[GRASS-SVN] r36655 - grass-addons/raster/r.terracost
svn_grass at osgeo.org
Thu Apr 9 05:18:50 EDT 2009
Author: neteler
Date: 2009-04-09 05:18:50 -0400 (Thu, 09 Apr 2009)
New Revision: 36655
grass-addons/raster/r.terracost/description.html
grass-addons/raster/r.terracost/main.cc
description moved to manual page
Modified: grass-addons/raster/r.terracost/description.html
--- grass-addons/raster/r.terracost/description.html 2009-04-09 08:54:48 UTC (rev 36654)
+++ grass-addons/raster/r.terracost/description.html 2009-04-09 09:18:50 UTC (rev 36655)
@@ -1,9 +1,43 @@
<h2>DESCRIPTION</h2>
-<em>r.terracost</em> is a scalable approach for computing least-cost-path surfaces
-on massive grid terrains. The module outperforms standard solutions as
-dataset size increases relative to available memory.
+<em>r.terracost</em> is a scalable approach for computing least-cost-path
+surfaces on massive grid terrains. The module outperforms standard solutions
+as dataset size increases relative to available memory.
+<h2>NOTES</h2>
+<em>r.terracost</em> computes a least-cost surface for a given cost grid and
+set of start points using an approach that scales to large grids. For details,
+see paper <i>"TerraCost: A Versatile and Scalable Approach for Path
+Computations on Massive Grid-Based Terrains"</i> by Hazel, Toma, Vahrenhold
+and Wickremesinghe (2006). The basic idea is to split the grid in tiles.
+<em>numtiles</em> is the number of tiles. Run with <em>-i</em> to see the recommended
+value for <em>numtiles</em>. When <em>numtiles=1</em> it runs Dijkstra's algorithm in
+memory. When <em>numtiles > 1</em> it runs an external SP algorithm that consists
+of 5 steps. For debugging purposes, it is possible to run the five steps separately.
+When running in separate steps, an intermediate config file stores temporary information,
+and other streams (see below) contain intermediate data.
+<ul>
+<li> Step 0 (setup) inputs from GRASS; outputs are "S0OUT" and "S0BND"
+<li> Step 1 (compute substitute graph: intra-tile Dijkstra) inputs are "S0OUT"
+ and "S0BND"; outputs are "S1OUT" and "S2BOUT"
+<li> Step 2 (sorting) input is "S1OUT"; output is "S1OUT"
+<li> Step 3 (inter-tile) inputs are "S0OUT", "S0BND", "S1OUT", and "S2BOUT";
+ output is "PHASE2BND"
+<!-- next unclear - explain better! -->
+<li> Step 4 (final-tile) inputs are "S0OUT" and "PHASE2BND"; output goes to
+ GRASS maps: Map names are specified relative to "VTMPDIR", or with absolute path
+ (name beginning with /).
+</ul>
+IOLibrary temporary streams will be in STREAM_DIR.
<h2>REFERENCES</h2>
<ul>
Modified: grass-addons/raster/r.terracost/main.cc
--- grass-addons/raster/r.terracost/main.cc 2009-04-09 08:54:48 UTC (rev 36654)
+++ grass-addons/raster/r.terracost/main.cc 2009-04-09 09:18:50 UTC (rev 36655)
@@ -75,38 +75,9 @@
#define STATS_ANS "terracost.stats"
#define DIST_GRID "terracost-lcp.asc"
-/* TODO this description is WAY to long...: move most content into manual */
-const char *description =
-"\nSynopsis:\n"
-" r.terracost computes a least-cost surface for a given cost grid and\n"
-" set of start points.\n"
-"\nDescription:\n"
-" set of start points using an approach that scales to large grids.\n"
-" For details, see paper \"TerraCost: A Versatile and Scalable Approach for Path Computations on Massive\n"
-" Grid-Based Terrains\" by Hazel, Toma, Vahrenhold and Wickremesinghe (2005).\n"
-" The basic idea is to split the grid in tiles. "
-" \n numtiles is the number of tiles. Run with -i to see the recommended value for numtiles.\n"
-" When numtiles=1 it runs Dijkstra's algorithm in memory."
-" When numtiles>1 it runs an external SP algorithm that consists of 5 steps."
-" For debug purposes, it is possible to run the five steps separately. When running in separate\n"
-" steps, an intermediate config file stores temporary information, and other streams\n"
-" (see below) contain intermediate data.\n"
-" Step 0 (setup) inputs from grass; outputs are "S0OUT" and "S0BND"\n"
-" Step 1 (compute substitute graph: intra-tile dijkstra)\n"
-" inputs are "S0OUT" and "S0BND"; outputs are "S1OUT" and "S2BOUT"\n"
-" Step 2 (sorting) input is "S1OUT"; output is "S1OUT"\n"
-" Step 3 (inter-tile) inputs are "S0OUT", "S0BND",\n"
-" "S1OUT", and "S2BOUT"; output is "PHASE2BND"\n"
-" Step 4 (final-tile) inputs are "S0OUT" and "PHASE2BND"; output goes to grass\n"
-"\nFiles:\n"
-" File names are specified relative to "VTMPDIR", or with absolute path\n"
-" (name beginning with /)\n"
-" IOLibrary temporary streams will be in STREAM_DIR\n"
+const char *description = _("Computes a least-cost surface for a given cost grid and set of start points.");
/* get the args from GRASS */
@@ -165,7 +136,7 @@
vtmpdir->type = TYPE_STRING;
vtmpdir->required = NO;
char vtmpdirbuf[BUFSIZ];
- struct passwd *pw;
+ struct passwd *pw; /* TODO: is this really needed? */
if((pw = getpwuid(getuid())) != NULL) {
sprintf(vtmpdirbuf, "/var/tmp/%s", pw->pw_name);
} else {
@@ -184,15 +155,12 @@
quiet = G_define_flag() ;
quiet->key = 'q' ;
quiet->description = _("Quiet") ;
- /* quiet->answer = 'n'; */
/* save ascii grid flag */
struct Flag *ascii;
ascii = G_define_flag() ;
ascii->key = 's' ;
ascii->description = _("Save output to ASCII file \"DIST_GRID\"");
struct Flag *debug_f;
debug_f = G_define_flag();
@@ -209,14 +177,12 @@
step0 = G_define_flag();
step0->key = '0' ;
step0->description = _("Step 0 only (-h for info)");
- /* step0->answer = 'n'; */
/* Run step 1 only flag*/
struct Flag *step1;
step1 = G_define_flag() ;
step1->key = '1' ;
step1->description = _("Step 1 only (-h for info)");
- /* step1->answer = 'n'; */
/* Run step 2 and 3 only flags */
struct Flag *step2;
@@ -511,12 +477,14 @@
/* initialize GIS library */
G_gisinit(argv[0]);
module = G_define_module();
+ module->keywords = _("raster, cost surface, cumulative costs");
+ module->description = description;
/* get the current region and dimensions */
region = (struct Cell_head*)malloc(sizeof(struct Cell_head));
assert(region);
if (G_get_set_window(region) == -1) {
- G_fatal_error("r.terracost: error getting current region");
+ G_fatal_error("r.terracost: error getting current region");
int nr = G_window_rows();
int nc = G_window_cols();
