatal("Unable to read input data.")
+ inf = file(infile)
+ grass.verbose("input file=[%s]" % infile)
+ #### set up output file
+ if not output:
+ outfile = None
+ outf = sys.stdout
+ else:
+ outfile = output
+ outf = file(outfile)
+ grass.message("output file=[%s]" % outfile)
+ #### set up output style
+ if not decimal:
+ outfmt = []
+ else:
+ outfmt = ["-f", "%.8f"]
+ #### do the conversion
+ # Convert cs2cs DMS format to GRASS DMS format:
+ # cs2cs | sed -e 's/d/:/g' -e "s/'/:/g" -e 's/"//g'
+ cmd = ['cs2cs'] + outfmt + in_proj.split() + ['+to'] + out_proj.split()
+ p = subprocess.Popen(cmd, stdin = subprocess.PIPE, stdout = outf)
+ while True:
+ line = inf.readline()
+ if not line:
+ break
+ line = line.replace(fs, ' ')
+ p.stdin.write(line)
+ p.stdin.flush()
+ p.stdin.close()
+ exitcode = p.wait()
+ if exitcode != 0:
+ grass.warning("Projection transform probably failed, please investigate.")
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Property changes on: grass/trunk/scripts/m.proj/m.proj.py
___________________________________________________________________
