[GRASS-SVN] r36654 - grass-addons/raster/r.terracost
svn_grass at osgeo.org
Thu Apr 9 04:54:48 EDT 2009
Author: neteler
Date: 2009-04-09 04:54:48 -0400 (Thu, 09 Apr 2009)
New Revision: 36654
Removed:
grass-addons/raster/r.terracost/.DS_Store
grass-addons/raster/r.terracost/main.cc
sigh - restored my fixes
Deleted: grass-addons/raster/r.terracost/.DS_Store
(Binary files differ)
Modified: grass-addons/raster/r.terracost/main.cc
--- grass-addons/raster/r.terracost/main.cc 2009-04-09 08:42:42 UTC (rev 36653)
+++ grass-addons/raster/r.terracost/main.cc 2009-04-09 08:54:48 UTC (rev 36654)
@@ -23,11 +23,11 @@
#include <pwd.h>
extern "C" {
-#include "grass/gis.h"
+#include <grass/gis.h>
+#include <grass/glocale.h>
-#include <ami.h>
+#include <grass/iostream/ami.h>
#include "main.h"
#include "common.h" /* declares the globals */
#include "sortutils.h"
@@ -75,7 +75,7 @@
#define STATS_ANS "terracost.stats"
#define DIST_GRID "terracost-lcp.asc"
+/* TODO this description is WAY to long...: move most content into manual */
const char *description =
"\nSynopsis:\n"
" r.terracost computes a least-cost surface for a given cost grid and\n"
@@ -120,7 +120,7 @@
input_cost->type = TYPE_STRING;
//input_cost->required = YES;
input_cost->gisprompt = "old,cell,raster" ;
- input_cost->description= "Input cost grid" ;
+ input_cost->description= _("Input cost grid");
/* source point raster */
struct Option *source_grid;
@@ -128,8 +128,8 @@
source_grid->key = "start_raster";
source_grid->type = TYPE_STRING;
//source_grid->required = YES;
- source_grid->gisprompt = "raster of source points" ;
- source_grid->description= "Input raster of source points";
+ source_grid->gisprompt = "Raster of source points" ;
+ source_grid->description= _("Input raster of source points");
/* output direction grid */
struct Option *output_cost;
@@ -138,7 +138,7 @@
output_cost->type = TYPE_STRING;
//output_cost->required = YES;
output_cost->gisprompt = "new,cell,raster" ;
- output_cost->description= "Output distance grid";
+ output_cost->description= _("Output distance grid");
/* main memory */
struct Option *mem;
@@ -147,7 +147,7 @@
mem->type = TYPE_INTEGER;
mem->required = NO;
mem->answer = "400"; /* 400MB default value */
- mem->description = "Main memory size (in MB)";
+ mem->description = _("Main memory size (in MB)");
/* temporary STREAM path */
struct Option *streamdir;
@@ -156,9 +156,9 @@
streamdir->type = TYPE_STRING;
streamdir->required = NO;
streamdir->answer = "/var/tmp";
- streamdir->description= "Location of temporary STREAMs";
+ streamdir->description= _("Location of temporary STREAMs");
- /* temporary STREAM path */
+ /* temporary VTMPDIR path */
struct Option *vtmpdir;
vtmpdir = G_define_option() ;
vtmpdir->key = VTMPDIR;
@@ -172,18 +172,18 @@
sprintf(vtmpdirbuf, "/var/tmp/%d", getuid());
vtmpdir->answer = strdup(vtmpdirbuf); // leak
- vtmpdir->description= "Location of intermediate STREAMs";
+ vtmpdir->description= _("Location of intermediate STREAMs");
struct Flag *help_f;
help_f = G_define_flag();
help_f->key = 'h' ;
- help_f->description = "Help";
+ help_f->description = _("Help");
/* verbose flag */
struct Flag *quiet;
quiet = G_define_flag() ;
quiet->key = 'q' ;
- quiet->description = "Quiet (suppress messages)" ;
+ quiet->description = _("Quiet") ;
/* quiet->answer = 'n'; */
@@ -191,68 +191,48 @@
struct Flag *ascii;
ascii = G_define_flag() ;
ascii->key = 's' ;
- ascii->description = "Save output to ascii file "DIST_GRID"" ;
+ ascii->description = _("Save output to ASCII file \"DIST_GRID\"");
struct Flag *debug_f;
debug_f = G_define_flag();
debug_f->key = 'd' ;
- debug_f->description = "Debug (for developer use)";
+ debug_f->description = _("Debug (for developer use)");
struct Flag *info_f;
info_f = G_define_flag();
info_f->key = 'i' ;
- info_f->description = "Info (prints useful information and exits)";
+ info_f->description = _("Info (prints useful information and exits)");
/* Run step0 only flag */
struct Flag *step0;
step0 = G_define_flag();
step0->key = '0' ;
-<<<<<<< .mine
- step0->description = _("Step 0 only (default: run all)");
- step0->description = "Step 0 only (-h for info)";
