[GRASS-SVN] r33621 - grass/trunk/scripts/r.shaded.relief
Tue Sep 30 12:58:06 EDT 2008
Author: glynn
Date: 2008-09-30 12:58:06 -0400 (Tue, 30 Sep 2008)
New Revision: 33621
Added:
   grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py
Convert r.shaded.relief to Python
Added: grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py
--- grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py	                        (rev 0)
+++ grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py	2008-09-30 16:58:06 UTC (rev 33621)
@@ -0,0 +1,195 @@
+#!/usr/bin/env python
+# MODULE:       r.shaded.relief
+# AUTHOR(S):	CERL
+#               parameters standardized: Markus Neteler, 2008
+#               updates: Michael Barton, 2004
+#               updates: Gordon Keith, 2003
+#               updates: Andreas Lange, 2001
+#               updates: David Finlayson, 2001
+#               updates: Markus Neteler, 2001, 1999
+#               Converted to Python by Glynn Clements
+# PURPOSE:	Creates shaded relief map from raster elevation map (DEM)
+# COPYRIGHT:	(C) 1999 - 2008 by the GRASS Development Team
+#		This program is free software under the GNU General Public
+#		License (>=v2). Read the file COPYING that comes with GRASS
+#		for details.
+#   July 2007 - allow input from other mapsets (Brad Douglas)
+#   May 2005 - fixed wrong units parameter (Markus Neteler)
+#   September 2004 - Added z exaggeration control (Michael Barton)
+#   April 2004 - updated for GRASS 5.7 by Michael Barton
+#   9/2004 Adds scale factor input (as per documentation); units set scale only if specified for lat/long regions
+#    Also, adds option of controlling z-exaggeration.
+#   6/2003 fixes for Lat/Long Gordon Keith <gordon.keith at csiro.au>
+#   If n is a number then the ewres and nsres are mulitplied by that scale
+#    to calculate the shading.
+#   If n is the letter M (either case) the number of metres is degree of
+#    latitude is used as the scale.
+#   If n is the letter f then the number of feet in a degree is used.
+#   It scales latitude and longitude equally, so it's only approximately
+#   right, but for shading its close enough. It makes the difference
+#   between an unusable and usable shade.
+#   10/2001 fix for testing for dashes in raster file name
+#        by Andreas Lange <andreas.lange at rhein-main.de>
+#   10/2001 added parser support - Markus Neteler
+#   9/2001 fix to keep NULLs as is (was value 22 before) - Markus Neteler
+#   1/2001 fix for NULL by David Finlayson <david_finlayson at yahoo.com>
+#   11/99 updated $ewres to ewres() and $nsres to nsres()
+#       updated number to FP in r.mapcalc statement Markus Neteler
+#% Module
+#%  description: Creates shaded relief map from an elevation map (DEM).
+#%  keywords: raster, elevation
+#% End
+#% option
+#%  key: input
+#%  type: string
+#%  gisprompt: old,cell,raster
+#%  description: Input elevation map
+#%  required : yes
+#% end
+#% option
+#%  key: output
+#%  type: string
+#%  gisprompt: new,cell,raster
+#%  description: Output shaded relief map name
+#%  required : no
+#% end
+#% option
+#%  key: altitude
+#%  type: integer
+#%  description: Altitude of the sun in degrees above the horizon
+#%  required : no
+#%  options : 0-90
+#%  answer: 30
+#% end
+#% option
+#%  key: azimuth
+#%  type: integer
+#%  description: Azimuth of the sun in degrees to the east of north
+#%  required : no
+#%  options : 0-360
+#%  answer: 270
+#% end
+#% option
+#%  key: zmult
+#%  type: double
+#%  description: Factor for exaggerating relief
+#%  required : no
+#%  answer: 1
+#% end
+#% option
+#%  key: scale
+#%  type: double
+#%  description: Scale factor for converting horizontal units to elevation units
+#%  required : no
+#%  answer: 1
+#% end
+#% option
+#%  key: units
+#%  type: string
+#%  description: Set scaling factor (applies to lat./long. locations only, none: scale=1)
+#%  required : no
+#%  options: none,meters,feet
+#%  answer: none
+#% end
+import sys
+import os
+import string
+import grass
+def main():
+    input = options['input']
+    output = options['output']
+    altitude = options['altitude']
+    azimuth = options['azimuth']
+    zmult = options['zmult']
+    scale = options['scale']
+    if not grass.findfile(elev)['file']:
+	grass.fatal("Map <%s> not found." % elev)
+    if input == output:
+	grass.fatal("Input elevation map and output relief map must have different names")
+    elev = input
+    if not output:
+	elevshade = elev.split('@')[0] + '.shade'
+    else:
+	elevshade = output
+    elev_out = "'%s'" % elevshade
+    alt = altitude
+    scale = float(scale)
+    # LatLong locations only:
+    if units == 'meters':
+        #scale=111120
+	scale *= 1852 * 60
+    if units == 'feet':
+        #scale=364567.2
+	scale *= 6076.12 * 60
+    #correct azimuth to East (GRASS convention):
+    az = azimuth - 90
+    grass.message("Calculating shading, please stand by.")
+    t = string.Template(r'$elev_out = eval(
+x=($zmult*$elev[-1,-1] + 2*$zmult*$elev[0,-1] + $zmult*$elev[1,-1] - \
+ $zmult*$elev[-1,1] - 2*$zmult*$elev[0,1] - $zmult*$elev[1,1])/(8.*ewres()*$scale),
+y=($zmult*$elev[-1,-1] + 2*$zmult*$elev[-1,0] + $zmult*$elev[-1,1] - \
+ $zmult*$elev[1,-1] - 2*$zmult*$elev[1,0] - $zmult*$elev[1,1])/(8.*nsres()*$scale),
+slope=90.-atan(sqrt(x*x + y*y)),
+a=round(atan(x,y)),
+a=if(isnull(a),1,a),
+aspect=if(x!=0||y!=0,if(a,a,360.)),
+cang = sin($alt)*sin(slope) + cos($alt)*cos(slope) * cos($az-aspect),
+if(cang < 0.,0.,100.*cang),
+if(isnull(cang), null(), 100.*cang))')
+    expr = t.substitute(alt = alt, az = az, elev = elev, elev_out = elev_out, scale = scale, zmult = zmult)
+    p = grass.feed_command('r.mapcalc')
+    p.stdin.write(expr)
+    p.stdin.close()
+    if p.wait() != 0:
+	grass.fatal("In calculation, script aborted.")
+    grass.run_command('r.colors', map = elevshade, color = 'grey')
+    # record metadata
+    grass.run_command('r.support', map = elevshade, title = 'Shaded relief of "%s"' % input, history = '')
+    grass.run_command('r.support', map = elevshade, history = "r.shaded.relief settings:")
+    t = string.Template("altitude=$alt  azimuth=$azimuth zmult=$zmult  scale=$scale")
+    parms = dict(alt = alt, azimuth = azimuth, zmult = zmult, scale = options['scale'])
+    grass.run_command('r.support', map = elevshade, history = t.substitute(parms))
+    if units:
+	grass.run_command('r.support', map = elevshade, history = "  units=%s (adjusted scale=%s)" % (units, scale))
+    if output:
+	grass.message("Shaded relief map created and named <%s>." % elevshade)
+    else:
+	grass.message("Shaded relief map created and named <%s>. Consider renaming." % elevshade)
+    # write cmd history:
+    raster_history(elevshade)
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    main()
Property changes on: grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py
___________________________________________________________________