->>>>>>> .r36646
+ step0->description = _("Step 0 only (-h for info)");
/* step0->answer = 'n'; */
/* Run step 1 only flag*/
struct Flag *step1;
step1 = G_define_flag() ;
step1->key = '1' ;
-<<<<<<< .mine
- step1->description = _("Step 1 only (default: run all)");
- step1->description = "Step 1 only (-h for info)" ;
->>>>>>> .r36646
+ step1->description = _("Step 1 only (-h for info)");
/* step1->answer = 'n'; */
/* Run step 2 and 3 only flags */
struct Flag *step2;
step2 = G_define_flag();
step2->key = '2' ;
-<<<<<<< .mine
- step2->description = _("Step 2 only (default: run all)");
- step2->description = "Step 2 only (-h for info)";
->>>>>>> .r36646
+ step2->description = _("Step 2 only (-h for info)");
struct Flag *step3;
step3 = G_define_flag();
step3->key = '3' ;
-<<<<<<< .mine
- step3->description = _("Step 3 only (default: run all)");
- step3->description = "Step 3 only (-h for info)";
->>>>>>> .r36646
+ step3->description = _("Step 3 only (-h for info)");
struct Flag *step4;
step4 = G_define_flag();
step4->key = '4' ;
-<<<<<<< .mine
- step4->description = _("Step 4 only (default: run all)");
- step4->description = "Step 4 only (-h for info)";
->>>>>>> .r36646
+ step4->description = _("Step 4 only (-h for info)");
/* Number of tiles; used in conjunction with step0 flag */
struct Option *numtiles;
@@ -260,7 +240,7 @@
numtiles->key = "numtiles";
numtiles->type = TYPE_INTEGER;
numtiles->required = NO;
- numtiles->description= "Number of tiles (-h for info)";
+ numtiles->description= _("Number of tiles (-h for info)");
numtiles->answer = "-1";
/* Stem name for stream outputs; used in conjunction with step0 flag */
@@ -269,7 +249,7 @@
s0out->key = S0OUT;
s0out->type = TYPE_STRING;
s0out->required = NO;
- s0out->description= "Stream name stem for step 0 output";
+ s0out->description= _("Stream name stem for step 0 output");
s0out->answer = S0OUT_ANS;
// struct Option *s1in;
@@ -277,7 +257,7 @@
// s1in->key = "s1in";
// s1in->type = TYPE_STRING;
// s1in->required = NO;
-// s1in->description= "Stream name stem for step 0 output";
+// s1in->description= _("Stream name stem for step 0 output");
// s1in->answer = "s1in";
struct Option *s0bnd;
@@ -285,7 +265,7 @@
s0bnd->key = S0BND;
s0bnd->type = TYPE_STRING;
s0bnd->required = NO;
- s0bnd->description= "Stream name for boundary data structure";
+ s0bnd->description= _("Stream name for boundary data structure");
s0bnd->answer = S0BND_ANS;
/* Name for config file output */
@@ -294,7 +274,7 @@
s1out->key = S1OUT;
s1out->type = TYPE_STRING;
s1out->required = NO;
- s1out->description= "Output file for step 1";
+ s1out->description= _("Output file for step 1");
s1out->answer = S1OUT_ANS;
@@ -303,7 +283,7 @@
s2bout->key = S2BOUT;
s2bout->type = TYPE_STRING;
s2bout->required = NO;
- s2bout->description= "Output file for source to boundary stream";
+ s2bout->description= _("Output file for source to boundary stream");
s2bout->answer = S2BOUT_ANS;
@@ -312,7 +292,7 @@
config->key = CONFIG;
config->type = TYPE_STRING;
config->required = NO;
- config->description= "Name for config file";
+ config->description= _("Name for config file");
config->answer = CONFIG_ANS;
@@ -321,7 +301,7 @@
phaseBnd->key = PHASE2BND;
phaseBnd->type = TYPE_STRING;
phaseBnd->required = NO;
- phaseBnd->description= "Name for phase2Bnd file";
+ phaseBnd->description= _("Name for phase2Bnd file");
phaseBnd->answer = PHASE2BND_ANS;
@@ -331,7 +311,7 @@
stats_opt->key = "stats";
stats_opt->type = TYPE_STRING;
stats_opt->required = NO;
- stats_opt->description= "Stats file";
+ stats_opt->description= _("Stats file");
stats_opt->answer = STATS_ANS;
struct Option *tilesAreSorted;
@@ -339,13 +319,13 @@
tilesAreSorted->key = "tilesAreSorted" ;
tilesAreSorted->type = TYPE_STRING;
tilesAreSorted->required = NO;
- tilesAreSorted->description = "Tiles are sorted (used in grid version) (y/n)";
+ tilesAreSorted->description = _("Tiles are sorted (used in grid version) (y/n)");
tilesAreSorted->answer = "no";
if (G_parser(argc, argv)) {
- exit (-1);
+ exit (EXIT_FAILURE);
assert(opt);
@@ -395,7 +375,7 @@
if(help_f->answer) {
G_usage();
printf(description);
- exit(0);
+ exit(EXIT_SUCCESS);
